Like Tree12Likes
 Old 09-10-2015, 08:23 AM   #1
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
Default Fore-Aft Clunk
So, this clunk has propagated itself and to be honest I cannot remember whether it was always there or if it just showed up after the AutoX at ENM. Regardless, it sounds pretty awful.
The main condition it happens is when I launch the vehicle in reverse. It happens every time on a flat surface, but it is much worse when the car is on a downgrade. It also seemed to occur under very heavy braking and turn in when running AutoX to the right.
It feels like something is shifting/moving and clunking hard against something. It's a very heavy clunk and occurs on the passenger side of the vehicle; feels like it comes from the area right under the feet of the passenger. @maisonvi; seems to have started to get the same type of condition, but we can't be certain it's the same thing.
It definitely seemed to be worse after I installed new TMM and PMM, but that could just be from things being more quiet or stiffening up.
I've checked:
- All suspension on that side
- Torqued down the subframe, control arm and any bolt I could get my hands on
- PMM torqued correct
- Checked play in the pass wheel while it was off the ground (6/12 grab and shake and everything)
- Replaced the half shaft/carrier bearing assembly
Only things I really have left to check/replace are:
- CV Shaft
- Front Sway Bar bushings
- Control arm/ball joint?
It should be noted that I have aftermarket bushings in the rear of my control arm similar to that of an anti-lift kit. @maisonvi; also has similar bushings in this area.
Need help. Someone must have had this happen before. Or maybe not. lol Beating my head agaisnt the wall here.
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
The Following User Says Thank You to HawkeyeGeoff For This Useful Post:
maisonvi (09-10-2015)
 Old 09-10-2015, 08:39 AM   #2
maisonvi's Avatar
Posts: 3,490   (View Stats)
maisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the world
Groans: 75
Yeah I have the same sound as well. Only happens on transfer of weight front to back, not a left to right thing, or going over pot holes or anything.
Dont know if it was before or after the autox either. 2 days before MWM I added a sub-frame brace, MD TMM and anti lift kit. So I changed a few things.
I went under there and torqued all the bolts back down; subframe, RMM, suspension. I have yet to get back up top to check my TMM. Prop shaft only has left to right play, not front to back.
Franken Turbo, built motor, meth.
DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more.
"Your signature should just say, I'm the shit." -LynzeC
maisonvi is offline   Reply With Quote
The Following User Says Thank You to maisonvi For This Useful Post:
HawkeyeGeoff (09-10-2015)
 Old 09-10-2015, 08:47 AM   #3
Interesting enough we both have all the same components that we changed, as we have discussed before.
 Old 09-10-2015, 08:52 AM   #4
SpeedRebirth's Avatar
Posts: 685   (View Stats)
SpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the world
Groans: 33
Might be the dead hooker in the trunk, sure you ditched her?
"It feels like something is shifting/moving and clunking hard against something" <--- her head
Mazdaspeed6 -06
Tuned with by Alex@Stratified
CP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP
Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation
Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit
JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2
Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025
Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp
Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter
Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
SpeedRebirth is offline   Reply With Quote
The Following User Says Thank You to SpeedRebirth For This Useful Post:
 Old 09-10-2015, 10:00 AM   #5
That would be @mole; 's MO.
 Old 09-10-2015, 12:52 PM   #6
dan7225's Avatar
Posts: 511   (View Stats)
dan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the world
axle nuts?
was a tsb looong ago for gen 1
but it was a clicking sound, not quite what you're explaining
dan7225 is offline   Reply With Quote
 Old 09-10-2015, 12:56 PM   #7
Originally Posted by dan7225 View Post
axle nuts?
I'll check the torque on it, but i doubt that's it. Thanks for the reply though.
 Old 09-12-2015, 07:51 PM   #8
drago86's Avatar
Posts: 12   (View Stats)
drago86 is a jewel in the roughdrago86 is a jewel in the roughdrago86 is a jewel in the roughdrago86 is a jewel in the rough
slight play in the RMM can cause this.
drago86 is offline   Reply With Quote
 Old 09-15-2015, 06:32 AM   #9
Thanks for the info, but this has been checked. There is no play in my motor/trans.
 Old 09-15-2015, 08:48 AM   #10
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
What is the age of your respective LCA balljoints?
Were they ever replaced when any of these other bushings/parts were replaced, or are they originals?
Also, neither of you have OEM upper strut mounts anymore, correct?
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
HawkeyeGeoff (09-15-2015)
 Old 09-15-2015, 09:05 AM   #11
This is correct. @maisonvi; is running CS upper strut mounts, and I have KSports.
I did not replace my LCA balljoints ever. I don't think Ken did either. (60k on mine mostly w/ the stiffer rear bushing, Ken just replaced his LCA rearward bushing w/ the ALK and pretty much started getting the clunks as well. Only pass. side. Ken's car has 100k+ on it).
It's very strange that it's only on the pass side. I am running OEM front LCA bushings and Ken is running Whitelines.
Thanks for the response man.
