-   -   Drop-in forged internals (http://www.mazdaspeedforums.org/forum/f10/drop-forged-internals-102383/)
Dano 07-26-2012 08:33 PM
hahahahahahahahahah
Chimmike 07-27-2012 06:15 AM
Tomas : singlehandedly making wet dreams everywhere.
Chimmike 08-17-2012 06:23 AM
@Tomas have you torn down yet?
Tomas 08-17-2012 06:26 AM
No.
Probably be another month or so before I get to it. I'd say before end of September for sure may be. lol
Chimmike 08-17-2012 06:38 AM
Ouch! Looks like I'll be attacking mine before then
DiGi Faggot 08-17-2012 09:38 PM
Towing my car to its final destination tomorrow. I will begin tear-down shortly. Exhaust Manifold+Turbo+DP is already off, and the intake manifold is half off.
I prob wont begin tear-down till I have all the parts. Waiting on K1 Rods from Edge. Should be another week or so. Then i'm also going to be ordering Pistons from @PositiveFabrication
So, Soon i'll be :slomo:
Tomas 08-18-2012 12:15 AM
2 weeks
theurgy 08-18-2012 11:37 AM
Originally Posted by Tomas (Post 1565209)
2 weeks
http://www.scatchan.net/img/1343274464185372.jpg
Dano 08-18-2012 01:36 PM
go 11:1 or go home :)
but seriously what comp ratio are you going with?
phate 08-18-2012 02:58 PM
Cool people do 12:1 ;)
Dano 08-18-2012 03:04 PM
orrly
DiGi Faggot 08-18-2012 08:42 PM
Just saying stock for now. Im CA so we have shitty gas and im not setup to run meth and such yet. Financially this build couldn't have come at a worse time. I also still dont hve an AP.
GLORIFIEDBOZO 08-19-2012 10:43 PM
11:1 is taken ;)
MS3-a(sore)ASS-rex 09-10-2012 07:38 AM
Bump @chimmike @Tomas
Have either of you started yet? Pics, updates, issues, anything?
Tomas 09-10-2012 08:48 AM
@chimmike has been pumping out magic juice for a while now.
http://www.mazdaspeedforums.org/foru...-build-122409/
MS3-a(sore)ASS-rex 09-10-2012 10:16 AM
This is what happens when I'm not on the boards for two weeks...
Great work @chimmike, hope you get that turbo bs figured out soon
Phoenix Speed3 09-15-2012 01:48 PM
subbed
mituc 09-18-2012 11:22 AM
Phoenix : thread tools -> subscribe. It keeps the thread cleaner.
Ok, so I'm thinking to go forged and I was set on Carrillo A-beam (lighter, and still strong enough for what I need) and MS3 gen2 smiley face pistons. Yesterday a friend of mine with a shitty tune (lots of advance, lots of boost, and still on stock K04) blew a piston on a gen2 which made me consider the forged pistons alternatives as well. I'm not decided yet and I will not before I get some facts from people who've been through this.
Also, probably the OEM pistons + rings are at about the same price as the forged Wiseco's (which are the ones I have in mind).
So what other side effects apart from piston slap when cold should I expect with the forged pistons?
Will the engine be noisier as well (all I'm concerned about is the cabin noise)?
The forged pistons can also be used with an OEM piston rings set or only their own?
The weather here is like Georgia during summer and Canada during winter. Is this bad for forged setups like the one I have in mind (carrillo+wiseco) or for the cylinder walls or it doesn't really matter and it's only a problem of extra noise?
theurgy 09-18-2012 12:03 PM
Pistons come with their own set of rings, I will say that a set of OEM rings will not fit on anything else but an OEM piston...
There's also issues with running stock pistons on aftermarket rods, not sure of the brands, but some guys have had issues getting the rods to mate up with the OEM pistons at the wrist pins as the eye is thicker than stock.
I would say, you're already rebuilding, do it right the first time and get the whole kit a kaboodle.
Brian MP5T 09-20-2012 12:10 PM
Correct..
Not only the size (Diameter) of the ring, but even the thickness of it has to be spot on to the piston makers specifications.
The Take-away point here is...
Use the Rings that are offered by the manufacturer of the Pistons... No Substitute.
You will just run the risk of folding a Ring Over inside the cylinder and then you will be taking the bus.
http://images.zap2it.com/images/movi...furious-21.jpg
DiGi Faggot 09-21-2012 04:16 AM
@mituc - Hey, Check out @PositiveFabrications' pistons. They're very nice, specially designed for the MS/DISI-MZR. They're Forged Smiley face pistons and they're decently priced!
