Like Tree12Likes
 Old 05-17-2011, 07:50 AM   #41
triplejumper18's Avatar
Posts: 2,569   (View Stats)
triplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the world
Groans: 196
Groaned at 57 Times in 47 Posts
Originally Posted by wildacex187 View Post
from what i've read it seems that the ap only "turns off" the cel but doesnt get rid of the code. once u go get an inspection or use a scanner it reads "not ready" or something like that and wont pass
would like to get this done but annual inspections suck!!
Most states that do OBDII testing allow one "not ready" and this mod is relatively easy to reverse.
triplejumper18 is offline   Reply With Quote
The Following User Says Thank You to triplejumper18 For This Useful Post:
rfinkle2 (05-17-2011)
 Old 05-17-2011, 08:12 AM   #42
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
Originally Posted by mtnrunner View Post
I just did mine on wednesday and dont regret it at all. I did it at the same time as my injector seals so it wasnt much extra work at all. Since i have an AP i just turned off the cel in atr and that has worked fine. My valves looked like absolute crap with 66000 miles. I have used sea foam multiple times but not in the last 10k or so. Also i just started running meth about 3k miles ago. I do not have an OCC yet but i will be getting one very soon after seeing my valves. For some reason the valves behind the vcts flaps were the worst.
These pics were taken with a iphone because thats all we had to work with.
OCC = ?
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
 Old 05-17-2011, 08:33 AM   #43
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groans: 98
Groaned at 72 Times in 51 Posts
This guy told me the egr block will kill my cat in the long run. Its not true, is it?
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
 Old 05-17-2011, 08:41 AM   #44
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
^^^ derp? kill the cat yourself and run catless.
James Geese likes this.
The Following User Says Thank You to karl-hungus For This Useful Post:
rigor (05-19-2011)
 Old 05-17-2011, 08:46 AM   #45
patrick failman
Groans: 74
Originally Posted by bnoon View Post
Total and absolute bullshit. Been to 30 below the last two winters and no issues whatsoever, ever.
That's correct. Just pull the shorter coolant line all the way off and connect the longer line to the other tube. If you do it quickly, you spill very little coolant. I messed up and dropped the line more than once, so I had to add a couple of quarts of coolant to top it off when I was done.
bnoon, can you get the nipple covers to plug the tb coolant holes from an auto parts store? you have intrigued me with your 30 below experiences and have me leaning towards the tb coolant bypass.
 Old 05-17-2011, 09:05 AM   #46
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Sorry to barge in on a question specific to bnoon, but most auto parts stores carry an assortment pack of vacuum caps in all sizes.
karl-hungus (05-17-2011), SLOWHATCH (08-27-2011)
 Old 05-17-2011, 09:28 AM   #47
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
im thinking of removing them and connecting them to each other via a male to male brass fitting
thoughts??
Monotonous ONE is offline   Reply With Quote
The Following 2 Users Say Thank You to Monotonous ONE For This Useful Post:
ak_spray (05-17-2011), SLOWHATCH (08-27-2011)
 Old 05-17-2011, 09:34 AM   #48
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Dont bother. Just follow the way bnoon said. It really is a stupid simple mod. 100% reversible in 5 mins if you keep the short hose.
 Old 05-17-2011, 09:38 AM   #49
patrick failman
Groans: 74
what size vacuum cap you boys reckon? my advance guys don't habla all that well.
wankular (05-17-2011)
 Old 05-17-2011, 09:41 AM   #50
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
thoughts??
Yeah finkle mentioned something about this in the GB thread for the TIG.
07 MS3 Sport
CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP
SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon)
JBR: RSB
Cobb: Accessport
Corksport: TMIC
CNT: Catted Downpipe
ak_spray is offline   Reply With Quote
 Old 05-17-2011, 10:08 AM   #51
wankular's Avatar
Posts: 4,343   (View Stats)
pat are you trying to catch up on the performance mods since danish called you a ricer?
Also interested in TB cap size. It looks to be about pinkie fingertip size.
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
 Old 05-17-2011, 10:11 AM   #52
rfinkle2's Avatar
Groans: 298
If you have a pep boys local to you, I've gotten an assortment pack.
AFAIK, picking up a few packs of what looks reasonably close will cost in the neighborhood of $2.00.
They are rubber, so stretching them to fit is pretty easy, my point being, it is best to err on the small side, than purchase one too big.
http://www.autozone.com/autozone/acc...ntifier=720714
http://www.advanceautoparts.com/1/1/...art-47397.html
 Old 05-17-2011, 10:17 AM   #53
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
This won't lead to air bubbles getting into the system continuously will it?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 05-17-2011, 10:20 AM   #54
rfinkle2's Avatar
Groans: 298
I've read guys having problems after doing it (air bubbles), but I've done it to a 350z years ago, with no issues.
