 Old 04-01-2010, 04:32 PM   #81
SpeedSixxx, you'll see a lower spike with higher temperatures.
SilverDeamon, it is expected to see more KR during cruise because now you have more oxygen content that used to be taken up by EGR before which is inert.
Did your fuel trims go up as well after the delete?
 Old 04-01-2010, 04:34 PM   #82
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
sixxx, i thanked you cause i believe its time to put the rest of your mods on
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
SpeedSixxx (04-01-2010)
 Old 04-01-2010, 04:34 PM   #83
Damn, These seem quite pricey for what they are.
Maybe that's the price for no boost creep and drop in replacement.
It's basically a GT2871 mated to the stock housings. Those turbos run over 1k new as is + you have to fuck around to get them to fit and change some parts.
djuosnteisn (04-01-2010)
 Old 04-01-2010, 04:37 PM   #84
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
lol, I'm waiting on a new compressor housing for the 35R.
now that the nice weather is here it's time.
The Following User Says Thank You to SpeedSixxx For This Useful Post:
 Old 04-01-2010, 04:39 PM   #85
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Lex, never checked the trims....sorry. I saw no difference in performance, only in lower manifold temps.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following User Says Thank You to SilverDemon For This Useful Post:
 Old 04-01-2010, 04:41 PM   #86
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
lol this thread is all over the place
 Old 04-01-2010, 04:52 PM   #87
aaronc7's Avatar
Groans: 370
I've already talked to Lex about this but these are my observations
I was getting exactly what Lex described in the OP.... if I would drive nice and easy for an extended time and then go WOT, car would kind of stumble, KR, puff of smoke. I could easily repeat this as many times as I wanted to and did to make sure it wasn't a fluke. I even started giving the engine a good rev before going down the 1/4 or go WOT for a few seconds before doing a roll race or something because it made a difference for me.
At this point... I have catch can(s), had seafoamed the car a few times but it still did it. Didn't have this issue early on but as I got more and more miles it seemed to get worse. Once I added meth it seemed to help a little but it would still do it from time to time. I had talked to a few other guys with higher miles like myself and they had seen it before, but none of the guys with lower miles had any idea what I was talking about.
Then... about 55k miles or something if I had to guess, I removed the EGR. Almost instantly I noticed my car didn't do the stumble/KR/smoke thing at WOT initially if I had been driving it easy.. EGR was the only change I did. Now does this puff of smoke, or whatever was going on contribute to blown motors.... I don't know, but I can say with pretty high confidence that the EGR did fix the issue which I discussed and Lex talks about in the OP. For me I think it's awesome because the car is a lot more consistent.
It's possible many of you guys here simply don't have enough miles on your car yet to experience this, or if you did the EGR delete a long time ago... your car never got to that point where it started to do it. But then again I'm sure someone will pop in who has 60k miles and hasn't seen this before, so who knows. All I know is when I read the "issue" Lex described in the OP I instantly could related and wanted to share my experience regarding it.
The Following 5 Users Say Thank You to aaronc7 For This Useful Post:
Lex (04-02-2010), madvillain (04-02-2010), mike8748 (04-02-2010), SpeedSixxx (04-01-2010), ToledoSpeed3 (04-02-2010)
 Old 04-01-2010, 04:56 PM   #88
Captain
Groans: 79
The puff of smoke has me a bit puzzled.
If it was legit detonation from a hot crown or slow timing retard... why would there be smoke? I mean maybe there is something to the oil in the intake theory.
Do you see the smoke with your knock Lex?
www.permtuning.com
 Old 04-01-2010, 05:03 PM   #89
aaronc7's Avatar
Groans: 370
on a side not I wouldn't always see KR with smoke... sometimes just a huge smoke screen.
but either way it was gone after EGR delete
The Following User Says Thank You to aaronc7 For This Useful Post:
 Old 04-01-2010, 05:04 PM   #90
Aaron, did you do any tuning on the car after the delete?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 04-01-2010, 07:40 PM   #91
TRex's Avatar
Posts: 3,139   (View Stats)
TRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the world
Groaned at 106 Times in 69 Posts
is there just a defect in our EGR system? (like the PCV system?)
as far as cruising knock i personally see it while cruising at around 3k in the first 5 min of driving...i chalk it up to the motor just adjusting timing ...after about 6-7 min it settles down...i will often see KR as high as 5...does this mean i have knock? i dont really think so...someone told me a long time ago that part throttle knock was very unlikely
now about the knock when going WOT i can say that i havent experienced this...my normal drive to and from work involves about 20 min of 60-65 mph with the occasional WOT sessions (when i run into S4's and BMW's acting like assholes) i have never experienced any knock while going knock ever....granted...my car only has 10k miles....so im wondering if there isnt something to this being a higher mileage problem
curious though....what years are people experiencing these problems...all pre 08.5?