 Old 09-15-2015, 09:08 AM   #12
maisonvi's Avatar
Groans: 75
Yep, OEM 100k ball joints. ALK, and whiteline bushings.
 Old 09-15-2015, 09:11 AM   #13
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Does the clunk come and go? I've had something that sounds similar on and off for a few months. Never during breaking conditions though, just during shifting and hard on/off on the accelerator.
It did it middle of last week and I intended to look this past weekend, but the noise went away again. If it comes back soon, I'll try to make time that day to get it up on stands and check out the suggestions so far and report back.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 09-15-2015, 09:14 AM   #14
Pretty much it will happen EVERYTIME launching in reverse. It's very bad on a decline reversing up the hill. Sometimes shifting, sometimes hard braking, it's hard to reproduce it in the dynamic conditions unless I was doing some track driving; it seemed much worse at the AutoX it didn't really happen at the Autobahn because I assume smoother roads.
WetzMS3 (09-15-2015)
 Old 09-15-2015, 10:11 AM   #15
Nliiitend1's Avatar
Groans: 67
I really should have ridden in your car that day before the trackday when you were trying to figure this out...
I'm inclined to think that this is balljoint-related.
The stiffer LCA bushing coupled with the stiffer, less compliant upper strut mounting points could definitely send a not-so-great-condition balljoint over the edge during transitions whose forces would otherwise be absorbed by the more compliant OEM pieces in those locating joints.
It can be hard to really confirm using a prybar with a car up in the air too, as it is difficult to put close to the amount of force through things as would be in play when the mass of the car is stressing those joints through the suspension articulation.
That's my two cents for now.
2008 MS3 GT
2016 MX-5 Club
The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post:
HawkeyeGeoff (09-15-2015), maisonvi (09-15-2015), WetzMS3 (09-15-2015)
 Old 09-15-2015, 10:22 AM   #16
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
ALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the world
Groaned at 8 Times in 3 Posts
load the car with a screw jack in the air. Geoff, if you want you can swing by and we can check play.
IMO, start with the easy and replace the swaybar bushings. I had a standard 3 popping in the rear like that, eventhough the bushings were tight in the air.
2011 MS3 COBB AP/Hypnotic Tuned/JBR 3.5in WP/CS Wiper Delete/EBAY DP/CS RMM/CS Lowering springs/Maisonvi shift bushings and knob/OBX Catback/AT Internals/Synapse DV/ CP-E TMIC/E30
ALPINEST4RS is offline   Reply With Quote
The Following User Says Thank You to ALPINEST4RS For This Useful Post:
 Old 09-15-2015, 11:11 AM   #17
There is A LOT of movement. Like a very heavy slam almost. There is nothing else that would indicate a sway bar being bad. Unfortunately, I think I may need to rip this ball joint out. zzzzz Thanks for the advice guys.
ALPINEST4RS (09-15-2015)
 Old 09-15-2015, 11:23 AM   #18
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
Why are we launching the car in reverse to begin with?
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
The Following User Says Thank You to MazdaspeedKills For This Useful Post:
 Old 09-15-2015, 11:32 AM   #19
Because....you know you have to do that thing where you back up. Unless you just run over curbs and children and do U-Turns all the time
 Old 09-15-2015, 11:49 AM   #20
maisonvi's Avatar
Groans: 75
I think your "launching" and his "launching" are different. You have to launch the car to get it moving. You dont have to do a hard launch like you would going forward at the drag strip.
MazdaspeedKills (09-15-2015)
 Old 09-15-2015, 12:23 PM   #21
Just ordered a new lower control arm w/ ball joint and all that. We will see if this solves it; get it Thursday and that's probably when it will be installed. I'll post back with results.
Edit: Only reason I did this was because it was more time effective for me to do this. If it solves it, I'll probably replace the ball joint + front bushing and then revisit the other side when I start hearing some noise. Or just go full OE again. Whatever.
 Old 09-18-2015, 07:22 AM   #22
Lower control arm installed-ed. But, unfortunately, my Pilot had a dome light left on so I had to snag the battery from my speed to get to work a few days ago, so my speed didn't have a battery. I'll be back on Sunday to throw that sloot back in there and test it. Pray for this bullshit to be gone.
The Following 2 Users Say Thank You to HawkeyeGeoff For This Useful Post:
maisonvi (09-18-2015), Nliiitend1 (09-18-2015)
 Old 09-23-2015, 07:31 PM   #23
Okay. So update. Sorry I forgot to do this.
The pop/clunk is still there. I am getting new sway bar bushings/brackets tomorrow in the mail. I'm going to swap those out and see how it goes. This is really testing my patience.
I will report back after I install said parts. I'm just throwing money at it at this point, straight rapper style.
