![]() | | #41 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score
GM has stated that they will be switching over to DI, so will Ford, Toyota and many others by 2012. Its going to be standarized for the industry here before to long. Either you agree to move forward or die watching, thats going to be the only options that we have. | |
![]() | | #42 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score i'm gonna call BS on that one. there are at least a dozen cars out there right now making over 320 HP at the crank. it doesnt take much man....TBE, CAI, IC upgrade, 18+psi.....DONE ! i have seen at least 3 cars with dynos at or just above 300WHP that would come out to over 320 at the crank. none of those cars had AFR problems. well laloosh's car has high AFRs all the time ! not to mention all the guys out there with the same or more mods than those guys that are not having a fueling problem. |
![]() | | #43 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
![]() | | #44 | ![]() |
![]() Join Date: Mar 2008 Location: PA
Rep Power: 1820 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
(Thread Starter) | Not Ranked : 0 score this mod understandably will not be for everyone the part of this fuel system that some people are leaving out of their equation is the term "system" not one magical part like a CDFP upgrade but all the parts that make up the delivery system, including the fuel lines we know the in tank fuel pump will only support about 400HP(crank) my extra OEM pump was flow tested at Kinsler and we have proof so being a self proclaimed common sense thinker, I'm going to have to say that the majority of the rest of the fuel system tops off at about that 400HP limit so what to do? you add a pump booster to increase the volatage to the in tank pump which increases the flow to the cam pump which now will support alomost 600HP at 16volts then you upgrade the CDFP>great plan what's next? From what I see...it's a 1.5mm feed hole that will hold you back from ever reaching a certain HP figure over 380-400(again crank HP)>after thinking about it, if the 1.5mm hole can support near 400HP>a 1MM increase in size will most likely be sufficient since 1mm is a 66% increase in size which equates to over 600HP of flow capability (again all theory) the last item is going to be the tough one...... the injectors I'm about to post a group testing donation thread over on the 6 club to confirm the flow capability of the injectors I've been told they have been tested before and are 800cc After we confirm the injectors are maxed out at the 400HP level, then what? I have an plan but that's later...
__________________ 2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008) 2008 Caliber SRT4 / 11.8 @ 120 Last edited by whoosh@Realtune; 04-29-2008 at 01:38 PM. |
| The Following User Says Thank You to whoosh@Realtune For This Useful Post: | mdogg (04-29-2008) |
![]() | | #45 | ![]() |
I will state it yet again, do the math for BSFC and you will see what I am getting at. It takes a while to do the math but when its all done you will see what I am getting at. | |
![]() | | #46 | ![]() |
| Not Ranked : 0 score We have 5 injectors sitting at the injector shop right now. I will have flow rates and upgraded unit here in a while if all goes well. I was looking to be the first to have upgraded injectors on the market since no one else feels it important to do anything with the stockers. Whoosh send me a link for that "donation" for testing I will be more then willing to help. |
| The Following 2 Users Say Thank You to ptperformance For This Useful Post: | MazdaMan13 (06-02-2008), whoosh@Realtune (04-29-2008) |
![]() | | #47 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groans: 57
| Not Ranked : 0 score 800cc wont support 500whp. My friends rsx is running 750 at 94 percent DC and is running out of fuel....His rsx makes about 350 max |
![]() | | #48 | ![]() |
GDI injectors have a different electronic coils that require an adaptor box to test them properly most places do not have this equipment and frankly are not interested in GDI(gasoline direct injection) if you are lucky enough to find a place that has the ASNU equipment to test the injectors, you'll be upset to find out that they will be tested at a max of 5 BAR or 72.5PSI I don't have to remind everyone that we would want flow testing at 1550PSI to 2000PSI so all you are left to do is calculate the "possible flow" from those numbers this GDI stuff gives me a headache I don't mind headaches though.....I'm used to it Jon, that was not a lecture for you as I'm sure you know this stuff it's basically FYI for those that want to know I'll certainly send you a link and I'm going to fire off a few PM's to you about some stuff...
__________________ 2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008) 2008 Caliber SRT4 / 11.8 @ 120 | |
![]() | | #49 | ![]() |
![]() Join Date: Mar 2008 Location: Yakima, Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
I agree. I have multiple datalogs showing the "Commanded Throttle Actuator" dropping before my boost has even peaked out. When it does this my car momentarily goes lean (12.5-13.5) then the throttle responds to the lean condition and starts opening again. Fuel pressure was always high (1600-1700 psi) during this. The thing is, nothing in my logs can justify why the throttle plate started closing. It does this when I can honestly say the "butt" dyno felt like the car was pulling hard as hell. On top of this, with all my mods, I honestly feel like i'm not getting much more power anymore. I think the ECU has adjusted to all the changes, almost like it's trying to keep the power output in check. After many days of driving and letting the ECU adjust, my SW dynos indicate almost the same HP/Tq as before my mods. I believe that changing fuel flow or injector capacity will only make the ECU reduce fuel pressure or the throttle plate....
