![]() | | #121 | ![]() |
![]() Join Date: Oct 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score A happy ending....and a new beginning ! Give it a few miles and double check the little stuff.Ken |
![]() | | #122 | ![]() |
![]() Join Date: Feb 2010 Location: San Antonio TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
Groaned at 6 Times in 3 Posts
__________________ Diane SASCA Autocross Novice Coordinator Mazdaspeedgirl: here's my latest pic: http://randompicturesblog.com/wp-content/uploads/2008/11/randompicturesblogcom-321.jpg senor blanco ms3: BITCH YOU BETTER SHARE THAT CAKE | |
![]() | | #123 | ![]() |
![]() Join Date: Jan 2009 Location: Venice, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 135
Groaned at 41 Times in 9 Posts
| Not Ranked : 0 score That was quick, I've heard of engine warranties taking more than a month to resolve. Congrats!
Still, it doesn't make sense - if a valve bends you generally know it right away, right? I missed a shift and had a minor over-rev once (just past redline on the tach before I caught it), but that was a long time ago, and the engine never skipped a beat. Smooth idle, no unusual oil burn. If some valves floated and got bent by a piston, seems like they should have failed immediately or shortly thereafter, not months or years later. If not, at best, I would think the engine would run pretty raggedly, if it still ran at all, after a valve strike. FWIW, I still think Lex is right about it being a valve timing failure of some kind. Like the timing chain snapping. From the way you described the failure mode, I'm guessing that's probably what happened. I'm not saying YOU broke the chain, but it was ready to let loose at some point and you just happened to be driving the car when it did. Anyway, no matter to you of course, and again, congrats on getting it resolved with too much diificulty! | |
| The Following User Says Thank You to kwsmithphoto For This Useful Post: | Mazdaspeedgirl (04-08-2010) |
![]() | | #124 | ![]() |
[quote=kwsmithphoto;479846]Did they know that from the ECU, or just assume that based on damage?[/quote\ As far as I know the ECU doesn't datalog anything. I am sure it was assumption.
I am going to the dealer today and will see if I can talk to the tech to get more information about the dissassembly.
__________________ Diane SASCA Autocross Novice Coordinator Mazdaspeedgirl: here's my latest pic: http://randompicturesblog.com/wp-content/uploads/2008/11/randompicturesblogcom-321.jpg senor blanco ms3: BITCH YOU BETTER SHARE THAT CAKE | |||||
![]() | | #125 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Winter springs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,251
Groans: 974
Groaned at 738 Times in 373 Posts
| Not Ranked : 0 score I know I've red-lined plenty of times when power shifting when I had the AP hooked up. Motor runs just fine. |
![]() | | #126 | ![]() |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
| Not Ranked : 0 score [QUOTE=Mazdaspeedgirl;480019]......[quote=kwsmithphoto;479846]Did they know that from the ECU, or just assume that based on damage?............. As far as I know the ECU doesn't datalog anything. I am sure it was assumption....../QUOTE] Whereas it seems true that the ECU itself doesn't datalog into some hidden file, there IS a "special" file/mode accessed by the dealer's IDS that logs the OEM calibration number that can only be "inserted" by the OEM flash. The way I understand it, when we (re)flash with ANY device it overwrites that number and it can't be recovered unless flashed by the dealer IDS. If the dealer doesn't see one of the OEM numbers in this file, it is valid grounds for drivetrain/emissions warranty denial, if they so choose.
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy |
![]() | | #127 | ![]() |
On modern road cars, you can usually get away with a bit of that if you're quick and paying attention. You might throw an accessory belt or fucup a timing chain/belt etc., but on a vintage car I'm gonna race this summer, with it's vintage Lotus motor and Hewland crashbox, everything blows, and the cost is $18K! Assuming you don't crash, which just adds to the cost. Like a lot. | |
![]() | | #128 | ![]() |
I was preparing the "dogs" for rebuttal if the claim had been denied.
