Like Tree22Likes
 Old 06-07-2012, 01:33 PM   #161
Posts: 9,484   (View Stats)
Originally Posted by Tomas View Post
Fuck. Now I am really torn between using some aftermarket pistons and the gen2s.
My engine has perfect compression. I was just going to change the pistons as part of changing rods to K1. Now I have to lay sleepless at night again trying to decide what pistons to use. lol
I actually did ask how much he thought one would have to hone to get the higher clearance and he said "quite a bit". Does not look like it going by the tolerance he gave of 1 thousand of an inch more, but I have no idea how much one would have to hone to get there.
just recently worked with a friend on his scoobie block...and we used some sort of badass adjustable fixed width 3 stone hone...very nice piece...started out with 100 grit and with 180 grit and tranny fluid as lube and you can cut a thou off in a split second. Well not a split second but only a few minutes. We honed a block with only 15K on it w deck plate and the out of roundness was the biggest issue. [due to the deck plate of course] so we had to go out 2 sizes over "drop in" pistons.
IMO if you are "on the fence" stay with OE pistons or hone out for the "drop ins"
Tomas, I assume you have a good bore gauge? measuring .0005 aint easy...lol
edit: hone
http://www.enginehones.com/lisle15000.html
atvfreek (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 01:37 PM   #162
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
CP Pistons FTW? Lol...
NATOR PA
 Old 06-07-2012, 01:40 PM   #163
theschrum's Avatar
Posts: 1,031   (View Stats)
theschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the world
Groans: 29
Groaned at 7 Times in 6 Posts
Good to know @Tomas. Nice find.
Yeah, I am not worried about that 0.0005-0.001 clearance differences. I am sure a light honing alone would take care of that (plus the wear from the last 89k). Most of my piston ring gaps were within spec without filing. I think I only needed to file 2 of the top rings by .001 and 2 of the 2nd rings about .001.
The pistons slid down smooth and fit perfectly.
06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block...
08 Speed 3|SOLD
theschrum is offline   Reply With Quote
The Following 4 Users Say Thank You to theschrum For This Useful Post:
 Old 06-07-2012, 01:43 PM   #164
Yeah, I am not worried about that 0.0005-0.001 clearance differences. I am sure a light honing alone would take care of that. Most of my piston ring gaps were within spec without filing. I think I only needed to file 2 of the top rings by .001 and 2 of the 2nd rings about .001.
not to split hairs here but the ring gap is no indication of if the PWC is enough...its the piston to wall clearance
I am sure you'll be fine.
atvfreek (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 01:50 PM   #165
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
edit: hone
Micrometer Head Adjusting Cylinder Hone 3" - 4.250" (expandable 2.75" to 10") - Lisle 15000
Lol. Fuck meassuring, This is a week end build. It's old pistons out, hone some, new pistons in see if the shit will run OK. I am not planning on wiggling a bore gauge in each cylinder to check clearance or out of roundness. I know myself. If I do that and I detect the slightest defect I'd stop everything to try to fix it and then I'd probably fuck it up. lol
I like theschrum's way.
Hone some, drop that shit in and go.
By the way. Out of roundness, or oval cylinder bores, is typical of boxer engines. Used to be a big thin on BMW bikes. The pistons lay on their sides on every start up and don't have the lubrication they need so shit gets all wobbly on those sngines. Straight cylinder blocks don't have that problem. At least not very often.
Dano likes this.
The Following 11 Users Say Thank You to Tomas For This Useful Post:
802MS3 (06-07-2012), 86AmishMs3 (06-07-2012), atvfreek (06-07-2012), Chimmike (06-07-2012), Dano (06-07-2012), dougefresh_ (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012), tddvrrn (06-08-2012), theschrum (06-07-2012), TiGraySpeed6 (06-07-2012)
 Old 06-07-2012, 01:58 PM   #166
hahahahah
what you describe is EXACTLY what happened to us and why we went out 2 sizes over
still laughing...started out with Manley skirt coated "drop-ins" requiring .0005 over OE, and within and hour knew those were out after working on 2 cyls..lol went another size out and was close enough really...but by buddy is OCD for sure and wouldn't let it go...so we ended up at max over size which on a high boost race car would crack the top of the cylinder bore...lol
hes just DD the car so it would have been fine....I think he sold the block to a guy that was going to sleeve it and is going to get brand new case halves and really only hone them this time
damn what a story...story of fail hahaha
edit: oh and good to know about the roundness of the boxers...IIRC it was not really ovalized like you describe but all over the place...more likely caused by us using the torque plate and OEM not. no?