__________________ 2007 MAZDASPEED 3, MS CAI, MS CBE. | |
![]() | | #50 | ![]() |
![]() Join Date: Mar 2008 Location: Orange County Ca.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,353
| Not Ranked : 0 score so how did this mod work out woosh? |
![]() | | #51 | ![]() |
| MSF Punished Member ![]() Join Date: Apr 2008
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score actually, i asked the duty cycle of the injectors, because even injectors in the intake cannot be on 100% of the time, because they will burn out... |
![]() | | #52 | ![]() |
![]() Join Date: Mar 2008 Location: Perth Amboy, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 704
Groans: 86
Groaned at 36 Times in 25 Posts
| Not Ranked : 0 score how about we keep this thread to the relevant information to allowing us to push more volume?
__________________ L76-powered |
![]() | | #53 | ![]() |
I don't even want to post results in this thread anymore Maybe I'll start another thread...
![]() | | #54 | ![]() |
![]() Join Date: Mar 2008 Location: North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
-enganear | |
![]() | | #55 | ![]() |
I get frustrated when threads that are meant to inform turn to shit when members down the road want to look for info, they are forced to read through tons of off topic crap
![]() | | #56 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,016
| Not Ranked : 0 score Cleaned up a bit !! |
| The Following 5 Users Say Thank You to NYpest For This Useful Post: | Crossbow (05-03-2008), FreeFlyFreak (08-25-2008), mdogg (05-02-2008), SLS MS3 (05-02-2008), whoosh@Realtune (05-02-2008) |
![]() | | #57 | ![]() |
![]() Join Date: Mar 2008 Location: sc
| Not Ranked : 0 score Reading through this thread I'm thinking what a decent idea. Then I start noticing all the comments about not being the guy that blows up. Well i'l be god damned if i didn't put a rod through my block on monday. I hate all of you for reminding me what its like being out in front of the industry.
__________________ I hate my mazdaspeed3 more than anything else in this world! |
![]() | | #58 | ![]() |
| Not Ranked : 0 score any idea why your motor went ? your mods dont look too insane ??? |
![]() | | #59 | ![]() |
| Not Ranked : 0 score your kidding right? name a mod i don't have
![]() | | #60 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 49
Groaned at 179 Times in 125 Posts
| Not Ranked : 0 score what kind of tune were you running on the standback? were you on the stock map? btw.... its hard not to take this topic a little "off topic".... when we are discussing the limitations of the fuel system on our cars its inevetitable that questions will be posed that dont relate to the diameter of the free fuel mod. I think this topic will always come right back on when we get results from the experimentations.... at this point this is speculation. Thank you Whoosh for your work here. I think the results good or bad will be big news around here. |
![]() | | #61 | ![]() |
| Not Ranked : 0 score jordan helped me tune the car over the phone. a/f never went over 11.2... on a mustang dyno i pulled almost 280 and 300 ft lbs (hitting fuel cut on stock boost) since than i added 4 lbs of boost, fuel pump, manifold, and new turbo, god only know what my numbers were. btw sorry for the thread jacking!!!!
![]() | | #62 | ![]() |
| Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,602
Groans: 244
| report the thread and we WILL clean it up.
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | |
![]() | | #63 | ![]() |
| Not Ranked : 0 score Guys i mean no disrespect but Woosh has asked that we keep this about the fuel mod ... |
![]() | | #64 | ![]() |
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
| Not Ranked : 0 score Hey whoosh, are you increasing the size of the hole in the return line as PTP mentioned, or are you trying it without first? |
![]() | | #65 | ![]() |
![]() | | #66 | ![]() |
| Not Ranked : 0 score I have modded dump valves for the pump now. Let me know if you want one for testing. |
![]() | | #67 | ![]() |
| Not Ranked : 0 score Whoosh I will be calling this weekend. I have some results I want to share with you since it has warmed up here. AFR's are all the way down into the low 8's now. I have so much fuel on the stock pump I am going to have to piggy back the MAF sensor. |
![]() | | #68 | ![]() |
![]() Join Date: Mar 2008 Location: Earth
| Not Ranked : 0 score So has this mod been tested yet? Whats the outcome? Status?
