 Old 09-19-2009, 09:03 AM   #41
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
Originally Posted by glocK23 View Post
Can you please explain why ? Serious question too.
And btw, I still think the stock tune is the safest way.
Well, when air temp drops, timing increases, to lean the car out. The computer does this to compensate for pig rich conditions. Unfortunately, if you dont dial down timing and boost, you will blow. Common in the boosted ford world, as probably every other platform as well.
Catch can isnt going to save this engine, neither will a BSD.
My theory is simple. Long term detonation deteriorates the rods, that low boost, low load, part throttle, is enough for the rod to let go. That little bit of lean condition at the o/c loop transition is enough to launch that rod. Being proactive and controlling knock from the get go, will save your ass, long term. Look at some of the threads here with pictures of bent rods, caught before the engine let go. A large percentage of these bent rods came from weeks of high knock levels. The after thought, was to put meth on the car to stop it, but the damage was already done.
I'm not so sure man ... for knock to bend a rod like that, you'd think you'd still see piston damage. Regardless I still have a knock warning just to be safe.
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 09-19-2009, 09:21 AM   #42
langer's Avatar
Posts: 20   (View Stats)
langer is a jewel in the roughlanger is a jewel in the roughlanger is a jewel in the roughlanger is a jewel in the rough
Cold air would require more fuel. Colder air has way more oxygen molecules than hot air. I hope people are dialing up more fuel if they are running bigger turbos.
And how would colder plugs going to lead to detonation?
langer is offline   Reply With Quote
 Old 09-19-2009, 09:23 AM   #43
Laloosh's Avatar
Posts: 5,166   (View Stats)
Groans: 57
timing does not change by itself. The blow because of leaner af ratios and fuel pumps that cant keep up in the colder months. Colder air is denser air...simply as that. The ecu is a joke
The Following User Says Thank You to Laloosh For This Useful Post:
djuosnteisn (09-19-2009)
 Old 09-19-2009, 09:31 AM   #44
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
not saying your wrong, but the fuel should also be colder, and more dense
2015 MUSTANG GTPP
gtlaw is offline   Reply With Quote
 Old 09-19-2009, 09:32 AM   #45
Laloosh's Avatar
Groans: 57
thats great, log your car when its 80 out, and log it when its 40 out...let me know what you see. My experience, same exact timing, 1-1.5 leaner af ratios
 Old 09-19-2009, 09:42 AM   #46
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Fuel does not compress, temperature will have a negligible effect on it's density.
Air however is readily compressible, and temperature will have a large effect on it's density... In the winter you end up with a leaner AFR because of this..
 Old 09-19-2009, 09:47 AM   #47
Race Roots's Avatar
Posts: 885   (View Stats)
Race Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the world
Groaned at 18 Times in 18 Posts
Originally Posted by Nitr0EngiE View Post
mazda dont go searching forums before they warranty
Actually they do, I have had multiple dealerships call me and ask for info on certain customers. This info I just don't share. I know of one guy in Ohio that got his warranty denied because he was posting about it on the forums about his motor blowing up. (This was for an RX-8)
Everyone that has their mods posted in their signature makes it even easier to prove, also these forums do have Location easily posted but yes...they do look, not always but you never know.
He tried fighting it....it was futile they showed him a print out of his post starting the thread and a list of his mods were in his signature.
My apologies to the OP, that sucks dude.
It is very important to tune for the weather, this should be common knowledge.
Race Roots is offline   Reply With Quote
 Old 09-19-2009, 09:48 AM   #48
2007speed3's Avatar
Posts: 1,486   (View Stats)
2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world
was the whole spark plug thing just pulled out of someone ass?
2007speed3 is offline   Reply With Quote
 Old 09-19-2009, 09:51 AM   #49
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
Yeah lol.
But on a factual note, incorrect tire pressure will cause your motor to explode.
glocK23 is offline   Reply With Quote
The Following 2 Users Say Thank You to glocK23 For This Useful Post:
2007speed3 (09-19-2009), vbt101 (09-25-2009)
The Following User Says NO Thank You to glocK23 For This Un-useful Post:
 Old 09-19-2009, 10:44 AM   #50
2007speed3's Avatar
thanks for the heads up,
just ran out to check my rubber my back right was at 28psi. I was a ticking timebomb and diddnt even know it, because of you Glock my car lives to drive another day.
The Following 3 Users Say Thank You to 2007speed3 For This Useful Post:
DaleNixon (09-20-2009), glocK23 (09-19-2009), predapio (09-19-2009)
 Old 09-19-2009, 10:45 AM   #51
First step: Take out spark plugs (all 4) and post detailed pictures of what they look like.
Second step: Take off your intake manifold and see how much liquid there is inside. Pour it in a clear cup to verify quantity and what actually is in there.
