![]() | | #41 | ![]() |
![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
| Not Ranked : 0 score So sorry dude I hate those fucking clips, all of them But the one on the TB, grrrrrrrrrr When i did my valves a couple years ago, i just was so drunk and pissed i just pried that piece of shit apart Fucking thing Goddamnm chinese suducko puzzle to undo a harness Needs a zipstrap to hold it together now I sure showed it whos boss....................... Or not
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
| The Following 2 Users Say Thank You to meicalnissyen For This Useful Post: | btstarcher (06-17-2015), wyeto (06-17-2015) |
![]() | | #42 | ![]() |
![]() Join Date: Dec 2013 Location: San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
(Thread Starter) | Not Ranked : 0 score haha I was surprised it survived the initial plugging and unplugging. I showed it whos boss too... stupid bitch. Anyway. I'm starting to think my ECU is fried. Freektune says my 02 isnt working my HPFP isnt working now all these codes. I want to say I forgot a ground or connectors somewhere but I know I didnt. All The grounds on the trans are intact and I have looked over every fucking connector. |
![]() | | #43 | ![]() |
(Thread Starter) | Not Ranked : 0 score Huge update: My HPFP has to be malfunctioning. Towed it to the new shop and same shit. dumping smoke, wont idle, running rough. clean maf: same thing boss has me crank it and he pulls the connector to the hpfp and it starts running perfectly. Idles great for about 20 mins and then it sputters out. I took a datalog after I got it running but I left the ap down at the shop on accident. Heard some odd noises coming from the timing section or possibly from the lifters. What in the Sam Hell would cause my car to run great with the hpfp connector disconnected?! if its idling as soon as it gets plugged in it dies out. My hpfp is a cpe so I dont want to break into it and void my warranty. I think the cels I had yesterday were due to key being on and me pulling connectors to check voltage. |
![]() | | #44 | ![]() |
Groans: 189
| Not Ranked : 0 score Last log wasn't reading any fuel pressure at all, so it was probably pegging out fuel pressure and trying to run high IDC...which would make it ridiculous rich. When you pull the spill valve plug it drops to ITFP pressure which will run normally even with high idc at idle.
__________________ |
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #45 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
| Not Ranked : 0 score I'm still thinking it's electrical. Harness, sensor, ground, or ECU. Possibly multiple issues, both mechanical and electrical.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
| The Following User Says Thank You to btstarcher For This Useful Post: | wyeto (06-18-2015) |
![]() | | #46 | ![]() |
I'm just really not sure where to go from here. Besides the noise under the valve cover everything seems to be running fine. What should the voltage of the hpfp connector read? That's one thing I can easily test while the car is running and check the ground. Where should I go from here? I think I may have to call CPE and see if they have any ideas... I want to think its a hpfp malfunction but I'm not sure.
I guess I could ghetto rig some sort of wire with a terminal on both ends hook it to both sides of hpfp positive side (pin on pump and wire harness), then hook the ground side up to the pin on hpfp and ground it to the block somewhere and start it up. That would rule a bad ground. But I tested it on the power probe and ground looked good so idk. If it runs off 12v I could hook 2 wires up to both pins and hook up a battery jumper to it.. Don't know if that one would work tho. | ||
![]() | | #47 | ![]() |
| Not Ranked : 0 score Yeah , so after popping these codes into search I came back to a thread from 2009 (again, three times now) with darksun calling dead ecu, and another dude calling eng bar 1 fuse I've been popping that fuse since the build fired back up melted the cheep fuse that comes with the add a fuse tap, blew a 15, thenI put a 30 amper in there and got my intake set right, with a good honeycomb, reflased the tuners map, running not bad, ran some errands pulled 3 MAF CAL logs, called it a day. this morn, actually put the bumper back on (forgot the styrofoamgrrr) and tossed in fresh pads, put the new fender liner in from rock. fired it up, headed out to get propane.. coughs and quits right in front of the house, eng bar 1 fuse is good, its effing dead, and I got these codes again proly toasted something the lighter fuses were protecting Ill go thru it again in the am, but this unreliability is killing my brain the highs and lows with yours, I had left that clip off once along time ago by accident, can't remember if it just wouldnt start, or just idled and died running 20 min and then quitting is super wierd, this car seems to me to be a black or white beast. and finicky as fuck have you been able to catch a fuel pressure log? sure would be nice if that mmds system at the dealer could actually test a PCM for faults, I'm really starting to think I have some Im crashin man, later
| The Following User Says Thank You to meicalnissyen For This Useful Post: | btstarcher (06-18-2015) |
![]() | | #48 | ![]() |
Groans: 112
| Not Ranked : 0 score I'd replace the entire harness to rule that out first. Also properly ground everything. See if anyone local is in the middle of an engine swap.
