![]() | | #41 | ![]() |
![]() Join Date: Jul 2011 Location: Edmonton, Canada
Rep Power: 55 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
![]() | | #42 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 1188 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,972
Groans: 153
Get a compression test done just to be sure. Tapa |
![]() | | #43 | ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 4097 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,091
Groans: 89
Groaned at 103 Times in 69 Posts
.002 isn't an issue on the old plugs. There isn't a MF'r in here that that can see/feel that difference. I was thinking the plugs opened their gap is all
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thats what I was thinking, which leads me to believe it wasn't a spark plug issue. But seeing as there is still a weak spark, it could be an ignition coil problem. We'll see when the new one comes in.
![]() | | #45 | ![]() |
Groans: 153
I'm not sure how strong our ignition system is, but I was thinking that maybe that could be enough to burn up a coil. Tapa | |
| The Following User Says Thank You to smoogs12 For This Useful Post: | pzr2874 (09-09-2012) |
![]() | | #46 | ![]() |
Groans: 89
| The Following User Says Thank You to pzr2874 For This Useful Post: | smoogs12 (09-09-2012) |
![]() | | #47 | ![]() |
Regapping the plugs to 0.028 tonight and putting a new ignition coil in as well and we'll see if that works. Cobb Accessport is also going to get ordered today to monitor what is going on.
![]() | | #48 | ![]() |
Groans: 153
Where are you getting the ap from and what are you paying. Tapa |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score I can't find one in the VIP section and I can't really afford to wait much longer...so I'll pick one up from one of the vendors here. So full price is what I'll be paying too I guess. I love my car, but I'm not sure if I can keep putting money into it like this |
![]() | | #50 | ![]() |
![]() Join Date: Jul 2008 Location: Vancouver, BC Canada
Rep Power: 772 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 519
Groaned at 6 Times in 4 Posts
It's a labour of love my friend... go with Edge Autosport, they'll hook you up for that AP.
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. ETS TMIC, Cobb SRI, Cobb TIP, TWM SS w/Bushings and TypeR knob, Cobb Shift Weight, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb RSB, Autotech HPFP Internals, Denso Iridium ITV-22, Cobb AccessPort, Port and Polished IM, VTCS & EGR Delete, CP-e Safe Seals, SURE TIG IM and TB, JBR Trilogy Mounts 70a Duro, GS EBCS, CP-e Catted Downpipe. Coming Soon: Stratified Tuning Guardian Angel and Lex Tuning. |
| The Following User Says Thank You to theurgy For This Useful Post: | smoogs12 (09-11-2012) |
![]() | | #51 | ![]() |
Groans: 153
Pm jp or Eric. I'm sure they can hook you up with a deal. Tapa |
![]() | | #52 | ![]() |
New ignition coil in, plugs re-gapped to 0.029. Problem still there....accessport has been ordered... Someone please help...car will be going in again for compression test, vacuum test, TPS, and computer diagnostic. Edit: problem is actually getting worse and happening when engine is warm. Seem's to happen under high engine load. |
![]() | | #53 | ![]() |
Groans: 153
I'm gonna say bad o2 sensor. Been a shit ton of those lately. Your ap will tell the story though once you get it. Tapa |
![]() | | #54 | ![]() |
Bad O2 sensor would give a rough idle and constant problems though. Not only when cold. Accessport is on the way so thats good news. I also went through and checked all the lines and clamps on the intake side of the turbo and installed my inlet pipe at the same time. No change when the car is cold, but holy crap when the car warms up the turbo is noisy haha. Can someone chime in on the possibility of short and long term fuel trims relative to the problem? I'm don't know much about tuning to understand that yet. |
![]() | | #55 | ![]() |
Had mazda look at it, they agreed it was an electrical problem *facepalm* I checked my MAF sensor again and it was dirty, cleaned it with MAF sensor cleaner, seems to be better however the problem is still there. Although the PROBLEM HAS CHANGED!!!! The problem is still the stutter, however this ONLY OCCURS AT 3100rpm now. Idea's? Accessport should be here this week.
__________________ ~SonicTuning S3 Coilovers~ ~Cobb SRI/AP/RMM~ ~Corksport TIP/CatBack/SkidPlate~ ~AutotechInternals~ ~Forge BPV~ ~Guardian Angel~ ~Bnoon Bolt~ ~CNT Downpipe~ And a missing gasket.... |
![]() | | #56 | ![]() |
UPDATE Problem had been solved, a completely new fuel pump + internals were installed and the car runs flawlessly now. Unfortunitely, I am not able to say for sure if it was the spill valve, internals, or the pump entirely that failed (cause everything was changed at the same time). Either way, replacing everything solved the problem. Thanks to everyone who helped diagnose the problem, aquire parts, and install them. Alot more money would have been spent without you guys.
| Fuel Cut? Boost Cut? Something Else? | CherryMicaChick06 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 06-18-2009 12:48 PM |
| Fuel Cut Vs. Boost Cut | kingpin748 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 09-30-2008 01:01 AM |
| Server/Forum Timestamp Fubar? | sweetpickles | Website Help/Feedback | 3 | 05-21-2008 08:52 AM |
