Notices
 Old 09-04-2012, 11:56 AM   #1
SpeedyGuy's Avatar
Posts: 229   (View Stats)
SpeedyGuy has a reputation beyond reputeSpeedyGuy has a reputation beyond reputeSpeedyGuy has a reputation beyond reputeSpeedyGuy has a reputation beyond reputeSpeedyGuy has a reputation beyond reputeSpeedyGuy has a reputation beyond reputeSpeedyGuy has a reputation beyond reputeSpeedyGuy has a reputation beyond reputeSpeedyGuy has a reputation beyond reputeSpeedyGuy has a reputation beyond reputeSpeedyGuy has a reputation beyond repute
Exclamation HELP fuel cut/boost cut/air cut/car fubar'd
I have spent hours searching this forum, mazda24/7, torontomazda, yahoo answers, etc and tried numerous things to try and fix this problem to no avail. I need help.
The problem:
Every morning (I mean EVERY morning) when the car is cold from sitting over night, I start the car and it turns over fine, starts with no problems, idle's great, like everything is as it should. Then when I go to leave and go anymore then about 20% throttle (push the peddal 1/5 the way down) I get a severe lurching/hesitation from the car similar to a new driver trying to learn how to drive a standard. The problem disapears after 10-15 minutes of driving (well after the guage has reached the middle of the temp scale). At which point the car drives completely normal and boost is built without issue. WOT acts completely normal and there is never any smoke while driving the car.
This happens without fail every time I go near the throttle, in every gear, at any RPM. If I rev the car up very slowly to 3000rpm in say 2nd gear, then attempt to build boost, the hesitation/lurching described above happenes. If I do the same, but rev slowly to 4000 or even 5000 RPM then attempt to build boost, the same happens.
I have put in new oem spark plugs (now with under 100km), checked the coil packs (all seemed good), done an oil change (which the usual oil), re-oiled the intake, done a visual inspection of all hoses for cracks or holes, and checked and re-tightened all clamps. I also checked the MAF and it was NOT dirty however I will be cleaning it with CRC MAF sensor cleaner tonight anyways to rule that out for sure.
The only other things I can think of is the main O2 sensor, fuel pump (in some way), computer programing (switching from STFT to LTFT?) or the fuel injectors. But if it were any of these then the problem would be present throughout the entire drive would it not?
I am at my wits end here...I am completely out of idea's and I know how much you guys hate when people don't search, so please trust me I have spent hours searching and want some more input before I start spending hundreds of dollars on fuel pumps or O2 sensors for no reason.
Car/modification info:
2007 Speed 3
91xxx km's
Cobb SRI
Corksport Cat-back
STOCK fuel pump
STOCK spark plugs/wires (recently replaced)
Recent oil change with full sythethic and new filter
Shell premium gasoline all the time and the tank is never less then 1/4 full
I always drive the car easy until it is warmed up (more so now then ever)
I only built boost or go WOT above 3000 RPM and never in 6th gear.
I do not have an AP so I have no way of monitoring what is going on and I don't really have the money to purchase one (university student)
Any help is appreciated, thanks for reading and I will update this if I think of anything or if problem is cured.
[Not so]SpeedyGuy[anymore]
UPDATE
Problem had been solved, a completely new fuel pump + internals were installed and the car runs flawlessly now. Unfortunitely, I am not able to say for sure if it was the spill valve, internals, or the pump entirely that failed (cause everything was changed at the same time). Either way, replacing everything solved the problem.
Thanks to everyone who helped diagnose the problem, aquire parts, and install them. Alot more money would have been spent without you guys.
SpeedyGuy is online now   Reply With Quote
 Old 09-04-2012, 12:05 PM   #2
Will fuck up ur day
chimmike's Avatar
chimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the world
Groans: 418
Groaned at 206 Times in 122 Posts
What's yer spark plug gap?
07 MS3 bone stock?
The original Genpoo Hater
GTX3076r
FenderRollerRental Rent a fender roller, or MZR DISI Timing tools!
Originally Posted by woodfloor View Post
According to Roddiy, A List of Things as funny as fucking with MSF:
  1. Pissing in a bee hive
  2. Bridging the bus bars in an electrical panel with your dick
  3. Running with the bulls
  4. Willingly climbing into the lion habitat at the Zoo
  5. Shooting yourself in the foot on purpose
  6. Jumping up and down on a Fire Ant hill
@kyle undefined loves giving blowjobs to @raider; in truckstop bathrooms
chimmike is offline   Reply With Quote
 Old 09-04-2012, 12:53 PM   #3
SpeedyGuy's Avatar
Gapped to 0.031, I understand it should be a little less (0.025-0.030 if I remember correctly) but I was running out of light to work so 0.031 is what they're at.
