![]() | | #81 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | djuosnteisn (04-23-2010) |
![]() | | #82 | ![]() |
(Thread Starter) | Not Ranked : 0 score We'd have to know the cam lift to have an idea about this. It's not simple to measure or even tell how deep the piston moves or how much the spring is compressed when the piston is fully out. Although with some calipers you can get an idea - just have to be able to turn the motor slowly (by hand). If trying a shim, I would only try it at the top of the pump, not at the retainer at the bottom. The shim can't too thick or the spring will pull off the top as well and you definitely don't want that. |
![]() | | #83 | ![]() |
(Thread Starter) | Not Ranked : 0 score What would have caused the noise to start "all of a sudden." I have a hard time believing the spring deformed or shortened during a run. Only plausible thing is that the bottom retainer slowly wore loose. |
![]() | | #84 | ![]() |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
I agree with Lex here. If the spring did/doesn't fit VERY snugly to the OD of the retainer raised section, it WILL vibrate in use and cause wear on either the retainer and/or the spring ID itself. I would expect to see the wear if you removed the keeper and spring to inspect them at the retainer end..... The HPFP is a high-speed precision-clearanced device. There is a plethora of failed attempts to create what we have today. EVERY attempt has met with several failures before any sustained success. A thorough web search provides tons of information on inventions/patents, etc. trying to develop/improve upon the design. Ours is a single piston design, but there are several mutli-piston HPFPs in use as well.....
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy | |
| The Following User Says Thank You to FORZDA 1 For This Useful Post: | Lex (04-23-2010) |
![]() | | #85 | ![]() |
(Thread Starter) | Not Ranked : 0 score There is wear on the spring seat at the retainer from the spring not fitting snugly and moving against the retainer. I wish I snapped more pictures. The question is - where do we go from here?
| The Following User Says Thank You to Lex For This Useful Post: | FORZDA 1 (04-23-2010) |
![]() | | #86 | ![]() |
| Not Ranked : 0 score At first look, I think CPE should produce a retainer with the correct ID to support their larger piston/spring OR use a piston/sleeve combo closer to those used by the "other" kit suppliers with OEM spring. The OEM spring has proven to be just fine in supporting the larger capacity piston. The further we get from the OEM design, the more problems we'll have. IMO, the aftermarket (even at CPE prices) just doesn't have the resources to adequately test/develop this part........
![]() | | #87 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's true with most aftermarket parts. This is especially difficult to produce due to the tolerances and design. It's a complex part as you mentioned. One thing to make a downpipe and another to make an HPFP. So you're right, either redo the retainer but it has to be done to OEM spec or it will fail like the competition. Or reuse the stock spring. That means the top mount and perhaps the piston itself will have to be redesigned like the competition with just the top of the piston being thicker. Sure, people can opt for one of those from someone else but I've read WAY too many stories of seized pumps. On top of that - the piston that is only thicker at the end suffers from less lateral support in the bore. This causes more lateral forces on certain parts of it leading to scuffing and ultimately failure. There's a reason the stock piston is the same diameter throughout. The CPE pump is closest - it's just the detail at the retainer.
![]() | | #88 | ![]() |
| Not Ranked : 0 score If the spring is worn at the retainer then ide say we have our answer, I had been thinking that it wasnt worn lol. I bet they can design a new retainer that uses the OEM button.
![]() | | #89 | ![]() |
![]() Join Date: Oct 2008 Location: Western Hemisphere
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
Groans: 91
| Not Ranked : 0 score I've heard that before. Thanks for updating the OP. This is good info.
__________________ Gay car #1: 2001 Miata (Gay White) Gay car #2: 2011 Mazda 2 (Gay Blue) |
![]() | | #90 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
How does the lateral laoding happen? The piston cup that rides on the cam follower can only move up and down, there is not lateral loading at the push end of the pump, so if the pump is not being pushed laterally how could is all the sudden be getting lateral loads in the pump?
Last edited by ptperformance; 04-29-2010 at 04:09 AM. Reason: MSF Database - Automerged Doublepost | ||||
![]() | | #91 | ![]() |
![]() | | #92 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score yeah i'm a slacker, i'm still trying to find my e8 torx |
| The Following User Says Thank You to bova For This Useful Post: | djuosnteisn (04-29-2010) |
![]() | | #93 | ![]() |
Groans: 79
| Not Ranked : 0 score Hahahahaha... Keep looking, its around there somewhere.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #94 | ![]() |
Groans: 91
| Not Ranked : 0 score Lex, does your pump rattle when you are idling and you turn the steering wheel left to right? My PTP pump started making a similar rattle on initial throttle application from a 700 RPM idle or causing the power steering to kick in while idling. It holds pressure fine, and the problem isn't always reproducible but I have noticed it. This does have me slightly concerned.
