Like Tree41Likes
 Old 01-18-2012, 12:37 PM   #281
BlueStreak's Avatar
Posts: 1,467   (View Stats)
I had a cracked ringland in cylinder 3 and had oil going through my intake tract like yours (starting at the VC vent and permeating to the IM).
'07 CWP MS3
Forged.
 Old 01-18-2012, 12:45 PM   #282
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Yeah, but I think oil gets in the intake from the vc regardless of broken rings.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 01-18-2012, 12:48 PM   #283
Originally Posted by Evan@COBB View Post
@Lex
Vacuum shows -10 on the AP.
You've got that in inches of mercury instead of psi? There is more resolution in that reading.
Note that a drop in compression can readily be seen in the steady state vacuum reading of the car.
Does not - it gets in there if blowby exceeds a certain amount (ie there is a certain amount of leakage into crankcase of combustion gases under load) as the crankcase pressure pushes the oil through the intake tract from the valvetrain.
Last edited by Lex; 01-18-2012 at 12:50 PM. Reason: MSF Database - Automerged Doublepost
BlueStreak (01-18-2012), Nliiitend1 (01-18-2012)
 Old 01-18-2012, 12:51 PM   #284
Tokay444's Avatar
Groans: 793
I need that valve flush. Bad.
Demodded.
The Seals
breakfasteatre (01-18-2012)
 Old 01-18-2012, 12:54 PM   #285
BlueStreak's Avatar
Agreed. The car was tracked extensively before and I never had this issue until the cracked ringland.
'07 CWP MS3
Forged.
 Old 01-18-2012, 12:57 PM   #286
Tokay444's Avatar
Groans: 793
I hais oil in my intake.
Demodded.
The Seals
 Old 01-18-2012, 12:59 PM   #287
BlueStreak's Avatar
I haz forged motor looking for a hew home
'07 CWP MS3
Forged.
 Old 01-18-2012, 01:00 PM   #288
Do you haz compression and leakdown test?
 Old 01-18-2012, 01:04 PM   #289
Tokay444's Avatar
Groans: 793
No leak down yet.
Compression in #3 is 165psi.
Bluestreak, how much.
I was gonna ask in private. Pm me if you'd like.
Demodded.
The Seals
 Old 01-18-2012, 01:18 PM   #290
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
JacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the world
I never posted my results from a couple months ago.
80,000 miles (10,000 on big turbo)
1. 184
2. 186
3. 188
4. 190
The car was still warm when the test was performed.
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M. Fifth/Sixth Port Injection -
- P.E.R.M.Tuning -
JacksonMS30 is offline   Reply With Quote
The Following User Says Thank You to JacksonMS30 For This Useful Post:
djuosnteisn (01-18-2012)
 Old 01-18-2012, 01:24 PM   #291
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
@SPEED6 KILLAH would have info on the Mazda valve flush.
Pablo... any info on restoring compression with a proprietary DI valve flush?
Tokay444 (01-18-2012), Tomas (01-18-2012)
 Old 01-18-2012, 02:24 PM   #292
Noddaford's Avatar
Posts: 198   (View Stats)
Noddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond repute
Groaned at 48 Times in 7 Posts
146,000 miles and approx. 170 psi on all cylinders.
'06 MS6 GT
Wild Wonderful, West Virginia
Cobb AP, Magnaflow Catback, Underbody Cat Delete, ETS TMIC, Corksport SRI & TIP, Spyder LED Tail Lights, HKS BPV, Drilled & Slotted Rotors front and rear w/Ferro Carbon pads, 35% Tinted Glass
Noddaford is offline   Reply With Quote
The Following User Says Thank You to Noddaford For This Useful Post:
djuosnteisn (01-19-2012)
 Old 01-18-2012, 02:52 PM   #293
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
20k miles on rebuilt motor with stock compression
1. 185
2. 188
3. 180
4. 190
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 01-18-2012, 03:17 PM   #294
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
On 26 May 2010, I did the test. I got:
Originally Posted by Cataphract_40 View Post
Passenger side
188
190
190
195
Driver's side
26k miles, entirely stock block
Just did it again today. 55k miles, still stock block.
Passenger side
175
175
175
180
Driver's side
Uh oh
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following User Says Thank You to Cataphract_40 For This Useful Post:
 Old 01-18-2012, 03:19 PM   #295
Passenger side
175
175
175
180
Driver's side
Uh oh
Atmospheric pressure as well as the tester used and heat of engine will affect readings. Make sure you are very consistent - those numbers are very even which is good.
