Like Tree22Likes
 Old 06-07-2012, 06:44 AM   #121
atvfreek's Avatar
Posts: 7,787   (View Stats)
Originally Posted by Tomas View Post
All aftermarket rods will work with the stock pistons as long as the small end bush accepts 22.50mm wrist pins.
The problem is with aftermarket pistons. Some of them hit the oil jets.
I am about 99% sure on this.
I have been looking into this drop in forged internals myself. Wish the god damn timing chain rail on the intake side of the engine would be like the exhaust side which is just sitting on a pin instead of bolted to the head. If the timing cover had a plug that you could remove to get at that bolt that would work too.
That way you would not have to remove the timing cover to take the head of. That would make this job sooo much easier.
Agreed, that would make it a ton easier. And that bolt for the chain guide is also a good point to make. I have seen people forget to take that out and pull up on the head. oops broken chain guide lol
The timing cover really isn't that bad to do. On the gen2's it's even easier. No Power steering pump! We had the Head off Doug's car in a couple hours. Started at 9 and had it off at 11:30.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 6 Users Say Thank You to atvfreek For This Useful Post:
86AmishMs3 (06-07-2012), dougefresh_ (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012), TiGraySpeed6 (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 06:44 AM   #122
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Tomas, you'd still have to take the timing cover to take the head off, iirc the cover is bolted to the head itself.
If you're gonna do the internals swap, it's a good time to swap chain and tensioner too...to be on teh safe side. That's my intent.
Now, @Tomas What aftermarket pistons hit the oil squirters?
And do we have any idea how strong the stock pistons are, genjuan or genpoo? I saw the ginormous ring land and my thought is it'd be pretty hard to put a crack in that sucker.....think they'd be strong enough for 500-550whp?
If people figure they're strong enough for 550whp, I might as well keep my stock pistons and just get some k1's or eagles!
07 MS3
The original Genpoo Hater
The Following 4 Users Say Thank You to Chimmike For This Useful Post:
86AmishMs3 (06-07-2012), atvfreek (06-07-2012), StayBroke (06-07-2012), TiGraySpeed6 (06-07-2012)
 Old 06-07-2012, 06:51 AM   #123
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
I know for a fact Wiseco pistons hit the squirters but I can't recall any others that do.
NATOR PA
The Following 3 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
86AmishMs3 (06-07-2012), Chimmike (06-07-2012), StayBroke (06-07-2012)
 Old 06-07-2012, 06:56 AM   #124
atvfreek's Avatar
I'd like to stick with my stock gen2 pistons. That's $500 in my pocket. Haha. And I think they are plenty strong enough for 500hp. The only issue I think we have seen was bluestreak cracked a ring land, but there haven't been any other known cases
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
86AmishMs3 (06-07-2012), BlueStreak (06-07-2012), charlesfist (06-07-2012), StayBroke (06-07-2012)
 Old 06-07-2012, 07:01 AM   #125
Will fuck up ur day
Chimmike's Avatar
Groans: 433
bluestreak cracked a ring land?
hmm.
I'd like to stick with my genjuan pistons. I'd think they're just as strong as the poo but obviously different flame pattern design.
07 MS3
 Old 06-07-2012, 07:29 AM   #126
atvfreek's Avatar
hmm.
Ya IIRC it was cylinder #3. He was having an intermittent misfire, then it was slightly low on compression, which is why he went forged.
EDIT: It was #3. Here is the link. http://www.mazdaspeedforums.org/foru...ml#post1043619
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
86AmishMs3 (06-07-2012), BlueStreak (06-07-2012), charlesfist (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012)
 Old 06-07-2012, 07:37 AM   #127
Will fuck up ur day
Chimmike's Avatar
Groans: 433
hmmm. That may dash some of my hopes.
07 MS3
 Old 06-07-2012, 08:32 AM   #128
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Yep. Cyl 3 took a crap on me during time attack.
I was out on the track for 30 mins at a time in 35*C (95*F) weather. That day did my motor in.
I imagine the pistons could put up with DD and 1/4mile abuse longer than tracking but that's just an educated guess based off me leaning back in my chair and staring at ceiling tiles.
EDIT: This was on my GT3071 at 20PSI and 12* timing up top. Kept things "safe" so I wouldn't pooch the motor.... Ha.
atvfreek likes this.
