 Old 04-07-2010, 01:49 PM   #41
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
The fueling window becomes more and more narrow as the rpm's climb.... assuming you plan to stay with DI.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 04-07-2010, 10:47 PM   #42
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
I don't see any reason direct injection can't support higher rpms. Educate me?
 Old 04-08-2010, 05:27 AM   #43
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
DI has a very short window to inject fuel. also that fuel needs time to atomize and distribute evenly within the chamber. higher RPM does not promote even distribution and efficient burning of fuel.
The Following User Says Thank You to 8.5MS3 For This Useful Post:
djuosnteisn (04-08-2010)
 Old 04-08-2010, 07:04 AM   #44
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
lol that mazda3 revving to 8k was slowwwwww
'08 CWP MS3 w/ T3 3071r
 Old 04-08-2010, 09:36 AM   #45
Captain
Groans: 79
Education:
Have you measured when the injectors...
www.permtuning.com
 Old 04-08-2010, 10:48 AM   #46
Mizzle's Avatar
Groans: 324
My main issue with that thread:
"The fuel system (injectors) is not adequately sized for producing more than around 350-380whp. At that point you're also looking at very poor combustion and efficiency in the upper RPMs."
I know someone making well in excess of 400 whp on stock injectors, hpfp and stock tank pump. He's in line to hit 500 whp on his current setup.
That being said, I definitely understand the complications are specific to higher RPMs and not overall power measurements. Does anyone know what PSI is reached at 15.5lbs of boost at TDC?
 Old 04-08-2010, 11:09 AM   #47
Captain
Groans: 79
I know as well, as i hit 390 on the stock injectors. I did have my fuel rail pressure increased roughly 10%, and have shown that this is indeed a successful way to increase fueling on the stock injectors, and probably good for up to 500+whp IMO.
www.permtuning.com
 Old 04-08-2010, 02:14 PM   #48
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
My main issue with this post is that the stock CDFP cant flow "well in excess" of 400whp until you hit rpms that are high enough that the injectors can no longer flow "well in excess" of 400whp. Unless you are God and you can bend math to your will, it isnt possible even on paper. Never mind the combustion process etc.
The PSI of what at 15.5lbs of boost at TDC?
2006 Mazdaspeed 6
 Old 04-08-2010, 02:15 PM   #49
8.5MS3's Avatar
Groans: 326
i think he wants dynamic compression at full boost, at TDC.....good luck with that
 Old 04-08-2010, 04:38 PM   #50
JoshProtegeGarage's Avatar
Posts: 102   (View Stats)
JoshProtegeGarage has much to be proud ofJoshProtegeGarage has much to be proud ofJoshProtegeGarage has much to be proud ofJoshProtegeGarage has much to be proud ofJoshProtegeGarage has much to be proud ofJoshProtegeGarage has much to be proud ofJoshProtegeGarage has much to be proud ofJoshProtegeGarage has much to be proud ofJoshProtegeGarage has much to be proud ofJoshProtegeGarage has much to be proud of
because im tunned for nitrous direct port...without my spray im slooooow had i spray i would of made your speed 3 look inferior lol. jk
JoshProtegeGarage is offline   Reply With Quote
 Old 04-09-2010, 08:41 AM   #51
Mizzle's Avatar
Groans: 324
Yep.
I wanna know what the differential is between the cylinders and fuel supply.
 Old 04-09-2010, 08:54 AM   #52
kilik2's Avatar
Posts: 1,254   (View Stats)
kilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the world
Groans: 127
Groaned at 40 Times in 31 Posts
I heard the tables in the ecu wont let you go past 7k. just what I heard.
kilik2 is offline   Reply With Quote
 Old 04-09-2010, 09:00 AM   #53
8.5MS3's Avatar
Groans: 326
Yep.
well dynamic compression is not the same as cylinder pressure. Its nearly impossible to calculate since there are so many different factors that come into play. but if you want to give it a shot...
http://www.hcs.harvard.edu/jus/0303/kuo.pdf
 Old 04-10-2010, 10:15 AM   #54
gogogomoveit's Avatar
Posts: 99   (View Stats)
gogogomoveit is a jewel in the roughgogogomoveit is a jewel in the roughgogogomoveit is a jewel in the rough
You can have a full authority engine control like Apexi Power FC that allows u to set your RPM.
But the easiest way to determine the RPM without all the academics is put the car on the dyno, run it and set it just after your peak Horse power drop off. Stock engine tops out at 5500rpm and redline at 6500rpm. There is no reason to run it all the way to redline once you past the peak HP and Tq output.
On a Naturally aspirated all motor, the peak output tends to be very close to the mfg set mechanical limit on the engine(redline), hence the idea of running all the way to redline. On a FI engine or diesel engine, the reverse is true.
gogogomoveit is offline   Reply With Quote
The Following User Says Thank You to gogogomoveit For This Useful Post:
ms3077 (04-10-2010)
 Old 04-10-2010, 08:15 PM   #55
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Originally Posted by 240mazspd3 View Post
RaceRoots redline was around 8k on stock head.
was RR's redline really near 8,000? I don't remember.. I though it was 7,000.
 Old 04-11-2010, 05:59 AM   #56
kilik2's Avatar
Groans: 127
I thought it was 7k also, maybe I remembered wrong too.
 Old 04-12-2010, 08:41 PM   #57
AK-speeder's Avatar
Posts: 46   (View Stats)
AK-speeder will become famous soon enoughAK-speeder will become famous soon enough
with only exhaust and intake on mine it fell right around 6k but once i put in the fidenza it would pull all the way to 7k easy when i would take the back seats out it would pull without a notice in power drop easily...
AK-speeder is offline   Reply With Quote
 Old 04-12-2010, 08:51 PM   #58
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
RR was set to 7500, which is as high as you can set it with the AP and I have done tests that show with a 7500rpm redline, the car will make it till ~7750 before it bounces...
jreiden1 likes this.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
djuosnteisn (04-12-2010), jreiden1 (03-27-2014)
Highest RPM stock motor can be rev'd to... ?? all4bspinnin MazdaSpeed 6 - Engine, Transmission & Driveline 17 08-31-2009 02:49 PM
highest psi with standback and meth? gsrtype1 MazdaSpeed 3/6 - ECU Computer Tuning 24 01-24-2009 04:43 PM
Highest CAT Temp per Scan Gauge? LBV MazdaSpeed 3 - Engine, Transmission & Driveline 6 06-25-2008 11:21 AM
Page generated in 0.38346 seconds with 30 queries
