Like Tree3Likes
 Old 08-30-2012, 08:37 AM   #241
Atomic41's Avatar
Posts: 1,174   (View Stats)
Atomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond repute
Groaned at 38 Times in 26 Posts
So I found my rattling metal noise ... it's my upgraded fuel pump.
but we got no solution to eliminate this rattling noise ?
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
Atomic41 is offline   Reply With Quote
 Old 08-30-2012, 08:39 AM   #242
dot584's Avatar
Posts: 426   (View Stats)
dot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the world
Groaned at 4 Times in 2 Posts
Its always been loud for me, never changed with my KMD v2 instal or at least I never noticed. Maybe you installed them wrong?
Sent from my ADR6300 using Tapatalk 2
CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers!
dot584 is offline   Reply With Quote
 Old 08-30-2012, 09:10 AM   #243
Atomic41's Avatar
Why I install them wrong?
If everybody got the noise here with the same product ?
 Old 08-30-2012, 11:22 AM   #244
dot584's Avatar
I'm not saying you did, but if yours was unusually loud then maybe it would be a good idea to take it apart and double check. I think for the most part everyone's pump is audible in the cabin if you know what to listen for. Go to a dealer and see how loud one of their cars are so you have an idea of how loud it should be.
 Old 08-30-2012, 12:16 PM   #245
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
It's a very brief (less than a second) rattle/vibration type noise that occurs when you tip the throttle pedal in. If you are driving at a constant speed, no noise. As soon as you push the pedal down, brief rattle.
It's something to do with the brief spike in increased pressure. At least, that's what my DeVry degree in Mazdaneering tells me.
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following User Says Thank You to Cataphract_40 For This Useful Post:
dot584 (08-30-2012)
 Old 08-30-2012, 09:18 PM   #246
dot584's Avatar
Yes that is a good description, I also here mine sometimes when going very slow and I let off the throttle, I can hear it slowing down.
 Old 09-19-2012, 12:21 AM   #247
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
This is normal for my autotechs as well.
I can hear it when i am idling with the AC on. Every time that the AC compressor clutch kicks on. I get the quick rattle at this sudden change of idle RPM.
www.tunedbynishan.com
rfinkle2 (09-19-2012)
 Old 09-19-2012, 01:29 AM   #248
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I have the rattle too, but seemed to have solved it with my new exhaust! LOL
Not the best advice, but sometimes I like to think if I can't hear it, it ain't happening!
ms3blackmica (09-19-2012), p057 (09-19-2012)
 Old 09-19-2012, 06:47 AM   #249
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
What's funny is, the noise has been around for a while now for me. Yet, i only get this sense of doom and fear when coincidentally my bank account funds are low.
When they're high, I don't have this feeling.
I wonder if it's correlated in some way?
currently, i am in severe fear and sky-is-falling mode.
The Following 2 Users Say Thank You to p057 For This Useful Post:
ms3blackmica (09-19-2012), rfinkle2 (09-19-2012)
 Old 09-19-2012, 07:00 AM   #250
BigJimMs3's Avatar
Posts: 4,859   (View Stats)
BigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the world
Groans: 76
Groaned at 22 Times in 20 Posts
Mine only does it when start up on cold starts. Theres first a slight rattle then goes away but then like 5 seconds later it comes back and rattles for like 3-4seconds. I check my fuel pressure all the time and its fine. Also i notice it does it worse when its colder. Ive had my KMDs in for about 13-14months now.
2006 Mazdaspeed 6
BNR S4 and supporting mods
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
2016 Ford Explorer Sport
Stock
BigJimMs3 is offline   Reply With Quote
The Following User Says Thank You to BigJimMs3 For This Useful Post:
 Old 09-19-2012, 11:26 PM   #251
Mchart's Avatar
Posts: 980   (View Stats)
Mchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the world
Groans: 54
Groaned at 42 Times in 32 Posts
I've made the observation that different oils change some of the sounds the pump makes.
Using M1 0w-40 the pump was always quite loud. Using M1 5w-40 TDT the rattles and other shit from the pump have quieted substantially.
