![]() | | #1 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
(Thread Starter) | Not Ranked : 0 score DP, TMIC, TIP and CAI. Custom Tune. Lately I've been getting damn rich readings, smells, rough idle and so on. Fuck it I said, and took it to the shop. Been whining on the forums too much, suspecting o2 sensors and so on. So the story is like this.. 188-145-130-175 these aren't lotto numbers.. leak-down showed air escaping through valve cover. sooooo.... what's next.. |
| The Following User Says Thank You to mrQQ For This Useful Post: | phate (03-08-2013) |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
| Not Ranked : 0 score New valvecover gasket? But those numbers look like a bad head gasket; what does your coolant look like? Also, can you show me a log that displays your AFR, LTFT, and STFT? Not WOT, just driving, give it a little gas and let off, etc.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
| The Following User Says Thank You to btstarcher For This Useful Post: | Mauro_Penguin (03-09-2013) |
(Thread Starter) | Not Ranked : 0 score if it were head gasket it would leak through that, now it leaks through valve cover went in leak-down test. as for log, the car is apart now, but basicly it's really rich in all the ranges, -16 at idle. |
![]() | | #4 | ![]() |
![]() Join Date: Jul 2012 Location: Clifton Springs NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,398
Groans: 51
Groaned at 29 Times in 22 Posts
| Not Ranked : 0 score No expert but I think it could be a head gasket as well. Air/coolant/oil doesn't need to leak outside of the engine for the head gasket to be blown.
__________________ I used to go zoom zoom with my speed.... Now i drive a slow stockish Focus ST... |
![]() | | #5 | ![]() |
Groans: 112
| Not Ranked : 0 score That's not your AFR; that's your LTFT. I need to see what your O2 sensor is actually reading. Sometimes it's obvious that something is wrong. This won't fix your compression issue, but you might have more than one problem.
![]() | | #6 | ![]() |
(Thread Starter) | Not Ranked : 0 score close loop afr always read 14,69 or around that. edit: it could be head gasket, but i dont think i have any loss of coolant/oil.. |
![]() | | #7 | ![]() |
Groans: 112
| Not Ranked : 0 score So then you're meeting your targets? When my O2 sensor took a shit it was stuck at around 29, which is why my LTFT was increasingly negative. Wait for an expert to chime in, but from what I remember when 2 adjacent cylinders have low compression it usually indicates a problem with the head gasket.
| The Following 2 Users Say Thank You to btstarcher For This Useful Post: | Mauro_Penguin (03-09-2013), mrQQ (03-08-2013) |
![]() | | #8 | ![]() |
![]() Join Date: Jun 2009 Location: Tally, FL
Rep Power: 3058 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,683
| Not Ranked : 0 score compression numbers do lean towards head gasket. If it was truly an issue there would be supporting evidence- milky oil, white shit on oil fill cap, smoke from exhaust & mysterious loss of coolant, etc. Any of these, or a combination of them. leak down test seems to be indicating a rings, however you've not provided any details beyond air loss- Which cylinders presented the symptom? 3? 2 & 3? Rich readings can be triggered by something as simple as a boost leak resulting in loss of metered air. Generically I'd approach these with a divide & conquer strategy. In this case I'd start with the low compression issue as that's more important than the rest. Define if it's rings or HG, then what you want to do. The Manual will tell you that as low as 125 is acceptable, but the variance between cylinders is, I think, too great to ignore. But, these are the ramblings of just another guy. The real mechanics will be along soon.
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq |
| The Following 3 Users Say Thank You to TiGraySpeed6 For This Useful Post: |
![]() | | #9 | ![]() |
(Thread Starter) | Not Ranked : 0 score Leak down was very small (i dont have any real numbers yet) on 1, 2 and 4, and was huge on 3, venting almost as fast as pressurising. Going out of valve cover breather. No oil or coolant loss. Smoke, but I was attributing it to turbo. But the intake/tmic was clean, so perhaps it wasn't turbo after all, perhaps was rich fumes? No idea. Oil and coolant seem to be clean. Frankly, I have no clue what could have caused this. And not sure what to do further to make sure what it is exactly.. btw, could you tag some of the experts please, i'm not really very familiar around here.. Last edited by mrQQ; 03-08-2013 at 07:20 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to mrQQ For This Useful Post: | BlueStreak (03-08-2013) |
![]() | | #10 | ![]() |
| Not Ranked : 0 score To me, and again I'm not the mechanical pro, it sounds like rings or lands in 3, which is a common(ish) wear area. IIRC, Intake or exhaust valve issues are usually found in leak down by losing the pressure to intake or exhaust mani's, rings are seen to vent to CC, then travel up through the TC area into the valve cover as the path of least resistance. Smokey turbo from oil or the common K04 bad seals has a distinctly burnt oil smell. Coolant smells much different than burnt oil, sounds silly but it smells like coolant. You'd know the difference, and you'd be seeing the resultant lower coolant levels as it was lost.
