 Old 02-05-2010, 11:35 AM   #81
Silver Ecstasy's Avatar
Posts: 2,450   (View Stats)
Groans: 24
How would you suggest doing a vacuum test?
Mike
 Old 02-05-2010, 12:55 PM   #82
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
maybe ask around at shops or possibly the dealer to see if they can test for vaccum leaks. If they do, they may have a machine that pumps smoke in one of your vaccum lines and the leaks will become apparent if you have any.
or u can try and spray carb cleaner and see if it gets sucked up and fluctuate rpm
easy is offline   Reply With Quote
 Old 02-05-2010, 01:48 PM   #83
BudUMfan's Avatar
Posts: 1,204   (View Stats)
BudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the world
Groaned at 9 Times in 7 Posts
Default Re: High LTFT's and Hesitation
I used a propane torch (unlit of course) and traced the vacuum tract. Rpm's will rise if sucked in. Dealer did the same thing, along with smoke test.
BudUMfan is offline   Reply With Quote
 Old 02-05-2010, 08:44 PM   #84
Groans: 24
Hmm. Ok.. lol don't know if i'll be doing that.
Mike
 Old 02-08-2010, 12:13 AM   #85
matsuda's Avatar
Posts: 35   (View Stats)
matsuda has a spectacular aura aboutmatsuda has a spectacular aura aboutmatsuda has a spectacular aura about
Originally Posted by FORZDA 1 View Post
Dude, I've been trying to be courteous and push you towards learning a bit about the specific open/closed loop switching logic in the Speed3/6 ECU, but it's plain to me you're simply a troll who has read some basic theory in the SAE documents that define the basic PID standards that the OEMs must follow in setting up their OBD communications for viewing by scanners, etc. It has nothing to do with the actual ECU function. Quoting basic PID info from the SAE standard just proves how little you actually know. It may impress some folks who have no clue what's going on here, but from my perspective please just go away if you're not going to learn anything because you obviously have no real knowledge about the information you're posting and crapping up this and the other threads you've posted in.
Wow... I'm sorry to confuse you. Allow me to simplify my response so as not to confuse you further:
The IDS confirms that LTFT does not zero out when running WOT / open loop (i.e. your assertion is wrong). Is that simple enough?
The point of the J1979 spec. was to let you know that fuel system status can be correctly monitored by a standard "OBD2" scan tool that supports this function. The IDS of course has ALL of the Mazda specific PID's (including many that are not found on a DH). Needless to say, you really cannot see the whole picture unless you have an IDS.
If you have any evidence to prove that the IDS is not logging data correctly, I am all ears.
The fuel trims WILL change if the intake size parameters (size, length, MAF position, etc.) are not EXACTLY the same as the OEM calibration("metering"). The changes may be small or LARGE, depending on what has changed.
Yes, now you're getting the idea.
Just as I said, "If the air is metered properly, the fuel trims shouldn't change..."
Last edited by matsuda; 02-08-2010 at 01:45 AM. Reason: MSF Database - Automerged Doublepost
matsuda is offline   Reply With Quote
 Old 02-08-2010, 12:55 AM   #86
matsuda's Avatar
Originally Posted by fjames View Post
On the intake vs. fuel trim thing - I don't see how you can
a. let in more air consistently over time
b. say that because of this your ecu increases fuel
c. claim no fuel trim change
d. because that IS a fuel trim change.
Aren't you forgetting the fuel maps?
Think of fuel trims as a bias or correction to the amount of fuel that is determined primarily by a fuel map. That is why they are called "trims".
As long as the incoming air mass is metered correctly, the ECU will "deliver" an appropriate amount of fuel. The amount of fuel is determined primarily by a table (fuel map) and is only biased by the fuel trims.
ONLY if the target AFR does not equal the actual AFR (as read by the O2 sensor), then the ECU will adjust the fuel trims.
In the OP's case, the Cobb has a high LTFT simply because the MAF voltage is lower (for a given air mass) than the stock air box. This is caused by differences in the MAF housing (MAF sensors are very sensitive). If the relationship between air mass and MAF voltage were identical for the two intakes, the fuel trims would not change (i.e. no correction would be necessary because the metering of the air is the same).
Maybe you have read about people installing an air straightener on their Mazdaspeed intake. The air straightener enables the MAF to meter air more accurately, which results in a difference in MAF voltage and thus a difference in fuel trims.
 Old 02-08-2010, 06:09 AM   #87
Groans: 24
Speaking of which,
I decided to install my Cobb SRI combined with the Cobb TIP this time around. Last time, it was only the Cobb SRI with stock TIP.
Fuel trims are immediately down to +6 and +8. Interesting. Hesitation is less pronounced, although the car definitely had to get used to the different intake. For a few runs, in 2nd gear, you'd hear the turbo spool up but the car was going nowhere, then all of a sudden you'd be pushed back in your seat. I've had intakes before, i've modded before, I know what it's supposed to feel like. It didn't feel like that. Anyways, will report back if I continue to notice hesitation. I'm thinking it's time I changed for brand new stock spark plugs.
