Like Tree41Likes
 Old 04-30-2010, 05:04 PM   #121
shpankey's Avatar
Posts: 496   (View Stats)
I think my low compression is coming from the timing slipping a tooth. Isn't there a known issue about the tensioner on our cars and it being loose? If so can someone link me to that thread. My compression tests perfectly 130 across the board but I don't think it's worn rings.
When I go WOT and do a hard pull, I can feel tiny "surges" (for lack of a better word) where my car pulls real hard like it used to, then goes back to meh, then hard then meh. Sometimes this come in terms of reciprocal surges, sometimes the whole pull is meh and on very very VERY rare occassion it pulls hard all the way.
This is not to say that the car runs like garbage. It is still a fast car, as evidence of dusting a 2000 Mustang GT in a most embarrassing way. Though I was fortunate that was one of the times the car decided to pull hard, lol. It just doesn't run or pull like it's supposed to most of the time. You can decidedly feel it when doing a pull with these surges.
I'm convinced my timing is somehow slipped a bit. I have new plugs (NGK Stock Iridium, pregapped) and just recently cleaned out the EGR and pipe. But yet I still experience an odd idle most of the time. I still plan on stocking out oneday soon when I get some time, and take it to the dealer. I only have a few bolt ons. I'm just really busy and when it comes to downgrading the car, somehow lazy. lol
09 Speed 3 GT
 Old 05-01-2010, 09:08 AM   #122
darth vader's Avatar
Posts: 665   (View Stats)
Dude, if your engine timing had "slipped a tooth" you'd be picking up pieces of your engine not dusting off Mustangs. The valvetrain is chain drive not belt so, it's pretty unlikely that the cause of the low comp is a mis-timed engine.
Do a leakdown test to determine cause of low comp. Air out the crankcase oil fill is rings, air out the exhaust or intake is valves on that side of the cylinder.
 Old 05-09-2010, 08:21 AM   #123
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
did mine yesterday
2008.5 MS3 16k on the ODO
Drivers side
185
185
183
185
Passengers side
The Following 3 Users Say Thank You to 8.5MS3 For This Useful Post:
djuosnteisn (05-10-2010), gsrtype1 (05-23-2010), Lex (05-09-2010)
 Old 05-23-2010, 04:13 PM   #124
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Did mine this morning, I'm almost at 73k. I don't know if this was normal with the gauge when I would crank it would go to target but then lose pressure quick. Like cylinder 1 would to 180 but it would drop so fast by the time I get out of the car to look its at 150 psi. Is that normal for the gauge to drop so fast?
From passenger side.
1. 180
2. 175
3. 160
4. 170
I think pretty decent for my mileage, driving habits and mods. Isn't there a roomer that cylinder 3 gets low because of the balance shaft? If thats tru then next mod.
The Following 2 Users Say Thank You to gsrtype1 For This Useful Post:
2007speed3 (05-23-2010), djuosnteisn (05-23-2010)
 Old 05-23-2010, 04:39 PM   #125
2007speed3's Avatar
Posts: 1,486   (View Stats)
2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world
1. 180
2. 175
3. 160
4. 170
The gauge that i use stays at the highest pressure recorded until you relieve the pressure then it goes back to zero. Maybe yours was broken..
2007speed3 is offline   Reply With Quote
The Following User Says Thank You to 2007speed3 For This Useful Post:
 Old 05-23-2010, 04:43 PM   #126
gsrtype1's Avatar
Groans: 102
Yeah I think it was cause it would drop real quick and looking at vids of other people doing test. I couldn't even get out of the car to check and it would already lose 30-40 psi. Maybe that mads it read lower than actually was cause it had a pressure leak..
 Old 05-23-2010, 06:08 PM   #127
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Normally I dont point out the spelling mistakes..... but I LOLOLOLOLOL'd
Suspension:
 Old 05-23-2010, 06:10 PM   #128
rigor's Avatar
Posts: 2,399   (View Stats)
rigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the world
Groans: 40
the little button you push, is a tire stem take it out and clean it or replace it, then it should hold your reading
BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw
472 hp 461tq virtual dyno and ran out of fuel!
nishan said theirs a easy 550 in the setup if i had the fuel but meh...
