Like Tree41Likes
 Old 12-17-2010, 03:46 PM   #201
shpankey's Avatar
Posts: 496   (View Stats)
Question: I bought Devil's Own meth-injection kit and the large tank with the pump in it. I haven't hooked it up yet as it looks a bit difficult (for me, lol) and I've been kind of lazy. Anyhow, if I hooked this meth kit up, and say I did have really bad carbon'd up dirty intake valves, would this actually REVERSE the process and clean the intake valves back to near factory clean? Or is this just something that basically stops them from getting any dirtier? Also, as far as cleaning goes, would it be better to run 100% meth or a mix or meth and water?
I've seen pics of intake valves of other direct injected cars, like the Audi 2.0 FSI at 15k miles and if our car is anything as bad as it, I fear what mine look like now at 27k miles because those were horrendous! I have a feeling this is where my power loss is at, but I don't know... I'm just guessing as I've pretty much given up on figuring out where my power has gone now.
09 Speed 3 GT
 Old 12-17-2010, 05:16 PM   #202
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Originally Posted by shpankey View Post
I know this sounds really dumb, but I'm not sure where the intake manifold is.
Oh boy.
Here, have a look at these pictures. I'm going to assume you still have the stock top-mounted intercooler. You can't really see the IM because the intercooler & its plastic shroud sit on top of it:
Here, the intercooler has been removed, and you can see the actual IM itself. Note four runners, one for each cylinder.
You've actually worked on it before, when you installed your OCC kit. You also shoot seafoam through it everytime you perform a seafoaming.
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 12-17-2010, 06:42 PM   #203
shpankey's Avatar
Cool thanks. How does one look into them to see if there are oil tracks there? Is it a difficult job? I can get down to that level pretty easy as I take the TMIC and SRI and TIP off a lot and the battery box out all the time.
09 Speed 3 GT
 Old 12-17-2010, 07:25 PM   #204
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
shpankey, if your compression is good, and if you maintain the car as well as you say, then i am not really sure that the intake valves are your problem.
i follow a similar route, maybe less rigorous, and i don't have power loss. i've pulled my plugs a few times and they look OK, about the same every time. i do seafoam thru the intake system once every other oil change or so.
my questions would be related to fuel and air -
- is your fuel pump working properly?
- do you have any boost leaks?
- is your MAF calibrated for the intake you have (if any)?
if you've been driving modified w/ a stock pump for a long time, your pump might be hosed, and that could cause a power loss. a boost leak would sap power as well, although you'd prolly hear it.
get a log of your car and post it up. we can go from there.
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
[sold - 90 Miata - summer/project car, turbo w/ goodies, DIYPNP, springs/struts, etc.]
[sold - 08 MS3 GT - intake/downpipe/tuning/fuel pump/TMIC/springs/struts/etc.]
 Old 12-18-2010, 03:47 PM   #205
shpankey's Avatar
I've been running the KMD Ver 2 pump for almost a year now. I don't have a logging tool, just a code reader that can do live readings. According to it, at WOT I'm 1750+ to 2000 psi with the average being between 1790 to 1850. It never goes below 1700 at any time at WOT and idle is close to 500 psi. So I've kind of ruled the fp out. Though I will admit the power loss did come around the time I installed it and a few other mods (step colder denso's, TIP, OCC). I've since taken everything off the car except the HPFP as my stock clip is broke and since I see such good pressure I think it's probably ok.
09 Speed 3 GT
The Following User Says Thank You to shpankey For This Useful Post:
08_ms3_gt (12-18-2010)
 Old 12-18-2010, 05:18 PM   #206
aspiring turbo guru
08_ms3_gt's Avatar
have you checked your boost pressure?
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
 Old 12-19-2010, 04:31 PM   #207
shpankey's Avatar
No. I don't really know how to do that tho.
09 Speed 3 GT
 Old 12-20-2010, 07:36 PM   #208
aspiring turbo guru
08_ms3_gt's Avatar
you've really gotta check your AFR and boost pressure.
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
 Old 12-21-2010, 05:19 PM   #209
shpankey's Avatar
I'm going to take it to a local shop to take the intake off and clean the intake valves next month some time. If that doesn't fix it I'll go from there. The way I figure it, I'm at almost 30k miles and they need cleaning no matter what, judging by pics I've seen of intake valves of many other direct injected cars. So it's something worth doing either way. I'm pretty sure this is the main reason for the power loss, and for a fact, at least SOME of it. So regardless of where the real problem may lie, this needs done anyhow.