Mike
 Old 02-08-2010, 12:04 PM   #88
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
FORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the world
[QUOTE=matsuda;420403]............If you have any evidence to prove that the IDS is not logging data correctly, I am all ears..........[QUOTE]
Nah, I’m done debating the issue as we’re crapping up this thread and you obviously have your mind made up so words will not sway you. The ECU logic is the baseline for all things displayed on a scan tool. Yours works the way you say and mine works the way I say………
For other's info here are a few sites for excellent OBD tools to assist you.
I like this one with Mazda/Ford enhanced SW and use it in my garage.
OBDScan-APEX - OBDII Diagnostic Scanner
http://www.obdscan.net/obdscan_mazda_m63_enhanced.htm
If you really want the OEM tool go here:
Ford Mazda Ids
or maybe here
mazda IDS VCM Products , China mazda IDS VCM Manufacturers, China mazda IDS VCM Suppliers, Made in China, Exporters, Factories - DIYTrade
`07 Speed6 Sport Tit Gray Sleeper Express... SOLD
`11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG
`12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan
`12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket
`17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy
FORZDA 1 is offline   Reply With Quote
 Old 02-08-2010, 10:04 PM   #89
YokiMazoku's Avatar
Posts: 320   (View Stats)
YokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the world
I had a very very similar problem however my car threw a code to help me figure out what it was. Try replacing your spark plugs after i did that it went away. I had to replace my plugs at like 20k or less.
YokiMazoku is offline   Reply With Quote
 Old 02-08-2010, 10:51 PM   #90
YokiMazoku's Avatar
Oh i almost forgot the second time this happened to me it was bad gas in the car. But im sure you probably have already ruled this out.
 Old 02-09-2010, 08:34 AM   #91
Groans: 24
Thanks for the tips! I am considering replacing the plugs.
Mike
 Old 02-09-2010, 07:56 PM   #92
Groans: 24
So i'm starting to think that the Cobb TIP is an absolute must with the SRI. Not only does it make it that much more fun to drive, but my fuel trims are half of what they used to be, and the car is running like a champ. Very pleased so far!!!
Mike
 Old 02-10-2010, 06:15 PM   #93
SRTie4k's Avatar
Posts: 1,715   (View Stats)
Interesting, because I have a similar problem with the Cobb SRI. My LTFT's are pretty crazy too:
Idle - +16.4%
Cruise - +8%
WOT - +10%
I also have a SU TMIC, so I checked for vac leaks and tightened all my hose clamps thinking it was a vacuum leak and unmetered air. That didn't fix it. Then I cleaned my MAF, that also didn't fix it.
Maybe I need to order a TIP.
 Old 02-10-2010, 08:49 PM   #94
Groans: 24
I'm not kidding man, order a Cobb TIP now.
Not only does it make the SRI that much better, but my LTFT's are spot on. I love it!!!
Mike
 Old 02-11-2010, 02:16 PM   #95
IndianOutlaw's Avatar
Posts: 225   (View Stats)
IndianOutlaw is the leader of the worldIndianOutlaw is the leader of the worldIndianOutlaw is the leader of the worldIndianOutlaw is the leader of the worldIndianOutlaw is the leader of the worldIndianOutlaw is the leader of the worldIndianOutlaw is the leader of the worldIndianOutlaw is the leader of the worldIndianOutlaw is the leader of the worldIndianOutlaw is the leader of the worldIndianOutlaw is the leader of the world
I just bought the PG inlet so we'll see what that does to the trims with a cobb sri
IndianOutlaw is offline   Reply With Quote
 Old 02-12-2010, 04:15 PM   #96
JohnMS3's Avatar
Posts: 754   (View Stats)
JohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the world
anybody figure out why the cobb sri is causing these high ltft's? i have a cp-e nano an planning on switching over to cobb just for the carb sticker
-John
| Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns |
JohnMS3 is offline   Reply With Quote
 Old 02-12-2010, 09:41 PM   #97
Groans: 24
No idea man, and I won't even try because I hate the "theories" method.
Mike
 Old 02-12-2010, 10:00 PM   #98
felt's Avatar
Posts: 1,504   (View Stats)
felt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the world
Groans: 1,364
Groaned at 589 Times in 386 Posts
Was your stock inlet securely clamped to your turbo???
felt is offline   Reply With Quote
The Following User Says NO Thank You to felt For This Un-useful Post:
 Old 02-12-2010, 10:22 PM   #99
Groans: 24
Yep. It was on there real good. I made sure to check as I was removing everything basically.
I'm thinking my o2 sensor still needs to be replaced, along with plugs. I'll be able to tell better once it warms up (if it continues) but as for now, i'm having way too much fun with the complete intake lol.
Mike
AFR and LTFT's: what are good #'s? red07 MazdaSpeed 3/6 - ECU Computer Tuning 11 11-16-2015 03:14 PM
fixing high LTFT's Jessed87
Cobb ATR Support
7 10-06-2009 09:38 AM
What do my negative ltft's mean? Addikted To Boost MazdaSpeed 3/6 - Turbo Induction 13 06-23-2009 07:57 PM
A/F ratios and ltft's dread
Cobb ATR Support
7 05-01-2009 05:37 PM
STFT's and LTFT's 802MS3 MazdaSpeed 3/6 - ECU Computer Tuning 3 01-20-2009 06:34 PM
Page generated in 0.39438 seconds with 30 queries
