![]() | | #1 | ![]() |
![]() Join Date: Oct 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 66
(Thread Starter) | Neutral : -1 score All transmission is tuned, all my gears are longer on 9% then stock. Both rear axles are Driveshaft Shop . But 2 times i've already broken left one! The first time Driveshaft Shop sent me repairing parts. There u can see foto of the first breakage ??????? ??????? ????????????? ??????? ??????? ??? ??????? ?? ????????? ??????? Driveshaft Shop And there is the second ??????? ??????? ????????????? ??????? ??????? ??? ??????? ?? ????????? ??????? Driveshaft Shop (????? 2) All THREE variant of axles were DIFFERENT! Look and compare ![]() |
| The Following 4 Users Say Thank You to Vadim aka ScooteR For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Moders, please remove it to MazdaSpeed 6 - Engine, Transmission & Driveline sorry, thanks! |
| Not Ranked : 0 score What suspension are you on, and what diff mounts do you have? I've gone just as fast in the 60' and launched it near 200 times this season...never broken a DSS axle. Also, how are you launching? Dumping it?
| The Following User Says Thank You to phate For This Useful Post: | qtrmile beast (10-16-2013) |
![]() | | #4 | ![]() |
![]() Join Date: May 2012 Location: New Philadelphia, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,087
Groaned at 4 Times in 2 Posts
Edit: he has videos in the other thread And dss has 1000 hp rated axles OP
__________________ 2006 WWP Mazdaspeed 6 KILLAH BUILT 700+ AWHP TUNED BY NISHAN | |
![]() | | #5 | ![]() |
| Not Ranked : 0 score Found them. I'm betting launch technique is the problem - there's no taking up the slack before dumping it...that kills drivetrain parts.
| The Following User Says Thank You to phate For This Useful Post: | jreiden1 (10-16-2013) |
![]() | | #6 | ![]() |
AWR rear engine mount . MG passenger & front engine mounts . MG diff mounts . Autoexe all strut bars kit . MG rear interior brace . KW Variant2 coil-overs . Whiteline RSB . My car is very similar to Pat's Mazda. My launching is usually on 6200rpm. 0.5Bar(7.25psi) on GTX3076, pick boost on 1 gear = 1.85bar(27psi), pick G = 1+ on 10-30mph. yes, i dump the clutch pedal. my 0-100kmph(0-62.5) is 3.2s with 1ft rollout or 3.4s with 0ft rollout. 0-60mph = about 3.2 with 0ft rollout. ![]() 60ft = 18m is 1.7s with 1ft rollout. ![]() | |
| The Following User Says Thank You to Vadim aka ScooteR For This Useful Post: | jreiden1 (10-16-2013) |
![]() | | #7 | ![]() |
![]() Join Date: Jan 2011 Location: Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 658
| Not Ranked : 0 score I bet if you were to preload those axles would be fine
__________________ Hx35 sold New sc6266 |
| The Following User Says Thank You to sleepyspeed6 For This Useful Post: | phate (10-16-2013) |
![]() | | #8 | ![]() |
(Thread Starter) | Not Ranked : 0 score can u explain? How should i do preload? Last edited by Vadim aka ScooteR; 10-16-2013 at 09:45 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #9 | ![]() |
| Not Ranked : 0 score This. If you're spinning off the line, your launch control is set too high. You can drop it down 100-200 rpm at a time to find the sweet spot. Slip the clutch for a split second THEN dump it. That tightens up the slack and you won't shock the drivetrain.
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #10 | ![]() |
| Not Ranked : 0 score Which that is called preloading... You can also preload by using the e brake but that takes some practice!
| The Following 2 Users Say Thank You to jreiden1 For This Useful Post: | phate (10-16-2013), sleepyspeed6 (10-17-2013) |
![]() | | #11 | ![]() |
| Not Ranked : 0 score There's lash in every connection in the drivetrain. A tiny amount of play in each joint, and it all adds up. You dump the clutch and it creates a HUGE force that loads the hell out of the drivetrain for a split second. That huge shock is what breaks parts. The easy way to do it is to slip the clutch for a split second, then let off the clutch as fast as you can as soon as you feel the car move. If you get good with that, you can slip the clutch for that same split second while holding the ebrake, then releasing the ebrake as you let off the clutch. I haven't been able to get any faster in the 60' using the ebrake, so I don't bother. I've been at the limit of street tires using this method, and have gone 1.70s really easily. That's launching at 0psi around 4500 rpm (depending on conditions).
| The Following 2 Users Say Thank You to phate For This Useful Post: | jreiden1 (10-16-2013), sleepyspeed6 (10-17-2013) |
![]() | | #12 | ![]() |
i tried to drop, but my starting boost depends on rpm. it's ceramic clutch. it doesn't like sliping at all. ACT 4 or 6 puck sprung What turbo do u use? | |
![]() | | #13 | ![]() |
Edit: this video shows it really well. You see the car move slowly, THEN I fully let off the clutch. I was cutting easy 1.7x's that day, and I think this video is a 1.70:
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
![]() | | #14 | ![]() |
(Thread Starter) | Not Ranked : 0 score this is Pat's launching on record |
![]() | | #15 | ![]() |
![]() | | #16 | ![]() |
| Not Ranked : 0 score K04, launching at 0 psi. Turbo doesn't change the concept of preloading the drivetrain.