54,000 miles big turbo! stock block
at 104000 2 bent rods
current miles 113000 and runs perfect! no hiccups!
tuned by nishan
rigor is offline   Reply With Quote
The Following User Says Thank You to rigor For This Useful Post:
 Old 05-23-2010, 06:29 PM   #129
gsrtype1's Avatar
Groans: 102
Well I rented it from autozone and already returned it. Im gonna try another autzone gauge and try to get a vid this time. if it was leaking that bad im thinking that may have given a lower reading.
On the next one I rent I will try what you said if it has the same problem, thanks!
The Following User Says Thank You to gsrtype1 For This Useful Post:
rigor (05-23-2010)
 Old 05-23-2010, 09:13 PM   #130
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Hopefully it's just the gauge Joe.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
rigor (05-23-2010)
 Old 05-23-2010, 09:31 PM   #131
gsrtype1's Avatar
Groans: 102
Yeah you think thats bad otherwise? 160 in cylnder3 and 170-180 in the others how bad can that be for 70k fully bolted hard miles? Weren't your results in the 160's?
djuosnteisn (05-23-2010), rigor (05-23-2010)
 Old 05-23-2010, 09:36 PM   #132
Captain
Groans: 79
Yeah mine were, but that's cause i'm at 5500ft. 2.5psi less up here, and with 9.5:1 compression it's like high 180's or so. Regardless of teh specific numbers, usually you look for differences between cylinders.
Your engine was warmed up, right?
www.permtuning.com
gsrtype1 (05-23-2010), rigor (05-23-2010)
 Old 05-23-2010, 09:38 PM   #133
gsrtype1's Avatar
Groans: 102
2.5 psi ? that doesnt seem like alot does it? I let the coolant temp get to 190 idling then did the test.
 Old 05-23-2010, 09:42 PM   #134
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
Joe
You are still within factory tolerances if those are true numbers. And honestly 70k fully bolted running the higher boost like you do, I would say that is to be expected. I wouldn't get worried unless it starts to dramatically fall off over the next few months. Like mine did. I went from stock, to 155, to 145 from 35k to 45k. I didn't have that many parts, so that's the point at which I started the big battle with the dealer for a new motor.
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following 3 Users Say Thank You to cpolly69 For This Useful Post:
djuosnteisn (05-23-2010), gsrtype1 (05-24-2010), rigor (05-23-2010)
 Old 05-23-2010, 09:46 PM   #135
gsrtype1's Avatar
Groans: 102
Originally Posted by cpolly69 View Post
Joe
Yeah thats what I was thinking especially with a faulty gauge.... hope you got your stuff worked out bro!
 Old 05-23-2010, 09:47 PM   #136
Captain
Groans: 79
2.5psi in a 9.5:1 compression motor is close to 25psi difference. (2.5 X 9.5).
Next time you do it, drive around for a while. You want the oil to be up to temp, not just the coolant. Give it a 5 - 10 minute drive and i bet your numbers improve.
And i also agree with cpolly, not really worth worrying about, but maybe check em every oil change or so and look for trends.
www.permtuning.com
 Old 05-23-2010, 09:51 PM   #137
gsrtype1's Avatar
Groans: 102
Ahh cool I didnt know 2.5psi is close to 25 cause of atmosphere. im gonna do another check next weekend with a different autozone gauge and get it on vid.
 Old 05-23-2010, 10:11 PM   #138
cpolly69's Avatar
Groans: 27
Yeah after 2 months and a massive battle I got a new engine. All thanks to Mazda Corp and no thinks to my dealer...
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following 2 Users Say Thank You to cpolly69 For This Useful Post:
 Old 05-24-2010, 08:08 AM   #139
gsrtype1's Avatar
Groans: 102
Sweet!!! Its cool that Mazda helped you out! Hey do you or does anyone know if the max variance "28.5psi" applies to all cylinders in general or referring to side by side cylinders. Like with my numbers is my variance 15 or 20?