09 Speed 3 GT
 Old 12-21-2010, 05:27 PM   #210
708
Erich's Avatar
Posts: 4,274   (View Stats)
I was between 200-205 on all 4. Though it wouldn't be a bad idea to check after running my 2100 PSI test.
Erich is offline   Reply With Quote
The Following User Says Thank You to Erich For This Useful Post:
VulgarKyle (08-30-2016)
 Old 12-23-2010, 02:02 AM   #211
javanc's Avatar
Posts: 423   (View Stats)
javanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the world
From left to right:
Cold: 180, 170, 170, 175
Hot- drove it like i stole it till ECT 190c- 175,170,165,165
25000 miles, MSCAI, CS midpipe, PP 5/40 for most of the cars life. Oh yeah and a recently drained of all oil run home from the store.
Piston tops looked a bit crusty, nothing a few ccs of Seafoam sitting on them for 15 mins didnt help. Recently Seafoamed thru the intake tracts that produced miles of thick grey smoke.
Next step leakdown test..............
Stock as hell and hating it!
u can Haz foley!
javanc is offline   Reply With Quote
 Old 12-23-2010, 02:14 AM   #212
javanc's Avatar
proof
u can Haz foley!
 Old 04-09-2011, 10:33 AM   #213
stokes620's Avatar
Posts: 281   (View Stats)
stokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the worldstokes620 is the leader of the world
2007 Mazdaspeed 3 GT
73,xxx Miles
1- 172
2- 170
3- 169
4- 165
Very happy with the results had the car for a year and loving every day
07 Speed 3
COBB AP / Sure Aeros SRI / HTP TIP / PG Pipes/Godspeed Type C Core / Autotech Internals / PTP Injector Seals / CNT Catless TBE / Sure TIG / CP-e 75A RMM / SU PMM & TMM / JBR SSP / JBR Heavy Shift Knob / KSport Kontrol Pro CO / JBR RSB / HTP Battery Tray / Prosport Boost Gauge
Permed CORN Fed 25% - SOLD
[COLOR="Blue"][CENTER]2012 Speed 3 - Sold
stokes620 is offline   Reply With Quote
The Following User Says Thank You to stokes620 For This Useful Post:
frivolous_rob (06-24-2011)
 Old 04-14-2011, 09:04 PM   #214
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
Originally Posted by 8.5MS3 View Post
did mine yesterday
2008.5 MS3 16k on the ODO
Drivers side
185
185
183
185
Passengers side
redid mine again tonight for the hell of it
26k on the ODO
Drivers side
190
190
185
190
Passengers side
Mods:
SRI/TIP/FMIC/HPFP/TP/CBE/DJ Tune
first test was only with SRI/TIP/Akuma Tune
guess its wearing in better.....or DJ has some black magic in his tunes
The Following 3 Users Say Thank You to 8.5MS3 For This Useful Post:
djuosnteisn (04-25-2011), Lex (04-26-2011), manelscout4life (04-25-2011)
 Old 04-25-2011, 05:05 PM   #215
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Lol
Great #'s for sure though.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 04-25-2011, 06:17 PM   #216
darth vader's Avatar
Posts: 665   (View Stats)
Arrr, I bought an Ebay 10mm lighted USB inspection camera just so I could take a look down the plug holes myself. That's how dedicated to DISI I am....
The Following User Says Thank You to darth vader For This Useful Post:
djuosnteisn (04-26-2011)
 Old 04-25-2011, 06:19 PM   #217
8.5MS3's Avatar
Groans: 326
i did that
it wasnt pretty
The Following User Says Thank You to 8.5MS3 For This Useful Post:
 Old 04-25-2011, 08:29 PM   #218
Groans: 30
Yep...looks a little like this, as viewed through the spark plug hole...
1995 Miata
The Following User Says Thank You to Cataphract_40 For This Useful Post:
 Old 04-26-2011, 08:26 AM   #219
Compression will differ slightly based on oil used, atmospheric pressure etc ... test on a warm sunny day (high pressure) for best results.
 Old 04-26-2011, 02:11 PM   #220
MaverickX3's Avatar
Posts: 341   (View Stats)
MaverickX3 has a reputation beyond reputeMaverickX3 has a reputation beyond reputeMaverickX3 has a reputation beyond reputeMaverickX3 has a reputation beyond reputeMaverickX3 has a reputation beyond reputeMaverickX3 has a reputation beyond reputeMaverickX3 has a reputation beyond reputeMaverickX3 has a reputation beyond reputeMaverickX3 has a reputation beyond reputeMaverickX3 has a reputation beyond reputeMaverickX3 has a reputation beyond repute
I've had to clean my piston tops twice (long story lol). Best thing you can do to stop crud from forming on your pistons/valves is to run an OCC and block off the EGR valve. Those with a newer valve cover with the different baffle might have less oil picked up on the breather tube. Just the nature of a direct injection engine.
