Like Tree22Likes
 Old 01-16-2012, 10:28 AM   #1
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Default Drop-in forged internals
Ok so I you're not familiar with the term drop-in internals, it pretty much means that instead of pulling the entire engine and tearing it down and rebuilding it completely, you pull the head and drop the oil pan to swap the pistons, rods, bearings and gaskets (preferably with better head studs). Its done without machine work to the block besides honing the cylinders.
I've done this quite a few times on 4G63's but I dont recall seeing anyone having done it on here. Usually it takes me about a weekend working at a comfortable pace to get this done.
Have any of you done this? And if so what combination of internals, bearings, gaskets and hardware do you recommend for best OEM fitment?
I was considering Eagle H-Beam rods with Wiseco Pistons (stock bore & wrist pin size), with ARP head studs and an OEM gasket kit. Thoughts...opinions?
NATOR PA
The Following 5 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
ak_spray (08-17-2012), alphasaur (01-17-2012), atvfreek (11-03-2012), dougefresh_ (01-17-2012), Phoenix Speed3 (09-15-2012)
 Old 01-16-2012, 10:30 AM   #2
trf5000's Avatar
Posts: 2,290   (View Stats)
No stock block with nitrous?
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following 5 Users Say Thank You to trf5000 For This Useful Post:
Chriscote (01-17-2012), Don06speed6 (01-16-2012), i8urgti (01-16-2012), MS3-a(sore)ASS-rex (01-16-2012), ridenfish39 (01-16-2012)
 Old 01-16-2012, 10:33 AM   #3
Groans: 224
I'd rather be safe than sorry. If I can get away with swapping my internals over a weekend I've got no problem doing it. Car needs to be drivable.
May do a small hit in the neighborhood of 20-25hp on stock block above 3500 rpm but it makes me uneasy haha.
NATOR PA
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post:
trf5000 (01-16-2012)
 Old 01-16-2012, 10:34 AM   #4
starscream's Avatar
Posts: 630   (View Stats)
starscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the world
Groans: 44
I dont think anyone has really done this because usually the block itself has a hole. So they have to pull.
Also this would only work if you know the engine block is 100% good right? or else you might have a warped deck on the block and you cant machine the block while in the car.
I think just the variables of people haveing blown blocks and all that limits how many would even attempt doing it this way.
starscream is offline   Reply With Quote
The Following User Says Thank You to starscream For This Useful Post:
 Old 01-16-2012, 10:37 AM   #5
trf5000's Avatar
Wouldnt it be just easier to pull the motor?
2010 MS3 - Sold
 Old 01-16-2012, 10:39 AM   #6
Groans: 224
I'm a fan of nipping shit in the bud. I'd like to think I wouldn't need to deck the block with 36k on it but it definitely is a variable
Not at all. It triples your work load
NATOR PA
Last edited by MS3-a(sore)ASS-rex; 01-16-2012 at 10:39 AM. Reason: MSF Database - Automerged Doublepost
rfinkle2 (01-17-2012)
 Old 01-16-2012, 10:39 AM   #7
trf5000's Avatar
If you do this, I want to watch.
2010 MS3 - Sold
The Following 6 Users Say Thank You to trf5000 For This Useful Post:
Billcraft78 (04-03-2014), Chriscote (01-17-2012), Don06speed6 (01-16-2012), karl-hungus (01-16-2012), manelscout4life (01-17-2012), MS3-a(sore)ASS-rex (01-16-2012)
 Old 01-16-2012, 10:42 AM   #8
Groans: 224
Sure thing
NATOR PA
Manny3 (06-07-2012)
 Old 01-16-2012, 10:43 AM   #9
crazyp's Avatar
Posts: 1,093   (View Stats)
crazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the world
Groans: 68
Groaned at 22 Times in 9 Posts
I was wondering the same thing. Definitely subbed to I this. I mean really all I want is stronger rods and head studs just like you
2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC
crazyp is offline   Reply With Quote
 Old 01-16-2012, 10:43 AM   #10
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
As long as the bore isnt damaged it would probably be ok, I dont know that it has been done on this engine before because nearly everyone blows then builds or they buy a second block to build then swap.
