![]() | | #1 | ![]() |
| Veblen Goods ![]() Join Date: Jan 2009 Location: Dania Beach, FL
Rep Power: 2126 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,375
(Thread Starter) | Not Ranked : 0 score This clutch can be used with the stock dual mass flywheel which is the main reason I went with it. Pictured below is the flywheel condition after about 36K miles and 15-20 HPDE days. I didn't see any scarring or major discoloration so I cleaned up the surface and that's it. According to the instructions Stefan at Eagle Motorsports sends witth the clutch it requires a minimum of 500 mile break in period in slow RPM shifting. Install: exactly the same as stock. The tears and suffering happen when you drop the gear box but once that's out installing the clutch is cake. Clutch disc: Clutch is more grabby than stock. Not a lot more but you do feel the difference. Clutch Feel / Pressure plate: exactly the same as stock. The PP supplied with the clutch is the same as the LUK stock one. First drive: besides the grabbier engagement there seems to be a very slight pulsing of the disc at a certain rpm when taking of from a stil stand. Not sure if this is due to imperfections on the stock flywheel or something else but it is barely noticeable. Overall the clutch seems to be working fine so far. The real test will be in two week once its broken in and I take the car to the track again. Will see if it holds 30 mins of lap after lap driving in 100 deg heat. ![]() ![]() ![]() ![]()
__________________ ![]() GHEY THUNDER Last edited by superskaterxes; 12-19-2011 at 05:28 AM. |
| The Following 10 Users Say Thank You to Tomas For This Useful Post: | charlesfist (08-03-2011), Docnox (08-03-2011), helmetface (09-16-2012), jracer (08-03-2011), karl-hungus (08-01-2011), kmac (08-01-2011), MGM_GT3 (12-25-2011), PunjabiPlaya (08-01-2011), spoolin00 (09-17-2011), wette460 (12-20-2011) |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 10009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,737
Groans: 98
lol new cluch looks like it has felt for material hahaha stefan, i thought all the PP's were the same pressure no matter what your stage was?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
| Banned ![]() Join Date: Nov 2010 Location: Tampa, FL
Groaned at 28 Times in 11 Posts
That is actually a Stage 3+ Not a 2 first of all. Segmented Kevlar on one side and Feramic on the other. The pp on the other hand is and OEM plate. Plate clamp load is ~2040lbs. The pulsing that you describe is completely normal for the materials. It is a shudder but thats exactly what will happen the further up the line you move in clutch materials. Just try to let it grab as quick as you can and let it do its job |
| The Following 5 Users Say Thank You to Tech/Sales@EM For This Useful Post: | Docnox (08-03-2011), jracer (08-03-2011), laxplayermjd (08-03-2011), Tomas (08-03-2011), wette460 (12-20-2011) |
![]() | | #4 | ![]() |
__________________ ![]() GHEY THUNDER | |
![]() | | #5 | ![]() |
Just the way it engages. Thats the only difference if we switched the sides. It is done sometimes when people run aluminum flywheels however. The stage 2 is kevlar on both sides but we put feramic one side to increase your ability to hold power.
![]() | | #6 | ![]() |
![]() Join Date: Dec 2009 Location: Chitown
Rep Power: 1463 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,818
Groaned at 66 Times in 49 Posts
Subbed for post breakin impressions as this is the setup I want to run too!
__________________ PERM Tuned - EFR 7163 Street Sleeper ![]() |
| The Following 2 Users Say Thank You to Alpha For This Useful Post: | jwilkins88 (08-06-2011), wette460 (12-20-2011) |
![]() | | #7 | ![]() |
I actually use the same materials in my personal S4 with a 2800lb pp.
![]() | | #8 | ![]() |
![]() Join Date: Mar 2010 Location: Memphis, TN
Rep Power: 230 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 594
stefan making a killin selling clutches!
__________________ 2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune |
![]() | | #9 | ![]() |
![]() Join Date: Sep 2008 Location: CT/NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,363
Groans: 35
That clutch looks great. It'll be nice to hear about someone putting it to the test. And the stock flywheel still looks mint in that picture.