Third step: Pull off the head and inspect damage on the top of the motor. Any piston top damage? Any other cylinders wet? How is the wear in the cylinder bore.
Fourth step: Pull of your PCV valve and test it. Then pull off your PCV box and inspect for any weird damage
Fifth step: Start carefully tearing the motor down starting with the injectors. If you could get those flow tested it would be ideal.
EDIT: At what PSI did meth start spraying and was it a progressive controller?
TheDoc (09-20-2009)
 Old 09-19-2009, 10:57 AM   #52
glocK23's Avatar
Groans: 701
Don't thank me, thank my keyboard.
The Following User Says Thank You to glocK23 For This Useful Post:
 Old 09-19-2009, 11:17 AM   #53
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Stock tune targets what, 10.5:1 afr's? Maybe there's a reason behind this, and pushing mid 12's, even with meth, was a bit extreme. Still who the hell knows.
Also afr's will probably drift a lil due to weather, though with a properly calibrated maf it seems like a point to point and half is alot. Not saying it doesn't happen, just saying i'll be damn surprised if it does. Definitely something we all need to keep our eyes on.
Both the closed loop and open loop - part throttle fueling tables in atr are load and rpm dependent. With a drop in temp, and potential increase in load, one would think things would be okay (assuming the tables didn't do anything stupid & fuel pressure is sufficient). I know mine are in mid to low 12's by about 2~3 psi, and my transition from closed to open is at like .5 load.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 09-19-2009, 11:22 AM   #54
Flash from the past boys:
engine boom=( w/o a boom sound
Same scenario right down to the guy changing his oil the same day. Same D05 nozzle ... Any relationship here or just coincidence?
2007speed3 (09-19-2009), bioevolve (09-19-2009), glocK23 (09-19-2009)
 Old 09-19-2009, 11:26 AM   #55
LBV
LBV's Avatar
In theory leaner AFR or advanced timing by itself does not blow motors. It's the resultant high cylinder temps and then the knock (which remember is just detonation at the WRONG time) that does.
You should be able to, again in theory, lean out and advance as much as you want as long as you're not seeing knock.
But this is new technology so the theory may just not apply ...
The oil level is weird on these cars ... I check it about 6 times over the course of the 2 days after I change my oil just to make sure it's right on the full line and then about once a week after that.
Wonder if the oil level was either too low or too high?
Last edited by LBV; 09-19-2009 at 11:29 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-19-2009, 11:47 AM   #56
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
I just thought I would post this here, and in the Meth thread too.
For those talking about too lean, this is from Travis@Cobb:
COBB Forums - View Single Post - AF's very different during single gear pull vs. multi gear pull, how do I tune out?
"On a DISI engine, this process is much more efficient, the fuel is injected directly into the combustion chamber where it is able to mix directly with incoming intake air. This process allows us to run much leaner without having to worry about uneven disribution of fuel among oxygen molecules. Also, this has a cooling effect as the gasoline is sprayed directly into the piston face.
A 12.7 AFR is actually about ideal for a DISI engine, 11.1 while ideal for say, a Subaru engine, is running quite rich."
So he is saying 12.7 AFR is ideal.
That prompted a question from me that if 12.7 is ideal why do the cobb maps run much richer?
No answer yet.
My guess, and it is only a guess is, maybe they have found their own car runs best at 12.7, that is where his post is coming from, and they run the OTS maps richer as an extra safety measure.
Suspension:
 Old 09-19-2009, 12:37 PM   #57
It's the same misunderstanding shit. Air was mixed with methanol - how does that affect AFRs? How much methanol was injected? How much got to what cylinder? Were the injectors balanced? So many factors.
In the end it comes down to was the damage done prior to this point and it finally let go or something big happened at that point and it let go.
Or was it something completely unrelated like an oil leak after a change? Otherwise just plain blowing a couple of psi of boost in doesn't make sense.
If these motors blew a few psi into boost because something was a major flaw; then why don't we see CX-7s drop like flies? Anyone know how many of those blow going to the grocery store?
 Old 09-19-2009, 12:45 PM   #58
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
fuck those SOB's at mazda
2015 Mazda 6
 Old 09-19-2009, 03:04 PM   #59
robspeed3's Avatar
Posts: 477   (View Stats)
robspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond repute
Groans: 58
Groaned at 286 Times in 281 Posts
i think im going to wait and see if ford puts a turbo ecoboost motor in the up coming focus and prob trade this car in for another focus only if ford comes out with a eco boost focus!!
