Like Tree12Likes
 Old 05-23-2011, 06:15 PM   #81
Originally Posted by Mizzle View Post
So you don't have to block it off to keep your intake clean while avoiding the CEL issue.
*shrugs*
A catch can is also needed to help keep the intake clean. The EGR is mostly responsible for buildup on the valves, though.
Even with both a catch can and EGR blockoff, I'd still run Seafoam occasionally. DI engines don't wash down the intake valves like port injection ones do, and are therefore much more susceptible to buildup.
rfinkle2 (05-23-2011)
 Old 05-23-2011, 08:06 PM   #82
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
I suppose I wasn't clear, so I'll restate:
I don't want to have to clean every oil change and I also don't want to block off my EGR and get a CEL, so I was assuming an EGR catch-can would be a good compromise (vs. a foolproof solution.)
 Old 05-23-2011, 09:08 PM   #83
MattJackson86's Avatar
Posts: 1,407   (View Stats)
It would take some manufacturing, but some way to catch the EGR or dump it to the downpipe (or ground?) would work. Not sure if its worth the work for most people.
 Old 05-24-2011, 07:51 AM   #84
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
By the time you've done all of this, you might as well just bought an AP.
You know.... Moose stuff
amoosenamedhank is offline   Reply With Quote
The Following 2 Users Say Thank You to amoosenamedhank For This Useful Post:
ak_spray (05-24-2011), Monotonous ONE (07-11-2011)
 Old 05-24-2011, 08:38 AM   #85
Agreed
 Old 05-24-2011, 09:37 AM   #86
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
ht raised the idle for us. hoping they can defeat this code now.
 Old 07-10-2011, 08:33 PM   #87
akbrazil's Avatar
Posts: 287   (View Stats)
akbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond repute
Had my EGR blocked off for who knows how long now (30,000 +). No regrets. Why would there be? No downside to this what so ever except for a CEL. The CEL can be removed with the AP.
how do you remove the CEL with the AP???
MODS: BNR STAGE 3 Turbo - CP-E Turbo Inlet - CP-E Cold Air Intake - Forge BPV - Street Unit Silicone Inlet & Outlet Hoses - UR Catted Down Pipe - UR Test Pipe - ETS Top Mount Intercooler - COBB AP (WOT-Tune) - KMD Internals - Grimmspeed EBC - HAWK HPS Front Pads - JB dog bone rear mount - NGK (1 step colder plugs) - DDM HID (Headlights & Fogs)
akbrazil is offline   Reply With Quote
 Old 07-10-2011, 08:59 PM   #88
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
You don't. You simply turn the light off.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 07-10-2011, 11:21 PM   #89
No, it does actually remove the CEL. Will not show up on a scantool.
I dont have ATR in front of me right now, but its in the advanced properties, just uncheck the CEL code you want to remove.
 Old 07-11-2011, 05:05 AM   #90
Tokay444's Avatar
Groans: 793
Ummm, yes it will.
It will scan in as something not being ready and that it's egr related. I forget exactly.
Demodded.
The Seals
 Old 07-11-2011, 04:48 PM   #91
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
thatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the world
Ummm, yes it will.
What he said.
I ran into the same issue. You get a comm error that throws a cel even if you remove the correct code.
| CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
The Following User Says Thank You to thatsmrgimp2u For This Useful Post:
Tokay444 (07-11-2011)
 Old 07-11-2011, 09:58 PM   #92
Well all I can say is that I have the AP removing my CEL and the DH will not pick up any codes what so ever. Works perfectly for me. Cobb did report a comm error for some people though not sure if thats fixed or what.
 Old 07-19-2011, 09:56 AM   #93
I gotthatzumzum's Avatar
Posts: 552   (View Stats)
I gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the world
Ummm, yes it will.
This isn't true. I don't have it done to my car, but you can deactivate any check engine light code you want with the correct tuning software. What you cannot do, however, is force the OBDII flags to set for emissions. You have flags for all kinds of different emissions systems like secondary air, o2 sensors, EGR, PCV, etc. What your thinking of is when you take your car to get smogged, they check for a check engine light, how many faults are in the engine system, and for how many OBDII monitors or flags are unset. By blocking off the EGR, you can clear the code and check engine light with ATR, but you cannot change the fact that the EGR OBDII monitor will never set. Here in Nevada, you are allowed 1 unset monitor or 1 fault with no check engine light on... so if this is your only mod that messes with your monitors, you will be fine.
