-   -   Failed transmission mount? (http://www.mazdaspeedforums.org/forum/f10/failed-transmission-mount-79402/)
staccato 05-01-2011 07:10 AM
Ok I've been having issues of torque steer even under light throttle lately. Tried absolutely everything from new lower arm bushes, tyres, alignment etc etc - everything. CP-e rear motor mount looks fine still. My mount above the transmission seems like it's failed. The front of the rubber boot has split and if you put your fingers underneath the mount you can move the rubber bush all over the place, almost pull it half out of the mount. When I rev the car stationary there looks to be loads of movement on that side of the motor too.
So I'm guessing the bush shouldn't move around like that?
Monotonous ONE 05-01-2011 07:15 AM
TRZ Drivers Side Transmission Mount - Revolution Performance Motorsports!
this is a known issue
with as much power as your car makes you should have gotten side mounts awhile go
staccato 05-01-2011 07:19 AM
Many thanks. CP-E did tell me this. My car drives in a straight line with the engine under no load, but as soon as even 5% gas is applied it begins steering left, then let off the gas and it 'wobbles' back to centre again.
Are the streetunit ones ok? Quite good price for both mounts.
Also, is there a 'how to' guide for replacement?
Monotonous ONE 05-01-2011 07:35 AM
I dont have any experience with side mounts...i can only say that certain ones are typically better than others...most are good
just dont buy anything from "Minerva Motorwerks"
personally...im waiting on side mounts from @jbarone...he says they will be released hopefully around late summer/early fall
but with your power levels...you should atleast swap that tranny mount...i provided you a link to the cheapest...and strongest one...but it also vibes and whines the most out of any of them
the TRZ could hold you over until SURE and JBarone release their side mounts.
CP-E side mounts are a hell of a lot cheaper at therpmstore.com also
and a how-to?? yes there are how-to's...but you can search for those...heres a hint...gen1 mazdaspeed > how to > mazdaspeed3 tutorial database
staccato 05-01-2011 07:40 AM
Excellent thanks very much
staccato 05-06-2011 05:04 AM
Ok trz have their transmission mounts on a 3 week delay, can't get hold of protege and street unit don't make theirs anymore.
Last nite I strengthened my tmm with chemical metal and the engine now hardly moves when revving stationary, but my car still pulls to the left. Its like torque steer but even off boost.
Put foot on clutch and it runs straight. The car pulls hard to the left under boost, but then wobbles back centre when you let off the gas.
Had tyres replaced, lower suspension arms etc all done. Do you think my cp-e rmm might be failing by running 330bhp with no side mounts??
Really need help guys....
Monotonous ONE 05-06-2011 05:49 AM
take out the rmm and take a look at it
there have been some others who put a lot of miles on them and they end up looking shredded
but i cant imagine why it would pull to one side or the other
take the rmm out and take pics of it so we can see
id go ahead and order a JBarone dogbone rear motor mount...the stiffer one...then send in the CPE for bushing replacement...then sell that fucker for more than what the JBarone cost
staccato 05-06-2011 12:20 PM
Ok rmm off. It's mint still.
But......
Swapped rear right wheel and front right wheel over and it's now pulling to the right not left.
The rear right wheel had a new tyre on it as I thought that wheel was the issue when I investigated last month but the new tyre didn't fix it. So a warped or distorted wheel maybe?
kpuser1 05-08-2011 08:42 AM
But......
Or you need 4 new tires not just one and then get an alignment...or at least get the wheels and tires balanced...
Tomas 05-08-2011 09:49 AM
due to the OEM rear neg camber your rear tires get worn on the inside more than the outside on daily driving. Not so much in the front. You need to rotate them every 3-5K.
If you put the rear wheel on a flat surface I would guess it falls inward.
RayRay 05-09-2011 10:57 PM
I ordered my TMM from the RPM store and was delivered within 3 days. Install was cake, took about 20 - 30 Minutes. Doesn't sound like that is your problem, but it is definitely a worthwhile purchase. +1 on the vibes and whine. It feels like a tank. But it's manageable.
staccato 07-29-2011 03:40 PM
Quick update - pair of brand new tyres on the front and it stopped. My fronts were only 50% worn but one or both must have had some kind of defect.
cabrone 08-06-2011 02:51 PM
I was going to say "check the PSI". One larger tire will do this. Glad you fixed it though
amc5 09-15-2011 02:13 PM
sounds like an issue im having. If i let off gas, the car sways just a little to right every time. Possible transmission mount or engine mount perhaps?
Raider 09-15-2011 02:15 PM
Take the battery out, remove tray, Post pics.
Page generated in 0.18069 seconds with 11 queries
