 Old 07-20-2009, 03:56 PM   #1
cbspeed3's Avatar
Posts: 203   (View Stats)
cbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond repute
Default has anyone with built motor broke a rod
has anyone with built motor broke a rod????
cbspeed3 is offline   Reply With Quote
 Old 07-21-2009, 05:28 PM   #2
JAZZY's Avatar
Posts: 27   (View Stats)
JAZZY is a jewel in the roughJAZZY is a jewel in the roughJAZZY is a jewel in the rough
Where are all the options for the rods and windage tray listed for the madaspeed3?
JAZZY is offline   Reply With Quote
 Old 07-21-2009, 05:44 PM   #3
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
yes, I once built a 427 for my luv truck (1st engine) , steel crank and rods tried a 225 shot at the track and instant see-through block at 7800rpm courtesy of #2 rod.
live and learn to NOT cut corners.
oh my bad ms3 talk...fuck phillyb
 Old 07-21-2009, 07:05 PM   #4
SgtP's Avatar
Posts: 2,130   (View Stats)
Groans: 106
usually the rod breaks, causing the engine to be rebuilt. i havent seen it the other way around.
13.2@111
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
 Old 07-21-2009, 07:21 PM   #5
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
ive been pounding on my built engine and it loves it.
Dyno'd at 355whp on the stock exhaust and im runnin 125hp worth of nitrous.
I think MrLilGuy was the only one to blow a built motor and it was due to a defect in the piston.
 Old 07-21-2009, 07:28 PM   #6
Laloosh's Avatar
Posts: 5,166   (View Stats)
Groans: 57
dynoed 355 and have yet to hit that number again. I wish you lucky, but i have a feeling your recent cutting is not the battery cable.
 Old 07-21-2009, 07:36 PM   #7
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
always there to shit on anyone who posts numbers, are you ever going to get over it?
802MS3 (07-22-2009)
 Old 07-21-2009, 07:41 PM   #8
Laloosh's Avatar
Groans: 57
true or flase: Speedshon has hit 355 one time, the next dyno days he wasnt even close. Answer the question then speak
 Old 07-21-2009, 07:56 PM   #9
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
^this guy is funnnnny.. you must enjoy making enemies
Deadman is offline   Reply With Quote
 Old 07-21-2009, 09:00 PM   #10
Looshie, this is for you:
335I Engine BLOWS @1400 miles! - BMW Forums - E90Fanatics
 Old 07-21-2009, 09:30 PM   #11
bova's Avatar
Groans: 45
true or false: the only time you've posted recently is when dyno numbers are brought up or the strength of rods? answer the question and i'll let you know if i actually care.
 Old 07-21-2009, 10:59 PM   #12
JumpingJackson's Avatar
Posts: 967   (View Stats)
JumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the world
Seriously Laloosh its getting fucking old. Post something constructive or GTFO.
JumpingJackson is offline   Reply With Quote
The Following 3 Users Say Thank You to JumpingJackson For This Useful Post:
802MS3 (07-22-2009), ChrisK (07-22-2009), triplejumper18 (07-22-2009)
 Old 07-22-2009, 05:51 AM   #13
socks's Avatar
Groans: 125
The reason i havent hit that dyno number again is because the only other dynos i have done were testing a manifold that obviously had a design issue. My car was not the only car that dyno'd lower on that manifold.
I havent gone back to the dyno yet because i had alot of different ends to tie up with the car. Youll see me dyno very soon.
would you like pictures of my melted battery cable? would you like pictures of where it was arcing and grounding out?
you so silly.
The Following 2 Users Say Thank You to socks For This Useful Post:
MarkyMark (07-22-2009), Sport6 (07-22-2009)
 Old 07-22-2009, 06:07 AM   #14
2007speed3's Avatar
Posts: 1,486   (View Stats)
2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world
so if on were to build this engine how much would it cost.??? 1 or 2 g's sound good?
what would you do just rods, maybe pistons, what else????
My engine is in 100% good condition no speed holes.
2007speed3 is offline   Reply With Quote
 Old 07-22-2009, 06:08 AM   #15
socks's Avatar
Groans: 125
it cost me about $1800-2000, dont even consider trying to do it for less.