Originally Posted by martyxattack View Post
i wish more than like 2 colors didnt look stupid on my fucking brightest red ever car
I gotthatzumzum is offline   Reply With Quote
 Old 08-05-2011, 08:15 AM   #94
Ummm, yes it will.
This is true...
Happened to me. I talked with cobb about it. Said some cars experience a cel even after deleting the code. The code i deleted wasnt throwing, but a communications code still popped up. You guys can sit here and tell me a code wont throw if you delete it in ATR all day long, but i spent over a month going back and forth with cobb and plenty of time in this forum to find out that there is jack shit that you can do about it. So far at least...
Best i can say for the guys wanting to do this, do so expecting to throw a code. If it doesent happen, awesome.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
Tokay444 (08-05-2011)
 Old 03-06-2012, 04:04 AM   #95
MrBret's Avatar
Posts: 12   (View Stats)
MrBret will become famous soon enough
Sorry for the noob question here but whats the AP and the CEL that everyone keeps mentioning.
I just got an 08 Speed3 with 35k & am thinking of some minor tweeks, the EGR block off being one of them.
Thanks for any info in advance
MrBret is offline   Reply With Quote
The Following User Says Thank You to MrBret For This Useful Post:
karl-hungus (03-06-2012)
 Old 03-06-2012, 04:07 AM   #96
FLHXterp's Avatar
Posts: 192   (View Stats)
FLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the world
Oh no.
I feel like it's going to be a long, tough road for you.
Please, I implore you to read the intro and new member/owner threads. If you don't we're going to crush you.
Here's your freebie.
AP = Tuning device made by Cobb
CEL = Check engine light
Please for the love of god go read the intro stuff.
FLHXterp is offline   Reply With Quote
The Following 2 Users Say Thank You to FLHXterp For This Useful Post:
ak_spray (03-06-2012), div2 (03-08-2012)
 Old 03-06-2012, 04:16 AM   #97
MrBret's Avatar
Thanks for that
 Old 03-06-2012, 08:59 AM   #98
Just to update, the newer versions of ATR alow the code to properly be removed, without a CEL.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
The Following 2 Users Say Thank You to thatsmrgimp2u For This Useful Post:
ak_spray (03-06-2012), deadlandxtreme (03-06-2012)
 Old 03-06-2012, 09:04 AM   #99
ak_spray's Avatar
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
Since someone brought this back from the dead. Who has noticed higher coolant temps with a deleted EGR? I'm just thinking if I go FM that if I do the EGR delete also that's only going to make the coolant temps even higher if what little info I have is true.
07 MS3 Sport
CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP
SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon)
JBR: RSB
Cobb: Accessport
Corksport: TMIC
CNT: Catted Downpipe
ak_spray is offline   Reply With Quote
 Old 03-06-2012, 10:02 AM   #100
Tokay444's Avatar
Groans: 793
What about the not ready code you still get with a scan tool?
Demodded.
The Seals
 Old 03-06-2012, 11:13 AM   #101
Havent checked that, i assume that would still be there, however, the light can be removed and will stay gone from the issue.
I want to say my coolant temps stays around 180, and was the same before i did the delete months ago.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 03-08-2012, 12:24 AM   #102
Skettio's Avatar
Posts: 5   (View Stats)
Skettio is an unknown quantity at this point
Wonder if any vendor will make a filter for the EGR. Did a quick google search and see that a lot of the diesel engines in Mercedes, Landrovers, etc have EGR filters not to mention VW Beetles. Looks like its as simple as changing an air filter.
That way the emissions systems stay intact and you keep the bad shit out of your intake track. Just thinking out loud.
Skettio is offline   Reply With Quote
 Old 03-08-2012, 09:20 PM   #103
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Past Mazdas & Speeds
2.5l block trigun22 MazdaSpeed 3 - Engine, Transmission & Driveline 34 06-21-2017 08:50 AM
iwg block off ? ms3boost MazdaSpeed 3/6 - Turbo Induction 5 04-12-2009 11:40 PM
Page generated in 0.42919 seconds with 33 queries