 Old 09-04-2012, 02:31 PM   #4
ztnedman1's Avatar
Posts: 172   (View Stats)
ztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the world
have you stretched the coil springs?
2010 Red MS3/ Corksport SRI+TIP/ NATOR Downpipe + CS Racepipe (Catless FTW)/ AP+(E30)selftuned/ KMD v3 HPFP/ S.S brake lines + ATF superblue/ stoptech brakes/ JBM EGR delete/ SWAS disconnect/ JBM 80 RMM+80PMM/ Mudflaps/ itv22/ Rx8 wheels with Yoko S.drive245/40/18 (no rubbing issues)
ztnedman1 is offline   Reply With Quote
 Old 09-04-2012, 04:59 PM   #5
SpeedyGuy's Avatar
No I didn't, they looked fine to me. However after finding the thread on how to do it I will probably get that done tonight as I have not found any ill effects to doing it so.
Does the spark plugs/coils sound like a viable problem?? Or could it be someone else?
 Old 09-04-2012, 05:17 PM   #6
smoogs12's Avatar
Posts: 3,647   (View Stats)
Groans: 166
I feel like you probably would have mentioned this, seeing as you were pretty thorough in your op, but you dont have a cel right?
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
smoogs12 is online now   Reply With Quote
The Following User Says Thank You to smoogs12 For This Useful Post:
rfinkle2 (09-05-2012)
 Old 09-04-2012, 05:23 PM   #7
bryansawiseone's Avatar
Posts: 397   (View Stats)
bryansawiseone has disabled reputation
Maybe a temp sensor malfunctioning???
2012 MAZDASPEED3 W/ TECH PACKAGE - COBB SRI - COBB TIP - COBB FMIC - COBB AP - CP-E RMM - JBR 80 DURO PMM AND TMM - AUTOTECH FUEL PUMP INTERNALS - JBR STAGE 2 SSP AND SOLID BUSHINGS - CP-E CATTED DOWNPIPE - CP-E TRITON CBE - FORGE V2 BPV - CORKSPORT OCC - DEVILS OWN DVC-30 WMI - NGK LTR7IX-11 PLUGS - 18" KONIG BACKBONES W/ PIRELLI PZEROS - FREEK TUNED
bryansawiseone is offline   Reply With Quote
 Old 09-04-2012, 06:12 PM   #8
SpeedyGuy's Avatar
Thanks for reminding me, there is no check engine light, and not even any codes.
Sounds viable, how would that effect it though?
Sent from my ST18a using Tapatalk 2
~SonicTuning S3 Coilovers~
~Cobb SRI/AP/RMM~
~Corksport TIP/CatBack/SkidPlate~
~AutotechInternals~
~Forge BPV~
~Guardian Angel~
~Bnoon Bolt~
~CNT Downpipe~
And a missing gasket....
 Old 09-04-2012, 06:19 PM   #9
RichieRichness's Avatar
Posts: 2,905   (View Stats)
Groans: 33
Groaned at 16 Times in 11 Posts
I doubt it's your spark plug gapping although you should close that gap to a .028 or .026. You need to post logs here if you have a DH or AP. Whens the last time you cleaned your MAF or did a boost leak test?
Cobb AP w/RichTune | IWG gt3071r | JMF IM | DNP Exh Mani | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | PG TIP | Denso ITV22 | PTP Intake Gasket | Prosport OCC | Prosport Gauges | TWM Bushings | NATOR D.C. SS | SU RMM | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Megan Springs w/Drag Bags | DSS Driver Side Axle | PERM CC Plate | JMF OCCs
331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 Stock Turbo
12.263 @ 111.75 mph 1.669 60' 11/17/2012 - Stock Turbo World Record!
Visit RichTune.org or message me for a tune
$699 for Cobb AccessPORT + RichTune
The Following User Says Thank You to RichieRichness For This Useful Post:
 Old 09-04-2012, 06:33 PM   #10
SFLA Nator's Toretto
Sid3wayS's Avatar
Posts: 4,474   (View Stats)
Groans: 56
Whats the weather like there??? Severly cold I assume since its canada.
