-   -   Driveshaft Shop axles on my MPS6 GTX3076 1.06 tial (http://www.mazdaspeedforums.org/forum/f10/driveshaft-shop-axles-my-mps6-gtx3076-1-a-157069/)
Vadim aka ScooteR 10-15-2013 03:27 AM
I have 458whp Mazda and this year had many drag runs, but no time on glue. so 60ft wasn't better then 1.7s.
All transmission is tuned, all my gears are longer on 9% then stock.
Both rear axles are Driveshaft Shop . But 2 times i've already broken left one! The first time Driveshaft Shop sent me repairing parts.
There u can see foto of the first breakage
??????? ??????? ????????????? ??????? ??????? ??? ??????? ?? ????????? ??????? Driveshaft Shop
And there is the second
??????? ??????? ????????????? ??????? ??????? ??? ??????? ?? ????????? ??????? Driveshaft Shop (????? 2)
All THREE variant of axles were DIFFERENT!
Look and compare
http://c.a.d-cd.net/8d58804s-960.jpg
http://f.a.d-cd.net/1d58804s-960.jpg
Vadim aka ScooteR 10-15-2013 04:16 AM
Moders, please remove it to MazdaSpeed 6 - Engine, Transmission & Driveline
sorry, thanks!
phate 10-16-2013 08:03 PM
What suspension are you on, and what diff mounts do you have? I've gone just as fast in the 60' and launched it near 200 times this season...never broken a DSS axle.
Also, how are you launching? Dumping it?
jreiden1 10-16-2013 08:28 PM
Dumping is an understatement lol his other thread has the back end of the car squatting a good foot on launches and "drifts"
Edit: he has videos in the other thread
And dss has 1000 hp rated axles OP
phate 10-16-2013 08:36 PM
Found them. I'm betting launch technique is the problem - there's no taking up the slack before dumping it...that kills drivetrain parts.
Vadim aka ScooteR 10-16-2013 09:31 PM
DSS rear axles .
AWR rear engine mount .
MG passenger & front engine mounts .
MG diff mounts .
Autoexe all strut bars kit .
MG rear interior brace .
KW Variant2 coil-overs .
Whiteline RSB .
My car is very similar to Pat's Mazda.
My launching is usually on 6200rpm. 0.5Bar(7.25psi) on GTX3076, pick boost on 1 gear = 1.85bar(27psi), pick G = 1+ on 10-30mph.
yes, i dump the clutch pedal.
my 0-100kmph(0-62.5) is 3.2s with 1ft rollout or 3.4s with 0ft rollout. 0-60mph = about 3.2 with 0ft rollout.
http://b.a.d-cd.net/6473404s-960.jpg
60ft = 18m is 1.7s with 1ft rollout.
http://h.a.d-cd.net/8c13ef8s-960.jpg
sleepyspeed6 10-16-2013 09:39 PM
I bet if you were to preload those axles would be fine
Vadim aka ScooteR 10-16-2013 09:45 PM
can u explain?
How should i do preload?
phate 10-16-2013 09:45 PM
This.
If you're spinning off the line, your launch control is set too high. You can drop it down 100-200 rpm at a time to find the sweet spot. Slip the clutch for a split second THEN dump it. That tightens up the slack and you won't shock the drivetrain.
jreiden1 10-16-2013 09:50 PM
Which that is called preloading... You can also preload by using the e brake but that takes some practice!
phate 10-16-2013 09:51 PM
Originally Posted by Vadim aka ScooteR (Post 2300321)
can u explain?
There's lash in every connection in the drivetrain. A tiny amount of play in each joint, and it all adds up. You dump the clutch and it creates a HUGE force that loads the hell out of the drivetrain for a split second. That huge shock is what breaks parts.
The easy way to do it is to slip the clutch for a split second, then let off the clutch as fast as you can as soon as you feel the car move. If you get good with that, you can slip the clutch for that same split second while holding the ebrake, then releasing the ebrake as you let off the clutch.
I haven't been able to get any faster in the 60' using the ebrake, so I don't bother. I've been at the limit of street tires using this method, and have gone 1.70s really easily. That's launching at 0psi around 4500 rpm (depending on conditions).
Vadim aka ScooteR 10-16-2013 09:51 PM
Originally Posted by phate (Post 2300323)
This.
not too high
i tried to drop, but my starting boost depends on rpm.
it's ceramic clutch. it doesn't like sliping at all.
ACT 4 or 6 puck sprung
What turbo do u use?
phate 10-16-2013 09:56 PM
Originally Posted by Vadim aka ScooteR (Post 2300329)
not too high
Meh, I have an FX400 4 puck clutch, and it is WAY more aggressive than those ACT clutches. [I also built an MS6 with an ACT 6 puck and really don't like them.] They will slip just fine, the car should leave the line like an automatic.
Edit: this video shows it really well. You see the car move slowly, THEN I fully let off the clutch. I was cutting easy 1.7x's that day, and I think this video is a 1.70:
Vadim aka ScooteR 10-16-2013 09:57 PM
this is Pat's launching on record
Vadim aka ScooteR 10-16-2013 10:06 PM
And so what turbo do u use? It's really important
phate 10-16-2013 10:07 PM
K04, launching at 0 psi.
Turbo doesn't change the concept of preloading the drivetrain.