Rods/pistons alone are gonna be at least $1250, then you need all your bearings, head studs, main studs, gaskets, machine work, etc...
 Old 07-22-2009, 07:11 AM   #16
Thermonuclear Skeet
FantasmoNegro's Avatar
Posts: 2,810   (View Stats)
FantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the world
Groans: 188
Groaned at 333 Times in 222 Posts
He is a douchebag, just ignore him.
El Fantasmo Del Negro
Helicopter Cat LIVES
FantasmoNegro is offline   Reply With Quote
 Old 07-22-2009, 07:21 AM   #17
socks's Avatar
Groans: 125
I thought the same thing when it started cutting. I initially thought it was fuel cut, because thats what it felt like. So I figured with the 125 jets i was taxing the low pressure fuel system too much. I made another pass with the nitrous off, and thats when i realized i was losing electrical power when it would happen. started poking around and my battery cable that was behind the heatshields was all kinds of fucked up...
 Old 07-22-2009, 12:04 PM   #18
Laloosh's Avatar
Groans: 57
every car breaks sometimes.....find 1 more and ill show you 100 over 400whp
 Old 07-22-2009, 12:05 PM   #19
Laloosh's Avatar
Groans: 57
true, where would you like me to post? In the nator performance thread, the poop thread, the weed thread or picture of Lara's white car thread?
The Following 4 Users Say Thank You to Laloosh For This Useful Post:
k0m (07-23-2009), Scatt Nasty (08-05-2009), silversurfer3 (07-22-2009), whoosh@Realtune (07-22-2009)
 Old 07-22-2009, 12:07 PM   #20
Laloosh's Avatar
Groans: 57
I am posting contructive stuff, bringing down people to reality and shooting down bs dynos is constructive for those who actual think these reasons/dynos are real. IF it bother you that much, dont post in it.
 Old 07-22-2009, 12:07 PM   #21
Laloosh's Avatar
Groans: 57
whats the matter? your sister turn you down this morning?
 Old 07-22-2009, 12:09 PM   #22
Laloosh's Avatar
Groans: 57
I want you to trap mid 120s, im just saying despite the battery cable grounding out, i think it will cut again once that problem is fixed, just a hunch though.
 Old 07-22-2009, 12:15 PM   #23
RayRayBauder's Avatar
Posts: 1,999   (View Stats)
RayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the world
Groans: 234
Groaned at 154 Times in 122 Posts
i dont think anyone with a built engine has broken a rod... or 400hp...
'08 MazdaSpeed3 - sold
RayRayBauder is offline   Reply With Quote
 Old 07-22-2009, 12:58 PM   #24
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
loosh, you suck.
'08 CWP MS3 w/ T3 3071r
 Old 07-22-2009, 02:04 PM   #25
Thermonuclear Skeet
Groans: 188
Your mother did.
Its pretty sad that your life outside of the computer is so insignificant that you have to let your insignificance on the internet effect you so badly it made you become nothing more than an attention whore with a dick. Dude you have nothing to contribute to this website, so why do you come on here? I think its because you really are a pathetic sad piece of shit and the little bit of importance you had on here once upon a time is all that you were worth. Too bad your words are irrelevant on here, it must suck.
 Old 07-22-2009, 02:24 PM   #26
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
"nightrider8288" on here John with nitrous made 380whp and 401wtq with stock turbo and stock engine at Turbochargers in houston I saw the dyno sheet and David with mazda3mods drove the car on the dyno.
 Old 07-22-2009, 02:39 PM   #27
socks's Avatar
Groans: 125
you think i havent used the nitrous? it hasnt cut once until the battery cable was an issue.
all the cuts except for the fuel pressure drop are gone. so if that not an issue, which it shouldnt be, i should be good to go.
 Old 07-22-2009, 03:40 PM   #28
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
subparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the world
Groaned at 6 Times in 6 Posts
Shons car is slow. I've seen him get beat by a huffy.