2006 Mazdaspeed 6
MS3-a(sore)ASS-rex (01-16-2012), rfinkle2 (01-17-2012)
 Old 01-16-2012, 10:43 AM   #11
MS3KO's Avatar
Posts: 579   (View Stats)
MS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the world
Hmm interesting i hear a lot of ppl dropping internals this way but never on the mzr platform subbd for info
2009 MazdaSpeed 3 Metro Grey-T3 Gt3071, Re-flanged RR mani, 44mm Tial WG, Cusom DP, Custom 4in to 3.5in intake, Custom 3.5in maf, Custom FMIC kit, Tial BOV, EVO Prosport Boost gauge, EVO oil temp gauge, AEM wideband, TRZ RMM, JBR PMM, JBR TM, JBR Shifter Plate, TWM SS, Hks CBE, COBB AP, Road Magnet Springs.
PERM Tuned!///389hp 360tq///Best time:12.2 @117 (with new tires 11's here i come!)
Hit up BC Autoworks for all your powder coating needs!
MS3KO is offline   Reply With Quote
 Old 01-16-2012, 10:59 AM   #12
Groans: 224
@socks
@SilverDemon
@essejemscraw
@djuosnteisn
Who else has a built block? Lol
NATOR PA
djuosnteisn (01-17-2012)
 Old 01-16-2012, 11:05 AM   #13
Posts: 9,484   (View Stats)
Tom u go for it, do a write up and let us know. I wouldn't mind doing this as well. You can get a rigid hone that will remove some bore taper but I don't have an answer on a warped deck or how you'd know it.
Tappin
MS3-a(sore)ASS-rex (01-16-2012), trf5000 (01-16-2012)
 Old 01-16-2012, 11:08 AM   #14
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
Do that shit
And do a write up
Monotonous ONE is offline   Reply With Quote
The Following 4 Users Say Thank You to Monotonous ONE For This Useful Post:
EL F00LI0 (01-16-2012), MS3-a(sore)ASS-rex (01-16-2012), Snotrocket (06-10-2012), trf5000 (01-16-2012)
 Old 01-16-2012, 11:20 AM   #15
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Intersting idea.. I have heard of this being done, but not for performance applications. Not saying that it shouldn't be done for a perfromance application, as long as everything is fine with the head and deck....go for it.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 3 Users Say Thank You to SilverDemon For This Useful Post:
djuosnteisn (01-17-2012), dougefresh_ (01-17-2012), MS3-a(sore)ASS-rex (01-16-2012)
 Old 01-16-2012, 11:31 AM   #16
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I think @dougefresh needs to look at this idea. he doesn't have a hole in his block and he could easily see from below if the bores are okay. It may not be a weekend thing considering you'd have to pull the head, so you're talking timing verification, disconnecting a whole lotta shit, new head gasket, new head studs, etc. etc., but it's doable.
07 MS3
The original Genpoo Hater
The Following 5 Users Say Thank You to Chimmike For This Useful Post:
dougefresh_ (01-17-2012), karl-hungus (01-16-2012), MS3-a(sore)ASS-rex (01-16-2012), rfinkle2 (01-17-2012), TiGraySpeed6 (01-16-2012)
 Old 01-16-2012, 11:37 AM   #17
Domino81's Avatar
Posts: 5,081   (View Stats)
No machine work at all? Makes me a little nervous.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 01-16-2012, 11:39 AM   #18
Groans: 224
Why? Boring out a cylinder should never be considered necessary when assembling a forged engine.
NATOR PA
 Old 01-16-2012, 11:43 AM   #19
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
I believe you mean when rebuilding an undamaged engine.
Interesting...
The Following User Says Thank You to Alpha For This Useful Post:
 Old 01-16-2012, 11:50 AM   #20
Groans: 224
Interesting...
Yes. Unless the cylinder walls have been scored
Edit: unless increasing the displacement is a goal
NATOR PA
Alpha (01-16-2012), duappleganger (01-16-2012)
 Old 01-16-2012, 11:59 AM   #21
Domino81's Avatar
I just feel like there should be some prep work when a motor needs to accept new parts. Maybe I'm wrong? If I am, I'm fine with that.
 Old 01-16-2012, 12:04 PM   #22
BlueStreak's Avatar
Posts: 1,467   (View Stats)
I'd be worried about proper bearing clearances...
With my builds, the rod caps had to be shaved down slightly to reduce the size of the bearing bore so the engine wouldn't hemorrhage oil. This issue arose with Carillo rods and OEM bearings.
I believe @djuosnteisn has the same issue and fixed it with a coating on the bearings.
'07 CWP MS3
Forged.
