  • 1 Post By thrisnospork
 Old 03-06-2017, 01:57 PM   #1
brucesushi's Avatar
Posts: 3   (View Stats)
brucesushi is an unknown quantity at this point
Default Engine ticking noise when warm. Vvt solenoide?
https://youtu.be/SHIdRRQMrmE
So i made this quick video to show you guys what i mean, the car has 40k miles on it, and at the 10sec mark you can hear a second tick over the regular tick.
Could this caused by the vvt solenoid? If so what is the price of this fix. If it is the solenoid ofcourse. Maybe other tips or tricks?
Thanks in advance
Sent from my A0001 using Tapatalk
brucesushi is offline   Reply With Quote
 Old 03-07-2017, 04:21 PM   #2
thrisnospork's Avatar
Posts: 250   (View Stats)
thrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond repute
I'm no expert but that's what my car sounds like too. Our injectors and high pressure fuel pump are both noisy. If you're concerned about the VVT assembly you can check your chain after warming up the car by removing your oil cap and sticking your finger down the hole (giggity). Feel for the timing chain, if there is any slack it's likely your VVT actuator is failing. At that point you may want to remove the valve cover and check for scoring right where the chain is. If there are groves get that shit repaired asap. Also if cylinder 1 (I believe, not sure though just search for it) is at TDC then the chain will seem tight even if it is loose so probably check it a couple times to be sure.
Sent from my STV100-1 using Tapatalk
brucesushi likes this.
thrisnospork is offline   Reply With Quote
 Old 03-10-2017, 11:25 AM   #3
brucesushi's Avatar
Thanks for your answer, ill try it out,
So if this is the case if the vvt actuator is done for, is it only replacing the actuator or you advice doing the whole chain
 Old 03-10-2017, 11:30 AM   #4
You'll want to replace the chain as well as the friction washers and probably some other small parts I'm not thinking of. If your ride has 40k on it it should all be covered by mazda under a TSB if your car falls within the right range of years so check with your local dealer. Mine was going to charge me for diagnostics and a new valve cover gasket but since my vvt actuator failed their test it was all covered.
 Old 03-10-2017, 11:56 AM   #5
brucesushi's Avatar
I dont think i have that warranty, because my speed is imported from the usa and i live in the netherlands. But im gonna give mazda a call next week to check if the car is still covered. I hope so!
 Old 03-19-2017, 03:29 PM   #6
pixelNate's Avatar
Posts: 619   (View Stats)
pixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the world
Mine just started doing the same bullshit at 117k. FML
2008 Cosmic Blue Mica
pixelNate is offline   Reply With Quote
 Old 03-19-2017, 04:40 PM   #7
djern's Avatar
Posts: 1,120   (View Stats)
djern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the world
Normal, drive your car.... these cars make a whole bunch of odd little ticks and whines, only time your VVT will truly make a noise is on cold startup
06 VRM Speed 6 W/Navi
05 Mazda Family Truckster
FREEKTUNED\\Cobb AP\\Autotech Internals\\Eibach Pro Springs\\Sure SRI+TIP\\Street Unit TP\\CPE RMM\AWR 88 Duro TMM\\Forge V1\\JBR Shortcut\\JBR SSB\\CPE & Sure Rear Diff Mounts\\Unicorn Blood (Rotella T6)
twitter.com/djern
instagram.com/djern
facebook.com/djern
djern is offline   Reply With Quote
 Old 03-19-2017, 04:43 PM   #8
wastedrainbow's Avatar
Posts: 4   (View Stats)
wastedrainbow is an unknown quantity at this point
Get a vvt kit cost about 330 UK pounds and any good garage should be able to fit properly... The kit contains everything that needs replacing including actuator.. Chain...sprocket etc had mine done a few months back... Mine was making same noise and when I removed oil cap after a run the chain was loose as fooook with about an inch off movement up n down... Now it's not making any noise and after a run is still tight with no ticking noise.... Get it done or it'll be zoom zoom boom
Sent from my E6653 using Tapatalk
wastedrainbow is offline   Reply With Quote
Ticking noise skiptowncat MazdaSpeed 3/6 - Troubleshoot/Diagnostics 62 08-22-2017 06:49 AM
Ticking Noise MythicxGun MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 08-04-2016 08:44 PM
Strange noise at the warm engine start piterus MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 08-31-2015 04:08 AM
Ticking noise RWDAddict MazdaSpeed 6 - Engine, Transmission & Driveline 18 03-10-2013 08:18 PM
Ticking noise 07CX-7KID CX-7 > Issues & Troubleshooting 14 08-14-2011 12:23 PM
Page generated in 0.29317 seconds with 24 queries