'07 CWP MS3
Forged.
The Following 6 Users Say Thank You to BlueStreak For This Useful Post:
86AmishMs3 (06-07-2012), atvfreek (06-07-2012), charlesfist (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), SilverDemon (06-07-2012), StayBroke (06-07-2012)
 Old 06-07-2012, 08:44 AM   #129
Groans: 224
Need money and timing tools! AAHHHHH!!!
NATOR PA
86AmishMs3 (06-07-2012), atvfreek (06-07-2012), BlueStreak (06-07-2012)
 Old 06-07-2012, 08:48 AM   #130
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
I just want to do rods. We have not seen a lot of piston failures just rods.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
 Old 06-07-2012, 08:51 AM   #131
Groans: 224
I agree but my thought process is this. If you're swapping the rods so that you can hand your car an epic beating whenever you'd like, why would you want your pistons to be your new potential weak point?
I'm not saying that it would ever even become an issue but for the peace of mind an extra $500 is well worth it.
NATOR PA
The Following 9 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
86AmishMs3 (06-07-2012), anavrinIV (06-07-2012), atvfreek (06-07-2012), BlueStreak (06-07-2012), charlesfist (06-07-2012), Dano (06-07-2012), fishin53 (06-07-2012), silvapain (06-07-2012), StayBroke (06-07-2012)
 Old 06-07-2012, 08:54 AM   #132
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
The bolts on the side of the head protrude through the timing chain cover so if you take them of the only thing holding the head down is that bolt on the chain guide. Well, and obviously the head bolts.
You are are right about replacing the chain and may be the VVT too. It's just that if you could do rods in one week end and chain and VVT in another it would be much less stressful than trying to do all this shit in a week end working solo. That's what I usually have to do. I can only have the car down for the week ends as I need to ride to work.
Correct. I can also confirm Wiseco's hit the oil jets. You can assume from this the CPe pistons do the same. Not sure about JP or Arias.
atvfreek (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012)
 Old 06-07-2012, 08:55 AM   #133
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Make sure you label all the bolts, etc. I had taken off some stuff before I even had it towed to save time, and had all my shit labelled in separate bags. Wouldn't you know it but the only missing shit (later found, but time wasted) was not in labelled bags, lol.
The Following 4 Users Say Thank You to dougefresh_ For This Useful Post:
MS3-a(sore)ASS-rex (06-07-2012), SilverDemon (06-07-2012), StayBroke (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 08:56 AM   #134
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Crap. Don't want to have to modify the jets/squirters.
and yeah I know what you mean, I'd be working solo too.
07 MS3
The Following 2 Users Say Thank You to Chimmike For This Useful Post:
 Old 06-07-2012, 08:57 AM   #135
4G63's Avatar
Posts: 1,479   (View Stats)
4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world
Groans: 123
Groaned at 157 Times in 79 Posts
Originally Posted by trf5000 View Post
No stock block with nitrous?
I'd rather be safe than sorry. If I can get away with swapping my internals over a weekend I've got no problem doing it. Car needs to be drivable.
May do a small hit in the neighborhood of 20-25hp on stock block above 3500 rpm but it makes me uneasy haha.
SIG:
358WHP & 381WTQ (93 OCTANE PUMP GAS K04 W/N2O!!)
LMFAO!! So much for that 5 months ago
MS3-a(sore)ASS-rex likes this.
2003 Evo VIII
BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever.
Old: 2009 White MS3. Fully bolted and tuned. Sold
4G63 is offline   Reply With Quote
The Following User Says Thank You to 4G63 For This Useful Post:
 Old 06-07-2012, 09:00 AM   #136
86AmishMs3's Avatar
Groans: 338
Modifying the squirters would be a breeze. If the skirt is hitting them or whatever is, just bend or dremel it a quarter of an inch shorter.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
BlueStreak (06-07-2012), StayBroke (06-07-2012)
 Old 06-07-2012, 09:02 AM   #137
BlueStreak's Avatar
I bent mine a little further to the center and rotated the entire assembly to make sure there wasn't any contact. I haven't taken the oil pan off to inspect but I'm assuming everything is still fine. I'm sure I would've had wristpin (grinding noises) issues by now if the squirters got damaged or weren't effective in their new position.
'07 CWP MS3
Forged.