The Following 8 Users Say Thank You to BlueStreak For This Useful Post:
06Speed6 (01-16-2012), Alpha (01-16-2012), djuosnteisn (01-17-2012), dougefresh_ (01-17-2012), kmac (01-16-2012), MS3-a(sore)ASS-rex (01-16-2012), rfinkle2 (01-17-2012), trf5000 (01-16-2012)
 Old 01-16-2012, 12:07 PM   #23
kmac's Avatar
Posts: 1,792   (View Stats)
I would want the rotating assembly balanced, but that's me. I wouldn't advise it. I'm not saying it won't work . I would just prefer it balanced.
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
The Following 3 Users Say Thank You to kmac For This Useful Post:
Alpha (01-16-2012), BlueStreak (01-16-2012), dougefresh_ (01-17-2012)
 Old 01-16-2012, 12:11 PM   #24
Groans: 224
This is the kind of info I made this thread for
NATOR PA
The Following 3 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
BlueStreak (01-16-2012), djuosnteisn (01-17-2012), kmac (01-16-2012)
 Old 01-16-2012, 12:24 PM   #25
trf5000's Avatar
Yea i think the bearings would be the biggest challenge. Would be a pain in the ass trying to set the clearences with everything still in the car wouldnt it?
2010 MS3 - Sold
 Old 01-16-2012, 12:32 PM   #26
Groans: 224
No, the bearings should already be manufactured to the correct clearance.
NATOR PA
Chimmike (01-16-2012)
 Old 01-16-2012, 01:03 PM   #27
Speeeeeed
06Speed6's Avatar
The crank should already be balanced, relatively speaking. Bearing clearances could be an issue because you wouldnt know if the crank is worn.
I havent tried this in a car engine, but on small engines I have unbolted the rod caps in the middle of the down stroke, rotated the crank to bdc, measured the bearing clearance, then rotated the crank back up to the rod and bolted it back in. Its not real hard to do and it would let you know if you need to coat the bearings or source some oversize bearings.
2006 Mazdaspeed 6
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
Chimmike (01-16-2012), djuosnteisn (01-17-2012), dougefresh_ (01-17-2012), MS3-a(sore)ASS-rex (01-16-2012)
 Old 01-16-2012, 01:14 PM   #28
they should but they are absolutely not guaranteed. Working with my buddy now on an 08 STI block. OE rod bearing clearances were within spec IIRC .0015-.0020...he threw in some ACL bearings on the Eagle H-beams and the clearance was .0007-.00010.
long story short that motor would have spun the bearings in .003 seconds when it was started. lol
don't know if the newer coating on the 08 STI crank made the clearance tight but it would have been ugly real fast.
he then ordered some under sized bearings from ACL. .001 under sized IIRC which should put him at .0017-.0020
this is all new to me but I think I have the correct amount of zeros in those numbers
This was all done with a bore gauge not plasti guage so no way to do that with the motor in the car....at least not on the mains.
 Old 01-16-2012, 02:37 PM   #29
Speeeeeed
06Speed6's Avatar
He isnt swapping mains, the rod bearings can be measured.
2006 Mazdaspeed 6
The Following 6 Users Say Thank You to 06Speed6 For This Useful Post:
Dano (01-16-2012), djuosnteisn (01-17-2012), dougefresh_ (01-17-2012), MS3-a(sore)ASS-rex (01-16-2012), rfinkle2 (01-17-2012), Tokay444 (01-16-2012)
 Old 01-16-2012, 02:45 PM   #30
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
JacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the world
Interested in this as well.
By the waty, is there a benefit to increasing displacement?
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M. Fifth/Sixth Port Injection -
- P.E.R.M.Tuning -
JacksonMS30 is offline   Reply With Quote
 Old 01-16-2012, 02:48 PM   #31
roger that
 Old 01-16-2012, 02:50 PM   #32
4G63's Avatar
Posts: 1,479   (View Stats)
4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world
Groans: 123
Groaned at 157 Times in 79 Posts
God damn Tom you got a lot of shit back on that car already! Can't wait to see this play out. All platforms need pioneers and I'm glad ur taking this head on should be good stuff. This is formerly AdrenalineRush btw.
2003 Evo VIII
BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever.
Old: 2009 White MS3. Fully bolted and tuned. Sold
4G63 is offline   Reply With Quote
The Following 3 Users Say Thank You to 4G63 For This Useful Post:
kmac (01-16-2012), MS3-a(sore)ASS-rex (01-16-2012), SLOWHATCH (01-16-2012)
 Old 01-16-2012, 02:55 PM   #33
may not be ideal but the crank/pully is fairly well balanced from Mazda...you can then balance your new rods and pistons which are very much less critical since they are not part of the rotating assembly.
