 Old 05-09-2011, 10:27 AM   #1
viper1b2's Avatar
Posts: 7   (View Stats)
viper1b2 has a little shameless behaviour in the past
Default Engine specs
I just installed my ap stage 1+ 93, and im wondering what all my #s should be at and how can i tell if there all right like vac,afr,temps,everying? lol is there a thread where it can tell you where everything should be at? would really appreciate it
viper1b2 is offline   Reply With Quote
 Old 05-09-2011, 11:10 AM   #2
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
VIP=$10.
 Old 05-09-2011, 11:11 AM   #3
magicka's Avatar
Posts: 520   (View Stats)
magicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the world
Here, here and here.
2009 CWP MS3 GT
Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes
TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP
PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot
BNR S3 | Stratified Boost Dial
magicka is offline   Reply With Quote
 Old 05-09-2011, 03:58 PM   #4
viper1b2's Avatar
u tell me then ill donate and whats vip due differently?
The Following User Says NO Thank You to viper1b2 For This Un-useful Post:
Post pwned (05-09-2011)
 Old 05-09-2011, 04:12 PM   #5
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,157   (View Stats)
Groans: 792
For one, you'll avoid posts like the previous.
And I think the search function gets enabled.
"Exclusivity" - CP-enis
Demodded.
The Seals
Vader (05-09-2011)
 Old 05-09-2011, 06:07 PM   #6
Vader's Avatar
Posts: 1,651   (View Stats)
Groans: 45
Pure win Tokay
Vader is offline   Reply With Quote
 Old 05-09-2011, 06:14 PM   #7
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
From here
2,260 cc 2.3 liters in-line 4 front engine with 87.5 mm bore, 94.0 mm stroke, 9.5 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder L3T
MS3,MZ3, MZ5 Engine Mount Torq Specs Grumpyjap MazdaSpeed 3 - Engine, Transmission & Driveline 0 04-05-2011 02:47 PM
Paris Preview: More Kia Soul images, engine specs Haltech Automotive News 0 09-02-2008 01:00 PM
Car Specs kosh Website Help/Feedback 2 03-11-2008 01:11 PM
Page generated in 0.27966 seconds with 25 queries