Cataphract_40 (01-18-2012), djuosnteisn (01-19-2012), Mizzle (02-16-2012), Nliiitend1 (01-18-2012), Tokay444 (01-18-2012)
 Old 01-18-2012, 03:29 PM   #296
Posts: 9,484   (View Stats)
No leak down yet.
that motor does need a good home...I would buy it but waaaay tooooo far away from me...lol
 Old 01-18-2012, 03:39 PM   #297
Tokay444's Avatar
Groans: 793
It's more than I can bite off right now, but worth every penny I'm sure.
Demodded.
The Seals
BlueStreak (02-14-2012), Dano (01-18-2012)
 Old 01-18-2012, 03:52 PM   #298
oh I am sure he would give a fellow Canadian a brother in law deal
I actually have no idea what a built motor would cost and frankly I am sure it would scare the shit out of me....lol
*knocks on wood and lowers boost targets on current map*
 Old 01-18-2012, 03:57 PM   #299
Tokay444's Avatar
Groans: 793
06speed6 I believe it was or maybe it was quartermilebeast quoted me around $2600.
This was substantially more than that. But there are two many variables to even try to compare the two.
Demodded.
The Seals
Tomas (01-18-2012)
 Old 01-18-2012, 04:40 PM   #300
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
^^ was this a complete motor with aftermarket rods/pistons? or stock?
 Old 01-18-2012, 04:56 PM   #301
Tokay444's Avatar
Groans: 793
It was built.
It was beast, and it was $5200 built.
Not 2600 because I'm and idiot. And it was months ago.
Demodded.
The Seals
Last edited by Tokay444; 01-18-2012 at 04:56 PM. Reason: MSF Database - Automerged Doublepost
Dano (01-18-2012), djuosnteisn (01-19-2012), Tomas (01-18-2012)
 Old 01-18-2012, 05:08 PM   #302
Bob Ross Fanclub
Tomas's Avatar
$2600 Canuc Dorra > $5200 American Durrah.
Dano (01-18-2012), djuosnteisn (01-19-2012), Tokay444 (01-18-2012)
 Old 01-18-2012, 05:30 PM   #303
Groans: 30
Moar info on this high pressure valve flush unicorn magic pixie dust job?
What's the official name of it? I.e. if I call my dealership, what do I refer them to?
1995 Miata
 Old 01-18-2012, 05:51 PM   #304
Tokay444's Avatar
Groans: 793
It's called the disi valve flush. If they say "wut?", it means they don't have the machine.
Demodded.
The Seals
Cataphract_40 (01-18-2012), daztdMS6 (02-14-2012), djuosnteisn (01-19-2012)
 Old 01-18-2012, 08:27 PM   #305
It was built.
hahah I was going to say there was some smuck trying to sell an OE longblock on here for 2600. now that waaay too much for a used disi but I would buy a dozen built motors if they were 2600
I am convinced the cold air kills brain cells....my brother moved to Grand Rapids about 15 years ago and I swear he gets dumber each year...he used to be fairly smart...i dunno...
is that a new dance move?
Last edited by Dano; 01-18-2012 at 08:27 PM. Reason: MSF Database - Automerged Doublepost
djuosnteisn (01-19-2012), Tokay444 (01-19-2012)
 Old 01-18-2012, 08:41 PM   #306
breakfasteatre's Avatar
Posts: 308   (View Stats)
breakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the world
tokay, is that a real thing? Im planning on doing a valve clean in the spring. I have one of those inspection cameras on a long flexible head. wonder if it would come in handy
@Tokay444
breakfasteatre is offline   Reply With Quote
The Following User Says Thank You to breakfasteatre For This Useful Post:
 Old 01-18-2012, 08:43 PM   #307
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
bg makes a two step valve flush for direct injection motors that some vw dealerships use. probably just a seafoam or gm top end cleaner copy but who knows? wish i hadnt just changed my oil or id try it out at work.
https://www.facebook.com/NorCalTintZone
instagram: sharpdetails
GoSpeed3Go is offline   Reply With Quote
 Old 01-19-2012, 03:55 AM   #308
Tokay444's Avatar
Groans: 793
Seafoam is drinking water compared to the shit they use in the valve flush.
@breakfasteatre, it's legit.
There's a dealer in richmondhill that does it.
One of two in the gta so far.
It's expensive, but works.
