-   -   Fkin motor blew! (stock '07) (http://www.mazdaspeedforums.org/forum/f10/fkin-motor-blew-stock-07-a-52385/)
mike8748 05-17-2010 02:21 PM
Originally Posted by Mazdaspeedgirl (Post 521650)
I posted it in the main thread about engines blowing, but this new motor did the same thing. Valve head sheared off in Cyl2. Another engine gone. This happened Wednesday May 12th. The motor had about 3100 miles on it.
WTF again?
mrFanel 05-17-2010 02:25 PM
Wowza... that is mind blowing....
pun not intended
knarfies 05-17-2010 02:26 PM
ya according to univ mazda in abq, they havent had any blown ms3 engines.
not to be an ass but the cai is prob all im doing. Dont want my baby blowing a load!
MGM_GT3 05-17-2010 06:53 PM
damn.. Sorry to hear...
skeeter149 05-17-2010 06:58 PM
speedgirl just curious what was the break in procedure you did?
snailD 05-17-2010 07:02 PM
what the hell are you doing to this car!?
mattizle14 05-23-2010 02:08 AM
oh btw i think i got u beat mazdaspeedgirl...havent been on in a few but i got the pics of my engine...
cyl 2
http://sphotos.ak.fbcdn.net/hphotos-..._1747612_n.jpg
cyl 3
http://hphotos-snc3.fbcdn.net/hs414...._3771482_n.jpg
cyl 2 wall...burned 1/4in hole in side
http://hphotos-snc3.fbcdn.net/hs434...._2930229_n.jpg
spark plugs 1-4
http://hphotos-snc3.fbcdn.net/hs235....4_887992_n.jpg
HLR Element 05-23-2010 08:00 AM
wtf? you flooring the car at 2k rpm?
mattizle14 05-23-2010 10:50 AM
Stock fuel pump...nough said
ms3077 05-23-2010 04:44 PM
So your fuel pump was operating correctly?
ms3077 05-23-2010 04:58 PM
I think there are two possible reasons for why some motors blow here.
A. Driver ignorance / lack of attention – 1. Not letting the car warm up/ cool down properly. People are just jumping in the car and taking off after the cars been sitting for several hours. Some aren’t letting the car idle long enough before shutting down after long drives / hard drives. 2. Too much load on engine caused by too much throttle in lower revs. Some folks are too lazy to down shift.
B. Some motors are actually defective.
felt 05-23-2010 05:25 PM
A stock fuel pump isn't going to cause your motor to blow dude. Were you on AP tune?
FreeFlyFreak 05-23-2010 06:03 PM
Oh I beg to differ.
With an aggressive tune and/or mods, the fuel pump cannot keep up and car knocks like a MF on cali 91 octane.
I have only a SRI and the AP.
With an aggressive ATR tune and cool weather, I can lose fuel pressure and begin to knock like crazy on the stock pump
knarfies 05-23-2010 11:00 PM
ya thats why im staying away from the ap since i have no clue how to tune it correctly.
or ill have dj tune it for me lol
mattizle14 05-24-2010 12:01 AM
it was a mixture of both...the fuel pump...tested it in a wot condition and was only producing max 1134psi...couldnt keep up and also i had defective injectors
kwsmithphoto 05-24-2010 12:29 AM
There go I, but for the grace of God.
As others have pointed out, you obviously have an issue with a part they didn't replace, and your timing jumped again. You might want to point that out since the failures were identical, busted valves/stock motor. You didn't toss a con rod through the block like most people do.
Good luck, bummer for the hassle (they gave you loaner car, yes?), and good luck with the new, new motor. It's all on the dealer now, they obviously missed a critical thing.
JefeSpeed 05-24-2010 02:01 AM
Why doesn't someone make a factory injector replacement. I hear a lot about bad injectors on this car. Really though, bad injectors? Why is that a weak point. I wonder if this has to do with ford meddling lol.
smakdown61 05-24-2010 05:21 AM
DISI injectors are expensive to make, and it makes it worse when its a motor with low production numbers like we have. When they switch the regular mz3 over to DISI like they were supposed to do last year, I bet you'll see them.
knarfies 05-24-2010 09:25 AM
WOW!!!
skeeter149 05-24-2010 10:24 AM
thats a whole lot of fail riker and picard just had to sit and witness.
Ploppity Drown 05-26-2010 01:03 PM
Sorry to hear about your bad luck. Hopefully the dealership makes it right again---for good this time...
Page generated in 0.19164 seconds with 11 queries
