-   -   Help!!!!! (http://www.mazdaspeedforums.org/forum/f10/help-165575/)
Mgruca11 03-02-2014 05:41 PM
Help!!!!!
Just bought a speed 6. Cars awesome besides one little problem. Occasionally when I start the car it won't shift into gear. The clutch is all the way down but for some reason it won't engage. Once i shut the car off it goes right into to gear no problem. Start it again and no go. I replaced the slave cylinder today and bleed they'd whole system real good. Any help is appreciated. Never any problems while driving.
mxlplx71 03-02-2014 05:51 PM
Likely the wire on the starter alittle coroded
Mgruca11 03-02-2014 06:00 PM
How would the starter affect the clutch?
taf0422 03-02-2014 06:42 PM
I would look into changing the tranny fluid.
Is it usually cold out?
Mgruca11 03-02-2014 06:47 PM
It happens weather it's cold or no. Very random. Somebody told me it could be the forks on the clutch are bend and sometimes they don't engage properly
Easter Bunny 03-02-2014 07:14 PM
What happens if you start it in gear?
Mgruca11 03-02-2014 07:16 PM
Just jumps forward and doesn't start. As if the clutch is not letting up but the car thinks it is.
mxlplx71 03-02-2014 10:37 PM
Misread op linkage ok? Some have fd up cables..look under council also and try each gear. Grab trans shift mech , move by hand to make sure it works freely
Easter Bunny 03-03-2014 07:35 AM
clutch is not disengaging then, try bleeding it some more or replacing the master cylinder
Page generated in 0.25279 seconds with 11 queries