__________________ ---------------------------------------------------------------------------- '06 Speed 6 Black MicaMazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe, 3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp Altered Customs fmic, Autotech fp internals Cobb AP, Stage 2+ 93 tweaked Centric blanks, EBC red pads Lotek center gauge pod: AEM wideband, Autometer boost and volts Tints, blacked emblems, spec-v front lip, Shark fin Redline MT-90, ITV-22s, Matt Damond OCC 13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap) DO Meth kit waiting on install |
![]() | | #10 | ![]() |
| Not Ranked : 0 score |
| The Following 3 Users Say Thank You to Tech/Sales@EM For This Useful Post: |
![]() | | #11 | ![]() |
![]() Join Date: Apr 2011 Location: Decatur, Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
Groaned at 8 Times in 7 Posts
subbed for post 500 mile drive results
__________________ 2007-Mazdaspeed 6 BNRSIII~all supportings Zoom Zoom Boom part out. |
![]() | | #12 | ![]() |
| Banned ![]() Join Date: Nov 2010 Location: Valley Park, Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,461
Groans: 126
Groaned at 59 Times in 47 Posts
How much power will this clutch hold? I was planning on going with a CM clutch, but I haven't seen any reviews on those yet
![]() | | #13 | ![]() |
Heres a link to the homepage for the OP clutch. Their are a couple reviews floating around on this site for the CM kits as well. http://www.mazdaspeedforums.org/foru...-clutch-78744/ |
![]() | | #14 | ![]() |
1200 mile update. Clutch is running just fine. I've noticed it is less grabby when it gets up to working temp. Took the car to the track last sunday. No complains. Lap after lap no slipping in high heat weather. This is on stock turbo. Now I have a 3071 installed and once its tuned its out to the track again. Then it's red line shifts instead of shifting at 6K as I am doing now.
![]() | | #15 | ![]() |
If your on the track the temps should actually be pretty low because their isnt much slip going on once your already in gear. Next time try and ride the clutch a little bit letting the feramic heat up then go on the track and see if you get a little better results. |
| The Following User Says Thank You to Tech/Sales@EM For This Useful Post: | Alpha (08-23-2011) |
![]() | | #16 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8420 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,258
![]() | | #17 | ![]() |
I am doing road racing. Not drag strip. How does what you describe help bring down lap times? Yeah. After 10-15 mins of 80% + driving on the circuit it would start to slip. Otherwise I really wouldn't have looked at other options but OEM. That, and since I was planning on going BT and quaife LSD, I thought might as well get a higher grade clutch.
![]() | | #18 | ![]() |
Didnt know if you were auto-exe or circuit track.
![]() | | #19 | ![]() |
Rep Power: 4092 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,497
Subbing for results. My stock clutch proved incapable of withstanding the BNR S3 on the road course, and started slipping in the hot afternoon sessions. I suppose with the stock turbo the power fell of more with temperature, where the BNR was able to maintain my requested loads in the higher heat and expose the stock clutch. Very frustrating having to behave like a miata and play the momentum game at 3/4 throttle. Educational to be sure, but I am not a good enough driver and my car is too heavy to pull that off. Really interested if the 3+ is enough or I should be looking at the CM replacement kit.
| The Following User Says Thank You to Ziggo For This Useful Post: | Fobio (09-15-2011) |
![]() | | #20 | ![]() |
| Driver ![]() ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1892 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,112
Groans: 44
I think I need a new clutch too...something with a stock feel on the street and hold on to more power past 3000rpm.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() | | #21 | ![]() |
Unless this guy responds soon I think I am going to be doing the CM FX400 kit just to be sure I don't have a problem. It might be aggravating to drive on a daily basis, but not nearly as aggravating as not being able to go WOT on a road course.
![]() | | #22 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 17 Times in 11 Posts
OMG how much powah ur s4 make??? sounds like sex!!