![]() | | #129 | ![]() |
| Not Ranked : 0 score ^ You know, the BP loves a turbo as long as you keep things under 250whp ![]() Looking forward to what the service manager has to say |
![]() | | #130 | ![]() |
The BP was made for the turbo awd 323 GTXs back in the day. That's why the little boogers can go for 200+k N/A tuned at low output like in the MX-5's case
![]() | | #131 | ![]() |
| Not Ranked : 0 score Having owned several BPs - one of which I fully built - I love the simple little engines. Nowhere near as refined as modern motors but they got the job done and are lots of fun. |
![]() | | #132 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's all I need <3
| The Following User Says Thank You to Mazdaspeedgirl For This Useful Post: | Lex (04-13-2010) |
![]() | | #133 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] | |
![]() | | #134 | ![]() |
![]() | | #135 | ![]() |
FWIW, if I could afford a dedicated track car, and all that implies (like a tow vehicle and trailer), my tow queen would not be a Mazdaspeed3, it would be something much different...and probably not a Mazda. BTW, the Fuelly figure in my sig is currently inflated because I've been driving a lot of unclogged freeways here lately, which is rare for me. My pure city mpg, just keeping up with everything from crossovers to Pious's is pretty awful, often below 15mpg. If I included track time into that, I'd be in the low 10's. Economy car? LOL, if I wanted one of those, I'd have bought a Yaris or a Fit! | |
![]() | | #136 | ![]() |
![]() Join Date: Feb 2010 Location: York, Pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,685
Groans: 50
__________________ 2012 CWP Tech Package: Powdercoated Rx-8 Wheels//35% Tint//Cobb SRI//COBB TIP//CS LED Kit//UR Test Pipe//Autotech Internals//TRZ RMM//Painted Front Grille//Painted Emblems// | |
![]() | | #137 | ![]() |
![]() | | #138 | ![]() |
![]() Join Date: Jan 2009 Location: Northern California
Rep Power: 0 ![]() ![]() Thanks: 44
| Not Ranked : 0 score Great, I'm very happy for you. That is the way it should be handled. Just as you said it makes for loyal customers. |
![]() | | #139 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sarcastic rhetorical overstatement gone awry.
![]() | | #140 | ![]() |
| Not Ranked : 0 score That's a beautiful picture of you. |
![]() | | #141 | ![]() |
![]() | | #142 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to Lex For This Useful Post: | BrianZX10R (05-17-2010) |
![]() | | #143 | ![]() |
![]() Join Date: Feb 2010 Location: Peru, IN
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score this same exact thing has happened to me...but not only did it melt my piston it melted my cyl walls and also melted the o2 sensor to the first bung on the downpipe and melted the spark plugs away and valves...yeaaa...its still in show and mechanic is keeping the bad parts so i can take pictures of them...ill let u all see when i take pics of them next week
__________________ 2008.5 Mazdaspeed 3 GT...Fully Forged Block...Ported Heads...Wiseco Forged Pistons/Pauter Forged Rods...COBB SRI...COBB DP...COBB AP...PnP Fuel Pump Internals...Cometic Head Gasket...ARP Head Studs...Denso Iridium HR:8...StreetUnit Rear Motor Mount...ACT 6 Puck Sprung Clutch Kit...Aluminum Flywheel... |
![]() | | #144 | ![]() |
![]() | | #145 | ![]() |
| Not Ranked : 0 score yes mine did...cyl 2 aand 3...mazda voided my warranty because i changed my own oil and couldnt provide records...and took it to a mechanic that told them that it wasnt to do with anything with the oil...then they said well u just voided ur warranty again because u just took it to a mechanic thats not mazda authorized
| The Following User Says Thank You to mattizle14 For This Useful Post: | Lex (04-16-2010) |
![]() | | #146 | ![]() |
![]() | | #147 | ![]() |
| Not Ranked : 0 score before the engine blew only mods i had were the cai...now yea i am building my motor...everything in my stat will be in my engine including ported heads...and my mechanic which is fam friend can only think from everything he has seen to be that and he took it off to see them fucked
![]() | | #148 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'd get a lawyer and fight the BS about voiding a warranty because you didn't have receipts. fk that.
![]() | | #149 | ![]() |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
__________________ 2009 MS3 sport MGM | |
![]() | | #150 | ![]() |
| Not Ranked : 0 score Taking your car to a "not mazda authorized" mechanic absolutely does not void your warranty. That's illegal. There's also no requirement to keep oil change receipts, but if your motor melts and you don't have any, well, that less than an ideal position to be in. BTW, most shops keep records for a while to cover their own bums (and do their taxes), you might be able to retrieve receipt copies from them. |
![]() | | #151 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score mazdaspeedgirl - i saw this thread when you first posted it. haven't followed it but i'm glad to hear you got a new engine. now, what we need you to do is get some more car pics with good looking chicks wearing skimpy clothes in suggestive poses.