![]() | | #17 | ![]() |
rpm, boost in bars, duty, knocks | |
![]() | | #18 | ![]() |
| Not Ranked : 0 score I think I'd probably try launching around 4500-5000 rpm with that setup. Preload like we've said. Not having as much boost off the line probably won't hurt you any since you don't have slicks. Any time I've ever spun off the line I've cut a worse 60'. It looks cool, but it's definitely not fast. Just my opinion.
| The Following 2 Users Say Thank You to phate For This Useful Post: | Downmented (10-17-2013), Vadim aka ScooteR (10-16-2013) |
![]() | | #19 | ![]() |
I sliping clutch and have boost but no spinning or i need dump the clutch on boost and spining off the line with ebraking before start) | |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here u can see the comparison of my 11.3s(at night) and 11.69s(day official result) 1\4mile. Second race was good at start, but then i had big problems with ignition((( Potential of this config is in <11sec. Next year i'll try to do this!))) ![]() PS No glue, guys, and street tires 235\45 17) Last edited by Vadim aka ScooteR; 10-17-2013 at 12:07 AM. |
![]() | | #21 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score @RichieRichness; and i hold the world record 60's at 1.66 and 1.63 respectively. Rich has broken 2-3 stock axles and 2 DSS axles. I have only broken 1 stock axle and i prob have triple the amount of passes that he does (easily over 150 on that single axle). It really does come down to how you leave the line like phate says. Both rich and i have the ACT 6 pucks and they slip just fine. I cant launch over 5000 or else i cant leave 1st gear because im spinning the whole time. When i can afford 4 slicks i will buy them and we will really see what the drivetrain can hold lol P.S. my record was done on 215/45/18 conti DWS's so tire really means nothing if you know how to drive.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner |
| The Following 5 Users Say Thank You to superskaterxes For This Useful Post: | jreiden1 (10-17-2013), lilred (10-17-2013), phate (10-17-2013), RichieRichness (10-17-2013), sleepyspeed6 (10-17-2013) |
![]() | | #22 | ![]() |
Pat dumps clutch pedal too. i want to try street drag radials next year. ![]() my problem may be because of drifting) Last edited by Vadim aka ScooteR; 10-17-2013 at 09:34 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #23 | ![]() |
until you have a time slip to prove your time's then your only speculating using that electronic device. Doesent russia have drag strips?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Downmented (10-17-2013), MZRSPEED (10-17-2013) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Ricer math is rice. If you are extrapolating that time from your ecu, then you're much slower than what you are calculating. Spinning = slower. Get a real slip and see what it does, try out the different methods prescribed here. It's not like the guys who are cutting better 60' times are giving you advice......right? But, you're the expert, do what you want.
| The Following 2 Users Say Thank You to phate For This Useful Post: | Downmented (10-17-2013), superskaterxes (10-17-2013) |
![]() | | #25 | ![]() |
In Russia 45000rub = 1400$ ) No there is no real drag stip in around 2000km of my city((( We have telemetry but no good strips with glue. Even Pat couldn't get a timeslip, but that was a Championship of Ukraine) | |
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Just look at my channel on YouTube (phate1985). I have quite a few from the strip, and a ton from autocross (autocross starts are completely unprepped). All launching with the same method, never breaking an axle lol.
| The Following User Says Thank You to phate For This Useful Post: | jreiden1 (10-17-2013) |
![]() | | #28 | ![]() |
but ebracking before start i'll try. | |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Lol
![]() | | #30 | ![]() |
| Not Ranked : 0 score Drag strips have a stickier surface causing more damage than asphalt/street roads
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
i dont really launch on the street ever but when i have i find its alot stickier then at the track for some reason. Maby its because im always on street tires in prepped lanes lol
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | jreiden1 (10-17-2013), Vadim aka ScooteR (10-17-2013) |
![]() | | #33 | ![]() |
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 ![]() | |
| The Following 4 Users Say Thank You to RichieRichness For This Useful Post: | Downmented (10-17-2013), jreiden1 (10-17-2013), superskaterxes (10-17-2013), Vadim aka ScooteR (10-17-2013) |
![]() | | #34 | ![]() |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6574 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() | |
![]() | | #35 | ![]() |
| Not Ranked : 0 score I felt the same way in my ms3, and I think it's the same in my 6...
| The Following User Says Thank You to phate For This Useful Post: | superskaterxes (10-18-2013) |
![]() | | #36 | ![]() |
Groans: 35
| Not Ranked : 0 score note: DSS told me they changed their manufacturing process for our axles early this year...I have like 50 launches on this DSS axle and @sonic tuning; coilovers. I have yet to break an axle with my new suspension set up. Maybe it's the axle, suspension or both that helped. But I still launch the car like a fuckin boss.
| The Following 2 Users Say Thank You to RichieRichness For This Useful Post: | jreiden1 (10-18-2013), superskaterxes (10-18-2013) |
![]() | | #37 | ![]() |
Have u foto of ur last axle? | |
![]() | | #38 | ![]() |
Groans: 35
| Not Ranked : 0 score Not on this revised axle...Last axle I broke was in February 2013. Oh btw how much of a pain in the ass it was to remove the broken off spline from the rear diff? LOL
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
Groans: 35
| Not Ranked : 0 score nope, when did you buy your last axle that broke?
| Mazda 6 MPS GTX3076 1.06 tial tuned by PAT & MazdaGarage | Vadim aka ScooteR | Drag Racing | 265 | 05-04-2016 06:58 PM |
| Mazda 6 MPS GTX3076 1.06 tial | Vadim aka ScooteR | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 4 | 10-15-2013 12:51 AM |
| Driveshaft Shop Discount | CruZ_MS6 | Mazdaspeed3/6 General Discussion | 6 | 06-14-2012 05:23 PM |