TRex is offline   Reply With Quote
 Old 04-01-2010, 10:50 PM   #92
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
My car doesnt do that, I have 93k miles.
2006 Mazdaspeed 6
 Old 04-02-2010, 01:40 AM   #93
Thanks Aaron for the input. I have 16k miles and mine does this. It happened after I installed the TMIC (which is now replaced by the FMIC) and I would get a boost spike above 20psi. Even with meth it did it.
The gas I get here on west coast is pretty shitty as well. I will remove the EGR but will do so by unplugging the valve - so we'll see if this makes a difference.
As for the puff of smoke - have you been behind a speed when they go WOT? There's always a puff of black smoke. If you get KR and the ECU dumps more fuel, you get an even bigger puff of black.
 Old 04-02-2010, 03:51 AM   #94
Speeeeeed
06Speed6's Avatar
Almost every turbo car has a puff of black smoke when going wot, I wouldnt worry about that.
I doubt the ECU dumps more fuel when it sees KR, it likely just pulls timing.
2006 Mazdaspeed 6
The Following User Says NO Thank You to 06Speed6 For This Un-useful Post:
 Old 04-02-2010, 05:34 AM   #95
mike8748's Avatar
Posts: 396   (View Stats)
mike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the world
Just did my PTP IM gasket and EGR delete... Watching for PT/WOT KR increase/decrease
07'MazdaSpeed3 Stage2+SF 93 FMIC Custom Map
Current Mods: COBB AP, COBB SRI, COBB Inlet, COBB Cold Air Box, COBB Shift Weight, COBB STS, COBB PCV Catch Can, COBB Rear Sway Bar, M3M FMIC, TWM Shifter Bushings, FORGE BPV, Nator Rear MM, TurboXS DP, TurboXS RP, TB BYPASS MOD, MSD Dash Hawk, Denso 2-Step Colder plugs, Eibach Springs, BSD, KMD ver2 internals, EGR delete, PTP intake cooler kit, CNT Racing CBE, PG Exhaust Manifold
mike8748 is offline   Reply With Quote
 Old 04-02-2010, 06:59 AM   #96
aaronc7's Avatar
Groans: 370
Mine still has a puff of smoke, but nothing like it was while I still had the EGR delete. I went from smoke screen to puff of smoke
and no... I didn't change anything in the tune
The Following 2 Users Say Thank You to aaronc7 For This Useful Post:
djuosnteisn (04-02-2010), SilverDemon (04-02-2010)
 Old 04-02-2010, 07:25 AM   #97
ToledoSpeed3's Avatar
Posts: 244   (View Stats)
ToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the world
How much diameter in your EGR tube had you lost due to carbon build-up at 55k? Was it plugged up pretty good?
ToledoSpeed3
09 MazdaSpeed3 GT, True Red
ToledoSpeed3 is offline   Reply With Quote
 Old 04-02-2010, 07:29 AM   #98
aaronc7's Avatar
Groans: 370
I think it was pretty clear... I still have the pipe let me check sometime later this weekend
 Old 04-02-2010, 07:34 AM   #99
SpeedSixxx's Avatar
Groans: 778
at 52k when i took it off i'd say near 1/4 of the diameter of my pipe was filled..
maybe a tiny bit less
 Old 04-02-2010, 08:23 AM   #100
Thanks, So if you did not change anything in the tune, then according to Lex there should be more oxygen in the combustion process, thus inducing more cruising knock. At least this is what Lex is telling me......
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 04-02-2010, 08:47 AM   #101
TRex's Avatar
i want to pin down this cruising knock....i was under the impression that knock was only really possible at high load/WOT conditions....so is this cruising knock REAL knock or is it just the engine retarding timing in order to get efficiency?
