-   -   fuel pump rattle (http://www.mazdaspeedforums.org/forum/f10/fuel-pump-rattle-53241/)
Atomic41 08-30-2012 08:37 AM
So I found my rattling metal noise ... it's my upgraded fuel pump.
but we got no solution to eliminate this rattling noise ?
dot584 08-30-2012 08:39 AM
Its always been loud for me, never changed with my KMD v2 instal or at least I never noticed. Maybe you installed them wrong?
Sent from my ADR6300 using Tapatalk 2
Atomic41 08-30-2012 09:10 AM
Why I install them wrong?
If everybody got the noise here with the same product ?
dot584 08-30-2012 11:22 AM
I'm not saying you did, but if yours was unusually loud then maybe it would be a good idea to take it apart and double check. I think for the most part everyone's pump is audible in the cabin if you know what to listen for. Go to a dealer and see how loud one of their cars are so you have an idea of how loud it should be.
Cataphract_40 08-30-2012 12:16 PM
It's a very brief (less than a second) rattle/vibration type noise that occurs when you tip the throttle pedal in. If you are driving at a constant speed, no noise. As soon as you push the pedal down, brief rattle.
It's something to do with the brief spike in increased pressure. At least, that's what my DeVry degree in Mazdaneering tells me.
dot584 08-30-2012 09:18 PM
Yes that is a good description, I also here mine sometimes when going very slow and I let off the throttle, I can hear it slowing down.
ms3blackmica 09-19-2012 12:21 AM
This is normal for my autotechs as well.
I can hear it when i am idling with the AC on. Every time that the AC compressor clutch kicks on. I get the quick rattle at this sudden change of idle RPM.
rfinkle2 09-19-2012 01:29 AM
I have the rattle too, but seemed to have solved it with my new exhaust! LOL
:wave:
Not the best advice, but sometimes I like to think if I can't hear it, it ain't happening!
p057 09-19-2012 06:47 AM
:wave:
What's funny is, the noise has been around for a while now for me. Yet, i only get this sense of doom and fear when coincidentally my bank account funds are low.
When they're high, I don't have this feeling.
I wonder if it's correlated in some way?
currently, i am in severe fear and sky-is-falling mode. :wall:
BigJimMs3 09-19-2012 07:00 AM
Mine only does it when start up on cold starts. Theres first a slight rattle then goes away but then like 5 seconds later it comes back and rattles for like 3-4seconds. I check my fuel pressure all the time and its fine. Also i notice it does it worse when its colder. Ive had my KMDs in for about 13-14months now.
Mchart 09-19-2012 11:26 PM
I've made the observation that different oils change some of the sounds the pump makes.
Using M1 0w-40 the pump was always quite loud. Using M1 5w-40 TDT the rattles and other shit from the pump have quieted substantially.
No clue why, but it has.
Been running KMD internals for 2 years now and 30k miles. Still no issues.
ms3blackmica 09-19-2012 11:44 PM
what you did there......
i see it
mhebert2001 09-30-2012 04:54 PM
Everytime I feel better about my Autotechs rattling I stumble over an older post that makes me go...what?
So let me ask one question.
Does everyone who has this rattle, agree that the rattle goes away if driving at a constant speed?
Cataphract_40 09-30-2012 07:14 PM
Yes.
mhebert2001 09-30-2012 07:17 PM
Originally Posted by Cataphract_40 (Post 1657140)
Yes.
Crap...then I may actually have an issue.
Thanks
Pseud0logik 09-30-2012 07:22 PM
I've made the same observation. I ran M1 5w30 exclusively up until I jumped on the T6 bandwagon a few months ago and after the switch my pump rattle was much, much louder. This last change I went to PU 5w30 and the pump is whisper quiet again. I thought I was crazy.
Cataphract_40 09-30-2012 08:13 PM
Correct me if I'm wrong, but apart from the lobe at the very end of the camshaft, the HPFP doesn't receive any oil...?
TurboGsxr600 10-11-2012 06:59 PM
I think my autotech internals have started rattling. At first I thought it was the VVT but the sound is loudest around the cdfp. The sound started as it got colder outside. When I first start the car its almost like a metal on metal sqeeling sound followed by a knocking sound. It only lasts until car is warmed up. Fuel pressure is fine. Does this sound normal?
mhebert2001 10-11-2012 08:45 PM
I don't know enough at this point to give any real advice. At this point my goals are to learn as much as I can and report on things that happen after my upgrades.
Since my internals were put in they have been very audible. This happens at tip in and also while maintaining a constant speed. To be accurate, at a constant speed they are not as loud as they are at tip in, but still annoying.
The tip in rattle is the same warm or cold. However, the rattle during steady cruising is somewhat worse when cold.
I don't know if this helps you or not, but when I start mine up in the morning it is like a factory vehicle. I don't have any rattling beyond what would be normal. Also, anytime at idle, warm or cold, the pump sounds fine.
Fuel pressure holding is not a bad thing, that much I can say!
xecuter2 06-26-2013 04:46 PM
I am running T6 with autotechs and noticed the tip in rattle since I installed them(thought it was something else and stumbled on this thread). Power is 100%, noise is only on throttle blip, and pressure is 100%. Should I deal with it? Me likey T6 and reading this eases my mind but makes me want to go to Penzoil :/
ms6mil 06-26-2013 06:08 PM
I have had my internals in for couple years with the tip in rattle, only noticeable when outside the vehicle and hood is up. I have double checked for wear and haven't found anything remarkable. Pressure is good no problems. I have installed them on a few cars and they too have the tip in rattle as well. Everyone is good so far. It's been 1-2 years of running their internals with no problems. I just keep an eye on FP as a part of my daily log checks.
86AmishMs3 06-27-2013 11:02 AM
Originally Posted by 86azms3 (Post 1266482)
We're still discussing this? Normal, it's a high pressure pump and it's not radial or centrifugal...its going to be noisy. Plus at tip in there is probably slight cavitation going on causing more noise. This is especially true when you have large delta pressure differentials.
Guess should hear positive displacement pumps when they start cavitating...clackety clackety clack. So loud you'd think it's metal metal contact, but not the case at all.
See above post.
Cataphract_40 07-02-2013 10:06 PM
tl;dr Noise is normal, don't worry about it.
/thread
Caligula 08-01-2013 12:26 AM
Subd
Sent from my Nexus 10 using Tapatalk HD
BigJimMs3 08-01-2013 06:55 AM
Holy shit this thread is still alive!!!!!
under28world 03-23-2015 12:45 PM
2 years later and problem still exists, pulled out and inspected and same issues exist!
Page generated in 0.20588 seconds with 11 queries