Tokay444 (05-17-2011)
 Old 05-17-2011, 10:41 AM   #55
shadesofgray19's Avatar
Posts: 794   (View Stats)
i temporarily regret mine.
failed inspection today because of it so i gotta switch back and go reinspect. then take it right back off haha
Skates, you said that you failed inspection? Did you mean to say emissions as VA has inspections and emissions and mine are not at the same time. I'd just like some more info on the topic and if it was due to the Cobb AP not ready state. You are allowed one not ready state so I would not think that is the issue.
shadesofgray19 is offline   Reply With Quote
 Old 05-17-2011, 10:41 AM   #56
patrick failman
Groans: 74
lol. danish calling me a ricer with his intake and cbe. these are 'i'm bored / broke' mods. gotta pay for my wife's titties.
The Following 4 Users Say Thank You to karl-hungus For This Useful Post:
breakfstincluded (09-03-2011), Chimmike (06-01-2011), Tokay444 (05-17-2011), wankular (05-17-2011)
 Old 05-17-2011, 11:08 AM   #57
Tokay444's Avatar
Groans: 793
I'm sure we'll all thank you for that in a nsfw thread.
Demodded.
The Seals
 Old 05-17-2011, 11:17 AM   #58
Ferdball's Avatar
Posts: 1,340   (View Stats)
Ferdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the world
In for pics.
Nothing to add, but something about this made me laugh.
Last edited by Ferdball; 05-17-2011 at 11:17 AM. Reason: MSF Database - Automerged Doublepost
Ferdball is offline   Reply With Quote
 Old 05-17-2011, 11:24 AM   #59
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
It's called docking.
thatsmrgimp2u likes this.
Bucker (06-01-2011), karl-hungus (05-17-2011), kgb (03-20-2012)
 Old 05-17-2011, 11:32 AM   #60
Groans: 819
my "docking" has just been completed
The Following User Says Thank You to Monotonous ONE For This Useful Post:
 Old 05-17-2011, 11:43 AM   #61
wankular's Avatar
Does coolant sit in the throttle body when the car is cold? As long as you take the hoses off and vise grip them, should any coolant spill out of the TB?
joeyspeed3 likes this.
2009 MS3 sport MGM
 Old 05-17-2011, 11:56 AM   #62
bnoon's Avatar
Posts: 1,770   (View Stats)
No need to cap off the TB ports. I've never done it on any of my TB's that I've bypassed and never had any deterioration or other issues. Just blow it out with an air hose if you're worried about coolant being left in there.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline   Reply With Quote
The Following 2 Users Say Thank You to bnoon For This Useful Post:
rfinkle2 (05-17-2011), wankular (05-17-2011)
 Old 05-17-2011, 12:20 PM   #63
Groans: 819
so i did the TIG throttle body spacer install + the coolant bypass
I bought a brass fitting and disconnected them both and attached them both. they have metal clamps on them but my fitting may have been a tad small because i had a tiny leak one 1 side. when i lift the connection a little higher...the leak goes away. so i threw a ziptie on each end in addition and i saw no further drip.
I bought some shelf end fittings cause their mad cheap and they come in mad sizes and i capped the 2 nipples on the throttle body
i think thats about it.
i took approximately three 3rd gear logs beforehand. Ill post some logs later on when i get a chance.
but i took a short drive and all the data looks ok. gonna wait a bit to get on it. but the coolant temp was normal...fuel trims were mostly ok but still settling...intake temps were aight...boost temps were aight...but since i didnt get on it its kinda hard to tell. i just wanted to make sure nothing was loose or whatever.
The Following 3 Users Say Thank You to Monotonous ONE For This Useful Post:
rfinkle2 (05-17-2011), wankular (05-17-2011), wolly6973 (05-17-2011)
 Old 05-17-2011, 01:10 PM   #64
I don't see how the TIG throttle body spacer would do anything. Wont hurt, but I doubt it does anything. The intake manifold spacer is another story. That thing works wonders. I have two of them in place and see cooler BAT's and the manifold is cold to the touch after driving.
The Following 3 Users Say Thank You to MattJackson86 For This Useful Post:
p057 (03-08-2012), rfinkle2 (05-18-2011), SLOWHATCH (03-06-2012)
 Old 05-17-2011, 01:43 PM   #65
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
Originally Posted by drknyte View Post
OCC = ?