![]() | | #49 | ![]() |
I just realized that I have an extra wire harness for the coil packs and all that stuff from a blown engine I bought off craigslist. I will swap it over and see if it makes a difference... fingers crossed. Does anyone know if the ecu's are plug and play? just out of curiosity could you plug one in and run it or does it have to be programed? | |
![]() | | #50 | ![]() |
Now I get what you're infering, was fragged out last night huh, wouldn't the PRV be bleeding that off if it was super high?? grasping hopefully OP got some data on that last log
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch | |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score called cpe and am waiting to hear back from their "master technician" so we will see what he has to suggest before I send their pump back. |
![]() | | #52 | ![]() |
| Not Ranked : 0 score Yeah, Anyone? nah bru, thats a dealer trip, I think, but I see ecu/PCM on ebay being sold with the steering colum/keysets mebbe if the go as a set its p&P still not sure where that leaves the PJB @alltheguru's;
![]() | | #53 | ![]() |
Groans: 189
| Not Ranked : 0 score Again, it's not the pump. CPE will tell you so. Something is wrong with your wiring, ECU or rail pressure sensor at a minimum.
![]() | | #54 | ![]() |
![]() Join Date: Aug 2012 Location: Friendly and affordable Northern NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
EDIT: Brainfart posting this. Didn't see page 2 haha oopps
__________________ 06' MS6 White Pearl - Blown Motor - Rebuilding | |
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score So fucking happy got it all figured out. After pulling off the cpe hpfp and talking to their tech he helped me narrow it down. Switched out the fuel sensor on the fuel rail and fired her up and it started running perfectly with fuel pressure! Didnt have time to bleed the clutch so I will have to wait to drive it but im so happy. Small oil look and a slightly larger coolant leak both coming from the turbo but I will get those figured out next week and take it from there. thanks for the help from everyone I should have changed that stupid sensor from the start. All it took was a 1 1/16" socket and I was able to slip it under the intake mani really easy. how do the logs look? |
![]() | | #56 | ![]() |
| Not Ranked : 0 score Thats good news man. So after changing the fuel sensor ALL of those codes disappeared?
![]() | | #57 | ![]() |
(Thread Starter) | Not Ranked : 0 score the codes were due to me trying to check voltage and ground of my electrical stuff while the car was KOEO. I was frustrated and didnt put 2 and 2 together. Let her run for about 20 mins and everything looked great. I gotta find where the coolant leak is coming from. I have a minor oil leak as well and its coming from my damn oil return line so I gotta get that figured out too. And of course bleed the clutch and put the new slave on and then time for the maiden voyage. |
| My forged build after ZZB | Zoom66 | 2010 MS3 - Build Diaries | 6 | 05-10-2015 08:02 PM |
| Chris' forged BT build | ffz | Mazda MZR DISI Engine Builds (2006-2013) | 8 | 03-23-2014 06:20 AM |
| Azazels Forged build thread | azazelthegreat | Mazda MZR DISI Engine Builds (2006-2013) | 167 | 11-13-2013 12:37 PM |
| My Forged Engine Build | JumpingJackson | MazdaSpeed 6 - Engine, Transmission & Driveline | 156 | 03-06-2010 04:26 PM |
