The timing cover really isn't that bad to do. On the gen2's it's even easier. No Power steering pump! We had the Head off Doug's car in a couple hours. Started at 9 and had it off at 11:30. |
Tomas, you'd still have to take the timing cover to take the head off, iirc the cover is bolted to the head itself. If you're gonna do the internals swap, it's a good time to swap chain and tensioner too...to be on teh safe side. That's my intent. Now, @Tomas What aftermarket pistons hit the oil squirters? And do we have any idea how strong the stock pistons are, genjuan or genpoo? I saw the ginormous ring land and my thought is it'd be pretty hard to put a crack in that sucker.....think they'd be strong enough for 500-550whp? If people figure they're strong enough for 550whp, I might as well keep my stock pistons and just get some k1's or eagles! |
I'd like to stick with my stock gen2 pistons. That's $500 in my pocket. Haha. And I think they are plenty strong enough for 500hp. The only issue I think we have seen was bluestreak cracked a ring land, but there haven't been any other known cases |
hmm. I'd like to stick with my genjuan pistons. I'd think they're just as strong as the poo but obviously different flame pattern design. |
EDIT: It was #3. Here is the link. http://www.mazdaspeedforums.org/foru...ml#post1043619 |
hmmm. That may dash some of my hopes. |
Yep. Cyl 3 took a crap on me during time attack. I was out on the track for 30 mins at a time in 35*C (95*F) weather. That day did my motor in. I imagine the pistons could put up with DD and 1/4mile abuse longer than tracking but that's just an educated guess based off me leaning back in my chair and staring at ceiling tiles. EDIT: This was on my GT3071 at 20PSI and 12* timing up top. Kept things "safe" so I wouldn't pooch the motor.... Ha. |
I just want to do rods. We have not seen a lot of piston failures just rods. |
I'm not saying that it would ever even become an issue but for the peace of mind an extra $500 is well worth it. |
You are are right about replacing the chain and may be the VVT too. It's just that if you could do rods in one week end and chain and VVT in another it would be much less stressful than trying to do all this shit in a week end working solo. That's what I usually have to do. I can only have the car down for the week ends as I need to ride to work. Quote:
Make sure you label all the bolts, etc. I had taken off some stuff before I even had it towed to save time, and had all my shit labelled in separate bags. Wouldn't you know it but the only missing shit (later found, but time wasted) was not in labelled bags, lol. |
Crap. Don't want to have to modify the jets/squirters. and yeah I know what you mean, I'd be working solo too. |
358WHP & 381WTQ (93 OCTANE PUMP GAS K04 W/N2O!!) LMFAO!! So much for that 5 months ago:burnout: |
http://farm8.staticflickr.com/7021/6...da4bfbdd_b.jpg |
There are some pics of my build on this thread. http://www.mazdaspeedforums.org/foru...eekend-110042/ Block stayed in the car and I used a Flex-Hone tool to hone it myself. Just nuts and bolts, not hard at all. I worked alone and probably could have finished in 2 days if I needed to finish that fast. My Wiseco pistons cleared the squirters, but apparently that's not the case for others. You should be able to bend them from up top though. Good luck |
I'm going back on the rollers soon to smash 400whp in the mouth |
As for the install....your cams look like they were at an odd angle with the timing tool in there. I think before I pop out the cams to remove the head I'll probably rotate to Cyl1 TDC and take a pic of the cam position with cam plate on just for reference when putting the chain back on, heh. |
The cam plate will not fit inside the slits on the cams unless they are positioned correctly. The slits on the cam ends do NOT run through the middle of the camshaft. They are off center. |
How about piston slap during start up? Is there much noise? Does the engine smoke more / have lower compression than stock? I have genpoo pistons ready to go for my week end "insitu" build but I'd concider doing forged pistons with updated Gen2 piston crowns if I don't have to precision hone the cylinder liners. Just de-glaze them. |
^^^ and 5 over |
So what I'm looking at doing is ball hone, I guess. Flex-Hone®, Cross Hole Deburring, Ball Hones |
@MS3-a(sore)ASS-rex going to be dropping mine in over the next few days. No major rush for me. Could be back together in a day......who knows maybe I will just finish it up once I start. But I like taking my time! |
3 1/2" (89mm) 240 grit. Quote:
How many runs did you do on each cylinder? |
Your goal is a 45* crosshatch. Make sure when you use the hone to also use a lubricant like liquid wrench to ensure no scoring of the cylinder |
IDK, I'm just a noob at this kind of stuff though. |
You mean flex hone as opposed to regular 3 leg stone hone? The flex hone uses lil balls. Like the ones sitting below my penis. And if there is still a nice cross hatch on the cylinder walls, why not just deglaze by using an abrasive nylon filament wire brush? Why hone at all? Edit: I just got of the phone with Wiseco. I asked whether the pistons they sell for the MZR DISI would require additional honing of the cylinder walls from a brand new stock block to accomodate the required cylinder to wall clearance and they said yes. I.e. the pistons are not made with a tolerance for a new block. Wiseco assumes if one were to install their pistons that it would be on an engine that will have the cylinders honed out a little larger. They said stock clearance is 0.003" and their pistons require 0.003 1/2 to 4. Not much actually but it might matter. The forgings are 2618 and expand quite a bit unlike the 4032 alloys. Not trying to crap on theschrum's party but I'd be worried when shit gets really hot that a piston might seize. So for me I am sticking to my gen2 pistons. |
I still hone the cylinder regardless of the condition of the factory crosshatch simply as part of a process I do. Edit to your edit: awesome info that you found for the Wiseco pistons. Honestly I dontthink clearances would become an issue on an engine with some mileage on it as opposed to a brand new block that hasn't had any piston rings seated to the cylinder walls. A bit of wear would probably be all the cylinders need to be "safe" to run the Wisecos. Perhaps that was their theory when they made them? Idk. |
Fuck. Now I am really torn between using some aftermarket pistons and the gen2s. My engine has perfect compression. I was just going to change the pistons as part of changing rods to K1. Now I have to lay sleepless at night again trying to decide what pistons to use. lol Quote:
What about the arias pistons? And yeah. When I do mine, I'll have 80k+ miles on the block....should be plenty of wear to just to a ball hone and throw the pistons in. |
.0005" is not much material, and I bet hitting with the hone alone would shave about that off, which would get it right within wiseco's spec of .0035"-.004" |
| All times are GMT -7. The time now is 06:46 AM. |