 Old 05-24-2010, 08:29 AM   #140
cpolly69's Avatar
Groans: 27
Default DISI Compression Results
Joe
My understanding is that it doesn't make any difference if you were talking about cylinders side by side or cylinders at opposite ends of the block. If there is a difference beyond that variance from any cylinder to another, it's worth being concerned.
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following User Says Thank You to cpolly69 For This Useful Post:
 Old 05-24-2010, 08:32 AM   #141
gsrtype1's Avatar
Groans: 102
Joe
Thanks yeah just called the dealer and thats what they said too. They said my numbers are well within spec and are good. I'm still gonna get another gauge and try again this weekend.
djuosnteisn (05-24-2010)
 Old 05-26-2010, 06:34 PM   #142
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Just did this, my local AutoZone had one of these in the store:
Amazon.com: Actron CP7828 Professional Compression Tester with Storage Pouch: AutomotiveAmazon.com: Actron CP7828 Professional Compression Tester with Storage Pouch: Automotive
so I bought it and did the test. I got:
Passenger side
188
190
190
195
Driver's side
26k miles, entirely stock block
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following 2 Users Say Thank You to Cataphract_40 For This Useful Post:
djuosnteisn (05-26-2010), gsrtype1 (05-26-2010)
 Old 05-26-2010, 07:28 PM   #143
gsrtype1's Avatar
Groans: 102
Passenger side
188
190
190
195
Driver's side
Dang impressive man! I will say though I have heard that gauges read different and why u and some others read higher than 185 seems wierd....
 Old 05-26-2010, 07:36 PM   #144
KayWhy's Avatar
Posts: 752   (View Stats)
KayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the world
Groaned at 9 Times in 5 Posts
185, 180, 180, 185 good?
KayWhy is offline   Reply With Quote
The Following 2 Users Say Thank You to KayWhy For This Useful Post:
 Old 05-26-2010, 07:40 PM   #145
gsrtype1's Avatar
Groans: 102
Peach 185 is new...
 Old 05-26-2010, 07:50 PM   #146
Nice numbers we're seeing on some of the lower mileage speeds. KayWhy, how many miles on the car?
 Old 05-27-2010, 10:47 AM   #147
shpankey's Avatar
I'm about to begin this battle myself (130 on all cylinders for mine). Any advice? Note I'm not throwing a CEL or anything and the car runs fine, other than the quite dramatic loss of power. I refuse to race anyone anymore, just don't want them thinking they waxed a real Speed 3 when I'm driving around a limped one.
09 Speed 3 GT
 Old 05-27-2010, 12:12 PM   #148
cpolly69's Avatar
Groans: 27
Don't show up with any mods on the car and if your ecu has been flashed in any way, don't bother showing up at all.
Bring your complete oil change records. Write down a list of symptoms - make sure to include loss of power, smoke out the exhaust, and sputtering.
Tell them you did a compression test, it tested low, and you want them to do a leak down test - under warranty. If you don't get the answers you want to hear in a reasonable time frame - couple weeks - call Mazda Corp and explain.
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 05-28-2010, 08:04 AM   #149
shpankey's Avatar
Cool, will do. Thanks man. I have never flashed my ECU or ran an AP or anything like that. Just basic mods so I think I'm good. I'm an oil fiend and have a huge stash of oil. I buy it all the time on sale, so I have enough oil change receipts for 5 cars. lol
09 Speed 3 GT
 Old 05-29-2010, 04:32 PM   #150
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
Just did mine today for the hell of it...
from pass side
190
190
193
193
25K on the odo, 12,500 on the motor... VERY happy with the results!
The Following 4 Users Say Thank You to Realgib3 For This Useful Post:
Cataphract_40 (05-30-2010), djuosnteisn (05-29-2010), FreeFlyFreak (05-29-2010), gsrtype1 (05-30-2010)
 Old 05-29-2010, 11:13 PM   #151
Groans: 30
from pass side
190
190
193
193
very happy to see those numbers, too. I was starting to wonder if mine were off... I mean, I'm pretty sure I did the test right...pulled the plugs, pinned the throttle, turned the engine over for about 6-8 seconds until the needle on the gauge stopped going up...
