![]() | | #41 | ![]() |
Groans: 189
| Not Ranked : 0 score I ask because if you are, basically what you're doing is building up a lot of heat then making the water pump slow way down. On my logging above, I don't hit the clutch after letting off for the first run, but do for the second gear run (which seems to match what you're saying). |
![]() | | #42 | ![]() |
| pewpew ![]() ![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 761 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,124
| Not Ranked : 0 score are you running pure water in there, philly, because pure water boils over 212F... that would fuck up your coolant system pretty fast, since it's not made to deal with that much pressure. |
![]() | | #43 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score i push the clutch in to change gears, but i don't stay in neutral. |
![]() | | #44 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score yeah, that's a good point. i know you mentioned that earlier in the thread. i'll add some water wetter and see where that takes me. |
![]() | | #45 | ![]() |
Groans: 189
| Not Ranked : 0 score I meant for slowing down. If you're idling the engine when slowing down after a pull, the amount of water flow is reduced compared to 5,000 RPM. |
| The Following User Says Thank You to Enki For This Useful Post: | phillyb (04-09-2010) |
![]() | | #46 | ![]() |
unless something is wrong (leaks or boiling), your 100% water should be working better than our stock 50/50 mix, because water conducts heat way better than coolant...it just happens to have the added side effect of boiling off if it gets too hot...=/ | |
![]() | | #47 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score ming, i don't actually know if it raises the boiling point. |
![]() | | #48 | ![]() |
| Not Ranked : 0 score ouch...ya, just pour in some coolant and call it a day...=d |
| The Following User Says Thank You to Sacrilicious For This Useful Post: | phillyb (04-10-2010) |
![]() | | #49 | ![]() |
Groans: 79
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #50 | ![]() |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score * Unique agent for cooling systems that doubles the wetting ability of water * Rust and corrosion protection allows for use of straight water in racing or reduced antifreeze levels in warm climates * Improves heat transfer and reduces cylinder head temperature * May allow more spark advance for increase power and efficiency * Use one bottle for most passenger cars and light trucks, treats 3 to 5 gallons or 13.2 to 15.9 liters. Vehicles with larger cooling systems should use two bottles. Small cooling systems should use 1oz (3 to 4 capfuls) per quart * Compatible with new or used antifreeze (including DEX-COOLTM and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems * Satisfies ASTM D2570 and ASTM D1384 corrosion tests for glycol-based antifreezes
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
![]() | | #51 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score aight...still have a fucking leak even after replacing the hoses. so i've been replenishing the system with coolant, and gonna see where that takes me. this doesn't look fucking promising. |
![]() | | #52 | ![]() |
Groans: 91
| Not Ranked : 0 score fuck philly hope you get this thing settled A. cheap B. soon C. not a lot of headaches
| The Following User Says Thank You to skeeter149 For This Useful Post: | phillyb (04-12-2010) |
![]() | | #53 | ![]() |
![]() Join Date: Mar 2009 Location: Denver Metro
Groans: 29
| Not Ranked : 0 score I just started thinking about my coolant as sitting in traffic this past weekend I got up to 217. It drops down to 180-187 cruising, 190 at WOT always. I've never seen it get that high before so I got a little freaked out... |
| The Following User Says Thank You to MOVOVR For This Useful Post: | phillyb (04-13-2010) |
![]() | | #54 | ![]() |
| ALL-IN. ![]() Join Date: Jan 2009 Location: Alberta
Rep Power: 1398 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 872
Groans: 30
| Not Ranked : 0 score Where is the leak coming from now? Same spot? |
![]() | | #55 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score that is normal. i went out to my car this morning, coolant all over the engine. coolant under the car. FML yes. even after replacing hoses. Last edited by phillyb; 04-13-2010 at 10:36 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #56 | ![]() |
Groans: 30
| Not Ranked : 0 score Are you sure the leak isn't coming from somewhere else but just dripping down the hose? |
| The Following User Says Thank You to AndyMS3 For This Useful Post: | phillyb (04-13-2010) |
![]() | | #57 | ![]() |
Groans: 1,940
![]() | | #58 | ![]() |
Groans: 30
A leak down test may help diagnose any issues as well. | |
![]() | | #59 | ![]() |
Groans: 79
Your fine, and the fans will kick on, but i believe its right around 220. You can also kick on your AC and that'll turn the fans one and bring your temps down quite a bit. Also a good trick at the 1/4 track. I'll always rock the AC while i'm on deck.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | 802MS3 (04-16-2010) |
![]() | | #60 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score idk wtf is going on. fuck filling up the car with coolant. it just leaks it. reservoir is completely empty. obv still coolant in the system, but it ain't in the reservoir. temps haven't gone above 190 in the past 2 days. i run on as little coolant as possible apparently. my car rejects coolant. fuck coolant. |
![]() | | #61 | ![]() |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
Groaned at 589 Times in 386 Posts
| Not Ranked : 0 score Take it to a shop and see if they can figure out why your coolant is going bye bye. I'm sure there are alot of messican shops that can diagnose. |
![]() | | #62 | ![]() |
Groans: 79
| Not Ranked : 0 score Mystery coolant loss is not good.