__________________ Installed: PTP reworked turbo//\\M2 Ebay DP//\\PNP intake mani.(by me)//\\DEI header wrap exh. mani//\\VCTS delete//\\EGR delete//\\CPE injector seals//\\Cobb AP//\\Autotech FP internals//\\Cobb SRI//\\Corksport TIP//\\Corksport FMIC//\\Silicone hoses//\\TWM STS stg 1 with bushing kit//\\BSD//\\Centric Blanks//\\HAWK HPS perf. pads//\\MOTUL DOT 4//\\RHO side plate mount//\\JBR heavy shift knob//\\HKS SSQV1//\\Shark fin antenna//\\Smoked side marker//\\SU RMM//\\DIY ipod adapter. In progress: Powdercoated Rims //\\SURE rear diff mount//\\SURE dreadnaught mount//\\SU rear interior brace//\\GT spec ladder braces//\\Whiteline adjustable RSB//\\Saiko Michi custom OCC setup//\\SPC adjustable ball joints//\\Devils own stage 2 meth injection//\\AWR adjustable front&rear end links//\\JBR intake manifold and throttle-body gasket//\\Perrin EBCS.[SIGPIC][/SIGPIC] |
![]() | | #23 | ![]() |
^ Not enough. Its currently under the Knife getting custom BBK and Custom KW Motorsport Coilovers teamed up with Custom control arms and Hotchkis Sways. |
| The Following User Says Thank You to Tech/Sales@EM For This Useful Post: | Alpha (09-16-2011) |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score Are u waiting for an update from me or EM Motorsports?
![]() | | #25 | ![]() |
| Not Ranked : 0 score Was hoping you were going to hit the track soon with that stage 3+. I was in a hurry, but my clutch seems fine for daily use, I am just going to have to replace it before I hit the track again but I don't have anything scheduled.
![]() | | #26 | ![]() |
I did. See post 14. In addition, I also ran the clutch on a road course with the ATP3071 I installed a few weeks back and it held up without any problems. No slipping.
| The Following User Says Thank You to Tomas For This Useful Post: | wette460 (12-20-2011) |
![]() | | #27 | ![]() |
Saw post 14, was looking for an update using the clutch and the 3071 on the track. I didn't have an issue on the K04 with the stock clutch but with the BNR it was spinning pretty badly. Details on the track time? 4th & 5th gear? Ambient temperature? What kind of torque (or loads) were you seeing? Zigatapatalka
![]() | | #28 | ![]() |
As a side note I would also like to point out that high torque number IMO are not what cause the stock clutch to slip. It's more overheating of the clutch plates which happens when you shift in high frequency at high RPM. If you hit 450 lbs torque at 3.5k rpm that won't make the clutch slip but if you shift at 6k+ rpm constantly it will. That it just my experience though and others might say differently. Meh.
![]() | | #29 | ![]() |
Thanks for the response. I don't think is purely a high torque number that causes it to slip, but that doesn't help. I was able to nurse it around the track by minimizing my shifts, and I know it would have done better if I could heel-toe in my driving shoes, which is something else I am going to fix by putting a fatter gas pedal on. Heat + torque are what does it in. Those seem like really low numbers for a 3071. It was consistent 2.2 loads (310-330ft-lbs) and ~330g/s that did the stock clutch in for me, and I want something that will be able to handle 400ft-lbs on a hot, shift happy day. Zigatapatalka
![]() | | #30 | ![]() |
8K mile update. Clutch started slipping at the track (road course) Currently running ATP 3071. It spikes at around 21-22 psi after every shift. Temps were about 85 degs. Not sure if the pp side or the flywheel side of the clutch is slipping. At any rate I am a lil disappointed. I am not even close to what this turbo can put out. Changing out the clutch is a major pain in the ass and doing big power numbers is kinda useless for my set up unless I can put the power down. Let's see how the new clutches EM brings out can do with the higher clamping pressures. Edit: The clutch was not slipping at the track. I am an imbecile and mistook a slipping clutch for a loose clamp causing a boost leak and rise and fall or RPMs while at WOT.
__________________ ![]() GHEY THUNDER Last edited by Tomas; 12-23-2011 at 09:53 AM. |
| The Following 3 Users Say Thank You to Tomas For This Useful Post: |
![]() | | #31 | ![]() |
Hmmm thanks for the update. Zigatapatalka
![]() | | #32 | ![]() |
Please remember these clutches are not designed for racing..thats the whole reason we also developed along with Clutchmasters a clutch designed for high output cars that would be racing or needed extra help from a powerful pressure plate. These clutches were designed to be cost effective OEM replacement clutches ideally daily driving situations. On another note you most likely just got the kevlar to hot. Once that happens its coefficient of friction is a bit less and requires some time to cool off before it can retain its maximum holding capacity again. |
| The Following 5 Users Say Thank You to Tech/Sales@EM For This Useful Post: | Alpha (12-19-2011), kunfu (12-19-2011), laxplayermjd (12-19-2011), Tomas (12-19-2011), wette460 (12-20-2011) |
![]() | | #33 | ![]() |
I would also prefer to keep the DM flywheel if possible.
