![]() | | #41 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
__________________ ![]() |
![]() | | #42 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score Weird, I am really curious now
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
![]() | | #43 | ![]() |
![]() Join Date: Mar 2010 Location: BOCA RATON FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 524
Groaned at 60 Times in 18 Posts
| Not Ranked : 0 score @Tomas Update? It's been about a month so maybe you have a few miles on the new Spec 3+. Is the disengagement getting better now that the disk material is wearing in/down? Would a oem TOB be the way to go or is the facing material too thick and it just needs to thin down a bit?
__________________ 2018 Audi S6 Prestige. APR Tuned 575 AWHP (current) 2017 Audi A4 APR tuned 315 AWHP (sold) 2014 IS350 (sold) 2013 MS3 Stage2 E85 (sold) 2011 MS3 Stage2 (sold) |
![]() | | #44 | ![]() |
![]() Join Date: Nov 2010 Location: Moscow, Russia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Groaned at 23 Times in 2 Posts
| Not Ranked : 0 score Sorry for being offtopic, but I can see that Tech/Sales@EM is banned.. What happened..?
__________________ Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc.. Last edited by paveltol; 09-16-2012 at 10:08 PM. |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes, the disengagement is better now after a little wear on the disc. Only minor synchro grinding if you don't shift from 1st to second the right way. All other gears work fine. Clutch is pretty grabby though. There is really only about 1/2" of travel from no engagement to complete engagement. You get used to it but sloppy gear changes won't do here. It also does stutter on take off if you are in the wrong rpm band but not more than the disc with kevlar / ferramic I was running before. Can't say if an OEM throwout bearing would have prevented it. Would be nice if the next person getting a spec 3+ were to measure the spec bearing and compare it to stock.
| The Following User Says Thank You to Tomas For This Useful Post: | warlord (09-16-2012) |
| SPEC Stage 3 clutch slipping? | Thestaplegunkid | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 12-22-2009 02:30 PM |
| Stage 3+ Spec Clutch | Nitr0EngiE | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 11-03-2009 08:40 PM |
| 4 or 6 puck stage 3 clutch ? | occschemguy | MazdaSpeed 6 - Engine, Transmission & Driveline | 17 | 02-16-2009 06:18 PM |