Does the issue come up if after you compleatly warm the car up ( drive for like 15-20 min) turn it off and then restart and try to drive.
2010 MS3 W/tech pkg Liquid Silver-Still Slower Then An Asthmatic Snail
Full Race:Verticle Flow fmic//HTP:3" Inatke//ATP:Catless DP
JBR:Holy Trinity,Rsb,Tigs//Forge:v.2 BPV//NGK:Plugs//AutoTechs:FP Internals
PTP:Seals&studs//Bosch:3-Bar//Grimmspeed:3-port EBCS//Stratified:G.A.//KW:v.1's//RotaGrids:18x9.5+38
Meth//E85//Nitrous Tunning by ms3blackmica
Sid3wayS is offline   Reply With Quote
 Old 09-04-2012, 08:39 PM   #11
SpeedyGuy's Avatar
I'll have to recap eventually but that shouldn't be causing it if it's off by so little. I don't have any way to log and don't have the money to purchase one at the moment (not easily anyways)
Edit: I cleaned the MAF sensor tonight and stretched the spring coils so I'll see what that does in the morning. Will update then.
First, not that cold here yet. And the problem has been arising in 'colder' and warm whether, it completely depends on whether or not the car has been sitting and has cooled off. The problem in non-existent when the car has completely warmed up after 15-20 minutes of very easy driving.
 Old 09-05-2012, 12:10 PM   #12
SpeedyGuy's Avatar
MAF cleaned, springs stretched, no change. Anybody???
 Old 09-05-2012, 12:13 PM   #13
Dizzy Turbo's Avatar
Posts: 1,011   (View Stats)
Dizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the world
I used to have the EXACT same problem, subbed
Dizzy Turbo is online now   Reply With Quote
 Old 09-05-2012, 12:30 PM   #14
rfinkle2's Avatar
Posts: 12,641   (View Stats)
Groans: 235
Do you have a ported intake manifold?
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
 Old 09-05-2012, 12:47 PM   #15
SpeedyGuy's Avatar
Use to? What did you do?
Negative. This car has no tuning done to it either.
 Old 09-05-2012, 12:53 PM   #16
Stock im. I simply started my car like 5-10 minutes andet it warm up before I drove it. That was on a ethanol mix. Then my fuel pump shit the bed ( install fail, nothing to do with ethanol). I'm now on pump and cpe fuel pump and haven't had it happen, and I do not let my car warm up anymore. It kinda just disappeared and I don't know why.
 Old 09-05-2012, 02:18 PM   #17
SpeedyGuy's Avatar
Hmmm.....hopefully its not the fuel pump...can someone chime in on whether or not this could be it? Low fuel pressure could cause this I guess, but I don't know how it would get better once the car is warm.
 Old 09-05-2012, 02:42 PM   #18
Complete guess, but I would think that when its cold there is a higher load which in turn increases demand on fp? My internals were installed wrong though, and I don't even know if that is what was causing the issue.
 Old 09-05-2012, 04:33 PM   #19
Posts: 9,794   (View Stats)
Groaned at 39 Times in 33 Posts
You're either running too rich or too lean causing it to bog.
You can run too rich/lean because the MAF is not reading correctly or you have some sort of a vacuum leak and it's worse when the car is cold since the ECU commands it rich anyways. Check for any air leaks.
Also pull your spark plugs and look at them. Do they all look the same and reasonable?
Finally, are there any noises, smells, etc. that you associate with this condition?
Chriscote (09-12-2012), smoogs12 (09-05-2012)
 Old 09-05-2012, 05:18 PM   #20
SpeedyGuy's Avatar
I just cleaned the MAF last night with MAF cleaner and the spark plugs were just replaced with bran new oem equivalent plugs gapped to 0.032.
There are no noises I can hear, or smells, or smoke from the car (had a following car observe).
I did a visual inspection of the hoses but have not done a vacuum check or any air leak checks. I will get that done ASAP. Thank you very much for the help I will let you know how that turns out.
 Old 09-07-2012, 12:13 PM   #21
SpeedyGuy's Avatar
No boost leaks. Upon closer eximation of cylinder 3, the spark plug is pretty chewed up. Ignition cylinder springs have been stretched, but no luck. New ignition coil going in cylinder 3 next week so hopefully that fixes everything...
