Notices
 Old 02-01-2010, 05:30 PM   #1
bnoon's Avatar
Posts: 1,762   (View Stats)
Default Ford Mustang Cobra electric PCV vacuum pump
Used to maintain vacuum in the crankcase in the Cobras from 96-98, not sure if the later SC Terminator ones used it or not. Not sure if the Lightnings or any other have these things either, but I'm thinking about trying one to see if it can get rid of or eliminate any of my other PCV mods.
Part number F6ZE-9A486-DC.
2008.5 MS3 GT - Sold!
2011 Ford Flex LTD Ecoboost
1986 Porsche 944 Turbo
bnoon is offline   Reply With Quote
The Following 3 Users Say Thank You to bnoon For This Useful Post:
Fobio (02-02-2010), FreeFlyFreak (02-01-2010), rigor (02-01-2010)
 Old 02-01-2010, 06:34 PM   #2
patrick failman
karl-hungus's Avatar
Posts: 4,646   (View Stats)
Groans: 74
The Following 6 Users Say Thank You to karl-hungus For This Useful Post:
danesti (02-02-2010), djuosnteisn (02-02-2010), FreeFlyFreak (02-01-2010), kgb (02-01-2010), NRSpeed (02-02-2010), speed23 (02-01-2010)
 Old 02-01-2010, 09:47 PM   #3
Cataphract_40's Avatar
Posts: 1,576   (View Stats)
Groans: 28
Originally Posted by pat bateman View Post
that's not mine.
2008 GT MS3
Cobb SRI - PG Turbo Inlet - M3M FMIC - Cobb Catted DP - Turbosmart BPV - Denso ITV22 plugs - KMD HPFP - Cobb AP - JBR RMM - CP-e Side Mounts - Hotchkis RSB - Moog Endlinks - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18
1995 Miata
Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - Hail Dents - Bent Suspension
 Old 02-02-2010, 04:55 AM   #4
patrick failman
Groans: 74
^^^^ sourced from volvo.
 Old 02-02-2010, 07:12 AM   #5
Driver
Fobio's Avatar
Posts: 2,476   (View Stats)
Groans: 44
I'd like to know the results if you or anyone else tries! Having read about the DI system in the new Ferrari 458, they run 3 salvage pumps...
They also have secondary fueling for WOT...a lot to think about...
-- Mario Andretti --
Fobio is online now   Reply With Quote
 Old 02-03-2010, 05:32 AM   #6
Speeeeeed
06Speed6's Avatar
Posts: 5,755   (View Stats)
If thats the Bosch part, it isnt oil friendly. The air has to be filtered first or the unit will crap out.
2006 Mazdaspeed 6
P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant
First Drive: Ford Mustang Cobra Jet, watch out for second! Haltech Automotive News 0 06-15-2009 09:50 AM
Ford Racing announces plans for 2010 Mustang Cobra Jet Haltech Automotive News 0 06-12-2009 07:30 AM
Ford Mustang Cobra Jet rumbles off the assembly line Haltech Automotive News 1 01-07-2009 12:11 PM
SEMA 2008: Ford ready to go drag racing with FR500CJ Cobra Jet Mustang Haltech Automotive News 0 11-04-2008 07:40 AM
Ford to launch Mustang Cobra Jet factory drag racer this summer Haltech Automotive News 0 06-15-2008 07:50 AM
Page generated in 0.28133 seconds with 24 queries
