:bong: |
Damn. I'm out of the loop. Lenny's BT'd and you popped. Shit. You were shooting loads in your intake again huh? Man, you didn't bend a rod, your jizz collected and hardened. God dammit, Roy. If you were that hard up, you should have just sprung for a fleshlight. |
I am sorry to hear that your motor took a shit though. Really, man. Although, I've been there a few times myself not only on this car, but others. It always sucks to hear about it. Good luck. |
Oh, and I would NOT tune someone elses' car to that level!!! |
Maybe you have to exceed that limit for a full second or two? if that's the case it would likely be too late. Has anyone else experienced this? |
Best safety net is a properly setup knock sensor and KR IMO. Cuts are helpful, but you can definitely detonate below cut thresholds in many cases, and many times the cut has to be "qualified", like exceeded for XXX milliseconds... which is often too late. |
I have been traveling most of the last 2 weeks and am just now reading through this thread... My best guess is that the boost went well over 24 PSI causing detonation or simply too much cylinder pressure (either = FAIL for the stock rods). Which map were you on when said FAIL occurred? I will look at if for some clues. It is a shame we don't have more logs to examine to better understand the exact failure mode. The single log you had from the boost targeting map appeared to be in early gears (2nd/3rd maybe) where there were very few data points to make any meaningful determination other than the WGDC was chasing it's tail wildly. |
It sounded like both maps to me. One session of fail with the boost targeting map, and the finishing blow after he went back to previous map. Cld12pk, was this the latest ATR? Oh, and i think he was logging on the boost targeting map IIRC, perhaps we could check those out... |
In late, damn man that sucks to hear about the motor. Glad to hear you had a spare motor. Good luck on the rebuild. |
Be interesting to see this map you initially caused the damage with.. unfortunately roy, i really wish you would of at least asked for a very very toned down map or even went to a stage 1 16 psi map just to see how the WGA and SST were going to work. I do not think this map is as much fail as your WGA modification and the SST itself. I have very little faith in Johns abilities and no faith in PG's ability when it came to "designing" the modified SST. I do not think there is one person now who has run an SST that has not blown. Anyhow, what did my man Dante say? |
If boost is out of control you want to do 3 things. Open WG, close throttle, cut spark, NOT fuel and you want to do it as quickly as possible. Might create a fireball in the exhaust but the motor is more likely to survive this way. I am not sure what strategy the car uses for the different cuts (load, boost, etc). |
mbc i bought solely for the BT....... so.... the ONLY thing that had changed was the TURBO.... not even the wga was diff...i re used the old one. that to me tells u that u cannot dismiss any variable just because u think its the same. |
I have not logged ANY throttle close occurances. Of course when logging I'm at WOT for pretty much the whole time, so any limit "excursions" are rapid and decisive! |
now that I think about it, I have hit fuel cut and I "think" it was fairly quick...I know throttle close is much slower to react but would actually be the absolute best thing to happen first. As Lex said spark maybe but, filling the cat with fuel on a hot exhaust aint so good. Better there than the motor though for sure. I would agree with Haltech on the SST...those can just be a bad idea because of their super fast spool and tendency to spike...then you make them more powerful. BT is MUCH better. we live...and hopefully....if we pay attention....we learn.... Edit: I went back to look at logs and Boost Limit - Throttle Close does nothing. I have logs where the limit is exceeded for over 2 seconds and the throttle was actually opening more. |
If it was just the second map, the key attributes on it where as follows:
Here is the single log from HE18: http://i77.photobucket.com/albums/j6...riortoboom.jpg I am assuming this is a 2nd/3rd gear pull. It is obvious that the WGDC is pretty much going bonkers and that he was running a full point leaner than on the previous maps prior to the turbo swap. HE19 was going to cut the boost dynamics in half and drop the boost limit - fuel cut to 22 PSI, alas it was too late by then. |
Sorry to hear that man going boom must suck, bright side is that now you can be built. Cheapest solution to building the block? Do it yourself, it's actually really simple. Just measuring a bunch of shit and installing. Or you could cut your losses and sell me your transmission for cheap :D Best of luck! |
EDIT - I meant 16b - sorry! Quote:
1 Attachment(s) Here's the map i was running when i popped |
I have the PTP wga and it actually adds to the spiking because it doesnt get blown open until much higher turbine pressures are reached, as compaired to stock. The bonus is that it holds boost longer. The spiking has been near impossible to tune out though. |
man this shit kinda makes me have second thoughts about letting xtian tune me with ebc |
We really just don't have enough data, but everything tends to suggest that the new turbo/WGA was responding much more aggressively than the previous setup. What is confusing is why the pull showed lean in the first gear during the pull. I wonder if the meth was not working or if we had unmetered air entering between the turbo and MAF? Lenny, What I would recommend when trying out new maps or after hardware changes would be the following procedure: 1.) do a partial throttle pull in a high gear (like 4th or 5th) to above the CL/OL transition (say 10 PSI) and log while watching AFR or KR on the AP. Review datalog to assure that your AFR is as per your fueling tables in OL else you need to fix something (recalibrate MAF tables, get meth working, fix unmetered air leaks). Also verify that nothing unexpected is occurring with the boost control/WGDC or KR. 2.) Once satisfied with the results, do other logs in a high gear to progressively higher boost levels until you have reached WOT analyzing the data after each pass (probably another 2-3 iterations). The reason I say do it in a high gear is that bad things can happen way too fast in the low gears to respond in time and in our case we cannot get sufficient data in any gear below 4th. If anything is amiss on the above pulls, lift immediately and analyze the logs for clues as to what is wrong. |
I put it right at my boost target which was 15psi and it kept boost from creeping above 17psi (before the limit it would creep to 18.4-19psi on cold nights and cause my fuel pressure to drop) I think it's more effective at preventing creep than preventing spiking. |
Sounds like it just requires more boost error prior to taking meaningful action based upon your findings... |
I don't think I have ever gone over 2 PSI beyond the Throttle Close table so maybe I'll try setting it lower to see what is what. |
| All times are GMT -7. The time now is 08:11 AM. |