 Old 09-07-2012, 12:16 PM   #22
rfinkle2's Avatar
Groans: 235
Wait... Describe "chewed up" in reference to the spark plug.
skiptowncat (09-07-2012)
 Old 09-07-2012, 12:47 PM   #23
SpeedyGuy's Avatar
I don't know how much you can see in this picture, but look at the middle spark plug in the pic, you'll see what I'm talking about (if you can see it)
Edit: open in new window/tab, then zoom in and you'll see what I'm talking about
 Old 09-07-2012, 12:51 PM   #24
skiptowncat's Avatar
Posts: 1,248   (View Stats)
skiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the world
Groans: 35
I would like to know that too, a "a chewed" up sparkplug could indicate something more sinister.
Tuned with by
Su tmic/corksport intake/custom 3" tbe/grimmspeed ebcs/forge bpv/jbr ssp/jbr rsb/Jbr side mount/sure tig set/sure r3 rmm/kmd internals/pg sst (tune in progress)/3 gauge pod
skiptowncat is offline   Reply With Quote
The Following User Says Thank You to skiptowncat For This Useful Post:
rfinkle2 (09-07-2012)
 Old 09-07-2012, 01:15 PM   #25
smoogs12's Avatar
Groans: 166
Looks like that middle plug is pretty well fouled.
Tapa
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
 Old 09-07-2012, 01:19 PM   #26
SpeedyGuy's Avatar
The middle one is "chewed up". Haha that's all I could think to describe it, but you guys get the point. Unfortunately that was not the cause of my issues. I think what caused that is what is causing my problem. Maybe. Unless someone else has another idea?
~Cobb SRI/AP/RMM~
~AutotechInternals~
~Forge BPV~
~Guardian Angel~
~Bnoon Bolt~
~CNT Downpipe~
 Old 09-07-2012, 01:59 PM   #27
smoogs12's Avatar
Groans: 166
Fouling can be caused by a lot of different things.
That looks like carbon fouling from the picture, which is "better" than oil fouling.
Could just be caused by a fuel mixture that's too rich.
I would replace that plug regardless.
Tapa
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
 Old 09-07-2012, 03:05 PM   #28
dan7225's Avatar
Posts: 365   (View Stats)
dan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the world
those are pics of the old plugs right? not the new ones that you just installed
my money is on bad maf sensor
//SURE INTAKE // HPS TIP // SURE RMM // BILSTEIN // MAZDASPEED SPRINGS // RACING BRAKE ROTORS // HAWK HPS PADS // SS LINES // TWM FULL STS // SURE TIGS // SURE OCC // DASHHAWK
Last edited by dan7225; 09-07-2012 at 03:05 PM. Reason: MSF Database - Automerged Doublepost
dan7225 is offline   Reply With Quote
 Old 09-07-2012, 03:40 PM   #29
SpeedyGuy's Avatar
Yes those are the old plugs and they are not in the car anymore. All 4 plugs have been replaced. If it was the MAF sensor would the problem not be present the entire drive? I cleaned the sensor with MAF cleaner and the was no improvement.
~Cobb SRI/AP/RMM~
~AutotechInternals~
~Forge BPV~
~Guardian Angel~
~Bnoon Bolt~
~CNT Downpipe~
The Following User Says Thank You to SpeedyGuy For This Useful Post:
smoogs12 (09-07-2012)
 Old 09-07-2012, 04:16 PM   #30
pzr2874's Avatar
Posts: 4,053   (View Stats)
Groans: 92
Groaned at 105 Times in 71 Posts
Do you always use the same gas/station? And were the autolites in your car previously? I know you said "equivilents", just taking stabs at it. Compression chk in order me thinks.
2007 CBM MS3
Originally Posted by Macncheese View Post
Sniff sniff... Bunch of vaginas in here.
R.I.P.
JVella22
MacnCheese
bmylez
The Following User Says Thank You to pzr2874 For This Useful Post:
predapio (09-07-2012)
 Old 09-07-2012, 04:37 PM   #31
theurgy's Avatar
Posts: 1,458   (View Stats)
Yeah I second doing a compression test on your cylinders.
You can pickup a tester from CT:
Equus Compression Tester Kit | Canadian Tire
Just lookup how to do a compression test properly on this site and let us know the results.
ETS TMIC, Cobb SRI, Cobb TIP, TWM SS w/Bushings and TypeR knob, Cobb Shift Weight, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb RSB, Autotech HPFP Internals, Denso Iridium ITV-22, Cobb AccessPort, Port and Polished IM, VTCS & EGR Delete, CP-e Safe Seals, SURE TIG IM and TB, JBR Trilogy Mounts 70a Duro, GS EBCS, CP-e Catted Downpipe.