The Following 9 Users Say Thank You to BlueStreak For This Useful Post:
atvfreek (06-07-2012), charlesfist (06-07-2012), Chimmike (06-07-2012), Dano (06-07-2012), dougefresh_ (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), SilverDemon (06-07-2012), StayBroke (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 09:11 AM   #138
Bob Ross Fanclub
Tomas's Avatar
You got to watch out with that assumption. Your wrist pins are still being lubricated by the oil being thrown through the crank journals and rods. Oil jets are not really needed in most engines. They are a nice performance upgrade Mazda made on these engines. I think that's also one of the reasons the OEM pistons hold up so well. Not because of good material but because they are being cooled by the oil from the jets. If one of the jets is bent, you would most likely not notice anything while driving around. Road racing on the other hand might all off a sudden cause one of the pistons to crap on itself. Melt, crack a ring land, etc.
The Following 7 Users Say Thank You to Tomas For This Useful Post:
atvfreek (06-07-2012), BlueStreak (06-07-2012), charlesfist (06-07-2012), dougefresh_ (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012), uncorked11 (06-08-2012)
 Old 06-07-2012, 09:12 AM   #139
theschrum's Avatar
Posts: 1,031   (View Stats)
theschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the world
Groans: 29
Groaned at 7 Times in 6 Posts
There are some pics of my build on this thread. http://www.mazdaspeedforums.org/foru...eekend-110042/
Block stayed in the car and I used a Flex-Hone tool to hone it myself. Just nuts and bolts, not hard at all. I worked alone and probably could have finished in 2 days if I needed to finish that fast.
My Wiseco pistons cleared the squirters, but apparently that's not the case for others. You should be able to bend them from up top though.
Good luck
06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block...
08 Speed 3|SOLD
theschrum is offline   Reply With Quote
The Following 10 Users Say Thank You to theschrum For This Useful Post:
atvfreek (06-07-2012), Cdnspeed6 (03-19-2016), charlesfist (06-07-2012), Chimmike (06-07-2012), dougefresh_ (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012), TiGraySpeed6 (06-07-2012), Tomas (06-07-2012), uncorked11 (06-08-2012)
 Old 06-07-2012, 09:29 AM   #140
Groans: 224
Originally Posted by 4G63 View Post
SIG:
FFFFUUUUUUUU
I'm going back on the rollers soon to smash 400whp in the mouth
dougefresh_ likes this.
NATOR PA
The Following 4 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
86AmishMs3 (06-07-2012), dougefresh_ (06-07-2012), fishin53 (06-07-2012), SilverDemon (06-07-2012)
 Old 06-07-2012, 09:31 AM   #141
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Good luck
I've heard from various sources that honing isn't really necessary on modern, close-tolerance motors.
As for the install....your cams look like they were at an odd angle with the timing tool in there. I think before I pop out the cams to remove the head I'll probably rotate to Cyl1 TDC and take a pic of the cam position with cam plate on just for reference when putting the chain back on, heh.
07 MS3
atvfreek (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012), theschrum (06-07-2012)
 Old 06-07-2012, 09:42 AM   #142
theschrum's Avatar
Groans: 29
Yeah, I had to correct the timing. I ended up shaving down a 21mm wrench to fit between the timing cover and VVT cam bolt, broke them lose then tq'd in the correct spot.
08 Speed 3|SOLD
The Following User Says Thank You to theschrum For This Useful Post:
 Old 06-07-2012, 09:42 AM   #143
Bob Ross Fanclub
Tomas's Avatar
The cam plate will not fit inside the slits on the cams unless they are positioned correctly. The slits on the cam ends do NOT run through the middle of the camshaft. They are off center.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
86AmishMs3 (06-07-2012), atvfreek (06-07-2012), dougefresh_ (06-07-2012), TiGraySpeed6 (06-07-2012)
 Old 06-07-2012, 09:53 AM   #144
Bob Ross Fanclub
Tomas's Avatar
Good luck
Are the wiseco pistons machined to go into the OEM bore size? I thought the bores had to be honed to a larger bore diameter for more piston to bore clearance. Does not look from your thread that you did any meassuring. And since it seems you haven't check your thread lately I am posting that question here.
How about piston slap during start up? Is there much noise?
Does the engine smoke more / have lower compression than stock?
