 Old 12-21-2010, 10:10 AM   #41
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Originally Posted by Dano2010 View Post
Hum
I don't want a shit ton more TQ @3.5k. LOL
This was smoothing out later this was just the immediate tune after about 3 or 4 pulls that was done the car also this was on a stock turbo so the spool was much quicker.
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
Dano (12-21-2010)
 Old 12-21-2010, 10:22 AM   #42
here is the with 15 psi and a little bit of tuning .... not sure if i have the final run but the hp was about the same just a little more power and the end of the powerband at this point we had made over 20 hp with the intake.
this is the one with the really high torque curve...
track weight 3220
street weight 3370
Dano (12-21-2010)
 Old 12-25-2010, 09:37 PM   #43
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
[QUOTE=whoosh@Realtune;659467]mazdaspeed
EGT leg cut, all exterior stands removed, flapper mount cut, everything is filled with epoxy and sanded smooth, all fittings replaced with nickel coated fittings, I have welded all the holes shut for a few guys but most have opted for the epoxy (cheaper)
and obviously the pnp work in the throat/TB mount area and runners
What did you use to fill the holes inside the runners?
11cruzito11 is offline   Reply With Quote
 Old 10-10-2011, 07:09 PM   #44
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Any recommendation for epoxy for filling the holes?
I might want to do this some weekend in the future...
 Old 10-10-2011, 10:13 PM   #45
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
Quick steel
NO! No way am I havin a dick made outta hamburger!
stocking out, buy my big turbo shit here, http://www.mazdaspeedforums.org/forum/f229/bye-bye-big-turbo-dreams-82241/ more to come as stock shit arrives
Intake manifold this, intake manifold that!!! ptperformance Mazdaspeed3/6 General Discussion 53 06-21-2010 02:51 PM
Intake manifold QuickSpool 2010 MS3 - Engine, Transmission & Driveline 0 11-18-2009 06:19 PM
Page generated in 0.27214 seconds with 24 queries