__________________ it's fun to do bad things |
![]() | | #152 | ![]() |
| Not Ranked : 0 score yeah its the kind of shit im goin through with my dealership...i really dont kno what to do...i got my oil and filters from autozone but they dont keep receipts they only keep warranty receipts...and thats exactly what i thought about taking it to a new mechanic...and they were like if ur transmission ever goes out it wont be warrantied because u r replacing ur engine with a new mechanic not ours...so if you leave the lot we will tag ur vehicle as not having a powertrain warranty anymore
![]() | | #153 | ![]() |
| Not Ranked : 0 score Well, just write it off as an expensive lesson, and enjoy the new build! Looks like you'll be pulling some good, reliable power if it's built and tuned right, so don't fester over losing the drivetrain warranty too much. Meanwhile, if your windshield wipers fail, at least they can't blame that on a lack of oil change receipts. FWIW, the frequency of engine pops are exactly why I buy my own oil and filters and take it to a pro shop around the corner. I staple the part receipts to the labor receipts, and file it with the rest of the car's paperwork. Intervals are logged by the shop on their receipts as is the VIN# so I can prove they were for my car. BTW, I'm perfectly capable of doing oil changes myself, but paying a pro shop $20 to do it for me gives me credibility if the motor pops (it's stock). It also saves some wear and tear on my body because I've really gotten sick of crawling under cars to do messy maintenance shit like oil changes. Over it, big time.
__________________ This car has never been raced, modified, or abused in any way. Maintained as required, only wear items have been replaced with OEM or better parts, in compliance with all warranty terms, and federal and state laws. Last edited by kwsmithphoto; 04-18-2010 at 10:57 AM. |
![]() | | #154 | ![]() |
| Not Ranked : 0 score yeah true...i just got stingy about money and i was like hey if they can do it why not me...and didnt even think about oil change records
![]() | | #155 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
I ALWAYS get a coupon from the dealer usually it is $35, this month I got one for $29.99 SCORE. By the time I buy a filter, oil, time, and drive to the store twice, once to get the oil and stuff, and the other time to recycle the oil. Plus the keeping of receipts and shit, and the possibility of a fight over warranty later. I'll pay the $30 Now installing my FSD's and brake pads, that is a whole different kettle of fish. Much cheaper to do it yourself........... unless of course you crash your car into a house in the process. :big laugh:
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 ![]() http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. | |
![]() | | #156 | ![]() |
| Not Ranked : 0 score Ya, you saved yourself a lot of money on that last brake job, didn't you. LOL My situation is a bit different - there's an Autozone not far and a perfectly competent shop just around the corner. I buy the stuff (Platinum synth and PureOne filter), drop it off at the shop, walk home and do something else for a while, then walk back when they call. I get the coupons too, but the nearest dealer is 20 miles away on one of the most crowded freeways in the country. Plus, I have to make an appt., and even then I'd just be sitting around waiting for it. Not worth the trouble. Besides, they use "x brand" oil, basically whatever they have in their bulk tanks, not the good stuff. With parts and $25 labor it works out to about $75, but $50 of that I'd have to pay for anyway if I did it myself, for the oil and filter. $25 is money well spent to keep me from a half day adventure to the dealer and burning up gas and time on the freeway. |
![]() | | #157 | ![]() |
| Not Ranked : 0 score yeah me nearest dealership is 80mi...bahahaha...not doin that lol
![]() | | #158 | ![]() |
(Thread Starter) | Not Ranked : 0 score I posted it in the main thread about engines blowing, but this new motor did the same thing. Valve head sheared off in Cyl2. Another engine gone. This happened Wednesday May 12th. The motor had about 3100 miles on it.
![]() | | #159 | ![]() |
![]() Join Date: Jan 2009 Location: Bangor PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,426
Groans: 88
Groaned at 121 Times in 75 Posts
| Not Ranked : 0 score holy shit, you blow engines like i blow loads
__________________ 1995 honda civic. 1.6L slow 2007 Kawasaki ZX10r |
| The Following 6 Users Say Thank You to BrianZX10R For This Useful Post: | 2007speed3 (05-17-2010), Blackspeed (05-17-2010), jack_hammer (05-20-2010), kgb (05-17-2010), MGM_GT3 (05-17-2010), phillyb (05-17-2010) |
![]() | | #160 | ![]() |
| Not Ranked : 0 score There's a common denominator here and it's not common amongst all MS3s .... If there was no driver error involved I'd be asking the dealer some hard questions. |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/fkin-motor-blew-stock-07-a-52385/ | ||||
| MSP3 == LOLz - Page 11 - 8th Generation Honda Civic Forum | This thread | Refback | 05-16-2010 12:14 PM | |
| My motor also blew today. | tburton101 | MazdaSpeed 3 - Engine, Transmission & Driveline | 94 | 06-11-2014 12:25 AM |
| I blew my motor | boosted3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 40 | 08-22-2009 04:59 AM |