 Old 04-02-2010, 02:07 PM   #102
danesti's Avatar
Posts: 4,186   (View Stats)
danesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the world
Groans: 137
knock is the result of heat and pressure.
the more lean the afr gets, the more prone to knock it is, as a lean mixture is a hotter burn.
the car wants good MPG while cruising, so it leans it out until it knocks to try and find a happy medium.
im not very concerned with the cruising knock any more. i HATE when i get wot or audible knock though. shits not cool.
2008 STi
Intake
Turboback
AP
danesti is offline   Reply With Quote
The Following 2 Users Say Thank You to danesti For This Useful Post:
krazycoble (05-14-2012), SpeedSixxx (04-02-2010)
 Old 04-02-2010, 03:01 PM   #103
One of the ECU's strategies to mitigate knock is to cool combustion by adding more fuel. This is why weak pumps always show up at high KR levels.
 Old 04-02-2010, 07:42 PM   #104
Captain
Groans: 79
Actually leaner mixtures will be a cooler burn. Similar to richer mixtures. You get more of a cooling affect from rich mixtures though, cause the vaporization of the extra fuel pulls additional heat out of the chamber.
Hottest burn ration i think is like 13:1 or something like that, and then temps drop on both sides (rich or lean).
www.permtuning.com
meicalnissyen (07-12-2012), SpeedSixxx (04-03-2010)
 Old 04-03-2012, 07:27 PM   #105
cjanota's Avatar
Posts: 6   (View Stats)
cjanota will become famous soon enough
I'm not sure if this is an issue on our car since people have done EGR delete without problems, but cutting out EGR will increase exhaust manifold pressures and temperatures. If a turbo is sized for an engine running a certain amount of EGR, the turbine can be too restrictive for the increased flow when you cut out the EGR.
cjanota is offline   Reply With Quote
 Old 04-03-2012, 07:39 PM   #106
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
hey, fool, this thread is 2 years old. this shit is old news..
thanks anyway.
also, egr is only open at partial throttle. at WOT, it is closed. at WOT, also, is when EM pressures are highest. the EGR has almost nothing to do with reducing EM pressure. indeed, it is the loss of pressure in the exhaust system (from cat deletes) that is believed to play a part in smoking turbos. so, by your line of reasoning, EGR delete will save k04s. yay.
The Following 4 Users Say Thank You to tddvrrn For This Useful Post:
Dash08 (07-11-2012), kgb (04-03-2012), meicalnissyen (07-12-2012), Nliiitend1 (04-03-2012)
 Old 04-03-2012, 08:01 PM   #107
melbaro's Avatar
Posts: 230   (View Stats)
melbaro is the leader of the worldmelbaro is the leader of the worldmelbaro is the leader of the worldmelbaro is the leader of the worldmelbaro is the leader of the worldmelbaro is the leader of the worldmelbaro is the leader of the worldmelbaro is the leader of the worldmelbaro is the leader of the worldmelbaro is the leader of the worldmelbaro is the leader of the world
You bitch! Almost threw a wrench in my install day!!
Problem Child (aborted in third trimester) -
2011 LSM Speed3 - Cobb AP Stage DIZZY - JBR SSP/SSB/EGR Delete/AP Mount - SURE Aeros v2 - CS TIP/TMIC/SkidPlate - UR Catless DP/TP - Autotech FP Internals - Denso ITv22 - H&R Springs - SPC Camber Arms
melbaro is offline   Reply With Quote
The Following 2 Users Say Thank You to melbaro For This Useful Post:
kgb (04-03-2012), tddvrrn (04-04-2012)
 Old 04-30-2012, 08:18 PM   #108
Dubcnea's Avatar
Posts: 223   (View Stats)
Dubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond repute
Hoping not to look like a complete tool here. i read through 95% of this thread (until it got way off topic...which was much of thread) but i never really saw a distinct "yes this is fine, depending on your KR" or "do this and suffer the consequences". i understand it could or will cause more pollution or throw a CEL...but what are the ramifications to the engine? i <3 the environment, but i'd rather not have carbon buildup that will eventually lead to shit performance after x number of miles.
i plan on getting an OCC. is that enough? EGR delete seems quite simple. i'm just more nervous since the car is still new and under 500 miles.
to sound a bit les n00by...i plan on getting the Cobb AP and running some baseline numbers to see exactly what my KR is in certain situations, etc. i just wanted to see some direct input on this actual mod.