| The Following 4 Users Say Thank You to TiGraySpeed6 For This Useful Post: |
![]() | | #11 | ![]() |
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
__________________ Damond Built Speed 6 | |
| The Following 3 Users Say Thank You to Deldran For This Useful Post: |
![]() | | #12 | ![]() |
| Not Ranked : 0 score goodness, can't swing a dead cat in this place without hitting a respectable mechanic. I gotta go do actual work stuff, but off the top of my head- @Dano; @phate; @BlueStreak; There are so many more
![]() | | #13 | ![]() |
(Thread Starter) | Not Ranked : 0 score just for the worst - IF i need to replace the rings..... a) can you just replace the rings? b) can those be used ones (don't shoot me, i know that a normal method is DO IT ALL, but...) c) what else needs to be done? just trying to gather some knowledge....... |
![]() | | #14 | ![]() |
| Not Ranked : 0 score Start by searching up some info on Drop-In builds. It worked a treat for dougefresh_, but Dano's was, well, let's just say it became a bit more involved. So, drop in is a possibility, but only if the stars line up and everything goes your way.
![]() | | #15 | ![]() |
(Thread Starter) | Not Ranked : 0 score thanks, found some threads except dougfresh_'s otherwise, what is the proper way to do it? |
![]() | | #16 | ![]() |
Groans: 118
It will be an extensive fix. Honestly with the questions you just asked i would recommend having a shop do it for you. It a lot of work, and if you want it done right you really need to pull the motor check all the specs and such, if the rings some how put a deep enough gouge in your cylinder wall you might need a new block. that would be worse case though
Yank the motor out, take it to a shop have it machined and go forged. wont be cheap though
__________________ Damond Built Speed 6 Last edited by Deldran; 03-08-2013 at 08:22 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following 5 Users Say Thank You to Deldran For This Useful Post: | BlueStreak (03-08-2013), Mauro_Penguin (03-09-2013), mrQQ (03-08-2013), phate (03-08-2013), TiGraySpeed6 (03-08-2013) |
![]() | | #17 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm not even planning to do it myself! I just want to visualize what it involves. |
![]() | | #18 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
Chances are the bore isn't scuffed or damaged so a drop in replacement with an OEM unit may be possible if you're on a tight tight budget; another option is a drop in forged build on all cylinders. Just need to ensure the bore is within spec w.r.t roundness.
__________________ '07 CWP MS3 Forged. | |
| The Following 4 Users Say Thank You to BlueStreak For This Useful Post: |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score ok, side question: could it be that I'm having two (or more) different issues at the same time? the reason i started digging was that I had some exhaust smoke (it wasn't really blue, it was pretty wite), some smells, bad mpg and very very rich trims (-16 at idle and higher). at first I suspected the WB o2. Found no leaks, neither intake nor exhaust, plugs were black, o2 were pretty poort looking, and the compression test returned the terrible result. Can the bad compression in #2 and #3 be the root cause of all the symptoms? Or let me rephrase: is it possible, that i have worn rings/leaking gasket, but it is NOT the cause of the above symptoms? Since the manufacturer rating is at least 125, it still is in it, so it should drive pretty normally? So perhaps for now I can just try to replace the wb o2 and see how that works out, while getting ready money ffor a build? Do I make any sense...? |
![]() | | #20 | ![]() |
Groans: 112
| Not Ranked : 0 score One quick question: did you follow the dry compression test with a wet test?
![]() | | #21 | ![]() |
| Not Ranked : 0 score I agree with the above, smells like ringlands cracking to me. Repeat the compression check wet and come back with results. Manufacturer rating also includes a cylinder to cylinder max variance which this exceeds. Zigatapatalka
| The Following 4 Users Say Thank You to Ziggo For This Useful Post: |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score if it's ringlands, what would wet test show? what about the question that it's still o2 sensor causing the symptoms, and this being just a separate problem? |
![]() | | #23 | ![]() |
| Not Ranked : 0 score And yes, this could cause the fueling to go wonky Zigatapatalka
| The Following 4 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (03-09-2013), BlueStreak (03-08-2013), Mauro_Penguin (03-09-2013), TiGraySpeed6 (03-08-2013) |
![]() | | #24 | ![]() |
Groans: 112
| Not Ranked : 0 score There's now way to really know for sure about the O2 sensor being a separate issue, so I'd try to fix whatever is causing your compression problem and then see if the fuel trims come back in line. It's interesting to note that my trims have been slowly increasing as well, and my compression in cylinder 3 is shitty. I'm pretty sure my O2 sensors are fine. My compression issue's root cause lies somewhere in the top half of the engine though. Probably.