2006 Lotus Elise: Toy car
1999 B4000: DD / Parts hauler / SC Project
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
subparpunk03 is offline   Reply With Quote
 Old 07-22-2009, 03:47 PM   #29
Laloosh's Avatar
Groans: 57
Your mother did.
back to work
you can say all you want, however im not the one who admitted to fucking his sister, then posting pics of her. like CMON. What do you have to contribute to this site? What did you contribute to this site....you a fucken waste with no info/knowledge.
 Old 07-22-2009, 03:53 PM   #30
Laloosh's Avatar
Groans: 57
like i said, its just a hunch. Have you used the nitrous for full 1/4 pulls on the street? over and over again? 0 issues?
 Old 07-22-2009, 04:16 PM   #31
socks's Avatar
Groans: 125
I have, 40-140, ive gone through 2 tanks now... pretty much one on a 55shot, and one on a 125shot.
zero fueling issues. only issues ive had were boost control (corrected via larger wastegate) and my battery cable, for which i admit (read track day didnt go so well thread) was my own fault.
 Old 07-22-2009, 04:41 PM   #32
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
Interesting threadjack catfight! No clear winner.
Returing to the OP's question: I'm assuming that broken, bent, or otherwise damaged rods are not happening with properly built engines, at least when not spraying nitrous or cranking the boost up to outrageous levels? Is that right?
 Old 07-22-2009, 04:41 PM   #33
Thermonuclear Skeet
Groans: 188
back to work
If you couldn't tell that I was fuckin with you, you are dumber than you look. I contribute plenty on here, you just don't read much because I am not crying out like an attention whore like you do.
 Old 07-22-2009, 05:43 PM   #34
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
i'm gettin a chubby again./..
 Old 07-22-2009, 05:45 PM   #35
Laloosh's Avatar
Groans: 57
no1 jokes around about fucking their sister....
what do you contribute or have contributed in the past? I read most of the treads, i see that your useless. proove me wrong
 Old 07-22-2009, 06:10 PM   #36
SpeedSixxx's Avatar
Groans: 778
chubby turning into larger erection!!!
 Old 07-22-2009, 06:14 PM   #37
danesti's Avatar
Posts: 4,186   (View Stats)
danesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the world
Groans: 137
has anyone besides mr lil guy blown on a built motor?
damn i wish i had the knowledge/time to build... shit would be straight titties.
loosh knows stuff he just likes the peepee in his butt...
2008 STi
Intake
Turboback
AP
danesti is offline   Reply With Quote
 Old 07-22-2009, 06:15 PM   #38
SpeedSixxx's Avatar
Groans: 778
did you say pee pee in da butt?
(_0_) <===((
The Following User Says Thank You to SpeedSixxx For This Useful Post:
danesti (07-23-2009)
 Old 07-22-2009, 08:25 PM   #39
Thermonuclear Skeet
Groans: 188
Well I guess I am a nobody then because I did joke around
http://www.mazdaspeedforums.org/foru...tml#post272484
Post # 62. Not technical at all but more than you have contributed in the same time period. When you get on here all you do is spit venom. Your reality is not reality. Maybe if you weren't so big a douche you would know about some of the pieces in the pipe line and you would see the same light that some of us do. Shit is getting done at DCR, major steps to making power have been accomplished but not spoken of and all you can do is talk shit about shit that has already been solved and moved on from. So with that homie. I am done letting you entertain me for the night.
 Old 07-23-2009, 05:17 PM   #40
k0m
k0m's Avatar
Posts: 134   (View Stats)
k0m has a spectacular aura aboutk0m has a spectacular aura about
one of the best posts ive seen...thanks loosh
k0m is offline   Reply With Quote
list of guys that has built motor and upgraded turbos johnac08 MazdaSpeed 3/6 - Turbo Induction 13 02-16-2010 06:35 PM
built motor ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 17 05-20-2009 10:22 AM
Broke out the camera... Radspeed6 MazdaSpeed 3/6 - Appearance 12 04-18-2009 03:56 PM
First o2 sensor broke sk33ny MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 02-12-2009 06:55 PM
Who Has A Built Motor? Need Impressions Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 99 12-22-2008 08:51 AM
Page generated in 0.59808 seconds with 39 queries