No clue why, but it has.
Been running KMD internals for 2 years now and 30k miles. Still no issues.
Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer.
HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04
Mchart is offline   Reply With Quote
The Following User Says Thank You to Mchart For This Useful Post:
Pseud0logik (09-30-2012)
 Old 09-19-2012, 11:44 PM   #252
Nishan
what you did there......
i see it
p057 (09-20-2012)
 Old 09-30-2012, 04:54 PM   #253
mhebert2001's Avatar
Posts: 491   (View Stats)
mhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Everytime I feel better about my Autotechs rattling I stumble over an older post that makes me go...what?
So let me ask one question.
Does everyone who has this rattle, agree that the rattle goes away if driving at a constant speed?
2012 MAZDASPEED3 BLACK MICA (Stage 1, Cobb AP, Autotechs, Cobb SF, TIP & Airbox)
Coming soon: 2nd etune
2013 MAZDASPEED3 Liquid Silver (Stock and not allowed to touch!)
mhebert2001 is offline   Reply With Quote
 Old 09-30-2012, 07:14 PM   #254
Groans: 30
Yes.
1995 Miata
 Old 09-30-2012, 07:17 PM   #255
Yes.
Crap...then I may actually have an issue.
Thanks
 Old 09-30-2012, 07:22 PM   #256
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groans: 79
Groaned at 34 Times in 31 Posts
I've made the same observation. I ran M1 5w30 exclusively up until I jumped on the T6 bandwagon a few months ago and after the switch my pump rattle was much, much louder. This last change I went to PU 5w30 and the pump is whisper quiet again. I thought I was crazy.
Pseud0logik is offline   Reply With Quote
The Following User Says Thank You to Pseud0logik For This Useful Post:
atvfreek (09-30-2012)
 Old 09-30-2012, 08:13 PM   #257
Groans: 30
Correct me if I'm wrong, but apart from the lobe at the very end of the camshaft, the HPFP doesn't receive any oil...?
1995 Miata
 Old 10-11-2012, 06:59 PM   #258
TurboGsxr600's Avatar
Posts: 127   (View Stats)
TurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond reputeTurboGsxr600 has a reputation beyond repute
I think my autotech internals have started rattling. At first I thought it was the VVT but the sound is loudest around the cdfp. The sound started as it got colder outside. When I first start the car its almost like a metal on metal sqeeling sound followed by a knocking sound. It only lasts until car is warmed up. Fuel pressure is fine. Does this sound normal?
TurboGsxr600 is offline   Reply With Quote
 Old 10-11-2012, 08:45 PM   #259
I don't know enough at this point to give any real advice. At this point my goals are to learn as much as I can and report on things that happen after my upgrades.
Since my internals were put in they have been very audible. This happens at tip in and also while maintaining a constant speed. To be accurate, at a constant speed they are not as loud as they are at tip in, but still annoying.
The tip in rattle is the same warm or cold. However, the rattle during steady cruising is somewhat worse when cold.
I don't know if this helps you or not, but when I start mine up in the morning it is like a factory vehicle. I don't have any rattling beyond what would be normal. Also, anytime at idle, warm or cold, the pump sounds fine.
Fuel pressure holding is not a bad thing, that much I can say!
 Old 06-26-2013, 04:46 PM   #260
xecuter2's Avatar
Posts: 100   (View Stats)
xecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to behold
I am running T6 with autotechs and noticed the tip in rattle since I installed them(thought it was something else and stumbled on this thread). Power is 100%, noise is only on throttle blip, and pressure is 100%. Should I deal with it? Me likey T6 and reading this eases my mind but makes me want to go to Penzoil :/
2013 white PU - | CP-E Down Pipe | CX FMIC | COBB SRI/AP V2 | HTP TIP | AutoTech HPFP Internals | CS OCC/BPV | Denso ITV22/NGK LTR7IX-11 | JBR Bushings/Weight/Knob/TBCBypass/RSB/88a RMM/88a TMM| RichTuned FTW
307/313 Dynocom dyno @ 88f
xecuter2 is offline   Reply With Quote
 Old 06-26-2013, 06:08 PM   #261
ms6mil's Avatar
Posts: 4,972   (View Stats)
ms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the world
Groans: 307
Groaned at 6 Times in 6 Posts
I have had my internals in for couple years with the tip in rattle, only noticeable when outside the vehicle and hood is up. I have double checked for wear and haven't found anything remarkable. Pressure is good no problems. I have installed them on a few cars and they too have the tip in rattle as well. Everyone is good so far. It's been 1-2 years of running their internals with no problems. I just keep an eye on FP as a part of my daily log checks.