| The Following User Says Thank You to DaleNixon For This Useful Post: | djuosnteisn (05-03-2010) |
![]() | | #95 | ![]() |
I can hear mine in any gear if I coast at low enough RPM and just tap the gas. There's a quick rattle as pressure builds. | |
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #96 | ![]() |
![]() Join Date: Aug 2009 Location: Albany, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 867
Groans: 39
| Not Ranked : 0 score mine has done that from day one, mr lil guy pump |
| The Following 2 Users Say Thank You to turd burglar For This Useful Post: | DaleNixon (05-03-2010), djuosnteisn (05-03-2010) |
![]() | | #97 | ![]() |
Groans: 91
| Not Ranked : 0 score So I guess it's an annoyance, but it's still safe to drive around like this right?
![]() | | #98 | ![]() |
Groans: 45
| Not Ranked : 0 score more or less yes. i found my e8 torx bit but haven't found the time to take the pump out. maybe tomorrow. |
![]() | | #99 | ![]() |
(Thread Starter) | Not Ranked : 0 score Do it bova! Mine's been rattling since I started this thread. Pressure is fine - rattle is the same. |
| The Following User Says Thank You to Lex For This Useful Post: | DaleNixon (05-15-2010) |
![]() | | #100 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score I hear mine now...in fact I've heard it way before and thought it was the axle...thanks for all the work Lex! (again!) my pump is definitely high mileage...but pressure is good, for now.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
| The Following 3 Users Say Thank You to Fobio For This Useful Post: |
![]() | | #101 | ![]() |
(Thread Starter) | Not Ranked : 0 score I also hear it at lower speeds when I tip-in from a coasting condition. |
| The Following User Says Thank You to Lex For This Useful Post: | knarfies (04-13-2012) |
![]() | | #102 | ![]() |
Groans: 44
| Not Ranked : 0 score definitely...that's in fact when I hear it the most, tip-in @ cruising. it's almost like a signal to not lug the engine...
| The Following User Says Thank You to Fobio For This Useful Post: | Lex (05-14-2010) |
![]() | | #103 | ![]() |
(Thread Starter) | Not Ranked : 0 score How many miles on your pump Fobio? Would you be willing to pull it out and take some pictures of the cam follower (both sides), the pump button, and the seat the spring rides on? |
![]() | | #104 | ![]() |
Groans: 44
unfortunately, I don't plan to wrench on the car anymore this season (all underhood parts are installed and waiting for suspension only now) as the rest of the time will be spent on suspension work. if however, the chance comes up, I'd do it...
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- | |
![]() | | #105 | ![]() |
Groans: 91
| Not Ranked : 0 score So how's the rattle club doing a month after the last post in this thread? Still getting this rattle here. Car still runs great.
![]() | | #106 | ![]() |
Groans: 45
| Not Ranked : 0 score rattle and running fine as always the one rattle that pisses me off, that i plan to take care of tonight or tomorrow is my exhaust rattle on the stupid ms6 fake tips. |
| The Following 2 Users Say Thank You to bova For This Useful Post: | DaleNixon (06-16-2010), dougefresh_ (06-22-2010) |
![]() | | #107 | ![]() |
Groans: 79
| Not Ranked : 0 score Hahaha... i always thought it was my tips rattling too, but turned out to be the muffler back there hitting a weld seam in the under carriage. I fucking hate rattles.
![]() | | #108 | ![]() |
Groans: 44
| Not Ranked : 0 score I fixed a rattle last night...it was the hatch's weather stripping that had a slight flip on it and wasn't pushing against the headliner...unkinked it and rattle gone...
![]() | | #109 | ![]() |
(Thread Starter) | Not Ranked : 0 score pump rattle still there. no change in pressure or how the car runs. |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | DaleNixon (06-16-2010), dougefresh_ (06-22-2010) |
![]() | | #110 | ![]() |
Groans: 91
| Not Ranked : 0 score You run your A/C much Lex? I noticed mine rattled almost constantly at idle with the A/C on. The pressure was around 530 or so IIRC.
![]() | | #111 | ![]() |
![]() Join Date: Jul 2008 Location: MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 174
| Not Ranked : 0 score Lex, any updates with your conversations with CPE? Have they read about your latest discoveries and acknowledged/confirmed your findings?
__________________ ---- Hey, do my fingers smell like your mother? |
![]() | | #112 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score Thanks for the great thread guys!! So the noise is the only downside of the CPE then? It sounds like you'd have to listen for it, or never play the radio to notice this sound.. is that right? I've had two PTP pumps shit the bed, so I'm leaning towards the CPE pump, but considering KMD internals as well. Can you hear that noise at tip in while cruising w/ the windows down, or only at Bova's daily stops at Jack in the Box? lol I keed I keed. Honestly, I just want a fucking pump that works and holds pressure well... if I don't hear it inside the cabin, the I could care less.....