Coming Soon:
Stratified Tuning Guardian Angel and Lex Tuning.
theurgy is offline   Reply With Quote
The Following User Says Thank You to theurgy For This Useful Post:
 Old 09-07-2012, 04:54 PM   #32
SpeedyGuy's Avatar
The old plugs were oem and had NEVER been changed before. So whatever they would have been from factory. And I always use Shell premium gas but not always from the same station. And what does a compression test do? Sorry I can't really look it up right now all I have is my phone.
~Cobb SRI/AP/RMM~
~AutotechInternals~
~Forge BPV~
~Guardian Angel~
~Bnoon Bolt~
~CNT Downpipe~
 Old 09-07-2012, 05:01 PM   #33
predapio's Avatar
Posts: 7,308   (View Stats)
Groans: 166
Groaned at 145 Times in 90 Posts
Like was stated above..compression test asap.
Good luck.
What a lovable bunch we are!!
predapio is online now   Reply With Quote
 Old 09-07-2012, 05:23 PM   #34
pzr2874's Avatar
Groans: 92
Local and I changed out some plugs on his car a while back and gapped them to the cunt-hair and he had issues. He took them out and blew out the cylinders with compressed air and them put them back in, no issues since. could try this when you do the compression chk.
Could be anything but a compression chk could tell the story of that one plug.
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
 Old 09-07-2012, 06:47 PM   #35
smoogs12's Avatar
Groans: 166
Basically you are just screwing a pressure gauge into the spark plug hole and cranking the engine (while holding your foot to the floor to disable the injectors) and then reading what the gauge says.
An ideal reading is 180 across the board, with no more than a 10% difference between cylinders. Honestly even 10% is a bit excessive.
You'll also want to preform a wet test, since you would really be looking for bad rings most likely. This is the same as a dry test, except you put a bit of oil in the cylinder prior to cranking the engine. If rings are an issue, then typically the reading will go up a good bit when you preform the test this way.
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
pzr2874 (09-07-2012)
 Old 09-07-2012, 06:54 PM   #36
rfinkle2's Avatar
Groans: 235
Tapa
I'd say. Did you really zoom in on that plug? Like real close?
 Old 09-07-2012, 06:56 PM   #37
pzr2874's Avatar
Groans: 92
90K those plugs still arent that bad.... I did zoom
Hey OP, did you chk the gap on the old plugs after you took em out?
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
 Old 09-07-2012, 09:09 PM   #38
ms3rick's Avatar
Posts: 2,424   (View Stats)
Groaned at 9 Times in 7 Posts
I had something like this when my air straightener decided to pop out and chill in my aem dryflow filter. Short and long terms went nuts
2010 MS3 siLver.
Next: TMIC(WTB PM me); meow DP
Official 60-100mph Times
Official Youtube Channels
 Old 09-08-2012, 01:39 PM   #39
SpeedyGuy's Avatar
Okay, so if I have a bad cylinder, would that be causing my issue?
Yes, cylinder's 1 to 4 were 0.034 0.036 0.036 0.035 respectively.
On another note, just got my car back from getting looked at. There is a weak spark in cylinder 4 which seemed odd to me....but I got a new coil pack, will be arriving Tuesday and it'll get put in cylinder 4 to see if that works. If it doesn't, does anybody know where I can get a Cobb Accessport for cheaper than 600$??? I can't afford that, but at this point I need to start looking at some data logs to see what the hell is going on. I have looked about the F/S section and no luck.
 Old 09-08-2012, 03:00 PM   #40
smoogs12's Avatar
Groans: 166
If your rings are fucked yeah that could be the cause for sure.
Also that's a pretty fat gap. You want to be at .028. A gap as big as yiure got it could cause issues as well.
As far as the accessport goes they sell in VIP for ~450 all the time.
Tapa
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
Fuel Cut? Boost Cut? Something Else? CherryMicaChick06 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 06-18-2009 12:48 PM
Fuel Cut Vs. Boost Cut kingpin748 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 09-30-2008 01:01 AM
Server/Forum Timestamp Fubar? sweetpickles Website Help/Feedback 3 05-21-2008 08:52 AM
Page generated in 0.57924 seconds with 36 queries
