Help, Throttle problems Hey guys, I pulled off the TB this past weekend to take some measurements/explore. Nothing was bumped or damamaged during the removal/install. I went to start the car this morning and foundd that the throttle is really slow to react to my inputs. Is there anything special I have to do when reinstalling a DBW TB (ignition on but not started and press the peddle a couple times)? It's sitting with the battery disconnected right now. Any help will be greatly appreciated as I have to be at work for 9am. Thanks, David EDIT: Fixed. I had rinsed out the stock air filter on Friday and set it aside to dry. It must have still been wet somewhere because the MAF was soaked. I dried the MAF with some electrical spray cleaner and let it dry. Started with no problems. |
edit |
LOL. |
No problem, glad you figured it out. Lol |
| All times are GMT -7. The time now is 11:18 AM. |
