http://tapatalk.imageshack.com/v2/15...e93d5bb1cb.jpghttp://tapatalk.imageshack.com/v2/15...d329df4221.jpg Mine looks nothing like that! Is that a stage 3 Daily Driver? |
Well I ended up taking it out and going with the luk clutch kit and fidanza flywheel. . I have to send my kit bak to SB for testing though im pretty sure it was install error on Rev Works Inc... I was told that the stock is known for holding more than or atleast 400whp which is where im near so we'll see.. If they warranty it ill have a stg3 DD to sell.. if they dont then ill be going after the shop that installed it improperly with the evidence that im putting together. To start off they didnt lube my release bearing.... smh |
Ya I looked at my pressure plate and looks like it was rubbing. Guess I never noticed any issues. What problems to people have when the pressure plate hits the bell housing? http://tapatalk.imageshack.com/v2/15...484674146d.jpg http://tapatalk.imageshack.com/v2/15...e83afec5e0.jpg http://tapatalk.imageshack.com/v2/15...2968d8e8d4.jpg |
Do both of you guys have a 2007? I don't have any issues with my stage 3 endurance yet... |
Mine is an 07 yes. |
Apparently the bell housing needs to be grinned down near the release fork... theres athread im told on here.. im an 09 |
I havent looked for it.. I was told there was.. At this point I already know about the issue andbyou confirmed it with your PP... lol |
What issues may we see if we don't grind the bell housing? |
Also taking measurements of my tob, luk vs exedy... theres a discrepancy. .. The exedy is really close to the size of the sleeve and the luk has more play... http://tapatalk.imageshack.com/v2/15...092df2cd53.jpg Sleeve ^ http://tapatalk.imageshack.com/v2/15...8ac148cd6f.jpg Exedy^ http://tapatalk.imageshack.com/v2/15...823aa16f6c.jpg Luk^ Look at the bell housing you should see marks in front of the fork.. http://tapatalk.imageshack.com/v2/15...bacccf6e48.jpg Like this^ |
Inside of my bell housing is fine. |
I have a question. .. wich way was the large hub side of the clutch disc facing? The PP or FW? |
http://tapatalk.imageshack.com/v2/15...1f7874464a.jpg http://tapatalk.imageshack.com/v2/15...165d24b2c8.jpg New throw out bearing installed. http://tapatalk.imageshack.com/v2/15...0e45df64c1.jpg http://tapatalk.imageshack.com/v2/15...7955b28071.jpg Cleaned up the pressure plate and flywheel with emery cloth and looks new now. http://tapatalk.imageshack.com/v2/15...836d0cb619.jpg http://tapatalk.imageshack.com/v2/15...980ab1f044.jpg http://tapatalk.imageshack.com/v2/15...30bf17f580.jpg http://tapatalk.imageshack.com/v2/15...e62d7223e2.jpg http://tapatalk.imageshack.com/v2/15...99fb07ca6b.jpg All back in http://tapatalk.imageshack.com/v2/15...86f51ae553.jpg |
Ill be getting my new fidanza fly wheel tomorrow and will be installing the luk kit instead.. its a shame because other than the xtremely heavy pedal and before the major issues afterwards, I liked the way the SB hooked... Once I get a few testimonies from mechanic shops of their impression on the codition of SB parts I took off, im sending it to SB for final testing. I honeatly dont know what went wrong other than "rev works" not lubricating the tob sleeve and botching my rear main seal install that cost $110 with the part... go figure :/ We'll see... I just need my car back on the road.. im tired of this shii.... |
Stay tuned for results |
Silly question; how do you torque the FW to crankshaft bolts with the engine still in the car? Is engine compression enough to make that happen? I'm considering the SB stage 2 enduro clutch but the fact that the pressure plate touches the bell housing is a small concern. |
Just wanted to toss out an update! Just finished the car up and went for a test drive and all is back to normal. Car shifts perfect and smooth as butter again. One thing I will mention regarding the clutch disk which i'm highly impressed with is the chatter. There is basically ZERO clutch chatter with this newly revised clutch disk I received from South Bend. It was really quiet to begin with when I had the old clutch disk but the new one is amazing. Compare this to an ACT and you'll think I have a stock oem clutch still in the car. Glad to have my car back on the road again. Time to get an alignment tomorrow and give my car a wash. |
Update on my end.. I put the luk kit and fidanza fw, it feels way too dam light :/ it's engages smooth right now (new feel) I hope it don't get any lighter after break in... I'll be sending the SB kit back this week to get inspected.. the saga continues. |
I'm really loving my clutch again. Now with all new hydraulics and a different clutch disk, this feels great! Just hope this clutch disk lasts longer than 20k miles. |
| All times are GMT -7. The time now is 06:01 AM. |