Whole thing takes about 2-3 hours.
Your camera should give you a good before and after image.
Demodded.
The Seals
breakfasteatre (01-19-2012), Tomas (01-19-2012)
 Old 01-19-2012, 11:02 AM   #309
How much?
 Old 01-19-2012, 11:07 AM   #310
theurgy's Avatar
Posts: 2,580   (View Stats)
If the whole thing takes 2-3 hours, figure shop rates that's about $200 in labour.
Now parts and such for the cleaning, I'm guessing is another $200.. so if I had to guesstimate a cost, I'm gonna say $300 - $400.
DO NOT QUOTE ME ON THAT.
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
theurgy is offline   Reply With Quote
The Following User Says Thank You to theurgy For This Useful Post:
 Old 01-19-2012, 11:22 AM   #311
Bob Ross Fanclub
Tomas's Avatar
 Old 01-19-2012, 11:29 AM   #312
Tokay444's Avatar
Groans: 793
It's around 3-400 bucks.
Lol.
Demodded.
The Seals
 Old 01-19-2012, 11:57 AM   #313
I would like to see what mine look like at 40K miles....20K with spraying meth...
then again to see what would happen to a newly cleaned set of valves and spraying WMI the entire time...I think I will always spray at least H20...on the E35 I don't currently need meth for fuel..right at 85% IDC.
I will def clean mine when I get the JMSD IM and see what's what.
 Old 02-14-2012, 08:38 PM   #314
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
I just did a compression test on my MS6 for the first time.
170
170
170
170
Miles: 117,8XX
Sea Level: 579 ft
Temp outside: 38 degrees
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline   Reply With Quote
The Following 2 Users Say Thank You to daztdMS6 For This Useful Post:
Lex (02-14-2012), Nliiitend1 (02-14-2012)
 Old 02-16-2012, 06:23 AM   #315
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I just tested mine last night
07 MS3 60k miles. right now it has cobb CBE, i think at somepoint it also had an SRI but before i bought it
Driver
180
165
180
180
Passenger
Should i be concerned that cylinder 2 is 15 psi under the rest?
Deldran is offline   Reply With Quote
 Old 03-21-2012, 09:00 PM   #316
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
I checked my compression tonight. '08 MS3 with ~49K miles.
From left to right, it was:
128
126
127
129
I need to check it again with a different gauge/tester, as I'm not too confident in the accuracy of the one I used.
Related thread here:
Oil Volume issues...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post:
djuosnteisn (03-22-2012), Lex (03-22-2012), Tokay444 (03-22-2012)
 Old 03-21-2012, 10:27 PM   #317
rigor's Avatar
Posts: 2,399   (View Stats)
rigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the world
Groans: 40
str8 180 0n all 4
65000 miles
bt 15000 miles
26 psi
BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw
472 hp 461tq virtual dyno and ran out of fuel!
nishan said theirs a easy 550 in the setup if i had the fuel but meh...
54,000 miles big turbo! stock block
at 104000 2 bent rods
current miles 113000 and runs perfect! no hiccups!
tuned by nishan
rigor is offline   Reply With Quote
The Following User Says Thank You to rigor For This Useful Post:
 Old 03-22-2012, 09:15 AM   #318
128
126
127
129
The consistency is great. I think the gauge is reading low because the power numbers you're making would not line up with compression that is 30% down.
I just redid mine:
cyl 4 (driver): 190
cyl 3: 188
cyl 2: 190
cyl 1: 190
60,000 km (37k miles)
Also remember to crank enough times - until the gauge stops going up. It can take up to 20 cranks. Remove all spark plugs when doing this so engine cranks easier.
djuosnteisn (03-22-2012), Nliiitend1 (03-22-2012)
 Old 03-22-2012, 10:25 AM   #319
EdgeAutosport.com's Avatar
Posts: 6,209   (View Stats)
Just did mine a couple weeks ago.
150
150
135
150
My injector seals are blown, We will see if it helps out cylinder 3
The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post:
djuosnteisn (03-28-2012), Lex (03-22-2012)
 Old 03-22-2012, 10:45 AM   #320
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
Did mine a month ago. 08 ms3 44k.
190 in all 4 and took about 6 cranks to hit that number.
Meder is offline   Reply With Quote
The Following 2 Users Say Thank You to Meder For This Useful Post:
djuosnteisn (03-28-2012), Lex (03-29-2012)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 05:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 09:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 03:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.58807 seconds with 39 queries
