flywheel brake Has anyone tried to make a flywheel brake? Ive got an old 1/4" sprocket that i could chop up. |
1 Attachment(s) This thing got my flywheel unbolted. Im hopeing it will pull through for when i do the crank bolt. |
What did you use to make that? Good idea. |
Just a piece of 1/4" steel plate. In my case it was an old sprocket. Drew up the shape i saw in the manual, cut it out with an angle grinder w/ cutting wheel. Then i used a table grinder to clean up and square up the edges. Then i used a file to clean up the part that has contact with the flywheel. The picture isnt the final product. I will take a pic next time im by my car. |
1 Attachment(s) That'll work fine, just have and aggressive lip engaging the gear this worked fine for me, easy peasy making the sst for the ITFP is a bit of a bitch...... |
You tightened the crank bolt with that? |
3 Attachment(s) Flywheel brake |
| All times are GMT -7. The time now is 07:27 AM. |