Tomas likes this.
dougefresh_ (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 02:08 PM   #167
Bob Ross Fanclub
Tomas's Avatar
Yeah. That's another one. Fuck torque plates! lol
Dano (06-07-2012), StayBroke (06-07-2012), theschrum (06-07-2012)
 Old 06-07-2012, 02:40 PM   #168
StayBroke's Avatar
Posts: 2,075   (View Stats)
@Tomas, so have you made your mind up on what pistons you will be using.
I am wondering if i keep my stock pistons and only do rods, will it be ok for about 470-500whp?
 Old 06-07-2012, 02:44 PM   #169
Bob Ross Fanclub
Tomas's Avatar
Fuck dude. That's a hard question to answer.
I would say go forged if you want 500 hp. That's a lot.
And no. I haven't made up my mind. And probably won't for a while. I am as indecisive as a teenage girl about to loose her virginity.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
Dano (06-07-2012), Don06speed6 (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-07-2012)
 Old 06-07-2012, 02:50 PM   #170
StayBroke's Avatar
Reason i said they high was just incase i ever did go that high...lol
yea but i was really going to do this like next month if i could just do rods and get away with it lol.
 Old 06-07-2012, 02:50 PM   #171
Groans: 224
Wait wait so you won't be measuring ring end gap, or rod bearing clearance or anything? Just throwing shit in there and saying "eh, fuck it"? Jesus you've got balls the size of asteroids dude. Lol
NATOR PA
The Following 3 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
BlueStreak (06-07-2012), Dano (06-07-2012), SLOWHATCH (06-07-2012)
 Old 06-07-2012, 02:54 PM   #172
... I am as indecisive as a teenage girl about to loose her virginity.
lol
thanks for the new sig quote...lol
lol yes he does...hell if a rod or main is too tight that's the end of the motor in about .0001 seconds. at leas use some shitty plastiguage
have you priced a crank lately?
edit: IIRC dustin's OE sized rod bearings were .0022 too small for OE spec so he had them coated...if he didn't measure them he would have been lose but either side of good is no good.
Last edited by Dano; 06-07-2012 at 03:03 PM. Reason: MSF Database - Automerged Doublepost
BlueStreak (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012)
 Old 06-07-2012, 03:08 PM   #173
Bob Ross Fanclub
Tomas's Avatar
That's right. I am gonna 1/2 way tighten the rods on the crank upside down and wiggle them. If it feels ok I'll leave it like that. And fuck plastigauge and ring end gap. If the piston slides in without having to pound it with a mallet its good to go. Lol.
But I'll do it in spite of my lil balls. Not because of them.
MS3-a(sore)ASS-rex (06-07-2012), SLOWHATCH (06-07-2012), tddvrrn (06-08-2012)
 Old 06-07-2012, 03:11 PM   #174
Groans: 224
You sir, terrify me.
TiGraySpeed6 likes this.
NATOR PA
The Following 4 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
BlueStreak (06-07-2012), Dano (06-07-2012), tddvrrn (06-08-2012), Tomas (06-07-2012)
 Old 06-07-2012, 03:14 PM   #175
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Rings butting up against each other is the prevailing thought as to why cyl 3 crapped out in my motor.
There were no signs of detonation there or in any other cyl.
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
Dano (06-07-2012), Tomas (06-07-2012)
 Old 06-07-2012, 03:34 PM   #176
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
I know there is time and money involved in pulling the engine and doing a proper build. I also know that tolerance precision and balancing effectiveness improve with each new generation of machine shop equipment.
I'm old school. I grew up in a family owned engine rebuilding plant and custom (racing applications) automotive machine shop and learned to operate every mill, boring bar, crank grinder and other piece of equipment before I even graduated from highschool.
