HELP! New clutch and pressure plate. Car does not move!! How tough could it be replacing the clutch and pressure plate in my 2003 Protege Speed? Turned the flywheel, replaced clutch, pressure plate and throw out bearing. Clutch pushes in as normal, car goes in gear great but when you let the clutch out to move it just spins lightly against the flywheel. You can hear it just barely touching. Car will not move. Bled the slave cylinder twice. Please help. Pulled the clutch out twice and put another new one in thinking they sent me the wrong clutch. Same results. Any suggestions? Thanks much to whowever can help me solve this mystery. |
Are you sure the throw out bearing is there? Is the clutch arm moving when the pedal is depressed? |
Everything is brand new. Goes in to gear like new. Let clutch out all the way and you just hear a light pressure like the clutch is just barely engaging. Very frustrating. This is a 2003 protege speed. I realized I'm in the wrong spot for answers. Thanks for any help you can give. |
| All times are GMT -7. The time now is 07:56 AM. |