__________________ 2008 Stage 3 Roush Mustang 302E 5.0L Stroker 647rwhp-620 rwtq |
![]() | | #69 | ![]() |
| Not Ranked : 0 score I am working the details out right now. I had to order another line because I have to much fuel now. No matter what I do I have black puffs out the back everytime I go WOT. It works very well and I suspect that is a major reason Whoosh has been able to run 20 + psi on the GT35 on his car now. |
![]() | | #70 | ![]() |
![]() Join Date: Mar 2008 Location: Planet Earth, v3.7
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
__________________ The fastest MS3 in the whole garage... | |
![]() | | #71 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to ptperformance For This Useful Post: | winniep (05-23-2008) |
![]() | | #72 | ![]() |
Groans: 49
| Not Ranked : 0 score thats awesome jon...geez. too much fuel? its almost hilarious just to say it. we have waited along time to say those words around here...lol |
![]() | | #73 | ![]() |
| Not Ranked : 0 score How much did you enlarge the orafice? How did it effect the rail pressure? |
![]() | | #74 | ![]() |
(Thread Starter) | Not Ranked : 0 score this mod is bigger than most realize I'm now playing with the fuel rail... after enlarging the feed line, the return orafice in the fuel rail to the CDFP is seemingly too small that is being enlarged as well with the upgraded CDFP + flow mods we won't need much more fuel to go big IMO which is a good thing vs. additional injectors, etc etc but the injectors are still the unknown at this point in terms of cc size and potential we're working on it guys....
| The Following 4 Users Say Thank You to whoosh@Realtune For This Useful Post: |
![]() | | #75 | ![]() |
| Not Ranked : 0 score i'm missing how there is too much fuel. the car is still ecu controlled correct ? its my understanding that the ecu controls the fuel addition by controling the injectory duty cycle. it bases how long the spray period based on the fuel rail pressure. so just having the abilty to get more fuel to the rail shouldnt matter as far as AFR's are concerned, because the pressure will still be the same, or likely lower than before. i do see this being beneficial when the stock system just cant flow what you need, but i dont see how it would have that kind of effect on a computer controlled car. |
![]() | | #76 | ![]() |
__________________ 2008 Stage 3 Roush Mustang 302E 5.0L Stroker 647rwhp-620 rwtq | |
![]() | | #77 | ![]() |
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
| Not Ranked : 0 score FYI: Be careful not to run that rich to long if you are catted. Fuel will collect in the cat's substrate, ignite and create extreme temps then eventually melt it. You will start feeling loss of power due the substrate clogging the exhaust flow, sound of hissing will be heard, also the cat will get so hot the car will catch fire. Oh yeah forgot, the metal of the exhaust piping, turbo, turbo manifold before the cats will start to extreme heat crystalize and become brittle and crack if ran like that for awhile before the hissing and fire lol. If you don't have cats then you are fine, it'll just come out the tail pipe. Last edited by bioevolve; 05-24-2008 at 07:12 AM. |
![]() | | #78 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
| Not Ranked : 0 score Who is the manufacturer of the injectors for our car. If it's not mazda, maybe the manufacturer has some info they are willing to share with someone. You all have probably thought of that though and got shut down. I just haven't heard of anyone trying this yet. |
![]() | | #79 | ![]() |
Groans: 244
| 50/50 chance its Bosch
![]() | | #80 | ![]() |
| Not Ranked : 0 score Yes way to much fuel. I have to get an idea on pump pressure but they still seem to be falling off. Upgraded pump piston is still going to be a must on these to keep the pressure where its needed.... up top. Volume is there, pressure is not. I will have more info on this in 2 weeks. |
| Holy shit! I've got an idea! | ATE BALLER | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 34 | 09-20-2008 10:04 AM |
| Rear bumper scuff guards, pics inside | Death-From-A-Mile | MazdaSpeed 3/6 - Appearance | 11 | 05-08-2008 08:07 PM |
| BMW to increase U.S. sourcing, and possibly manufacturing volume | Haltech | Automotive News | 0 | 04-15-2008 03:10 PM |
| Painted the lip of my wheels, pics inside! | Death-From-A-Mile | MazdaSpeed 3/6 - Wheels & Tires | 16 | 04-14-2008 12:41 PM |
| VTU's Bright Idea About Brake Lights | Haltech | Computers & Technology News | 0 | 04-07-2008 09:20 AM |
