 Old 06-07-2009, 04:30 PM   #1
Jessed87's Avatar
Posts: 149   (View Stats)
Jessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to behold
Default engine build with stock compression
Hey guys, just looking to see who out there has done an engine rebuild with the stock 9.5:1 compression ratio, and what kind of power are you making? I want to do a full rebuild and turbo swap but the 8000 bucks for everything at once is on the pricey side, so id like to just do pistons rods and bearings right now and wait a while and then do the turbo, standback, FMIC, etc. This would require stock compression for the reason that I cant run the stock turbo without a tune or with the AP with lower than stock compression (as far as I know.) Feel free to chime in with info or ideas and what not.
Edit: Also just to make sure, with new pistons and rods (with stock compression), bearings and a cosmic head gasket, it will be okay to run a stock or cobb map right? I see no reason why it wouldnt work. Just until I save some more cash for the turbo setup. thanks!
Jessed87 is offline   Reply With Quote
 Old 06-07-2009, 06:06 PM   #2
quickspeed6's Avatar
Posts: 202   (View Stats)
quickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant future
8000 might be a little much for just a engine build unless you are doing some head work. Then i will get up to that much. Also most ARE just doing the rods and pistons..... We have the highest hp to date with 385 on our mustang dyno with 9.5:1 pistons in the car with 23 psi..
quickspeed6 is offline   Reply With Quote
 Old 06-07-2009, 06:51 PM   #3
Jessed87's Avatar
thank you for the response, exciting to know that much power can be made with stock compression. Anyone else feel free to chime in!
 Old 06-07-2009, 07:26 PM   #4
martyxattack's Avatar
Posts: 924   (View Stats)
martyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the world
Groaned at 37 Times in 27 Posts
know your roll
martyxattack is offline   Reply With Quote
 Old 06-08-2009, 11:35 PM   #5
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
Groaned at 7 Times in 6 Posts
I was told its best to stick with the stock compression unless you are going to do head work.My new motor is running 9.5:1 with no head work done at this time.I am running a re-built PG turbo for alittle more flow.
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
 Old 06-09-2009, 05:31 PM   #6
ms3boost's Avatar
Posts: 400   (View Stats)
ms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to behold
have you got your build motor in?
2008 TR MS3 Sport[/B]:Cobb Sri,AP/Corksport Dp/Vibrant Dp Back/Pg HF CDFP/SU Boost Tubes/TRZ Poly MM/TWM STS, Shifter bushings/DashHawk/Turbosmart DualPort BOV/15,35% Tints/AutoExe Shift Knob/ Redline Shifter,E-brake Boot
Future Mods[/B]auter Rods/CP pistons/PTP SST K04/PG Tubular Manifold EWG/Turbo XS Dp/Cobb TIP/HKS Plugs/Perrin OCC/Devils Own WM Injection/BC Racing Coilovers/Hotchkis H&R Sway Bars/Rotora F&R slotted Rotors/EBC Red stuff Pads/Goodridge Stainless Brake Lines/ACT Street clutch and flywheel/Cobb FMIC/Tial 38mm v-band and screamer pipe/SU Side Mounts/8000k HIDs/PTP BS delete,WT/rx8 wheels/samco silicone hoses/235-40-18 Falken Azenis RT-615/P&L Motorsports ATP or ATR tune we will see though although 350whp is the goal!
ms3boost is offline   Reply With Quote
 Old 06-10-2009, 12:20 AM   #7
SharkDiver's Avatar
Not yet..It should be all done and installed by the end of this month.
 Old 06-10-2009, 08:25 AM   #8
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
this guy is running lower compression with stock ecu. his mods on in the description of the video.
I dont know the status on the car.
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 06-12-2009, 11:55 PM   #9
Jessed87's Avatar
cool, I'm excited now. I'm already saving good money so we will see where it takes me! I think I will go with a GT3076R after the build because I don't think I'll be able to reach the limits of that turbo, nevermind the 35R. random thought.
Safe Horsepower on stock engine build? cl45music MazdaSpeed 3 - Engine, Transmission & Driveline 36 02-17-2009 07:27 AM
-+- Some accoutrements to an engine build -+- socks MazdaSpeed 3 - Engine, Transmission & Driveline 14 11-12-2008 07:18 PM
the proper way to build a ms3 engine? blackmsp3 487 MazdaSpeed 3 - Engine, Transmission & Driveline 11 10-19-2008 10:56 AM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.30981 seconds with 25 queries