Don't make me pop the trunkt!!
robspeed3 is offline   Reply With Quote
The Following User Says NO Thank You to robspeed3 For This Un-useful Post:
 Old 09-19-2009, 04:15 PM   #60
2007speed3's Avatar
The Following 12 Users Say Thank You to 2007speed3 For This Useful Post:
802MS3 (09-19-2009), aaronc7 (09-20-2009), DaleNixon (09-20-2009), Darksun280 (09-19-2009), djuosnteisn (09-20-2009), glocK23 (09-20-2009), madvillain (09-19-2009), mexicant (09-23-2009), ms3077 (09-19-2009), SoyBean (09-24-2009), toprock (09-25-2009), xcoldricex (09-20-2009)
 Old 09-19-2009, 04:31 PM   #61
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Originally Posted by smakdown61 View Post
Isn't the whole point of having a load based ecu to make it more consistant all year around? Even with the colder air, I would think it should adjust boost (lower it) to hit the same load target.
When have you ever seen this car dial down boost, seriously? No, this computer doesnt dial down boost based off temps. Load has nothing to do with ambient temperature.
Originally Posted by wcm250f View Post
so if i just left the ecu and boost stock but just had either a sri or cai plus a catback exhaust ( planning on using only mazda accessories if i can for the new ms3) would i be ok during the winter or should i take those parts of.
You would be fine.
Depends on the material of the rod.. these arent forged rods.. they are powder forged and can take only so much torque.
Ive never seen rod's bent on an engine in my life, like what ive witnessed happening with the MZR.
Your knowledge of ECU function is a joke... This car DOES add timing in colder weather, hence why the car is running leaner.. it adds timing or yanks fuel based on air density and temp. The fuel pump cant keep up during extreme colder weather because the car is making more power in the colder weather.
That would be awesome if they did that here as they would be in serious violation to my TOS agreement.
Last edited by Haltech; 09-19-2009 at 04:41 PM. Reason: MSF Database - Automerged Doublepost
ms3077 (11-24-2009)
 Old 09-19-2009, 05:22 PM   #62
nue
nue's Avatar
Posts: 110   (View Stats)
nue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud of
So is this guy modded or what? Seems like a strange argument to expect a manufacturer to cover for aftermarket mistakes...
nue is offline   Reply With Quote
 Old 09-19-2009, 05:39 PM   #63
evo2ms3's Avatar
Posts: 287   (View Stats)
evo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the world
He never said he's trying to get it covered under warranty.
//Cobb AccessPORT//Cobb E-Tune@20psi//SU TMIC//Mazdaspeed CAI//HKS SSQV//RPMC Turbo Inlet//CP-E HPFP//Corksport Race Pipe//Resonator Delete//Corksport MM Inserts//TWM STS//TWM Bushings//Denso ITV22//Prosport Premium Boost//RX-8 Wheels//Kumho Ecsta XS's 235-40//Valentine One//35% Tint//TRADED IN
WW EVO X GSR//SSS//Navi//Advan Racing RS 19x10//BC Racing Coilovers//Cobb AccessPORT//Perrin 3-port/AMS FMIC//UR UICP//Works Air Filter//UR Test Pipe//Trust PE II Exhaust//Defi Boost Gauge//APR Vortex Generator//Ralliart Tails//20% Tint//Valentine One//
evo2ms3 is offline   Reply With Quote
 Old 09-19-2009, 05:49 PM   #64
Decepticon's Avatar
Posts: 1,221   (View Stats)
Decepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the world
Groaned at 43 Times in 28 Posts
dammit...i was gonna get another speed3..
06 MS6, Cobb AP, -TUNED on corn mix, KMD v2 fp internals, NGK Iridium IX sp, Cp-e Xcel NANO, PG tip, SU bpv, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback, Altered Custom fmic, H&R springs...
R.I.P. 08.5 MS3, Cobb Ap, KMD v2 fp internals, Denso ITV22 sp, Cobb Sri, TurboXS bpv, SU rear mm, SU shifter bushings, ETS TMIC, SU boost tubes, Cp-e catted dp, Enkei EKM3.
Decepticon is offline   Reply With Quote
 Old 09-19-2009, 09:24 PM   #65
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
AFCadet,
Did you have the PCV fix from PTP?
Just curious to know,
Cobb AP, 504whp 492wtq
11cruzito11 is offline   Reply With Quote
 Old 09-19-2009, 09:49 PM   #66
jahman's Avatar
Posts: 903   (View Stats)
jahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the world
Groaned at 9 Times in 7 Posts
I've seen it many times on my car. Every winter since I've had the car. When it was on stock tune it would barely pull 14psi. This last winter when temps got sub zero, I was making no more than high 11, low 12 psi on a Cobb v103 OTS map. When temps rebound the boost goes back up.
I'm not sure if its based on ambient temperature alone, or maybe something in relation to the ambient temperature. But its consistent.
I dont know about load, never logged it in cool temps since I never logged it before ATR.
07 Mazdaspeed3
jahman is offline   Reply With Quote
 Old 09-19-2009, 10:06 PM   #67
Arrowpoint's Avatar
Posts: 364   (View Stats)
Arrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the world
My post was based on a mistaken observation.
