-   -   evac (http://www.mazdaspeedforums.org/forum/f10/evac-27045/)
rodrigo 05-03-2009 11:09 AM
evac
JEGS Crankcase Evacuation Kit - JEGS (done at the DP of course)
I have used this product on 3 of my muscle cars (yes daily drivers and dedicated strip cars as well)
anyone consider trying this for our purposes?
aaronc7 05-03-2009 04:01 PM
wtf is it and does it do exactly? looks interesting
rodrigo 05-03-2009 04:13 PM
it uses the exhaust gas speed to pull a vacuum from a metal tube that is angled (and welded into) into the DP (acuatlly header collector on muscle cars) a hose is attached from the tube to the crankcase....breather on valve cover, pcv valve..whatever........and it basically sucks the air out of your crankcase.....it could perhaps also suck oil out if put in the wrong location especially too close to where oil pools up....but thats easily fixed with the right location and a baffling chamber that will allow air to climb up but not the oil.
I honestly think this is more effective than anything I have seen yet and its wasted free energy that we just dump out the tailpipe.
Addikted To Boost 05-03-2009 06:17 PM
this seems like a good idea we just need somebody to test it out...
rodrigo 05-03-2009 06:21 PM
its been used for decades guys. its not like its a newsflash. its proven to work
boosted3 05-03-2009 07:22 PM
good fucking idea..someone needs to try this
martyxattack 05-03-2009 08:04 PM
i am really loving this avatar one up contest we got going on
cpolly69 07-15-2009 06:01 PM
i've heard this is a bad idea on turbo cars because the surges in exhaust gas pressure can pull oil out
wassup61 07-18-2009 10:37 AM
This is a true statement. You don't make enough vac with a turbo car in boost, and with the way the exhaust pulses flow with a turbo, you are more apt to pressurize the crankcase in boost. I was looking into this, and found that this method on a turbo car barely made enough vac (.2inHg) to register, and sometimes pressurized up to 2psi.
Jeff at PG
cpolly69 07-18-2009 05:46 PM
thanks - i was asking about this in the other thread too b/c i'm doing a rebuilt k04 and not gonna put it on until i have a real solution to the pcv issue
06Speed6 07-19-2009 01:44 AM
Jeff at PG
Thats because some dumbass welded the tube in before the cat, you have to weld it in after the cat.
jmhinkle 07-19-2009 01:47 AM
how does that work on catless cars exactly?
cpolly69 07-19-2009 09:12 AM
decreasing the backpressure (no cats) is what has exposed the pcv messing up the oil flow through the turbo in the first place - if you run a cat you don't even have this issue as much - this whole solution is for someone who doesn't want cats
Wenis Prinkle 08-01-2009 01:28 AM
sounds like a bad idea on our cars sense they loose so much air, oil and fuel pass the rings causeing alot of blowby crap to recirc into our intakes. by sucking that blowby air with oil and gas in it into the exhaust system your losing quite abit of air that was metered by the mafs, just like having a leak in your intake system. if that crankcase air is not recirculated back into the intake after the mafs your car might run funny and throw engine lights, plus all the oil and gas pumping into your exhaust will cause smoke and a an awful smell from the back of your car. this trick is only good for older cars with no mafs or turbos. using a nice oil catch can set up wold be the best way to stop oil,fuel and crap from getting inside your motor plus your still recirculating the cleaner filtered air so that your mafs and ecu wont freak out. hope this helps.
cpolly69 08-01-2009 06:26 AM
lots of people run catch cans (some folks even 2) and vent their crankcase (including me) and it doesn't solve the problem - hopefully Mazda's solution will be a better one
spnkr21 01-15-2011 11:44 AM
Wow this was a lOng time ago.
I've been running a Venturi pipe for almost 10k now and seems to work well. No cats on my car and I do have a cc hooked up.
06Speed6 01-15-2011 11:51 AM
Pics or it doesnt exist
spnkr21 01-15-2011 11:52 AM
Haha I've already posted pics of it. My build thread has it or my bt three thread. I'll put some news ones up for you guys.
spnkr21 01-15-2011 03:19 PM
3 Attachment(s)
The catch can inlet is connected to the pcv. I have the catch can outlet Y'ed off. One goes to the IM with a moroso check valve. The other goes to the venturi pipe with check valve.
SilverDemon 01-15-2011 03:23 PM
For some reason I remember someone on here doing quite a bit of testing with this.......hmmmmm....... HAHAHAHA!!
spnkr21 01-15-2011 03:34 PM
:) wonder who I got this from..
hmmmmmmmm
turd burglar 01-15-2011 03:44 PM
^so is that effective at keepin oil outta your intake mani? i'm runnin 2 catch cans and still haz gunky valves
SilverDemon 01-15-2011 04:11 PM
Yes, but only when 2 check valves are used, one on the intake manifold, and of course one on the exhaust venturi....
spnkr21 01-15-2011 04:32 PM
Haven't had my mani off in awhile so don't know about gunk. We will see soon I guess.
Page generated in 0.18387 seconds with 11 queries