No oil catch can yet, haha. I will be getting one then cleaning my valves and intake mani at the same time. Hopefully the combination of meth, occ, and egr delete will keep the valves clean.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
 Old 05-17-2011, 07:50 PM   #66
wildacex187's Avatar
Posts: 154   (View Stats)
wildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond repute
so its either this or the catless downpipe.
red mazdaspeed 6 gt
fujita cai, tip, test pipe, turbosmart dual port bpv, SURE rmm (in blue ), jabrone shifter bushings and 1lb shift knob, cobb ap stg 1 fucai93 map with LC and idle edited just cuz
wildacex187 is offline   Reply With Quote
 Old 05-17-2011, 08:03 PM   #67
mtnrunner's Avatar
^^ the catless dp will not give you any cel if you use a o2 bung extender. Its not like you have to turn the cel off in atr, it just does not show up. I ran a catless dp for like 30k untuned with no cel, then like another 10k on the sb with no cel.
 Old 05-17-2011, 08:15 PM   #68
did u use the bung extender? i hear is a hit or miss.
red mazdaspeed 6 gt
 Old 05-17-2011, 09:51 PM   #69
patrick failman
Groans: 74
ebay, cpe and cobb dp all have an extended o2 bung. safe as kittens.
here's your docking aid.
wildacex187 (05-17-2011)
 Old 05-17-2011, 09:55 PM   #70
mtnrunner's Avatar
Yeah, my dp came with the bung and i have ran it since day one.
The Following User Says Thank You to mtnrunner For This Useful Post:
 Old 05-18-2011, 08:46 AM   #71
Correct. My DP came with an extended bung, and it didn't work. Had to use the AP to turn off the code.
wildacex187 (05-18-2011)
 Old 05-18-2011, 09:26 PM   #72
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
thatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the world
Back to the egr topic. I feel like my car is running rich now. Sometimes when i stop at idle its in the 15's... but its still mostly 14.6. TONS of soot on my tailpipe, but that may still be accumulating from the seafoam treatment. There are two codes that throw when you block the EGR, P0401 and U2064. Ones for the actual EGR (that can be deleted) the other a network comm failure that cannot be deleted. Ive read some cars are just unfortunate (like mine) and will throw the cel with just u2064 even if P0401 has been removed. I have an ap, i removed the code, i still get a cel... and i cant deal with having to clear it everytime i drive. I'm going to reinstall the plate to make sure its not leaking, but if i still have the cel afterwards ill be putting the pipe back on for sure.
| CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
 Old 05-18-2011, 10:23 PM   #73
I have never thrown the U2064 with the EGR blocked. At least the DH doesn't display that code. That sounds like an AP issue. No way EGR would throw a Network com error.
http://forums.cobbtuning.com/forums/...rown-this-code
NM...just saw you posted in that thread too.
 Old 05-19-2011, 06:31 AM   #74
^^^ thanks for clearing that up. Just realized I didn't mention it. Apparently the only people who get it are ap users... Not all but some. But you need an ap to clear the p0401 code... I'm installing a img soon. Im going to be taking a part my entire intake assembly again, reinstalling the egr block off, and double check all of my connections. I'm fairly confident it's being thrown as a result of the p0401 code not existing.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 05-19-2011, 08:01 AM   #75
Tokay444's Avatar
Groans: 793
14.6 and 15 afrs are not rich. They'er almost stoich and lean.
Demodded.
The Seals
wildacex187 (05-19-2011)
 Old 05-19-2011, 09:12 PM   #76
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Originally Posted by Mizzle View Post
3.) Has anyone thought of doing a catch-can type thing on the EGR pipe to let it function, but capture the solids?
Anyone?
 Old 05-20-2011, 06:54 AM   #77
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
Anyone?
.... but why?
You know.... Moose stuff
amoosenamedhank is offline   Reply With Quote
 Old 05-20-2011, 08:23 AM   #78
ak_spray's Avatar
Originally Posted by amoosenamedhank View Post
.... but why?
Kinda thinking the same thing seems like more work than necessary just clean your EGR out periodically. Where would you mount it?
07 MS3 Sport
JBR: RSB
Cobb: Accessport
Corksport: TMIC
 Old 05-22-2011, 07:49 PM   #79
Mizzle's Avatar
Groans: 324
.... but why?
So you don't have to block it off to keep your intake clean while avoiding the CEL issue.
*shrugs*
 Old 05-22-2011, 08:17 PM   #80
ak_spray's Avatar
Usually people seafoam to clean the intake even of they do have the EGR delete.
DIY: Sea Foam
07 MS3 Sport
JBR: RSB
Cobb: Accessport
Corksport: TMIC
2.5l block trigun22 MazdaSpeed 3 - Engine, Transmission & Driveline 34 06-21-2017 08:50 AM
iwg block off ? ms3boost MazdaSpeed 3/6 - Turbo Induction 5 04-12-2009 11:40 PM
Page generated in 0.57741 seconds with 39 queries