Vadim aka ScooteR 10-16-2013 10:19 PM
with ebrake ,yes, but i can't start without boost! look at my dyno sheet) I need boost all the time and rpm everytime 4300+. U can see my log of 1/4mile on about 11.2s))
rpm, boost in bars, duty, knocks
phate 10-16-2013 10:28 PM
I think I'd probably try launching around 4500-5000 rpm with that setup. Preload like we've said. Not having as much boost off the line probably won't hurt you any since you don't have slicks. Any time I've ever spun off the line I've cut a worse 60'. It looks cool, but it's definitely not fast.
Just my opinion.
Vadim aka ScooteR 10-16-2013 10:36 PM
Just my opinion.
There are two variants. Real.
I sliping clutch and have boost but no spinning or i need dump the clutch on boost and spining off the line with ebraking before start)
Vadim aka ScooteR 10-16-2013 11:43 PM
Here u can see the comparison of my 11.3s(at night) and 11.69s(day official result) 1\4mile. Second race was good at start, but then i had big problems with ignition((( Potential of this config is in <11sec. Next year i'll try to do this!)))
http://img-fotki.yandex.ru/get/9317/...51dc4_orig.jpg
PS No glue, guys, and street tires 235\45 17)
superskaterxes 10-17-2013 08:59 AM
@RichieRichness; and i hold the world record 60's at 1.66 and 1.63 respectively. Rich has broken 2-3 stock axles and 2 DSS axles. I have only broken 1 stock axle and i prob have triple the amount of passes that he does (easily over 150 on that single axle).
It really does come down to how you leave the line like phate says. Both rich and i have the ACT 6 pucks and they slip just fine. I cant launch over 5000 or else i cant leave 1st gear because im spinning the whole time. When i can afford 4 slicks i will buy them and we will really see what the drivetrain can hold lol
P.S. my record was done on 215/45/18 conti DWS's so tire really means nothing if you know how to drive.
Vadim aka ScooteR 10-17-2013 09:34 AM
U see my graph ) It's rather fast for no glue asphalt) and it could be better if i shifted later on 65kmph, not 55. It's really a 1.6s 60ft start on not glue special strip. I think u haven't <11s results because of your start.
Pat dumps clutch pedal too.
i want to try street drag radials next year.
http://www.hoosier.ru/images/quickca.../dsc_0050-.jpg
my problem may be because of drifting)
superskaterxes 10-17-2013 09:37 AM
those are the tires im buying except im getting the 225's
until you have a time slip to prove your time's then your only speculating using that electronic device. Doesent russia have drag strips?
phate 10-17-2013 09:44 AM
Ricer math is rice. If you are extrapolating that time from your ecu, then you're much slower than what you are calculating. Spinning = slower. Get a real slip and see what it does, try out the different methods prescribed here.
It's not like the guys who are cutting better 60' times are giving you advice......right? But, you're the expert, do what you want.
Vadim aka ScooteR 10-17-2013 09:48 AM
what is a price for 4 radials in USA?
In Russia 45000rub = 1400$ )
No there is no real drag stip in around 2000km of my city(((
We have telemetry but no good strips with glue.
Even Pat couldn't get a timeslip, but that was a Championship of Ukraine)
Vadim aka ScooteR 10-17-2013 09:55 AM
Have u videos of good start not on strip? I'd look at.
phate 10-17-2013 09:59 AM
Just look at my channel on YouTube (phate1985). I have quite a few from the strip, and a ton from autocross (autocross starts are completely unprepped). All launching with the same method, never breaking an axle lol.
Vadim aka ScooteR 10-17-2013 10:11 AM
Autocross starts were very slow. And have anybody videos of start on simple asphalt? To compare with mine.
but ebracking before start i'll try.
phate 10-17-2013 10:42 AM
Lol
jreiden1 10-17-2013 11:13 AM
Drag strips have a stickier surface causing more damage than asphalt/street roads
Vadim aka ScooteR 10-17-2013 11:18 AM
i know) so it's interesting to me who dumps clutch pedal on glue dragtrip.
superskaterxes 10-17-2013 12:41 PM
i think they were like $950 for the set, still alot of money for a set of tires im going to drive on 6-8 times a year for a total of about 20 miles lol
i dont really launch on the street ever but when i have i find its alot stickier then at the track for some reason. Maby its because im always on street tires in prepped lanes lol
RichieRichness 10-17-2013 12:55 PM
Only launched my car twice on the street. 1st time @CWP_MS3; nuked my PTO. Second time I snapped a DSS axle.
CWP_MS3 10-17-2013 01:06 PM
Because your car is a pussy. Let's just clear that up... lol And I have learned to slip since. :P
phate 10-17-2013 01:19 PM
I felt the same way in my ms3, and I think it's the same in my 6...
RichieRichness 10-18-2013 08:57 AM
note: DSS told me they changed their manufacturing process for our axles early this year...I have like 50 launches on this DSS axle and @sonic tuning; coilovers. I have yet to break an axle with my new suspension set up. Maybe it's the axle, suspension or both that helped. But I still launch the car like a fuckin boss.
Vadim aka ScooteR 10-18-2013 09:04 AM
so have u broken or not?
Have u foto of ur last axle?
RichieRichness 10-18-2013 09:06 AM
Not on this revised axle...Last axle I broke was in February 2013.
Oh btw how much of a pain in the ass it was to remove the broken off spline from the rear diff? LOL
Vadim aka ScooteR 10-18-2013 09:08 AM
Have u foto of new and broken?)
u can see 3 variant of axle on my fotos)))
RichieRichness 10-18-2013 09:10 AM
nope, when did you buy your last axle that broke?
Page generated in 0.26544 seconds with 11 queries
