![]() | | #41 | ![]() |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
Groans: 98
| Not Ranked : 0 score tapatalk, it sucks |
![]() | | #42 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
I remember u recently changed the 1/2 axle support on that side bc urs was done. Have u checked the axle? Axle nut? The new support? Even wheel lugs nuts(i would think u would have vibration issues too if it was the lugs) sturts tight top nuts and bottom? Spring tension?
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned | |
![]() | | #43 | ![]() |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD Last edited by HawkeyeGeoff; 09-27-2015 at 09:28 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #44 | ![]() |
![]() Join Date: Jun 2012 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score Sorry my advice on the subframe and FSB bushings didn't help. I still have a passenger side clunk as well, but my PMM is bad so that's next to go. I'm out of town and can't do shit at the moment. I have MOOG front endlinks, the nipples that come with them don't fit and I had to go buy some 90 degree nipples. Maybe just try different endlinks.
__________________ 2009 CWP MS3 | JBR short shift plate, JBR shifter bushings, CP-e stage 2 RMM, JBR RSB, JBR Wide-Path, CS downpipe, UR catted test pipe, Cobb cat-back, Forge BPV V1, Swift Spec R springs, Bilstein B8, Whiteline KCA428 ALK, Whiteline Bumpsteer Correction, Corksport injector seals, Weds Sports SA55M 18x8 +48, Bridgestone S-04 245/40/18, BLOX Limited 490g shiftknob Dyno'ed at 277whp/290lb-ft on 91 piss |
![]() | | #45 | ![]() |
Groans: 98
tapatalk, it sucks | |
| The Following User Says Thank You to monkey.bones.007 For This Useful Post: | HawkeyeGeoff (09-28-2015) |
![]() | | #46 | ![]() |
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD | |
| The Following User Says Thank You to HawkeyeGeoff For This Useful Post: | WetzMS3 (09-28-2015) |
![]() | | #47 | ![]() |
| Not Ranked : 0 score Have you checked ur motor mounts?
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score Indeed. 2 DM side mounts and cpe stage 2 rmm. They're solid.
![]() | | #49 | ![]() |
![]() Join Date: Oct 2008 Location: Greenbackville, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,927
Groaned at 23 Times in 12 Posts
| Not Ranked : 0 score Here for a solution, and potentially any more info on the tsb mentioned earlier with "clicking" something about axel nuts? I def have clicking when initially accelerating... I've had clunking for quite awhile, but figured it was my endlinks.. so hope you find a solution to help me narrow down my search.
__________________ CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC PERM TUNED Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around 2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP |
| The Following User Says Thank You to jax ms3gt For This Useful Post: | HawkeyeGeoff (09-29-2015) |
![]() | | #50 | ![]() |
| Not Ranked : 0 score I would recheck ur stage 2 rmm. I have that and had a issue with clunking. I had to tq it to 90lbs to get it to stop. Trust me check it again
I nees to do the axle nut thing too
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned Last edited by blackms3_71; 09-29-2015 at 05:20 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #51 | ![]() |
- CV Axle (unlikely) - Endlinks - Subframe Bushings - Top hats But, it should be noted that I have no performance issues that I can tell....and I do not have hear noises going over bumps at all. So the top hats are pretty much eliminated. The endlinks have always made a ton of noise; they are by design super noisy, lots of clicking. But they are also loosey goosey open ended ball socket type deals. If you shake the FSB back and forth you get clicks from them as well as initial take offs....normal for these IMO. Regardless I will be swapping some endlinks on there when @jgarmo; hooks me up with one of his when he is finished doing his thing. Trying to save a little dough here now instead of blowing my load all the time. lol
![]() | | #52 | ![]() |
I hear u on the fsb endlinks. I have shiity sonic tuning end-links and they are noisy as fuck
| The Following User Says Thank You to blackms3_71 For This Useful Post: | HawkeyeGeoff (09-30-2015) |
![]() | | #53 | ![]() |
Groans: 98
| Not Ranked : 0 score So it was my end links. Adjusted my whiteline links to a longer length and the noise is going away. It went from all the time to some time and from passenger side to driver side. I'll pull it apart again to get it settled. Hopefully. tapatalk, it sucks |
![]() | | #54 | ![]() |
(Thread Starter) | Not Ranked : 0 score Interesting. I may just replace both with oem length then.....or maybe mine are too short? I dunno. lol I have Ksport coils and they are very short compared to the Konis/OEM style struts.
![]() | | #55 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
Groans: 67
| Not Ranked : 0 score They just need to be the right length to keep your swaybar's "arms" parallel to the ground at static ride height.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club Last edited by Nliiitend1; 10-07-2015 at 09:20 AM. Reason: typo |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | monkey.bones.007 (10-07-2015) |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score Parallel when the vehicle is jacked up or on the ground? I have adjustable (noisey mother fuckers) endlinks so I can pretty much make whatever happen.
![]() | | #57 | ![]() |
Groans: 98
| The Following 2 Users Say Thank You to monkey.bones.007 For This Useful Post: | HawkeyeGeoff (10-07-2015), Nliiitend1 (10-07-2015) |
![]() | | #58 | ![]() |
Groans: 67
![]() Sorry about the "and" when I meant to say "at."
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
| The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post: | HawkeyeGeoff (10-07-2015), monkey.bones.007 (10-07-2015) |
![]() | | #59 | ![]() |
a little slow today. Or it could be from all the clutch vapor poison i've ingested at work today.
| The Following User Says Thank You to HawkeyeGeoff For This Useful Post: | Nliiitend1 (10-07-2015) |
| Clunk/Pop | feldm4n | MazdaSpeed 3/6 - Suspension & Brakes | 19 | 04-23-2012 01:13 PM |
| Report: More details on Honda's hotter CR-Z come to the fore | Haltech | Automotive News | 0 | 03-21-2011 02:50 PM |
| clunk from right front | rodrigo | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 01-22-2011 04:08 AM |
| Fore! Volkswagen rolls out 2010 Jetta Golf wagon | Haltech | Automotive News | 0 | 05-21-2009 01:50 PM |