Doing racing application work for speed shops and race car owners (sometimes to their specs) I learned just how much power can be gained and how much stronger an engine can be made by attention to detail and by true blueprinting techniques. I'm talking about machining those rods. I don't care how expensive. That means making sure that the distance between big eye and little eye are EXACT, rod to rod and that weight is too.
It means sometimes actually boring the block all the way into the water jackets and putting in sleeves so that you can make every damn hole exactly like the other one and each and every one square. It means boring with a torque plate. It means putting that finishing cross hatch micro finish on just right.
It means line boring the block. It means indexing the crank so that every damn journal is exactly the same number of degrees apart from the others and that every journal stroke is exactly the same.
It means setting piston to cylinder wall clearances all the same but on the "loose" side of the tolerance. Same with rod and main bearing journals. And, yes, we grind the crank with a dial indicator that reads in "tenths", down to .0001.
It means milling the deck of the block and the head with absolute attention to squareness and getting every combustion chamber cc as identical as possible.
It means three valve angle cylinder head work and getting valve spring pressures exactly the same with shims. This excludes any separate porting of heads or manifolds. We're talking basic blueprinting.
It means meticulous balancing of everything that moves.
It means a lot of tiny details.
My long ass post is to illustrate that (1) you can pick up huge amounts of "free" horsepower and a huge increase in safe rpm headroom by doing this, even with stock internals and (2) the life of the engine is greatly increased.
Now, you don't have to do all of this shit, and doing all of it is going to be big bucks. But if you want to make power safely, you ought to be doing at least some of the more basic things.
Just honing/deglazing the block and putting in new internals might get you by for a while, but you are still going to have an engine that for all practical purposes started out with sloppy factory tolerances and has a lot of wear and abuse on it.
This is not likely to work out very well on a high output forced induction engine being pushed to its limit with an aggressive tune.
Doing just the basic machine work without focusing on true blueprinting is still far superior to the suggested "shade tree mechanic" approach. Sorry for being so rough. At least consider pulling the engine and have someone or yourself go through it and do the basic machine work before putting it back to gether and in the car.
I know, I have a bias because I have access to all this shit, but damn it, don't skimp on an engine this fucking expensive.
The Following 5 Users Say Thank You to MSMS3 For This Useful Post:
atvfreek (06-07-2012), BlueStreak (06-07-2012), SLOWHATCH (06-07-2012), smoogs12 (06-08-2012), tddvrrn (06-08-2012)
 Old 06-07-2012, 03:49 PM   #177
Ingle's Avatar
Posts: 421   (View Stats)
Ingle is the leader of the worldIngle is the leader of the worldIngle is the leader of the worldIngle is the leader of the worldIngle is the leader of the worldIngle is the leader of the worldIngle is the leader of the worldIngle is the leader of the worldIngle is the leader of the worldIngle is the leader of the worldIngle is the leader of the world
..I guess I know what I'm looking at next with 117k on the clock..
Ingle is offline   Reply With Quote
 Old 06-07-2012, 03:50 PM   #178
What the hell just happened in here?
Lol.
Tappin
 Old 06-07-2012, 03:58 PM   #179
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
He can build an engine, but he still uses hypertech to tune......
back to topic......
07 MS3
The original Genpoo Hater
The Following 6 Users Say Thank You to Chimmike For This Useful Post:
86AmishMs3 (06-07-2012), Cdnspeed6 (03-19-2016), Dano (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), SLOWHATCH (06-07-2012), StayBroke (06-08-2012)
 Old 06-07-2012, 04:02 PM   #180
back to topic......
well that's why you would need a BnB engine...to stay together with an HT tune...
lol
i keed...but the thread title is "drop in forged internals" not balanced and blueprinting 101.
we know its a cheap easy way to go and for most instances it would be just fine for a DD car...not a race car.
