MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Jun 2017 Location: San Diego Ca.
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | ![]() ![]() ![]() |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 1329 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,702
Groans: 105
| ![]() ![]() ![]() Stick with OEM for gasket and bolts.
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Sep 2016 Location: Georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 3 Times in 1 Post
| ![]() ![]() ![]() I would tend to stick with mazda for those things. more expensive but at least you know it will fit and work. |
![]() | ![]() | #4 | ![]() |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2416 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 805
Groans: 48
| ![]() ![]() ![]() Custom head and timing cover gaskets Thread was better before photobucket decided to fuck everyone, but the new head gasket looks really good, and the timing cover gasket is way better than gasket maker..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks Soon to be installed: ST manifold w/ port injection : Raduim Engineering PCV Plate : Radium Engineering PCV valve : Radium Engineering Fuel filter : Aeromotive FPR : DCR VVT : TI Automotive F90000262 Fuel Pump : NX 15718 : Split Second AIC |
The Following User Says Thank You to SSinstaller For This Useful Post: | impossible (08-22-2017) |
![]() | ![]() | #5 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 241
| ![]() ![]() ![]() OEM Mazda gasket will hold more than double the power/boost than you will make.
__________________ Gen 2 2012 - ATP GTX3076r IWG - Full Race exhaust mani - 2NV Industries built Forged bottom end - PNP Head - JMF Intake Mani- UR Turbo Back - JBR tru 3.5 intake - TR8 FMIC - Devils own stage 2 WM - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
![]() | ![]() | #6 | ![]() |
(Thread Starter) | ![]() ![]() ![]() I thought Cometic only made TC gasket that one time. I checked the website and it doesn't list it for our vehicles. |
![]() | ![]() | #7 | ![]() |
![]() Join Date: Feb 2012 Location: bethpage ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,270
Groans: 71
Groaned at 7 Times in 6 Posts
| ![]() ![]() ![]() Go with oem head bolts you dont need studs unless you are chaseing big numbers or you want to reuse them. Stick with oem 3 layer. Custom gaskets 4 and 5 layer are for when you have a lot of material taken off of the block and/or head surface and want to make it up with the gasket.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra | |
![]() | ![]() | #8 | ![]() |
Groans: 48
| ![]() ![]() ![]() I ordered one a few weeks ago, it's not on the site but if you call they will sell it to you. It was $36 shipped..
![]() | ![]() | #9 | ![]() |
![]() Join Date: Nov 2015 Location: Rochester Hills, MI
Rep Power: 102 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| ![]() ![]() ![]() no need for a fancy, thicker/more layers, gasket unless the machine shop took too much off during the deck job(on that note be very very careful most shops dont have the correct specs for height). Felpro would be fine, oem takes all the guess work out of it. Either will do for your expectations. Stock bolts are more than adequate for the job. I'm running stockers on a fairly modified setup with zero issues. Half the cost, no modifications to install, and no retorque required. Black RTV the TC. If you do it correctly you will have zero leaks. 99% of leak whiners are the result of not properly allowing to setup. Apply, and hand thread bolts. Let sit over night THEN torque to spec. Black rtv MUST be allowed to firm up/expand prior to clamping force being applied. Same goes for the valve cover.
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... |
![]() | ![]() | #10 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,040
Groans: 30
| ![]() ![]() ![]() I have a Hockeynube-special Cometic headgasket that I will be running but OEM is solid too
__________________ Forged, keyed, ported, and Port injected build underway... |
Display Modes | |
Head gasket failure, damage to block/head....can this be fixed? | btstarcher | MazdaSpeed 3 - Engine, Transmission & Driveline | 29 | 02-27-2015 06:43 AM |
5 layer head gasket/head stud combo's. | ptperformance | Mazdaspeed3/6 General Discussion | 9 | 12-01-2008 12:07 AM |