"Here am I. Send me!"
____________________________________________
Columbus, GA 2006 MazdaSpeed 6
EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel
GT3076 - 393/380 3/9 e85
GT3076 - 426/400 E85/DO10 Meth
PTE5862 - TBD
ms6mil is offline   Reply With Quote
The Following User Says Thank You to ms6mil For This Useful Post:
xecuter2 (06-26-2013)
 Old 06-27-2013, 11:02 AM   #262
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Originally Posted by 86azms3 View Post
We're still discussing this? Normal, it's a high pressure pump and it's not radial or centrifugal...its going to be noisy. Plus at tip in there is probably slight cavitation going on causing more noise. This is especially true when you have large delta pressure differentials.
Guess should hear positive displacement pumps when they start cavitating...clackety clackety clack. So loud you'd think it's metal metal contact, but not the case at all.
See above post.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 07-02-2013, 10:06 PM   #263
Groans: 30
tl;dr Noise is normal, don't worry about it.
/thread
1995 Miata
dinoxor (01-12-2016)
 Old 08-01-2013, 12:26 AM   #264
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
Subd
Sent from my Nexus 10 using Tapatalk HD
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
 Old 08-01-2013, 06:55 AM   #265
BigJimMs3's Avatar
Groans: 76
Holy shit this thread is still alive!!!!!
xecuter2 likes this.
2006 Mazdaspeed 6
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
Stock
Vader (08-01-2013)
 Old 03-23-2015, 12:45 PM   #266
under28world's Avatar
Posts: 24   (View Stats)
under28world is a name known to allunder28world is a name known to allunder28world is a name known to allunder28world is a name known to allunder28world is a name known to allunder28world is a name known to all
2 years later and problem still exists, pulled out and inspected and same issues exist!
2012 Mazdaspeed3, "Silky Johnson"
* Corksport 80 RMM * JBR 80 PMM * JBR 88 TMM * Cobb V3 Acessport * Autotech HPFP * Corksport TIP/CAI * JBR Boost Tubes * UR Race Pipe * SU TMIC * Forge V1 BPV * JBR EGR Delete * Corksport Carbon Fiber Hood Scoop * Corksport Single outlet CBE * NGK One step Colder * Rear Wiper Delete * Stickers to add to the RICE * PURPLEDRANK Tune * * Environmentally Friendly allll Organic *
Winter Vehicle 2004 Ford V8 Explorer "Boss Hogg"
* Kenwood in-dash dvd * 2 Kicker 12" CVR Comp" * Apline 1000w Mono amp*
under28world is offline   Reply With Quote
The Following User Says Thank You to under28world For This Useful Post:
TheProYodler (02-02-2016)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/fuel-pump-rattle-53241/
PTP pump, bushings and spark plugs This thread Refback 03-18-2012 10:09 PM
Possible CP-E HPFP going bad? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 07-19-2011 01:47 PM
Log after PTP Fuel Pump taf0422 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 03-02-2010 03:30 PM
Issues with fuel pump pressures, aftermarket pump... ptperformance MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 10-04-2009 06:17 PM
PTP Fuel Pump Cornerfreak Mazdaspeed3/6 General Discussion 4 09-28-2009 09:35 AM
Do I need a fuel pump. dread
Cobb Access Port/Maps
13 12-14-2008 08:06 AM
which fuel pump to get? Buildabong MazdaSpeed 3/6 - Turbo Induction 20 10-15-2008 11:43 AM
Page generated in 0.45954 seconds with 36 queries