chuckms6 (06-08-2012), MS3-a(sore)ASS-rex (06-07-2012), SLOWHATCH (06-07-2012), StayBroke (06-08-2012)
 Old 06-07-2012, 04:13 PM   #181
Will fuck up ur day
Chimmike's Avatar
Groans: 433
lol
I agree....and if you make sure clearances are good on bearings, these aren't 50 year old iron v8's with ultra-loose tolerances from the factory that could gain tons of power from a good B&B........these motors are tight from factory, close tolerances with mostly precision machining. Cover our butts with good clearance on the rod bearings and make sure the bore is clean, with or without a new deglazing via ball hone, should be fine. And what, so you burn a quart of oil every 3k miles, no big deal. My s2k used to burn a quart in a day of autocrossing, and that was NORMAL! lol
07 MS3
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
86AmishMs3 (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-08-2012)
 Old 06-07-2012, 04:21 PM   #182
MSMS3's Avatar
Groans: 157
back to topic......
Yes. Those are not inconsistent. If I actually thought I could make more reliable and usable power with a different tuning option with my mods on stock turbo and pump gas, and if I had the time and patience, I might look at something else. It meets my needs on a daily driver.
Agree on one thing: back to topic.
 Old 06-07-2012, 04:27 PM   #183
MSMS3's Avatar
Groans: 157
You guys might be surprised at how sloppy some of the tolerances are today (and yes on Mazdas) according to our shop foreman. Much better, but you'd be surprised what gets out past inspection. And put a lot of miles on it and it's not much better than one of those right off the assembly line V8's of the past.
I'm not advocating full blueprinting for this situation. I am a big advocate of basic machine work along with the internals upgrade.
BTW: Most machine shops today will not guarantee their machine work under these circumstances unless there is proof of (1) a new oil pump and pick up screen assembly if so equipped, (2) new timing chain and tensioner because of the likely wear on those components.
Patchwork solutions have a very high fail rate. When done to save $$$, it is understandable, but the fail rate is high.
 Old 06-07-2012, 04:40 PM   #184
atvfreek's Avatar
Posts: 7,787   (View Stats)
The fail rate is also very high on old school v8 machinists that think they can build an mzr.
The bearing spec for rod bearing to crank clearance is .001-.002 that is pretty tight. That is only a .001 tolerance.
Lots if high hp guys running on stock block, and so far the main weakness is the rods. Replace those, pay attention to as much detail as possible, and viola, you have a solid motor.
Freekn tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 8 Users Say Thank You to atvfreek For This Useful Post:
802MS3 (06-07-2012), 86AmishMs3 (06-07-2012), altaprecision (03-24-2015), Dano (06-07-2012), dougefresh_ (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), SLOWHATCH (06-07-2012), StayBroke (06-08-2012)
 Old 06-07-2012, 04:59 PM   #185
Groans: 224
Seeing as how I've done this nearly a dozen times now on cars ranging from ~400whp all the way to 800+, that the above statement is incorrect.
I appreciate your perspective and input but I made this thread out of personal experience, not just hearsay and guesswork.
NATOR PA
The Following 8 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
86AmishMs3 (06-07-2012), atvfreek (06-07-2012), BlueStreak (06-07-2012), Dano (06-07-2012), Don06speed6 (06-07-2012), dougefresh_ (06-07-2012), SLOWHATCH (06-07-2012), StayBroke (06-08-2012)
 Old 06-07-2012, 06:11 PM   #186
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 62
Dammit I <3 you, can't wait to figure out what you guys are gonna do so you can rebuild mine.
MS3-a(sore)ASS-rex likes this.
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
The Following 3 Users Say Thank You to Don06speed6 For This Useful Post:
atvfreek (06-07-2012), MS3-a(sore)ASS-rex (06-07-2012), StayBroke (06-08-2012)
 Old 06-07-2012, 06:14 PM   #187
Bob Ross Fanclub
Tomas's Avatar
Freekn tappin
Tight tolerances indeed.
Camshaft journals are 0.02
Valve tappets 0.01
Camshaft run out 0.03
I spent about 20 hours cleaning a used head I bought, porting the head, lapping the valve seats, and adjusting valve tappet clearance. If I would have measured every single item in the engine manual I could have spent another 40 hours. That's not an exaggeration. You have the above tolerances and then tappet bore ID, valve stem OD, cam lobe OD, etc etc.