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
![]() | | #113 | ![]() |
![]() Join Date: Aug 2009 Location: Toronto, Ontario, CANADA
Rep Power: 545 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 251
Groans: 44
| Not Ranked : 0 score I am interested in buying a HPFP, and CPe is my main choice. But kinda holding back to wait and hear if CPe has anything to say or what they are willing to do about this.
__________________ |
![]() | | #114 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have heard nothing more from CPE. It does seem the rattle is a common issue with their pumps but I don't think anything will be done unless failure (wear on other parts, loss of pressure) starts to become an issue. No, the pump does not rattle constantly for me, just when there is a rise in pressure. If I listen carefully without music, I can hear it every tip-in such as during gear changes. The noise has maintained the same intensity. I will be taking it off the car again in more miles to check for wear etc. IMO the CPE pump is the best pump on the market with the least catastrophic failures so I would not hesitate getting it over something that may seize. |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | DaleNixon (06-23-2010), dougefresh_ (06-23-2010) |
![]() | | #115 | ![]() |
Groans: 45
| Not Ranked : 0 score yeah the pump only makes noise on rise in pressure and i don't think it is just cp-e, as i have a pump from PG which were kmd internals at the time i think. it runs great but just makes that noise on pressure rise. and douge, we don't have jack in the box here in pittsburgh, so that ain't it, haha. |
| The Following User Says Thank You to bova For This Useful Post: | dougefresh_ (06-23-2010) |
![]() | | #116 | ![]() |
![]() | | #117 | ![]() |
| Not Ranked : 0 score I've been through a couple PTP pumps, and it's time to move on to the CPE pump instead. I just got a new stock pump from PTP (+ refund soon), and I put it on yesterday. And what do you know? It rattles like some of the aftermarket pumps. I just wanted to let you guys know it can happen on a stocker as well! I started a new thread on the MS6 section and linked them here in the OP. I've read this entire thread before, and I find that it's not that loud, and it doesn't bother me. This sounds like the other vids to me:
![]() | | #118 | ![]() |
Groans: 91
| Not Ranked : 0 score Rofl today I had my RPM's just right at the Wendy's drive thru (A/C on, steering wheel slightly cocked). The guy taking my order couldn't understand me over the horrible rattle. I had to turn the A/C off to get it to stop.
| The Following 2 Users Say Thank You to DaleNixon For This Useful Post: | dougefresh_ (07-02-2010), karl-hungus (07-01-2010) |
![]() | | #119 | ![]() |
![]() Join Date: Jul 2010
Rep Power: 0 ![]() ![]() Thanks: 0
| The Following User Says Thank You to 9SECVTEC For This Useful Post: | dougefresh_ (07-02-2010) |
![]() | | #120 | ![]() |
![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score What happening with this tread ? We lost lot of post ?
__________________ Mazdaspeed6, CP-E dyno 275WHP/255 WT ,BNR turbo ,CP-E intake,CP-E turbo inlet,CP-E flash,CP-E standback,CP-E fuel pump,CP-E mount,Turbosmart bov,Corksport catback,ATP catted downpipe,ETS tmic ,Saikou Michi OCC, Turbinetech mounts,TWM short shifter stage II + bushings + shifter plate ,Aem boost et wideband gauge,Dashhawk,Autoexi tower bar, Apexi turbo timer,Mazdaspeed mags,huiles Amsoil,Fiberimages CF hood & truck ,Speedline CF grill, R1 concept disques de freins,EBC red stuff pads,Hankook tires,Megan racing coilover ,Kicker amplifier . |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/fuel-pump-rattle-53241/ | ||||
| PTP pump, bushings and spark plugs | This thread | Refback | 03-18-2012 10:09 PM | |
| Possible CP-E HPFP going bad? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 07-19-2011 01:47 PM | |
| Log after PTP Fuel Pump | taf0422 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 03-02-2010 03:30 PM |
| Issues with fuel pump pressures, aftermarket pump... | ptperformance | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 0 | 10-04-2009 06:17 PM |
| PTP Fuel Pump | Cornerfreak | Mazdaspeed3/6 General Discussion | 4 | 09-28-2009 09:35 AM |
| Do I need a fuel pump. | dread | Cobb Access Port/Maps | 13 | 12-14-2008 08:06 AM |
| which fuel pump to get? | Buildabong | MazdaSpeed 3/6 - Turbo Induction | 20 | 10-15-2008 11:43 AM |