On a side note, once you see/think you have lower compression, a leak down test is your best friend. I have yet to do one but wish I had earlier before I took the engine apart lol. In my case, looks like it is going to be the injector seals that are toast (see Change those seals yo).
'06 MS6 Sport 130,000km
Cobb TIP, CP-E TMIC, AEM oversied CAI, CP-E Safe seals, BSD, AP
Garaged: custom race Magnaflow catbck
MaverickX3 is offline   Reply With Quote
The Following User Says Thank You to MaverickX3 For This Useful Post:
djuosnteisn (04-27-2011)
 Old 05-29-2011, 03:15 AM   #221
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
Okay, here's my turn.
Did the test yesterday when changing the spark plugs. Ambient was about 77. Elevation approx 511 ASL. The car runs fine, the vacuum at idle is 21ish. 35k miles on the clock.
183
176
176
183
Confused about the difference between two central cylinders and the other two..
paveltol is offline   Reply With Quote
 Old 05-29-2011, 07:26 AM   #222
Normal to see accelerated wear on the inner cylinders of any in line engine. Typically, they run hotter than the outer 2. I'd be concerned if the 3s were way down on 2 adjacent cylinders, indicating a hg leak.
paveltol (05-29-2011)
 Old 06-08-2011, 08:24 PM   #223
Metal409's Avatar
Posts: 316   (View Stats)
Metal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the world
Went ahead and tested my car again today. 2009 Speed3, 42,600miles, more than half of that was stage 1, car is stage 2 now. Was roughly 80degrees out when I tested, 570~ ASL.
1: 185
2: 185
3: 185
4: 185
Only did 6 cranks to get these readings, 7 on cylinder 1.
Metal409 is offline   Reply With Quote
The Following User Says Thank You to Metal409 For This Useful Post:
Lex (06-08-2011)
 Old 06-17-2011, 01:31 AM   #224
MPSdriver's Avatar
Posts: 136   (View Stats)
MPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the world
I had my inj seals replaced with the safeseals and asked for a before and after compression check.
I asked them to do the check on a warm engine but they did the b/f with a cold one anyway...
b/f replacement of seals (cold engine) in psi
1: 160
2: 130
3: 130
4: 160
after replacement of seals (warm engine) in psi
1: 160
2: 130
3: 115
4: 160
Compression results are pretty bad I guess. Cylinder 3 is obiously out of spec, what a surprise.
I'm at 103k miles most of which have been with an upgraded TMIC, BPF and catback. Never used anything else then premium 98ron fuel. Dealer overfilled the oil a couple of times but as I check the level regularly I noticed and had them drain it the next day. I had some crazy knock counts when my timing chain tensioner gave up but other than that all has been fine.
Last couple of months I started noticing 2 - 4° KR past 4k rpm when getting on the gas especially after a 4 - 5 gear change. Based on the info on the forum I suspected that the seals had gone bad. Well the good news is WOT KR is back to less than one degree which is were it has always been so my seals were probably somewhat toasted and the safeseals are taking better care of the injectors now.
When I got the car I thought getting 125 - 150k miles out of this car would be no problem but now I don't know if it's going to hold that long.
MPSdriver is offline   Reply With Quote
The Following 2 Users Say Thank You to MPSdriver For This Useful Post:
djuosnteisn (06-23-2011), Lex (06-23-2011)
 Old 06-23-2011, 11:33 AM   #225
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
just hit 50k and i have 180 in all cylinders i guess im good for another few miles until my shit explodes
crazyp likes this.
The Following 2 Users Say Thank You to TWOptSL0W For This Useful Post:
crazyp (08-08-2012), djuosnteisn (06-23-2011)
 Old 06-23-2011, 01:17 PM   #226
1: 160
2: 130
3: 130
4: 160
1: 160
2: 130
3: 115
4: 160
If the before and after tests were done with basically 0 miles in between I would suspect something is up with the tester/method in both tests.
I would get this redone and get a leakdown test done as well to see what is leaking compression.
Are you burning any oil?
 Old 06-24-2011, 03:58 AM   #227
MPSdriver's Avatar
I didn't attend the testing, it was all done by a local ford /mazda dealer. They're good people but kinda old school.
I would expect the test to be better after replacement of the seals not b/c of the seals but b/c the engine was hot compared to the 'cold' before test (so I guess they took it for a drive after replacing the seals). The 115 psi kinda freaked me out but the car does run 'normal'. Only anomaly is the WOT knock in higher gears which got slightly better after the seal replacement.