It just comes to a point where you have to trust that some of the tolerances are OK from the factory.
On the pistons alone you have
piston OD 0.03
piston ring and piston rings groove ( that's 12 measurements right there plus piston ring gap another 12 = 24 measurements)
Piston pin and pin hole ID. 12 measurments.
That's 42 points of measurement on a single location (which you shouldn't. You should always measure on multiple locations)
I'll be damned if I am gonna fumble with each piston with a bore gauge in one hand and a micrometer screw on the other plus a feeler gauge in the crack of my ass to make sure everything is within spec. I am going to assume the new Gen 2 pistons I have are within spec from the factory.
This is what I will measure on a "drop in" rebuild.
*Cylinder block distortion
*Bore of the big ends of the connecting rods to OEM spec. If they come out OK, I am going to assume the OEM big end bearings are within spec and slap the two together on the crank. Wiggle the rods comparing that all 4 have about the same turning resistance and leave it like that. No plastigauge.
*Wrist pin OD and small end bore ID. Again making sure all 4 pistons with wrist pins with the small ends through them feel the same.
*Weight of con rods and piston assembly. If more than a few grams difference I will tighten the weight difference by grinding somewhere.
Things like bore ID, con rod length... meh.
The goal is total time from start to finish < 18 hours. So 1 week end.
The Following 14 Users Say Thank You to Tomas For This Useful Post:
802MS3 (06-07-2012), 86AmishMs3 (06-07-2012), atvfreek (06-07-2012), charlesfist (06-11-2012), Chimmike (06-07-2012), Dano (06-08-2012), dougefresh_ (06-07-2012), Ingle (06-08-2012), mrmonk7663 (06-07-2012), MS3-a(sore)ASS-rex (06-08-2012), SLOWHATCH (06-07-2012), StayBroke (06-08-2012), torquemaniac (12-24-2013), uncorked11 (06-08-2012)
 Old 06-07-2012, 08:26 PM   #188
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Another reason I want to just change rods is less worrying about clearances. Only really need to worry about 8 points really, right?
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 06-07-2012, 09:22 PM   #189
Bob Ross Fanclub
Tomas's Avatar
^ If by that you mean check con rod big and small ends then yes. As mentioned earlier though there is of course more you can do. Probably going to be OK but once you take the head off it's possible something gets out of whack.
I think changing pistons at the same time and a light hone is a good idea. Whether OEM gen2 or aftermarket.
86AmishMs3 (06-07-2012), Chimmike (06-08-2012), StayBroke (06-08-2012)
 Old 06-07-2012, 11:20 PM   #190
86AmishMs3's Avatar
Groans: 338
Well like I said i'm strongly thinking about just leaving the stockers in, so no need to hone...plus my block is in mint condition, great compression, 35k miles on it, no issues. I figure i'm really only shooting for a mild build, low 400's. Just want rods for piece of mind. The only thing I'm worried about is spinning a bearing. I don't really know what to look for or how to measure the journal bearing clearances.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
Tomas (06-08-2012)
 Old 06-08-2012, 05:53 AM   #191
Groans: 224
Plastigauge.
NATOR PA
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post:
Tomas (06-08-2012)
 Old 06-08-2012, 06:12 AM   #192
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Now, we know that genpu has stronger rods than genjuan, but are the pistons stronger as well? I'm thinking about dropping in some forged rods with OEM genpu pistons, will that work?
Is this what @@ wants to do as well?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 06-08-2012, 06:12 AM   #193
MSMS3's Avatar
Groans: 157
I'm just suggesting that the block be bored for oversize pistons, that the crank be reground for fresh bearings, head and block decks checked for warp and that new chain and oil pump be used. These basics are the key, IMHO, to good success.
It is BECAUSE the tolerances are so tight that these things should be done. It does not take much wear to be completely out of spec and short life after a drop in rebuild.
Sorry if I offended. Just suggesting that a little basic machine work and checking a few specs could pay dividends.
mituc (06-08-2012)
 Old 06-08-2012, 06:21 AM   #194
Groans: 224
Unless there was damage to the cylinder walls there's no way in fuck I'd ever comsider boring out the cylinder.