I wouldn't rev this type of swap out to 8K by any means but the OE redline or 7K ish should be fine.
no?
 Old 01-16-2012, 03:00 PM   #34
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
Brian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the world
Subs
Brian MP5T is offline   Reply With Quote
 Old 01-16-2012, 03:33 PM   #35
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Just a note, Ill be tossing on my Zex kit with a 35hp nozzle at the end of the month on stock block/ 25PSI K04 and dont have too much concern. Are you intending to run more nitrous than that?
403whp/451ft/lb Dry Shot
The Following 2 Users Say Thank You to Bucker For This Useful Post:
Chriscote (01-17-2012), rfinkle2 (01-17-2012)
 Old 01-16-2012, 03:53 PM   #36
Groans: 224
No more would be run on the stock block/turbo for sure but down the road a monster hit would be nice for that unsuspecting corvette on the highway.
I'd be doing more so that I'd be able to spray at a lower rpm without fear of bending or ejecting a rod.
Also, connecting rods generally are balanced +/- 1 gram
Oh shit hey alex lol. Yea man I'm playing no games this time around
NATOR PA
Last edited by MS3-a(sore)ASS-rex; 01-16-2012 at 03:53 PM. Reason: MSF Database - Automerged Doublepost
4G63 (01-16-2012)
 Old 01-16-2012, 04:11 PM   #37
kmac's Avatar
no?
Anything that moves should be bal . Imbalances cause harmonic resonance and that's what destroys everything . You should even bal with a lightened clutch setup.
<3 Tokay.
The Following User Says Thank You to kmac For This Useful Post:
 Old 01-16-2012, 04:46 PM   #38
troubled81's Avatar
Posts: 126   (View Stats)
troubled81 has a reputation beyond reputetroubled81 has a reputation beyond reputetroubled81 has a reputation beyond reputetroubled81 has a reputation beyond reputetroubled81 has a reputation beyond reputetroubled81 has a reputation beyond reputetroubled81 has a reputation beyond reputetroubled81 has a reputation beyond reputetroubled81 has a reputation beyond reputetroubled81 has a reputation beyond reputetroubled81 has a reputation beyond repute
If you do this i suggest the CP pistons as i put them in my motor and they do not require you to bend the piston squirters. (i have read that the Wiseco pistons do) The do run a tight .0035 wall clearance so without over boring it they might be loud untill they warm up.
As for the rods i went with K1 with stock OEM bearings and so far everything is good. I checked the clearances of all of them (i forget now what each was) and they all were within spec.
troubled81 is offline   Reply With Quote
The Following 3 Users Say Thank You to troubled81 For This Useful Post:
06Speed6 (01-16-2012), dougefresh_ (01-17-2012), MS3-a(sore)ASS-rex (01-16-2012)
 Old 01-16-2012, 05:18 PM   #39
Yup. The eagles for the sti build, 3 were identical with one being one gram heavier
There is also balancing each end of the rod and we will be doing that and getting them to within .5 of a gram iirc. Getting the whole rotating ass balanced as well. Pully-crank-FW
This is also going to be a high compression setup, somewhere around 9.5 iirc
Should be fun.
For me, I like to put in some gen2 pistons if you can get them cheap, w k1 rods and call it a day.
For you and nitros I would replace the pistons fo sho.
Tappin
 Old 01-16-2012, 06:13 PM   #40
starscream's Avatar
Groans: 44
Heres a way you can check the deck of the block yourself at home
The Following 6 Users Say Thank You to starscream For This Useful Post:
daztdMS6 (01-17-2012), dougefresh_ (01-17-2012), manselainen (02-10-2012), MS3-a(sore)ASS-rex (01-16-2012), p057 (01-16-2012), Tabasco69 (09-21-2012)
Getting forged internals, but what? Speedie6 MazdaSpeed 6 - Engine, Transmission & Driveline 55 05-17-2010 03:46 PM
Forged internals + GT3076r johnac08 MazdaSpeed 3/6 - Turbo Induction 24 10-19-2009 12:06 AM
should i go forged internals? boostednut MazdaSpeed 3 - Engine, Transmission & Driveline 14 04-01-2009 09:52 AM
Powder forged rods versus drop forged. Lex MazdaSpeed 3 - Engine, Transmission & Driveline 1 01-24-2009 06:27 AM
Forged Internals for All!!! In Stock!!! CaptainKRM Mazdaspeed3/6 General Discussion 43 10-10-2008 06:08 PM
Page generated in 0.61663 seconds with 38 queries
