-   -   Heard some knock heres what i seen (http://www.mazdaspeedforums.org/forum/f10/heard-some-knock-heres-what-i-seen-52625/)
ms3-87 03-31-2010 12:29 PM
i droped the ol pan theses are pics of cyl #1 tell me what u think is goin on
http://i31.photobucket.com/albums/c3...0331101151.jpg
http://i31.photobucket.com/albums/c3...0331101150.jpg
http://i31.photobucket.com/albums/c3...331101151a.jpg
Lex 03-31-2010 12:30 PM
If I am reading this correctly, your rod is bent and the crank counterweight is hitting the bottom of the piston.
DO NOT START THE CAR!!!!!!
ms3-87 03-31-2010 12:36 PM
can i just replace that one cylinder lol?
and believe me havent ran it since it started this on the dyno 5 months ago
Lex 03-31-2010 12:38 PM
Likely more than 1 rod is bent. The piston has been hit as well. Replace at lest ALL rods and the impacted piston.
This really calls for a full rebuild - at least you don't have a hole in the block.
ms3-87 03-31-2010 12:39 PM
yea no kiddin will i need a new crank
Lex 03-31-2010 12:41 PM
crank should be fine.
ms3-87 03-31-2010 12:42 PM
okie dokie thanks for the input now i just gotta find a local machine shop that does good work
Page generated in 0.16950 seconds with 11 queries