I always check the head and the deck for warping while the head is off as well.
NATOR PA
86AmishMs3 (06-08-2012), atvfreek (06-08-2012), MSMS3 (06-08-2012), StayBroke (06-08-2012)
 Old 06-08-2012, 06:28 AM   #195
Will fuck up ur day
Chimmike's Avatar
Groans: 433
IMO, if you don't want to go the route of forged pistons, get genpoo pistons and cryo them. That'll increase strength like 10-15%, and if you want, shot peen them too...that strengthens them.
07 MS3
Tomas (06-08-2012)
 Old 06-08-2012, 06:34 AM   #196
DiGi Faggot's Avatar
Posts: 1,212   (View Stats)
DiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the world
Groans: 148
Groaned at 89 Times in 51 Posts
Gen Pu pistons has a smiley face design meant to better fuel combustion. Iirc I read somewhere they also prevent hot spots in the chamber.
DiGi Faggot is offline   Reply With Quote
 Old 06-08-2012, 06:49 AM   #197
Bob Ross Fanclub
Tomas's Avatar
I don't know if in Romania the rods of the Gen2 are stronger than the Gen1 rods.
Most decidedly not in North America. They are both exactly the same.
The piston crowns are different between generations. That is all as far as internals. The Gen2s have smiley faces on them to improve flame propagation and avoid cylinder wall washing.
atvfreek (06-08-2012), MS3-a(sore)ASS-rex (06-08-2012), MSMS3 (06-08-2012), StayBroke (06-08-2012)
 Old 06-08-2012, 01:16 PM   #198
mituc's Avatar
Groans: 111
Are you sure the gen1 and gen2 rods are the same? The genpu rods are a bit heavier, differently shaped...
 Old 06-08-2012, 01:35 PM   #199
Bob Ross Fanclub
Tomas's Avatar
From Canada, with love, to Romania
http://www.mazdaspeedforums.org/foru...rences-110109/
mituc (06-08-2012)
 Old 06-08-2012, 01:47 PM   #200
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Groans: 112
Ok so I you're not familiar with the term drop-in internals, it pretty much means that instead of pulling the entire engine and tearing it down and rebuilding it completely, you pull the head and drop the oil pan to swap the pistons, rods, bearings and gaskets (preferably with better head studs). Its done without machine work to the block besides honing the cylinders.
I've done this quite a few times on 4G63's but I dont recall seeing anyone having done it on here. Usually it takes me about a weekend working at a comfortable pace to get this done.
Have any of you done this? And if so what combination of internals, bearings, gaskets and hardware do you recommend for best OEM fitment?
I was considering Eagle H-Beam rods with Wiseco Pistons (stock bore & wrist pin size), with ARP head studs and an OEM gasket kit. Thoughts...opinions?
A couple issues that put my engine out of spec when I had it machined... just a fyi.
- OEM sized bearings (mains/rods) were too small and out of spec from mazda. Had to get the oversized bearings and grind down the crank to spec.
- Car had 30,XXX miles on it, yet the cylinders where "ovaled" had to get it bored out with the oversized wiseco pistons instead of OEM size.
860whp/677wtq
2.7 V6 Ecoboost
The Following User Says Thank You to PapaSmurf For This Useful Post:
Getting forged internals, but what? Speedie6 MazdaSpeed 6 - Engine, Transmission & Driveline 55 05-17-2010 03:46 PM
Forged internals + GT3076r johnac08 MazdaSpeed 3/6 - Turbo Induction 24 10-19-2009 12:06 AM
should i go forged internals? boostednut MazdaSpeed 3 - Engine, Transmission & Driveline 14 04-01-2009 09:52 AM
Powder forged rods versus drop forged. Lex MazdaSpeed 3 - Engine, Transmission & Driveline 1 01-24-2009 06:27 AM
Forged Internals for All!!! In Stock!!! CaptainKRM Mazdaspeed3/6 General Discussion 43 10-10-2008 06:08 PM
Page generated in 0.64108 seconds with 34 queries