I have genpoo pistons ready to go for my week end "insitu" build but I'd concider doing forged pistons with updated Gen2 piston crowns if I don't have to precision hone the cylinder liners. Just de-glaze them.
 Old 06-07-2012, 09:59 AM   #145
theschrum's Avatar
Groans: 29
Sock bore, stock compression, I get absolutely no piston slap at start up. The engine runs just as it did stock. I expected it to be a little noisy, but you honestly would never be able to tell that it was built unless you dropped the oil pan.
Tomas, 86AmishMs3 and TiGraySpeed6 like this.
08 Speed 3|SOLD
The Following 3 Users Say Thank You to theschrum For This Useful Post:
86AmishMs3 (06-07-2012), atvfreek (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 10:07 AM   #146
86AmishMs3's Avatar
Groans: 338
^^^ and 5 over
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 06-07-2012, 10:30 AM   #147
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I think you're thinking deglaze anyways tomas. Hone is typically done so that the rings can seat against a "fresh" surface (deglaze?). Any more aggressive than that and I'd call it a cylinder bore hone.
So what I'm looking at doing is ball hone, I guess. Flex-Hone®, Cross Hole Deburring, Ball Hones
07 MS3
Tomas (06-07-2012)
 Old 06-07-2012, 10:33 AM   #148
Death-From-A-Mile's Avatar
Posts: 1,371   (View Stats)
Death-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the world
Groans: 87
@MS3-a(sore)ASS-rex going to be dropping mine in over the next few days. No major rush for me. Could be back together in a day......who knows maybe I will just finish it up once I start. But I like taking my time!
Death-From-A-Mile is offline   Reply With Quote
The Following 2 Users Say Thank You to Death-From-A-Mile For This Useful Post:
86AmishMs3 (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012)
 Old 06-07-2012, 10:41 AM   #149
Bob Ross Fanclub
Tomas's Avatar
That's exactly what I got.
3 1/2" (89mm) 240 grit.
What grid did you use on the hone?
How many runs did you do on each cylinder?
 Old 06-07-2012, 11:14 AM   #150
theschrum's Avatar
Groans: 29
I don't fully remember. I went on Flex-Hone's website and followed the demonstration. Something like 10 sec with a few slow passes, then 5 sec with a few fast passes. Just be carefull need the squirters because it could catch. The rings do not reach the very bottom of the sleeve anyway.
08 Speed 3|SOLD
The Following 2 Users Say Thank You to theschrum For This Useful Post:
 Old 06-07-2012, 11:20 AM   #151
Groans: 224
With a ball hone I do three passes up and down in quick succession to get myself a nice crosshatch (which is the goal of honing). Odds are that when you pull the pistons you'll still have a nice crosshatch from your factory hone unless your car has epic high mileage.
Your goal is a 45* crosshatch. Make sure when you use the hone to also use a lubricant like liquid wrench to ensure no scoring of the cylinder
NATOR PA
theschrum (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 11:29 AM   #152
atvfreek's Avatar
We ended up using motor oil to lube the hone and walls. We also didn't go all the way down, so we wouldn't risk hitting the crank.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
MS3-a(sore)ASS-rex (06-07-2012), theschrum (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 11:32 AM   #153
theschrum's Avatar
Groans: 29
I think flex hones instructions said to do some 20* passes then a few 45* passes, so this sounds right to me. The first passes are probably to help deglaze I assume. I used P'BLaster as honing lube. It seemed to work well.
08 Speed 3|SOLD
The Following 4 Users Say Thank You to theschrum For This Useful Post:
atvfreek (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 11:46 AM   #154
Groans: 224
Same difference, the oil will prevent scoring and carry away particles as well. Going to the bottom of the cylinder isn't a big deal either since the piston doesn't travel all the way to the bottom of the cylinder.
You're correct. I prefer a ball hone to a flex hone as a personal preference
NATOR PA
Last edited by MS3-a(sore)ASS-rex; 06-07-2012 at 11:46 AM. Reason: MSF Database - Automerged Doublepost
atvfreek (06-07-2012), StayBroke (06-07-2012), theschrum (06-07-2012)
 Old 06-07-2012, 11:48 AM   #155
theschrum's Avatar
Groans: 29
IIRC, Flex hone says to use a water based oil and not to use motor oil on one of their 'how to' videos (or it may have been something I read). I don't see how motor oil could hurt though.
