Keep in mind if you want a fresh surface for the rings (which frankly was the thing everybody was told to do with new pistons/rings, but isn't so much necessary anymore based on the new tight tolerances), Sears sells a cylinder bore hone kit that you throw on an electric drill. I knew a guy who built SR20's, and any block with clean cylinder walls, he'd use that on with great success. I agree that bearings can be measured in the car, rod bearings, and if anything, have the piston/rod combo assembled prior to installation and balanced to match weight as best as possible. |
Anyhow see if this works... I got a video for checking cylinder bore too. They are all from that 100 series blueprinting youtube series. good stuff for a DIY to see if the block is good. |
That guys entire series of vids are great. I ran across them about a month ago I have them all bookmarked. |
I'll probably have a few friends whom are very experienced in engine assembly help me with this if/when I decide to do it. Even though they're not familiar with the MZR themselves engines are universal in theory and application. Also, I'd like to avoid moving the oil squirters so it seems CP pistons are in order opposed to the Wiseco pistons I originally intended. I'm not a fan of the K1 rods strictly because they're not of the stronger H-Beam design, and if I'm loading the car up with nitrous at low RPM's I need the peace of mind lol. |
Lol. I may be off on the comp ratio. How about a higher Than OE comp ratio? He's already on E w 1200cc top feed injectors. |
Gen2's, per Mazda's literature, come with Forged Rods and Forged Crank from the factory. Pistons are hyper I believe. |
Forged does not = strength |
Just stating the literature...not debating over the effictiveness of aftermarket selection. I know the aftermarket is superior in metallurgy, design, and strength :) |
In for future fail.. I kid, if you need any help lemme know |
Well, since I spun a rod bearing about a month and a half ago and required a new crank and rods and etc. I could be interested in giving this idea a shot possibly. waiting on the new rods to show up so I can take everything to get balanced and then it's game on again :) |
I saw that, I read the thread earlier on my phone and saw the tag. anyways, depending how I feel at the time when it comes to start rippin' apart my car I'll decide if the motors coming out, or if I would want to give it a shot with it in if you haven't already. depends how lazy I want to be about it :) I'm giving the Eagle rods a shot this time too. although the K1's were damn nice, I cant buy just a single K1 so, I went with Eagle H-beams this time. it's been two months almost since my cars ran, shit's making me depressed now. |
OE is 8:2 I believe ( according to him) so although not a "high" comp motor it's higher than OE. Tappin |
Also, what pistons are you running? |
Subs for.... Poor Compression |
CP Pistons link: CP Pistons Mazdaspeed 3 MS3 Mazdaspeed 6 MS6 |
No Poor Compression as in... Installing new Pistons into an engine that has not been machined... and thus not holding compression because the rings are not seated properly... |
https://lh6.googleusercontent.com/-E...ompression.jpg |
Stock is 9.5:1 Do allows u to run higher comp ratio on boosted cars |
I agree that machining is not always necessary. Someone mentioned using gen2 pistons. Is there a difference between gen1 and gen2 pistons? Second, forged, yes there's a difference. Our stock rods are forged powdered metal, if I remember correct. Aftermarkets are either forged or billet. Again, I'm thinking if all the surfaces are good with no scoring (they should be), then you should be good to go. However, you may need a week or so downtime because you'll need to measure for bearings, order bearings, and perhaps have the bearings coated to make sure clearance is within spec. But, if you get the pistons/rods assembled with rings, make sure they're balances as best possible, I don't see how you'll have any issues throwing them on the crank. As people mentioned, stock crank and harmonic balancer are pretty well balanced from factory. If I were building a motor and had the money to spend, I'd have it all balanced, but I'd also have the crank knife-edged and cryo'd. Knife edge to minimize friction with the oil and splashing as well as reduce weight, and cryo'd for additional strength. Then of course have the crank, pistons/rods/pulley/flywheel/clutch all balanced together. |
Gen2 pistons are dished which promotes better atomization and flame front travel. I will have to look up 06speed6's compression numbers but I think you guys are getting static compression confused with dynamic compression. What the piston manufacturer states their pistons are is not what compression you will have in the cylinder. in the scoobie example his weisco's are 9:8:1 and in the car he will be running 9:2:1 our cars compression calculates out to 8. something with OE cams. BRB |
8 seems rather low. We'd be pretty damn sluggish off the boost with 8:1 compression..........that doesn't seem right. Remember, the OEM compression rating isn't referring to the pistons. |
Here is one post but not the one I was looking for. I guess it doesn't really matter which compression ratio you quote but everyone does need to be on the same page and I for one think you need to be referring to Dynamic ratio but who knows...lol so we are somewhere between 8:1:1 with no VVT and 8:58:1 at full advance OE cams Quote:
ok here is the post I was looking for which just has more "what if's" for LSA. Quote:
http://www.mazdaspeedforums.org/foru...tml#post318778 |
Bearing clearance seems to be the biggest issue so far. That's why I'm waiting on Jesse to assume his engine with the eagle rods. Well, that and the head. I hate fucking timing chains. I suppose itd be smart to swap the vvt shit while it was all apart |
lol where does it end...get a DCR VVT if your going there. yes it does seem that the oil clerenes are a big unknown for us thus far...some are way lose [Dustin] some are way tight [jesse]. There are alot of rod bearing combos so the only way to know is measure. |
I'm gonna try and get my hands on a spare long block so that I can experiment with some shit. Don't know when I'll get one but this way I can spec everything out then just do the swap in the car (and by that I still mean the drop-in internals) fuck pulling the engine. |
The dynamic compression ratio for this setup with my aftermarket cams is 8.0:1 which is the middle of the acceptable range of 7.5:1 and 8.5:1 for pump gas engines. Anything less than 7.5:1 is bad for power and torque and anything above 8.5:1 will generally knock on pump gas. back in the day I had a 302 with 10:5:1 pistons and had to run either C12, C14 or I could get by on a mix of 93 and C12 if I retarded my advance...and to do that you turned the distributor....lolololol |
Where's Pablo? |
you do know we haz turbos that increase the compression ratio way beyond 8:5:1 right? my quotes are from 06speed6 and the work he did on his MZR. |
In looking at that thread, I find the following very interesting too: Quote:
http://www.mazdaspeedforums.org/foru...23/index3.html |
lol...I'm not sure of the definition of "stock block" in the 1K HP story. If its the motor I am thinking about its a MZR block with PI head and only the "block" is stock....not the internals. Meaning no girdling or gussets added to strengthen the block itself. I could be totally wrong but god 1K HP would be insane on our rods and long stroke. still interested to see the end of this "drop-in" story...be it Tom or Jesse. |
Im running ~2.2 load at 2000rpm, stock block and turbo, zero knock. I am also running ~30* max cam advance from idle to about 1500rpm because there isnt enough oil pressure to keep the vvt from hitting its internal stops. |
| All times are GMT -7. The time now is 06:46 AM. |