I have to add oil regulary but no more than one to two liter between dealer visits (every 10k). I think most of the oil consumption is related to crankcase ventilation. I have an oil trail from the valvecover vent to the intake and TIP and the flange on the cold side of the IC is an oily mess. I had the dealer clean the entire intake side b/c it needed to be disassembled for the seal swap. They told me it was very oily and the valves were basically carbon turds. They didn't dare to clean the valves though. So I went back two days ago and had them run a "sea foam" kind of product which helped recover some smoothness of the engine. I asked for another compression test but they didn't have the time.
It would probably be best to try and get a second opinion on that compression test or man up and try it myself.
 Old 06-24-2011, 05:13 PM   #228
Captain
Groans: 79
On the motor i'm currently building, the machinist mentioned that he wanted to clean up the valves and valve seats... because they were pretty pitted.
Kinda makes sense to me, judging from how much carbon build up they see with DI. Yet i don't recall anyone having bad leakage past the valves, etc.
MPS, i wonder if your test would be any different if you sea foamed the car.
www.permtuning.com
 Old 06-26-2011, 11:45 AM   #229
MPSdriver's Avatar
Well the dealer ran some sort of a seafoam product through the car a couple of days after I had the seals changed but they didn't have time to do another compression test. I'm going to look into doing a compression test myself when I come back from holidays to see what I come up with.
 Old 06-26-2011, 12:04 PM   #230
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
I will never get an compression test. Ignorance is bliss. Plus I've recorded my favorite saying so when passengers ask me, "what's that noise?" I put the recording on loop "its suppose to sound like that"
 Old 06-26-2011, 01:57 PM   #231
I have noticed on more "tired" engines that there is a lot of oil in the valvecover to intake line and down the intake. Oil there is a sign of blowby - in other words there is quite a bit of gas getting past the rings which lines up with the lower compression.
Any serious shop would do a leakdown test at this point.
 Old 06-26-2011, 08:26 PM   #232
frivolous_rob's Avatar
Posts: 1,374   (View Stats)
frivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the world
Groaned at 44 Times in 17 Posts
So, I ran a test yesterday. 67k miles, 104 degrees outside, let idle up to 180 degrees coolant temp. Then did the test.
86,89,85,89.
Im not sure why they're are so low, as to if it was a bad gauge, poor tester (me), or what. I just changed the oil the day before the so the oil was brand new.
My car runs fine, but that shit is low, at least its consistent.
Choke me, I like it.
frivolous_rob is offline   Reply With Quote
 Old 06-26-2011, 08:35 PM   #233
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
86,89,85,89.
i don't see how that can be accurate - maybe your gauge had a funky scale and those were really 186,189, etc
if those were really your numbers your car would run like shit - most likely w/ coolant temp thru the roof or bellowing smoke out the exhaust
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 06-26-2011, 09:07 PM   #234
The gauge was the oem brand rental from autozone. Looked normal to uss. Think it went up to like two hundred on psi side. Never saw anything above 89 when doing it. No smoke and car still beasts on peopleople so i have a feeling it had to be the gauge
The Following User Says Thank You to frivolous_rob For This Useful Post:
djuosnteisn (06-28-2011)
 Old 06-30-2011, 04:38 PM   #235
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 06-30-2011, 04:49 PM   #236
Captain
Groans: 79
Go BT.
www.permtuning.com
frivolous_rob (06-30-2011), Tokay444 (06-30-2011)
 Old 06-30-2011, 08:01 PM   #237
Tokay444's Avatar
Groans: 793
Who me? Lol.
Demodded.
The Seals
djuosnteisn (07-06-2011)
 Old 07-01-2011, 01:03 AM   #238
Errrrrrrrrrrrrr fkn body!
 Old 07-02-2011, 12:51 PM   #239
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
07 ms3 sport
52K
engine kinda warm, cooled off in garage for 30-45 minutes before test
175
174
175
176
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
The Following 2 Users Say Thank You to themytb For This Useful Post:
djuosnteisn (07-06-2011), Lex (07-04-2011)
 Old 08-22-2011, 11:03 PM   #240
08.5 MS3
47k km
1 (driver side): 195
2: 190
3: 195
4: 195
Cranked about 16 times until needle stopped climbing. Engine was warm to the touch but not hot.
Dano (08-23-2011), djuosnteisn (08-23-2011), FreeFlyFreak (08-23-2011), IshiKage (09-14-2011), Tokay444 (08-23-2011)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 05:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 09:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 03:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.58415 seconds with 40 queries