@Clint@posifab.com
Heres what they look like. http://www.mazdaspeedforums.org/foru...9/#post1500858
http://www.mazdaspeedforums.org/foru...9/#post1547531
MS3-a(sore)ASS-rex 09-21-2012 05:37 AM
@Clint@posifab.com
Unless he's considering a higher concentration of e85 the higher compression pistons aren't the best idea.
Chimmike 09-21-2012 05:54 AM
Well fellas, I did it. If I did, anyone else can too. Just be thorough in your preparation and research, take your time and do it right.
I get no piston slap when "cold" (but we're talking summertime cold, 70's in the mornings) with the CP pistons. Running 5w30.
DiGi Faggot 09-21-2012 06:24 AM
The pistons are custom. I'm getting entire stock spec for pistons. Bore, Compression, Etc. Just forged and has fuel relief. So he can have stock compression, even more/less if he so desires.
MS3-a(sore)ASS-rex 09-21-2012 06:35 AM
Thanks for clarifying. It's nice to have another option
Jay@posifab.com 09-21-2012 06:44 AM
We are doing stock compression ratio as well, though I am not sure we will be able to go below stock compression.
MS3-a(sore)ASS-rex 09-21-2012 07:20 AM
I can haz??
Deldran 09-21-2012 07:29 AM
If you went from 9.5 to 10 would u need e85 to run that at the same power levels as 9.5 on pump
Sent from galaxy Nexus vis CM10
Jay@posifab.com 09-21-2012 08:59 AM
Originally Posted by MS3-a(sore)ASS-rex (Post 1642625)
I can haz??
PM me if your interested.
phate 09-21-2012 10:20 AM
Who doesn't want more E85?
MS3-a(sore)ASS-rex 09-21-2012 11:02 AM
Everyone should...lol. But I have no idea what corn availability is like across the pond
theurgy 09-21-2012 12:17 PM
Sadly not readily available here in Canada either.
mituc 09-21-2012 12:49 PM
Thanks man, that's good to know as from what you're saying may be what I'm looking for even if for now I postponed the rebuild, I decided to wait at least until it will burn a drop of oil at like 2-3 changes.
Gr8Speed 04-03-2014 01:23 PM
Well, now that my brain hurts from all that reading... Sorry to rez the old as dirt thread, but what was the consensus on this? I had the idea to drop the oil pan, pop the heads, and just swap rods/rod bearings. I think the OEM pistons will be fien. Has anybody actually done this yet? Provided the block is in good shape, this should be fine?
I'm really only shooting for mid-low 400's and I think upgrading rods would reliably allow me to do this.
@atvfreek; @phate; @MS3-a(sore)ASS-rex; @gingermike;
Chimmike 04-03-2014 04:25 PM
Don't waste your time to do all that work and keep the stock pistons. Enough evidence around to show ringlands crack too.
If you do it, buy new OEM bearings, and have the bearings and the big end of the rods measured by a machine shop, and I'd have someone help you gap the rings who has experience. Assuming your bores are clean, a simple hone with the craftsman tool should suffice to deglaze. I'd also have a machine shop assembled the pistons on the rods.
Use a plastigauge to measure the tolerances on the rod bearings to the crank and make sure they're in spec. If not, you may need to try different bearings or look into other options.
Use a good OEM headgasket, and use good studs, H11's or L19s. Probably a good idea to have the head decked, it's probably warped and off by a few thousandths....pretty common.
Gr8Speed 04-03-2014 08:51 PM
Well shit. There goes that idea of pulling the car in, jacking it up and building the engine in a weekend. Might as well just build a block and swap with how much work that'll be. Thanks man.
mxlplx71 04-03-2014 08:59 PM
how many miles on your engine?
mine had around 42k when I did the rod piston swap with the block in the car.
it took about 40 hours over 4 days. also not the first engine ive torn into.
if you know what your doing and have at least one good helper you could probably get it done in three days or less.
building one and swapping is the better way to do it though.
Gr8Speed 04-03-2014 09:01 PM
mine had 32k when I did the rod piston swap with the block in the car.
Lol 96k. That's the scary part. I'm doing a compression test tomorrow, but the engine seems healthy.
Chimmike 04-04-2014 10:49 AM
my bores were clean with 82k on them.
theurgy 04-04-2014 09:33 PM
If your engine is fine, then getting a second block and selling your old block should be pretty easy.
Page generated in 0.21697 seconds with 11 queries