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score hm, well, since it's much easier to fix o2, i'll try to start with that and see how that goes. another thought - could injector seals be a cause? |
![]() | | #26 | ![]() |
Groans: 112
| Not Ranked : 0 score Well one thing I'm sure of, the O2 sensor won't fix anything. Not until you deal with the compression issue.
| The Following 3 Users Say Thank You to btstarcher For This Useful Post: |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score yes, but shouldnt 9 be enough for engine to still run pretty normally? |
![]() | | #28 | ![]() |
Groans: 112
| Not Ranked : 0 score It's not the AFR causing the crappy running. It's your shitty compression. Ask me how I know LOL. You asked if the compression was causing the rich AFR's; it's possible that your compression problem is the only one. However that doesn't make the opposite true.
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score yea i know, but the fact is, that my o2 sensors still read different, its running damn rich, plugs are black, narrowband reads 0.7v (rich), but wb reads 1.0000, stoich. so i'm thinking, perhaps the worst symptoms are caused by the o2 sensor, but, ofc, shitty compression doesn't help. |
![]() | | #30 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score stop trying to beat around the bush motor needs to be yanked and the low cylinder needs to either be replaced or the whole block machined and rebuilt calibrating sensors to mask a mechanical problem will only cause you to vent the block, leaving absolutely nothing salvageable do it right |
| The Following 2 Users Say Thank You to 8.5MS3 For This Useful Post: | Juyoung (03-10-2013), Mauro_Penguin (03-09-2013) |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score i'm not making any decisions yet, I'm just gathering information. the biggest problem by far, is that I don't have access to parts. Ring set from dealer costs 500$ here, it costs 150$ at your place. So I have to measure all my moves. Even if I order from US, it still is like 3 weeks or so of delivery/clearing time, so I need to time my shop work very accurately. Thats the reason why I'm trying to calculate my moves. If I had access to the parts like you guys have, I could just say fck it and build the motor, but I dont, so I need to figure out what to do. |
![]() | | #32 | ![]() |
| Not Ranked : 0 score Its unlikely that it is just the rings. What the wet test does is rule out problems with the valves/valve seats. If the compression goes up wet then the valves and valve seats/guides are not the issue Zigatapatalka
![]() | | #33 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
Sent from your couch I was the one that did a stock rod/piston swap for dougefresh to get him up and running. If you have any questions feel free to hit me up. Sent from your couch
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 Last edited by atvfreek; 03-09-2013 at 05:41 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following 3 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #34 | ![]() |
Groans: 326
| Not Ranked : 0 score sorry op, forgot you were international what about scrapyards for cx7 blocks? |
![]() | | #35 | ![]() |
thought about that, but nothing, or even if there are, they are crazy expensive... Last edited by mrQQ; 03-09-2013 at 08:59 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #36 | ![]() |
If the engine has a slight misfire/incomplete burn, you can determine from the narrow band whether its a rich or lean misfire. That's also why the ecu can set a p2096 code which is "post catalyst lean" it is monitoring the rear o2 and seeing that condition. Edit: I personally would not throw an o2 at the car. Especially knowing there is a mechanical issue. All mechanical issues need to be addressed any electrical components is replaced. Sent from your couch
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following 2 Users Say Thank You to atvfreek For This Useful Post: | btstarcher (03-09-2013), mrQQ (03-11-2013) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score RE: Injector seals as cause of compression loss- With losses that bad you'd clearly be able to hear the seals venting as a popping kind of sound. Additionally you would be able to visually identify an oily looking residue in the area around the injector. Since you're still on the K04 it's highly unlikely to be the seals but anything is possible. I wouldn't bet money on this being the issue tho. It would, however, be a worthwhile thing to swap in a set of CPE seals while your doing all this work however.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | mrQQ (03-11-2013) |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score ok, so I need to prepare the parts. Which parts do I need if I decide to: a) just fix everything oem way b) possibly upgrade internals I've read that sleeves are not replaceable in this engine. might be looking to buying bnr s3 eventually, but definitely nothing else. |
![]() | | #39 | ![]() |
| Not Ranked : 0 score There have been a few projects that included sleeves here, but I've no idea of the costs involved. Just one quick example of sleeving the MZR is the cpe stage 3 short block Here's one of the builds- Nothing special
![]() | | #40 | ![]() |
| Not Ranked : 0 score How many conclusive ringland failures have we had leading to these symptoms? I know of 2 (Dano, BlueStreak) yet I know of lots of cars with low compression numbers. Who else can chime in with the failure when they pulled the motor apart with low compression? @BlueStreak; did you guys take that motor apart yet that had low compression numbers?
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
| Tune almost finished but having small issue | ztnedman1 | 2010 MS3 - ECU Computer Tuning | 16 | 09-22-2012 03:49 PM |
| Report: Volkswagen recalling small number of 2012 Beetle models over tire issue | Haltech | Automotive News | 1 | 07-23-2012 05:43 PM |
| Ford recalls 20,000 small pickups for light issue | Haltech | Automotive News | 0 | 07-20-2011 10:00 PM |
| Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon | Haltech | Automotive News | 3 | 04-17-2010 08:40 PM |
| Small recall for big suspension issue on 2008 Honda Element | Haltech | Automotive News | 0 | 08-19-2008 12:50 PM |