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #63 | ![]() |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Water should boil at 212F at sea level pressure. Increase the pressure and the temperature where you get air bubbles in the water itself increases. I don't know that much about our cars coolant system, but I bet it pressurizes itself as it warms up it increase the boiling point. My understanding is that the coolant's primary job is to decrease the freezing point and to prevent metal corrosion. Using pure water would increase the freezing point up to 32f (which might not be a problem in a warm climate) and increase the efficiency of the cooling system in general but I bet there is going to be corrosion in the system somewhere if used all the time. This is what I know from working on an older mustang so my ideas might to moot. A 95 mustang doesn't use the same coolant that our cars do. |
![]() | | #64 | ![]() |
![]() Join Date: May 2009 Location: Toledo, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 121
| Not Ranked : 0 score Cooling system is 21 psi I believe (going from memory of what it says on the coolant overflow cap), so it would take ~230F to boil IF the system is without any leaks. Even in hotter climates, it's best to at least run some coolant to raise the boiling point, provide lubrication, and to prevent corroision. Maybe go with 75/25 or 80/20 water/coolant if you want better cooling properties in a non-freezing climate.
__________________ ToledoSpeed3 ![]() 09 MazdaSpeed3 GT, True Red |
![]() | | #65 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score fuck this shit. there has to be more pressure building up inside my cooling system. one of my fucking hoses popped off on saturday. water/coolant all over my engine bay. put the shit back on, and it's fine now, but still leaking. what could cause more pressure in the system? radiator? blockages? why are there blockages? someone please help. |
![]() | | #66 | ![]() |
![]() Join Date: Mar 2008 Location: orange county
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,807
Groans: 137
| Not Ranked : 0 score all water=low boiling point. low boiling point= a lot of pressure. dont know. insurance fraud ftw.
__________________ 2008 STi Intake Turboback AP |
| The Following User Says Thank You to danesti For This Useful Post: | phillyb (04-19-2010) |
![]() | | #67 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score yeah, i feel you on the water boiling issue. i've started replacing the water with coolant, and the shit still popped off. this was with mostly coolant, not water. temps also haven't been rising, but the pressure is still causing a leak. |
![]() | | #68 | ![]() |
Groans: 137
| Not Ranked : 0 score have you pressure tested the cooling system? go rent one of those tools from vatozone that screws on the radiator cap. should be free once you return said tool
| The Following 2 Users Say Thank You to danesti For This Useful Post: | djuosnteisn (04-20-2010), phillyb (04-19-2010) |
![]() | | #69 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score i have not. thank you dane. |
![]() | | #70 | ![]() |
Groans: 137
| Not Ranked : 0 score to be honest i have only done that shit once.. it was a lab procedure in my auto class a few years ago. i forgot how to do it. think it was easy though.
![]() | | #71 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score k |
| The Following User Says Thank You to phillyb For This Useful Post: | danesti (04-19-2010) |
![]() | | #72 | ![]() |
Rep Power: 0 ![]() ![]() ![]() Thanks: 13
Groans: 28
Groaned at 51 Times in 20 Posts
| Not Ranked : 0 score distilled water btw ![]() if you run 100% distilled water it wont ruin anything. regular water has all the shit in it that causes corrosion. and it wont boil if you dont have leaks in the system so once the leak is fixed dont worry about shit boiling. it pressurizes itself as it gets warmer and pressure and the boiling point of a liquid go together. HVAC certification FTW! |
![]() | | #73 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score yes, it was distilled water. |
![]() | | #74 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
Groans: 35
| Not Ranked : 0 score Philly.. take your car to a shop.. while your waiting... get a dog up ya. |
| The Following User Says Thank You to Doc For This Useful Post: | phillyb (04-20-2010) |
![]() | | #75 | ![]() |
Obviously if there is a leak, you have bigger problems...
__________________ ToledoSpeed3 ![]() 09 MazdaSpeed3 GT, True Red Last edited by ToledoSpeed3; 04-20-2010 at 05:57 PM. | |
![]() | | #76 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score head gasket getting replaced. hahahah fml |
![]() | | #77 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score pics. thanks skt. ![]() ![]() ![]() |
![]() | | #78 | ![]() |
Groans: 79
| Not Ranked : 0 score That head has so much room for improvement IMO. If i get the wrench bug again (or when, more likely), i'm knife edging the fuck out of those dividers, and opening up the IM side like silverdemon.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | phillyb (06-01-2010) |
![]() | | #79 | ![]() |
Groans: 137
| Not Ranked : 0 score philly whos doing your head gasket?
![]() | | #80 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score family automotive in canoga park |
| The Following User Says Thank You to phillyb For This Useful Post: | danesti (06-02-2010) |
| High RPM in 6th? | Ironside | 2010 MS3 - Engine, Transmission & Driveline | 5 | 03-21-2010 06:47 PM |
| Geneva 2010: Citroen DS High Rider rides in on its high horse | Haltech | Automotive News | 0 | 03-03-2010 07:30 AM |
| High Speed, High Fashion: Izod secures deal as IndyCar title sponsor | Haltech | Automotive News | 0 | 11-08-2009 03:40 PM |
| Got a log, is boost high enough? | Speedsicks | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 10-04-2009 01:28 AM |
