Like Tree11Likes
 Old 05-16-2017, 06:32 AM   #41
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
You must tune the car if you run a catless dp and rp. Otherwise you will overboost by at least 2 psi and hit boost cut with nssty 21-22 psi boost spikes under certain conditions. Also, you must upgrade the high pressure fuel pump internals as the pump cannot keep up with the increased fuel demands and will drop pressure to unsafe levels. Looks like you already have the pump internals. You will want to verify that.
But, with catless dp/rp, internals, a CAI or SRI intake and even a conservative tune it pretty much maxes out the K04 on pump gas at just over 300 whp 300 torque. With an E tune as you plan you can probably get it up to 320-330 whp.
I've been running the catless TurboXS dp/rp for over eight years with mods below. Catless is also loud and droning even with stock CBE. I added a straight through reso in the rp section. That killed the drone with no detectable power loss.
The setup outflows the K04 on pump gas.
zenit likes this.
kgb (05-17-2017)
 Old 05-16-2017, 07:17 AM   #42
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
FWIW, @Carskick;, Speed Daddy does sell a shorty DP for our car; I just ebay'd one last week for about $85 shipped. If you haven't ordered the test pipe yet, that could be an option id you still want to try to pull off a catless DP/catted TP setup for fewer dollars.
Genpoo stuff
The Following User Says Thank You to sharksinspace For This Useful Post:
Carskick (05-16-2017)
 Old 05-16-2017, 12:40 PM   #43
Carskick's Avatar
Posts: 315   (View Stats)
I saw that, but I decided to just go TP and be done. Primary reason was cost of install and less risk of something going wrong. I may eventually change it, but that's the current plan.
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
Velocity Factor Racing suparobg Gen2 MS3 General Discussion 18 12-27-2014 11:48 AM
Lutz lays out his strategy for GM advertising: "Memorable," "clever," "viral" [w/VIDEO] Haltech Automotive News 0 08-04-2009 09:40 AM
Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" Haltech Automotive News 0 04-14-2009 01:40 PM
Page generated in 0.25321 seconds with 22 queries