IDK, I'm just a noob at this kind of stuff though.
08 Speed 3|SOLD
atvfreek (06-07-2012), StayBroke (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 12:33 PM   #156
Bob Ross Fanclub
Tomas's Avatar
S
Huh? I thought they're the same thing?
You mean flex hone as opposed to regular 3 leg stone hone?
The flex hone uses lil balls. Like the ones sitting below my penis.
And if there is still a nice cross hatch on the cylinder walls, why not just deglaze by using an abrasive nylon filament wire brush? Why hone at all?
Edit:
I just got of the phone with Wiseco. I asked whether the pistons they sell for the MZR DISI would require additional honing of the cylinder walls from a brand new stock block to accomodate the required cylinder to wall clearance and they said yes. I.e. the pistons are not made with a tolerance for a new block. Wiseco assumes if one were to install their pistons that it would be on an engine that will have the cylinders honed out a little larger.
They said stock clearance is 0.003" and their pistons require 0.003 1/2 to 4. Not much actually but it might matter.
The forgings are 2618 and expand quite a bit unlike the 4032 alloys. Not trying to crap on theschrum's party but I'd be worried when shit gets really hot that a piston might seize.
So for me I am sticking to my gen2 pistons.
atvfreek (06-07-2012), BigjohnB20 (06-07-2012), theschrum (06-07-2012)
 Old 06-07-2012, 01:08 PM   #157
Groans: 224
Edit:
They said stock clearance is 0.003" and their pistons require 0.003 1/2 to 4. Not much actually but may it be matters.
The forgings are 2618 and expand quite a bit unlike the 4032 alloys. Not trying to crap on thescrum's party but I'd be worried when shit gets really hot that a piston might seize.
I was referring to a flex hone as the 3 leg stone hone. I've only ever referred to a ball hone as a ball hone, never a flex hone. Fault is mine.
I still hone the cylinder regardless of the condition of the factory crosshatch simply as part of a process I do.
Edit to your edit: awesome info that you found for the Wiseco pistons. Honestly I dontthink clearances would become an issue on an engine with some mileage on it as opposed to a brand new block that hasn't had any piston rings seated to the cylinder walls.
A bit of wear would probably be all the cylinders need to be "safe" to run the Wisecos. Perhaps that was their theory when they made them? Idk.
NATOR PA
The Following 5 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
atvfreek (06-07-2012), Dano (06-07-2012), StayBroke (06-07-2012), theschrum (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 01:16 PM   #158
Bob Ross Fanclub
Tomas's Avatar
Fuck. Now I am really torn between using some aftermarket pistons and the gen2s.
My engine has perfect compression. I was just going to change the pistons as part of changing rods to K1. Now I have to lay sleepless at night again trying to decide what pistons to use. lol
I actually did ask how much he thought one would have to hone to get the higher clearance and he said "quite a bit". Does not look like it going by the tolerance he gave of 1 thousand of an inch more, but I have no idea how much one would have to hone to get there.
 Old 06-07-2012, 01:19 PM   #159
Will fuck up ur day
Chimmike's Avatar
Groans: 433
What about the arias pistons?
And yeah. When I do mine, I'll have 80k+ miles on the block....should be plenty of wear to just to a ball hone and throw the pistons in.
07 MS3
 Old 06-07-2012, 01:32 PM   #160
atvfreek's Avatar
.0005" is not much material, and I bet hitting with the hone alone would shave about that off, which would get it right within wiseco's spec of .0035"-.004"
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
Dano (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012), Tomas (06-07-2012)
Getting forged internals, but what? Speedie6 MazdaSpeed 6 - Engine, Transmission & Driveline 55 05-17-2010 03:46 PM
Forged internals + GT3076r johnac08 MazdaSpeed 3/6 - Turbo Induction 24 10-19-2009 12:06 AM
should i go forged internals? boostednut MazdaSpeed 3 - Engine, Transmission & Driveline 14 04-01-2009 09:52 AM
Powder forged rods versus drop forged. Lex MazdaSpeed 3 - Engine, Transmission & Driveline 1 01-24-2009 06:27 AM
Forged Internals for All!!! In Stock!!! CaptainKRM Mazdaspeed3/6 General Discussion 43 10-10-2008 06:08 PM
Page generated in 0.65794 seconds with 29 queries