![]() | | #34 | ![]() |
8K mile update edited.
![]() | | #35 | ![]() |
*Smacks forehead! Hey will you be down for some track time. Have your checked out the threads I posted on this subject? |
![]() | | #36 | ![]() |
Link?
![]() | | #37 | ![]() |
![]() | | #38 | ![]() |
Sounds good. Thanks. Posted on your thread.
![]() | | #39 | ![]() |
Clutch had to come of after only about 15-20K miles. Installed it just about a year ago. It was slipping and there was an oil leak somewhere. I am not sure where the oil leak originated yet. Could be the rear main seal or the seal on the input shaft of the gear box. The gear box never lost much oil so I am going to say it was the rear main seal. I will know for sure once I take the gear box apart. It's also possible the clutch was slipping due to the surfaces of the pressure plate and flywheel being contaminated with oil. Swapped the clutch with a Spec 3+ although the EM clutch is still in pretty good shape. There is no wear at all on the PP side which is in contact with the kevlar side of the clutch disc. The flywheel did show some wear which is to be expected with the carbon/metal compound on the other side of the clutch disc. Not sure which side was slipping. Probably the PP / kevlar side. Supposedly kevlar loses some of its grabbing ability once it overheats and starts to slip but I did not notice it getting worse after repeated slipping on the road race courses around here. I kept driving that bitch lap after lap and expected the kevlar to be toasted but it does not look in bad shape at all. Kevlar / PP side ![]() Carbon metal / FW side ![]() Spec 3+ besides EM. I am having a little bit of issues with the Spec 3+. When actuating the clutch pedal it won't completely disengage the pressure plate so the synchros grind a lil and the gear are sometimes hard to pop out. If you rev match its not so bad but it's still annoying. Everything on the MS3 is self adjusting including the pressure plate and master cylinder so there is really nothing you can do except wait till the clutch disc wears out a lil. The spec pressure plate is Luk OEM but painted in blue. So is the clutch disc except for the surface material of course. Only difference to OEM was the throw out bearing. It was a lil different. Could be the throw out bearing was a little shorter in height and that's why the pressure plate won't lift all the way. Don't know. Called Spec and they also said there is nothing you can do except to wait till the disc wears out a lil bit. That's just shit. Clutch is pretty grabby but not much more than the EM and so far it does not shudder. ![]() Some marks of the kevlar on the PP. Probably from when it overheated. But otherwise the pressure plate looks like new. There is almost zero wear on the metal. ![]() DIY flywheel resurfacing FTW ![]() ![]() ![]() This time around I decided to drop the engine cradle. Makes stabing the gear box back into the engine much easier and I got to clean and re-lube the bushings on the Hotchkiss front sway bar. Would have been better to replace them but I did not think of buying new ones earlier. ![]() Zip tied steering rack to down pipe ![]() Naughty dirty lil bell housing. ![]() Pilot bearing removal, This tool worked great. ![]() Original rear main seal. Hard to tell if there was a leak somewhere. If there was, it was not on the seal itself but on the lower part that seals to the block with sealing compound. The oil around it could have been slung by the transmission oil on the clutch and flywheel but I think its more likely it was just leaking. ![]() New rear main seal with shit loads of high heat sealing compound. ![]() Needles to say I am fucking pulp. Doing this alone took me about 14 hours this week end.
| The Following 5 Users Say Thank You to Tomas For This Useful Post: | Code Monkey (08-13-2012), EdgeAutosport.com (08-16-2012), jracer (08-14-2012), Nliiitend1 (08-16-2012), Realgib3 (08-13-2012) |
![]() | | #40 | ![]() |
Rep Power: 6755 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,368
Did you catch the part number on the spec supplied tob? If they used the oem pp I am curious why they changed the tob.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant |
| SPEC Stage 3 clutch slipping? | Thestaplegunkid | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 12-22-2009 01:30 PM |
| Stage 3+ Spec Clutch | Nitr0EngiE | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 11-03-2009 07:40 PM |
| 4 or 6 puck stage 3 clutch ? | occschemguy | MazdaSpeed 6 - Engine, Transmission & Driveline | 17 | 02-16-2009 05:18 PM |