1995 Miata
The Following User Says Thank You to Cataphract_40 For This Useful Post:
Realgib3 (05-30-2010)
 Old 05-30-2010, 02:18 AM   #152
Realgib3's Avatar
Groans: 52
i'm starting to wonder if the break in of these motors is affecting this. I know i beat this new motor up from day one and am seeing some of the best readings i've seen anywhere... what do u guys think? not askin whether or not to romp on your new motor from day one, but could this actually be havin some lasting effect?
 Old 05-30-2010, 08:26 AM   #153
The Kamikaze King!
Groans: 754
I know I romped on mine from day 1....
Guess I should do a compression test, test ur theory.
Suspension:
 Old 05-30-2010, 09:38 PM   #154
Captain
Groans: 79
This is a huge controversy from what i've read. Not sure how much merit it has, but who know's i'm noob as shit still.
www.permtuning.com
 Old 05-31-2010, 04:24 PM   #155
shpankey's Avatar
I did the same thing. I drove it incredibly hard right off the bat. Heck, even the test drive when it had 6 miles on it. My compression is completely shot now.
09 Speed 3 GT
 Old 05-31-2010, 05:45 PM   #156
cpolly69's Avatar
Groans: 27
+1
I drove the shit out of my car since the day I got it and my compression started dropping at around 30k and my first motor was done at 45k.
I'm going to stick with what I've always said.
Some of these motors are shit and some are great.
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
Realgib3 (05-31-2010)
 Old 06-17-2010, 05:50 PM   #157
shpankey's Avatar
I took my car in. My shifter broke so it made me go ahead and get down to business. They replaced the shifter but told me my car was fine. They said: there is no CEL so the car is perfectly fine. I explained to them that I've lost power dramatically and that I had two independent Compression tests done. Both came back at 130psi on all four cylinders. They said: well our tech drove it and he said it drives like every single other MS3 he's driven. I noticed they drove over 10 miles on my car, so I'm wondering, what he was doing... hot rodding it? How else could he tell if it was missing power?
The tech manager said that if I was losing compression so bad, I'd have plugs fouled out and a CEL. I told him I just recently done a tune up, complete with EGR, MAP, MAF cleaning, new air filter, new NGK plugs, etc etc.
So they say, well, we can do a compression test, but it will cost you $200 for us to do that. I said, well what if the compression is low, do I still have to pay, they said well if it's as low as you say it is, no we will pay to fix it, otherwise you do.
Not sure what to do. I know I've lost power, I've tested the damn compression like 5 times, every single time it comes back 130psi on all 4. But I don't have $200 to spare.
P.s. when I had the shifter fixed, they had it for 4 days and said they no longer offer dealer cars to drive when getting cars fixed. Is this true for all Mazda or just my dealer? I had to borrow a company truck to get around. Not sure if I can borrow it again especially for a long period of time, if they have to replace the engine.
Lastly, does anyone know the EXACT amount of PSI that the car has to be down to before them fixing it? Mine's at 130 which is very low, but is it low enough for them to fix it? The car does run and doesn't throw a cel. The power loss is significant to me, but might not be to them. As it's still a fast car, just not what it was. If the stock car is 264hp, I'd guess I'm down to around 200hp. The torque loss % is probably a tad more than the hp. So it's still fast for most people but definitely not what it was.
Advice please...
09 Speed 3 GT
 Old 06-17-2010, 06:34 PM   #158
The Kamikaze King!
Groans: 754
Advice please...
Pay the $200
Suspension:
08_ms3_gt (06-18-2010)
 Old 06-17-2010, 07:09 PM   #159
2007speed3's Avatar
there is a number for how low compression has to be before they would replace the motor. I want to say 120ish but im not sure...
 Old 06-17-2010, 08:03 PM   #160
cpolly69's Avatar
Groans: 27
140 is the min i believe - they are also looking for a 40lb difference in between any 2 cylinders iirc
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 05:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 09:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 03:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.59904 seconds with 33 queries