2012 CPW Mazdaspeed 3
Dubcnea is offline   Reply With Quote
 Old 04-30-2012, 08:25 PM   #109
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
it's fine to do. you can turn off the code with the AP later, and your valves won't be as bad as many people's are since you're doing it so early.
Blue Pu.
 Old 05-14-2012, 10:58 PM   #110
Dubcnea's Avatar
i got all the way to the install of the SRI and for some reason this EGR thing seemed like an incredibly daunting task. there is shit all over the top of the TB. is 2012 different than previous years? son of a bitch.
so i bitched out and didn't do it yet. i was having issues with the SRI install so i said fuck it. only 750 miles on car so not too worried about build up quite yet.
am i just a DIY noob?
 Old 05-14-2012, 11:03 PM   #111
tddvrrn's Avatar
Groans: 103
yes, you are. sri install is about as easy as it gets, maybe second only to shift knob replacement.
maybe you should buy some legos and practice..
The Following 3 Users Say Thank You to tddvrrn For This Useful Post:
KevMS6 (05-15-2012), outshined (05-15-2012), Spoolnak (02-24-2015)
 Old 05-15-2012, 12:03 AM   #112
Dubcnea's Avatar
my issue wasn't with the SRI...but the EGR due to all of the equipment on top of the TB.
 Old 05-18-2012, 02:29 PM   #113
WOT @1k RPM!
NRSpeed's Avatar
Posts: 1,570   (View Stats)
NRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the world
Groans: 47
Groaned at 50 Times in 33 Posts
2 year old threads make me miss Philly. LOL.
A week ago I got EGR Flow CEL. LAWLS, 25k and my EGR valve is already full. Proof that EGR delete is a requirement.
MazdaSPEED3 2009 - Mica Black
http://www.mazdaspeedforums.org/forum/f8/setting-avatar-new-users-other-noobs-43712/
http://www.mazdaspeedforums.org/forum/f8/uploading-adding-images-your-post-43704/
No BB URL code = sux
NRSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to NRSpeed For This Useful Post:
Dash08 (07-11-2012), melbaro (05-21-2012)
 Old 07-11-2012, 08:24 PM   #114
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
I was just reading about cool buttons you get when racecar...
Turbo Anti-lag systems - A technical description
But what stuck out to me is what the say at the very end:
Starting in 2002 new anti-lag techniques, such as Exhaust Gas Recirculation (EGR), are slowly overtaking the method described above as they are kinder on the engine's mechanical parts.
Never knew EGR had functions for faster spool on other applications out there.
I think I'll just assume that if true, this EGR is completely different in function than our EGR.
 Old 07-11-2012, 08:38 PM   #115
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Since this is an egr thread regardless of how old I thought I'd share this link for future reference.
New egr delete kit
this forum serves 2 purposes
The Following 3 Users Say Thank You to Dash08 For This Useful Post:
breakfstincluded (07-11-2012), Dubcnea (07-12-2012), meicalnissyen (07-12-2012)
 Old 11-20-2012, 07:13 PM   #116
Sig_Nasty's Avatar
Posts: 272   (View Stats)
Sig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the world
Groaned at 4 Times in 1 Post
so was there any conclusion? i just bought an egr delete kit a week ago, saw this thread today, and am now skeptical if i want to install it. do not want zzb.
Sig_Nasty is offline   Reply With Quote
EGR delete/VCTS delete codes Speedie6 Mazdaspeed3/6 General Discussion 7 07-24-2009 10:22 AM
VW, Ford top survey of owner enthusiasm Haltech Automotive News 0 06-29-2009 04:10 PM
Cat delete vs resonator delete taf0422 MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-08-2009 05:57 PM
Survey: What does the LBGT community really drive? Gaywheels.com wants to know Haltech Automotive News 1 02-26-2009 07:36 AM
Survey: Consumers hot for hybrids, but not E85 Haltech Automotive News 0 07-16-2008 09:50 AM
Page generated in 0.55564 seconds with 38 queries
