Notices
 Old 07-15-2012, 09:26 PM   #1
sgwrist's Avatar
Posts: 1   (View Stats)
sgwrist has a little shameless behaviour in the past
Default Gear-like noise at Idle, stops when clutch is pressed
I have an 09' MS3 at 24k miles. When the car sits at idle, I hear gear-like chatter, but as soon as I press the clutch in, the chatter goes away. Is this normal?
sgwrist is offline   Reply With Quote
The Following 2 Users Say NO Thank You to sgwrist For This Un-useful Post:
emag remrofni (07-15-2012), Mizzle (07-15-2012)
 Old 07-15-2012, 09:34 PM   #2
tddvrrn's Avatar
Posts: 2,572   (View Stats)
Groans: 103
yes. it is your throw out bearing. it's normal. some are noisier than others.
searchy searchy next time, yes?
 Old 07-15-2012, 09:34 PM   #3
Posts: 7,988   (View Stats)
Groans: 34
I would guess you didn't buy the car new?
could be the TO bearing or that is what a single mass flywheel will sound like. OE uses a dual mass wheel which masks the gear noise in the tranny.
perfectly normal if the flywheel has been replaced.
PERM
07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
The hardest part of modding is knowing when you've met your goal
I dunno though; it sounds good in my head but I'm mostly talking out of my ass.
Dano is online now   Reply With Quote
 Old 07-15-2012, 09:39 PM   #4
tddvrrn's Avatar
Groans: 103
could be an aftermarket TMM as well. they make all the noise in the tranny audible.
mine's noisy as fook, but when i push the clutch... silence.
 Old 07-15-2012, 11:44 PM   #5
86azms3's Avatar
Posts: 2,988   (View Stats)
86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world
Groans: 237
Groaned at 70 Times in 36 Posts
Fuuuuckkk!!!!!
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
Treadstone 3" MAF, HTP 3" turbo inlet, hallman pro rx bc, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP,
Turbosmart Hybrid bpv, SURE TIG's + coolant bypass,
ITV24's, CP-E 75d RMM, Medefail Tranny mount,
DDM 35W 6000K HID's, SURE Counterweight,
18x8 245/40 NT-05's up front, R: 225/45 Sport Maxx TT's
390whp/400wtq
86azms3 is offline   Reply With Quote
 Old 07-16-2012, 12:44 AM   #6
Track Fiend
Standsideways's Avatar
Posts: 405   (View Stats)
Standsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the world
Release bearing
Standsideways is offline   Reply With Quote
 Old 07-19-2012, 11:46 AM   #7
MazdaSpeed3NY's Avatar
Posts: 26   (View Stats)
MazdaSpeed3NY has a spectacular aura aboutMazdaSpeed3NY has a spectacular aura about
Good old throw out bearing.
Sent from my iPhone using Forum Runner
MazdaSpeed3NY is offline   Reply With Quote
 Old 07-19-2012, 12:21 PM   #8
King Pimp/Scammer Hunter
Raider's Avatar
Posts: 14,817   (View Stats)
Groans: 446
I have a TRZ Transmission mount, and I get the noise clutch out too Goes away when depressed. It is probably got a mount installed. If not, TOB.
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
 Old 07-22-2012, 07:35 PM   #9
Boother's Avatar
Posts: 135   (View Stats)
Boother has much to be proud ofBoother has much to be proud ofBoother has much to be proud ofBoother has much to be proud ofBoother has much to be proud ofBoother has much to be proud ofBoother has much to be proud ofBoother has much to be proud ofBoother has much to be proud ofBoother has much to be proud of
It is not the throwout bearing, it is the transmission. Essentially all manual transmissions are consant mesh which means that all gears are "engaged" all the time. When you release the clutch, it is spinning all the gears in the transmission and you can hear them.
This is perectly normal and all manual trans cars will do this.
Boother is offline   Reply With Quote
The Following User Says Thank You to Boother For This Useful Post:
outshined (07-22-2012)
 Old 07-22-2012, 07:37 PM   #10
whyte07's Avatar
Posts: 49   (View Stats)
whyte07 is a splendid one to beholdwhyte07 is a splendid one to beholdwhyte07 is a splendid one to beholdwhyte07 is a splendid one to beholdwhyte07 is a splendid one to beholdwhyte07 is a splendid one to behold
I think its the TO bearing
'10 F150 blackout..CAI, Borla exhaust, superchips
08 MS3 GT Tech...
Corksport TIP
Corksport SRI
CP-e RMM
OBX test pipe
CNT CBE
Escort passport 8500 x50 blue
plati dip emblems and stocker wheels
whyte07 is offline   Reply With Quote
 Old 07-22-2012, 08:12 PM   #11
Boother's Avatar
There is no load on the TOB when the clutch pedal is released. It would make more noise when the pedal is depressed.
 Old 07-24-2012, 11:48 AM   #12
Track Fiend
http://www.valeoclutches.com/media/d...ithPedalUp.pdf
This Will be a Good read for some of you
 Old 07-24-2012, 11:55 AM   #13
SpeedPerf6rmanc3
voltron's Avatar
Posts: 3,368   (View Stats)
voltron is the leader of the worldvoltron is the leader of the worldvoltron is the leader of the worldvoltron is the leader of the worldvoltron is the leader of the worldvoltron is the leader of the worldvoltron is the leader of the worldvoltron is the leader of the worldvoltron is the leader of the worldvoltron is the leader of the worldvoltron is the leader of the world
Groans: 43
Groaned at 14 Times in 14 Posts
I put my JBR tmm 88 on, makes same noise. Annoying as fuck.
2012 HYPNOTIC TUNED
12.15@117 Mason Dixon Raceway 4-14-13 fastest stock block gen2
SpeedPerf6manc3 blessed
voltron is online now   Reply With Quote
 Old 07-24-2012, 03:42 PM   #14
sidekick's Avatar
Posts: 1,463   (View Stats)
Groans: 30
Groaned at 42 Times in 26 Posts
THIS. The gears on the input are always touching the gears on the output shaft, so there will be gear noise with the clutch pedal released. Simple as that. A bad TOB will make a noise like ball bearings bouncing around inside of the trans. Ask me how I know...
Vibration/noise when turning car off and idle ShadyZealot MazdaSpeed 3/6 - Troubleshoot/Diagnostics 11 08-28-2012 09:01 AM
Weird noise at idle XerocX MazdaSpeed 3 - Engine, Transmission & Driveline 9 05-04-2012 04:52 PM
Rattle noise from engine at idle RichB MazdaSpeed 3 - Engine, Transmission & Driveline 20 09-22-2011 09:19 AM
Clutch noise Blackhawk MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 08-15-2011 12:40 AM
oil, idle and clutch question. 07ms3obrien MazdaSpeed 3 - Engine, Transmission & Driveline 2 11-21-2010 03:54 PM
Page generated in 0.36657 seconds with 30 queries