Last edited by Arrowpoint; 09-20-2009 at 07:33 AM. Reason: This post was based on a mistaken observation
Arrowpoint is offline   Reply With Quote
 Old 09-20-2009, 12:00 AM   #68
fjames's Avatar
Posts: 1,058   (View Stats)
I've got the same values at 4500 in the ones I checked.
That table seems to be changing a lot. I've always used the same base map - I've just been working on the same map since day 1. My original table, then the original ATR modded table, then the newest ATR table are all different. That last is an assumption based on 105 maps since I'm using the first "FFS" ATR, not the latest.
Whatever, it looks like any ATR map will have a smooth table without the big values at 4500.
 Old 09-20-2009, 07:07 AM   #69
AFcadet's Avatar
Posts: 937   (View Stats)
AFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the world
I didnt have the PCV fix or a catch can.
I did have PTPs baffle tray...and their BSD
AFcadet is offline   Reply With Quote
 Old 09-20-2009, 07:32 AM   #70
Arrowpoint's Avatar
I looked again after your post and found a 102 map which had that value and that as you said the table changes on some other 103 maps making my whole theory questionable since I don't know when Cobb originally worked on them so I pulled that post. Thanks for pointing out my bad.
 Old 09-20-2009, 10:37 AM   #71
Laloosh's Avatar
Groans: 57
You would be fine.
Timing was always the same on my car no matter what....as long as it didnt knock, which it didnt. So maybe your understanding of the ecu is fucken joke. The fuel pump doesnt go out in warm weather at 300whp but goes out in cold weather at 260whp....once again, a fucken joke.
 Old 09-20-2009, 06:40 PM   #72
richie b 74's Avatar
Posts: 84   (View Stats)
richie b 74 will become famous soon enough
if you only have 40,000 miles on it why dont you return it to stock and get it covered under powertrain warrantee, doesnt last till 60,000 miles or am i wrong
mscai, 15% tint
richie b 74 is offline   Reply With Quote
 Old 09-20-2009, 08:22 PM   #73
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
So you leaned it to mid 12s where you actually felt you were losing power ... did you monitor KR ... and then it seemed to blow thereafter. Is this too much of a coincidence or is there something missing from the story?
How many miles on the car?
SLS was also running leaner and recently blew.
Not that I'm drawing conclusions.
Are you going to tear it down and see what went wrong?
You misunderstand, I was running richer than stock, not leaner. At the point I blew, stock tuning is trying to figure out if you are seriously on the power or not. So it would normally still target 14.7, or at best low 13's. I was in the low 12's at that point.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 09-23-2009, 02:29 PM   #74
I meant leaner under WOT ... at least from my understanding you were ususally seeing WOT in the 12s?
 Old 09-25-2009, 08:40 AM   #75
SLS MS3's Avatar
At WOT I targeted 11.8 tapering down to 11.6
 Old 09-25-2009, 08:44 AM   #76
Any news from the teardown?
 Old 09-25-2009, 11:02 AM   #77
toprock's Avatar
Posts: 749   (View Stats)
toprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the world
Groans: 40
Sorry in advance if I'm beating on a dead horse here...but what were the OP's mods again?
From what I read he had Meth, Colder Plugs, and BSD?
toprock is offline   Reply With Quote
 Old 09-25-2009, 11:40 AM   #78
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
SLS
When did you have your meth turn on?
I am currently having mine activate at 2.9v on the MAF (pretty much anytime I am in boost above 2500 RPMs).
 Old 09-25-2009, 01:07 PM   #79
SLS MS3's Avatar
Teardown should start on Tuesday
SLS
I never got around to installing my meth kit, it's been sitting in my closet for 2 months or so. At first I was too busy to install it. Then I decided to wait until after the track day I was signed up for this coming Monday. I didn't want to mess with my tune so close to the track day, and I was also worried about running out of meth during the event.
 Old 11-05-2009, 09:06 AM   #80
Got your failed parts and I am looking at them. What a strange failure generally speaking. The rod broke cleanly. Your piston seized in the bore of course. At least one of the other rods you sent me was also bent in the engine for a while.
DaleNixon (11-05-2009), MPSdriver (11-05-2009)
BOOM-'FREAKIN-BOOM tutuga MazdaSpeed 3 - Engine, Transmission & Driveline 181 05-09-2009 12:53 AM
engine boom=( w/o a boom sound johnac08 MazdaSpeed 3/6 - Turbo Induction 96 05-05-2009 08:46 PM
Uh oh i make boom boom Jarods7920 MazdaSpeed 3 - Engine, Transmission & Driveline 167 05-03-2009 09:00 AM
Page generated in 0.63519 seconds with 46 queries