 Old 09-23-2015, 09:27 PM   #24
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Groans: 98
I've got clunking in the front and its my passenger side end link. Everything is tight. The piece at the top that connects to the strut just makes a tremendous racket when it flops back and forth while accelerating of breaking. It doesn't seem broken, but it makes a ton of noise. I'm going to have to pull it apart to get a proper look to make sure it hasn't broken or the length hasn't changed due to the suspension settling. It has been good for over a year so I'm at a loss now.
tapatalk, it sucks
monkey.bones.007 is offline   Reply With Quote
 Old 09-24-2015, 08:01 AM   #25
tapatalk, it sucks
Is it a popping sound? It's very strange because it sounds like it comes out of the passenger floor area. I guess I could swap an OEM endlink with my roomie and see what happens....it ALWAYS happens when I launch the vehicle in reverse. lol I am at a loss and it's super annoying.
monkey.bones.007 likes this.
 Old 09-24-2015, 12:56 PM   #26
Groans: 98
Mine is always taking off or braking at lower speeds. Never while hitting bumps.
tapatalk, it sucks
The Following User Says Thank You to monkey.bones.007 For This Useful Post:
HawkeyeGeoff (09-24-2015)
 Old 09-24-2015, 12:59 PM   #27
tapatalk, it sucks
Interesting. Mine also does not happen from bumps. @maisonvi; seems to have symptoms more in line with yours. He also has a jacked up passenger endlink. Interesting. I will try everything and report back.
 Old 09-24-2015, 01:06 PM   #28
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
What control arms did u get? Oem from edge?
Also check ur brake caliper.
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
Last edited by blackms3_71; 09-24-2015 at 01:06 PM. Reason: MSF Database - Automerged Doublepost
blackms3_71 is offline   Reply With Quote
 Old 09-24-2015, 01:21 PM   #29
Groans: 98
I've got whiteline end links, that's probably relevant info.
tapatalk, it sucks
 Old 09-24-2015, 01:44 PM   #30
tapatalk, it sucks
What in my brake caliper would be making this noise? It happens everytime...not just once in a while.
And I have some random non-greasable endlinks. They are literally just a metal ball open to atmosphere. Ken has OEM's. Interesting. The plot thickens.
Edit: I got an AC Delco control arm. It didn't help at all, so I switched back to my stocker w/ my aftermarket rear bushings.
monkey.bones.007 and ms3gt08 like this.
WetzMS3 (09-24-2015)
 Old 09-24-2015, 06:50 PM   #31
Sway bar bushings did not do the trick.
Next up: try an OEM endlink. The sound after being under there banging around the sway bar sounds like the sway bar hitting the subframe....somehow....lol but it's just a guess at this point.
 Old 09-24-2015, 07:34 PM   #32
Groans: 98
Ill see if I can get some video tomorrow of what I'm hearing and where it comes from. Maybe you'll have the same issue as I do.
tapatalk, it sucks
 Old 09-24-2015, 08:00 PM   #33
tapatalk, it sucks
I'd appreciate it man. Thanks!
 Old 09-24-2015, 08:15 PM   #34
Pads? Maybe loose bolt? Just thinking.
The Following User Says Thank You to blackms3_71 For This Useful Post:
 Old 09-24-2015, 08:17 PM   #35
Checked it, they're solid. Thanks for the advice though man.
ms3gt08 likes this.
 Old 09-25-2015, 04:53 AM   #36
maisonvi's Avatar
Groans: 75
Dude, this sucks you are still chasing this. I havent felt mine ever since I tightened up the sub frame to the tq specs. Granted I havent driven my car much the past week either.
The Following 2 Users Say Thank You to maisonvi For This Useful Post:
HawkeyeGeoff (09-25-2015), WetzMS3 (09-25-2015)
 Old 09-25-2015, 10:18 AM   #37
Honestly I think ours might be different issues now. Mine is a POP sound more than a clunk now.
 Old 09-25-2015, 11:34 AM   #38
maisonvi's Avatar
Groans: 75
Stop breaking shit. (granted I cant talk, waiting on O2 sensor)
 Old 09-25-2015, 01:37 PM   #39
WetzMS3's Avatar
Groans: 430
My clunk still has not returned, but I'm fairly certain we've got different issues anyway.
Have you considered it not being suspension related? I have assumed that mine may be my poorly hung exhaust or dumptube hitting something down in that area at some times, if not an axle related noise. It sounds like you've gone through most if not all of the suspension, it may be worth looking at other potential causes.
2013 MS3 Black Mica
HawkeyeGeoff (09-28-2015)
 Old 09-25-2015, 06:53 PM   #40
Groans: 98
https://app.box.com/s/njbc0q9qrle7qmozm9ty49kdiww7hv19
Here is video of my noise. Annoying as fuck!
tapatalk, it sucks
The Following 2 Users Say Thank You to monkey.bones.007 For This Useful Post:
HawkeyeGeoff (09-27-2015), WetzMS3 (09-25-2015)
Clunk/Pop feldm4n MazdaSpeed 3/6 - Suspension & Brakes 19 04-23-2012 01:13 PM
Report: More details on Honda's hotter CR-Z come to the fore Haltech Automotive News 0 03-21-2011 02:50 PM
clunk from right front rodrigo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 01-22-2011 04:08 AM
Fore! Volkswagen rolls out 2010 Jetta Golf wagon Haltech Automotive News 0 05-21-2009 01:50 PM
Page generated in 0.58975 seconds with 30 queries
